"Create a new application" -> "Copy a Sample" -> "BLE Central UART"
I get this error:
I get this error:
Based on the error message, it seems you are trying to copy the folder and paste into its subfolder. If the OS allows your copy operation, I believe the folder `central_uart` will be copied recursively and your hard drive will be filled within several minutes. Can you try to copy the folder to somewhere else?
e.g. Create a new folder called `Tutorials` under the `c:\NordicSDKfiles` when the VSCode asks for your target location. You can use `c:\NordicSDKfiles\Tutorials` as the destination.
GL HF
Ok, o now understand that the IDE is asking for a “new location” in the same drop-down box the originally selects the sample to be used. This is confusing.
Now that I can select a sample, build and program it, I need to know how to interface to the “mesh chat”.
What application is used to define the mesh nodes and what application is used in iOS to be a node?
Good to hear you god the original question resolved. Please make a new thread for your mesh related question.
