I am currently using some code from the HTTP client sample to send HTTP requests to a server from my application. I have encountered an issue where the thread from which I send the request occasionally blocks. The serial log indicates that the execution stops at the getaddrinfo function and hangs indefinitely. I have left it running for up to 20 minutes before resetting, but getaddrinfo did not return.
This issue occurs randomly, sometimes minutes after booting, and sometimes after hours of sending data to the server. Other threads (like the LCD) are working fine and remain responsive during this time.
Here are the details of my setup:
Module: Avnet AVT9152
SoC: nRF9160
SDK: nRF Connect SDK v2.5
Modem Firmware: Latest version
Here is the function I use for HTTP requests:
int http_client_send_request(struct http_request *request) {
int err;
int fd;
struct addrinfo *res;
struct addrinfo hints = {
.ai_family = AF_INET,
.ai_socktype = SOCK_STREAM,
/* Set socket timeout */
struct timeval timeo = {
.tv_sec = 10,
.tv_usec = 0,
/* Set the callback function and receive buffer */
if (request->response == NULL) {
request->response = http_response_cb;
} else {
LOG_INF("Response callback already set");
LOG_INF("Getting address info\n");
/* Resolve hostname */
err = getaddrinfo(request->host, HTTPS_PORT, &hints, &res);
if (err) {
LOG_ERR("Failed to resolve hostname %s, error: %d\n", request->host, err);
return err;
LOG_INF("Creating socket\n");
/* Create socket */
fd = socket(res->ai_family, SOCK_STREAM, IPPROTO_TLS_1_2);
if (fd < 0) {
LOG_INF("Failed to create socket, error: %d\n", errno);
err = -errno;
goto clean_up;
/* Setup TLS socket options */
err = tls_setup(fd);
if (err) {
goto clean_up;
err = setsockopt(fd, SOL_SOCKET, SO_SNDTIMEO, &timeo, sizeof(timeo));
if (err) {
LOG_ERR("Failed to set socket timeout, error: %d\n", errno);
err = -errno;
goto clean_up;
err = setsockopt(fd, SOL_SOCKET, SO_RCVTIMEO, &timeo, sizeof(timeo));
if (err) {
err = -errno;
goto clean_up;
LOG_INF("Socket created\n");
/* Connect to server */
((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
err = connect(fd, res->ai_addr, res->ai_addrlen);
if (err < 0) {
LOG_ERR("Failed to connect to server, error: %d\n", errno);
err = -errno;
goto clean_up;
LOG_INF("Connected to server\n");
/* Send HTTP request */
err = http_client_req(fd, request, 5000, request->recv_buf);
if (err < 0) {
LOG_ERR("Failed to send HTTP request, error: %d\n", errno);
err = -errno;
goto clean_up;
LOG_INF("HTTP request sent\n");
clean_up:
freeaddrinfo(res);
close(fd);
LOG_INF("Socket closed");
return err;
}cellular.conf
I would appreciate any guidance or suggestions to resolve this issue. Thank you in advance for your help.
