Here is my backtrace
Here is my schematic design:
8585.nrf52840-lte-tracker-nRF52840.pdf
I measured VDD_nRF is 1.8V
The code was running on nRF52840 DK
here is my build .conf
Yes, it should. JLink only support chips listed at Supported Devices - J-Link (segger.com).
You can see the following log when I start a debug process for nRF9160. It will read out the chip "Target related settings".
JLinkGDBServerCL: SEGGER J-Link GDB Server V7.94e Command Line Version JLinkGDBServerCL: JLinkGDBServerCL: JLinkARM.dll V7.94e (DLL compiled Jan 15 2024 15:18:46) JLinkGDBServerCL: JLinkGDBServerCL: -----GDB Server start settings----- JLinkGDBServerCL: GDBInit file: none JLinkGDBServerCL: GDB Server Listening port: 62038 JLinkGDBServerCL: SWO raw output listening port: 2332 JLinkGDBServerCL: Terminal I/O port: 2333 JLinkGDBServerCL: Accept remote connection: localhost only JLinkGDBServerCL: Generate logfile: off JLinkGDBServerCL: Verify download: off JLinkGDBServerCL: Init regs on start: off JLinkGDBServerCL: Silent mode: on JLinkGDBServerCL: Single run mode: on JLinkGDBServerCL: Target connection timeout: 0 ms JLinkGDBServerCL: ------J-Link related settings------ JLinkGDBServerCL: J-Link Host interface: USB JLinkGDBServerCL: J-Link script: none JLinkGDBServerCL: J-Link settings file: none JLinkGDBServerCL: ------Target related settings------ JLinkGDBServerCL: Target device: nRF9160_xxAA JLinkGDBServerCL: Target device parameters: none JLinkGDBServerCL: Target interface: SWD JLinkGDBServerCL: Target interface speed: 12000kHz JLinkGDBServerCL: Target endian: little
Charlie
What I mean is, although I used west debug with nRF52840 as target, JLink still can connect to nRF52832 on the board.
I thought it may check and failed to connect to 52832
You have to set the target correctly. See the reply from the Segger team:
