about nrf9160 slm mqtt tls1.2
hi,
    1、How can I  setting cipher suite version? When I was doing tls bidirectional authentication.
     I can't find the AT comand.
                      thanks a lot !
AT#XMQTTCON=<op>[,<username>,<password>,<url>,<port>[,<sec_tag>]]
  • The <op> parameter is an integer. It can accept one of the following values:
    • 0 - Disconnect from the MQTT broker.
    • 1 - Connect to the MQTT broker using IP protocol family version 4.
    • 2 - Connect to the MQTT broker using IP protocol family version 6.
  • The <username> parameter is a string. It indicates the MQTT client username.
  • The <password> parameter is a string. It indicates the MQTT client password in cleartext.
  • The <url> parameter is a string. It indicates the MQTT broker hostname.
  • The <port> parameter is an unsigned 16-bit integer (0 - 65535). It indicates the MQTT broker port.
  • The <sec_tag> parameter is an integer. It indicates the credential of the security tag used for establishing a secure connection.
