TWIM doesn't work using nRF5340DK with I/O voltage above 2.5V
TWIM does not work well with nRF5340DK as shown in the subject. The conditions are shown below.
- I/O voltage is not 1.8V. The waveform is distorted around 2.5V, though I wrote in the title that it does not work at 2.5V or higher.
- When using multiple TWIMs, only TWIM1 does not work well. If only one is used, it does not matter which one is used.
- The evaluation board from Fanstel (EVM-WM02-V6) has an I/O voltage of 3.3V, and I confirmed that TWIM does not work with this board.
The following are the results of my experiments.
- I confirmed that TWIM works with nRF7002DK. The I/O voltage of nRF7002DK is fixed at 1.8V.
- I tried to run the same firmware on nRF5340DK, but it returned TWIM error. When I looked at the waveforms on the oscilloscope, SCL did not output anything and SDA was fixed at about 1.5V.
- I added firmware to change the I/O voltage of nRF5340DK to 1.8V. This time it worked fine.
    if ((NRF_UICR_S->VREGHVOUT & UICR_VREGHVOUT_VREGHVOUT_Msk) != (UICR_VREGHVOUT_VREGHVOUT_1V8 << UICR_VREGHVOUT_VREGHVOUT_Pos)) {
		NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
		while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
		NRF_UICR_S->VREGHVOUT = (UICR_VREGHVOUT_VREGHVOUT_1V8 << UICR_VREGHVOUT_VREGHVOUT_Pos);
		NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
		/* a reset is required for changes to take effect */
		NVIC_SystemReset();
From these verification results, I conclude that the nRF5340's TWIM does not work when the I/O voltage is set to anything other than 1.8V.
If something is wrong with my experiment, please point it out.
And... perhaps this is an errata?
