Development environment: ncs 2.6.0.
my application need BLE-DFU, so i added multi-image support to my project.
the pm_static.yml is the typical default system configuration
mcuboot: address: 0x0 size: 0xc000 region: flash_primary mcuboot_pad: address: 0xc000 size: 0x200 app: address: 0xc200 size: 0x38e00 mcuboot_primary: orig_span: &id001 - mcuboot_pad - app span: *id001 address: 0xc000 size: 0x39000 region: flash_primary mcuboot_primary_app: orig_span: &id002 - app span: *id002 address: 0xc200 size: 0x38e00 mcuboot_secondary: address: 0x45000 size: 0x39000 region: flash_primary settings_storage: address: 0x7e000 size: 0x2000 region: flash_primary
The results of my project compilation (-Os) are as follows
[240/248] Linking C executable zephyr\zephyr.elf Memory region Used Size Region Size %age Used FLASH: 208164 B 208384 B 99.89% RAM: 59724 B 64 KB 91.13% IDT_LIST: 0 GB 32 KB 0.00%
DFU work perfectly.
BUT. as you see, the flash is full. <FLASH: 208164 B 208384 B 99.89%>, when I add some little source-code, the compile will prmot overflow-mistake.
I found MCUBOOT just has 32K-size, 8KB settings-storage, and <mcuboot_primary> has 24KB nvs-storage.
I changed MCUBOOT-size to 40KB, or settings-storage to 4KB, compile will OK, but DFU failed.
my Question:
1. MCUBOOT-size changed to smaller feasible? Or the size can only be 0xC000=48KB?
2. i need settings-storage area, but the size can be smaller ?
3. nvs-storage=24KB Is it necessary? how to make it smaller ?
