Power Optimization
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK.
The nRF52840-DK was powered externally by the N6705B DC power analyzer (supply voltage of 3V) and the nRF_ONLY switch was enabled.
  1. If the UART-0 peripheral is enabled using the configuration option and the devicetree (CONFIG_SERIAL=y; status = "okay") then I have called the
    pm_device_action_run(uart_dev, PM_DEVICE_ACTION_SUSPEND);
    function before the SoC transitions to the idle state to reduce the average sleep current consumption from approx. 500µA to 8µA.
    If this function is called should the application first perform prior checks (on-going transmission/reception, power state, etc.)?
  2. Can you confirm that there is no way to switch off the UART receiver to soley use the transmitter for logging purpose to reduce power consumption?
  3. I have read this blog from Nordic regarding the power optimization for the nRF52840 and I would like to know if 8µA (accounting for SoC variations) is reasonable in your opinion using only Zephyr functions and no vendor SoC specific functions (RAM retention, etc). Do you think 8µA offers still room for improvement?
  4. As far a I am aware, Zephyr uses the low frequency clock automatically when it is in a low power mode. Can you confirm this?
  5. May you explain why the I2C-Twim driver uses PM_DEVICE_RUNTIME feature and the UART does not (PM_DEVICE)?
    When implementing a driver when should someone use the runtime version of the power mangement feauture? Does it depend on device usage or any hardware restriction?
  6. Can you share a sample or a scenario (block diagram) where an application should make use of the power domain feature of Zephyr? Since the Thingy:53 offers additional peripheral circuits may you share how to make use of this feature with that hardware and why.
If you could share your knowledge regarding this topic I am grateful.
ATla5
  • Hello Atla5,
    Can you please try to power the DK like you would normally do (via the micro-USB port on J2), put the nRF_ONLY back to Default, and then try to measure the current on P22? Does the current consumption go down if you do that?
    Edvin
  • I see that you edited the ticket after my reply, but I don't have access to a changelog. I'll await your reply before looking into this.
    BR,
    Edvin
  • Hello Edvin,
    I have performed the following measurements again
    1. Measurement #01
    • nRF52840-DK
      • SW6: DEFAULT
      • J2 USB power supply
    • PPK2
      • Ampere meter mode
    • SW
      • suspends SPI and UART-0 (other peripherals disabled) and calls k_sleep(K_FOREVER)
    • Results:
      • average current consumption is 3.52µA
    2. Measurement #02
    • nRF52840-DK
      • SW6: nRF_ONLY
    • PPK2
      • Ampere meter mode
    • SW
    • Results:
      • average current consumption is 3.54 µA
    What do you think causes the approximately 4µA difference  between measuring with the
    • PPK2 (measured at P22)
    • N6705B (measured at P21)
    Also, do  you have an answer for points 4 to 6 of the original question?
    ATla5
  • Hello ATla5,
    Without being able to say exactly where, I believe what you are seeing is that some parts of the DK (such as the debugger) is being backpowered from the nRF when the DK is not powered separately. It will not be operational, but you will see some leak current, possibly through the UART pins.
    • As far a I am aware, Zephyr uses the low frequency clock automatically when it is in a low power mode. Can you confirm this?
    Yes. It uses the LFCLK for timekeeping when it is sleeping.
    • May you explain why the I2C-Twim driver uses PM_DEVICE_RUNTIME feature and the UART does not (PM_DEVICE)?
    I don't know this. Perhaps because UART is the default backend for all printk() and logging (log module, such as LOG_INF()), which is why it is set up differently.
    I am not sure I understand this question. Are you asking when you should power down peripherals? It depends. Some peripherals draw more current than others. The UART is an example of a peripheral that draws more power, because it will keep the HFCLK running (because you don't know when the other device will transmit something, so it needs to be ready (it's asynchronous). This is not the case with most other serial protocols, such as SPI. In this case, the slave can wake on the CS pin, and the master will be in control of the events, so it doesn't need to keep the HFCLK when not in use.
    Edvin
    Sry for my late reply. No, what I mean are power domains. Note, that the links provided by Zephyr are not working and the sample folder does not contain any examples. That is why I wanted to know if you can share a use case, where power domains are applicable.
    If not, then we can close this ticket.
