nrfSniffer only works one time at Wireshark startup
I have the software installed and I am using the nRF52840DK with Ubuntu 22.04. The uart link is /dev/ttyACM0
When I start wireshark and do a capture on all advertising channels, it works fine. However, when I stop the capture and then try to restart a second capture, I get no Packets found.
If I stop wireshark and restart, again I can do one but only one capture; this is repeatable.
Before starting a second capture I have done a >lsof /dev/ttyACM0 in case it was still open and locked, but this command came back with nothing. I have also started to try some of the straight python examples from the doc ble-sniffer subdirectory, and so far these seem to work as expected. However, it would be nice to get wireshark usable. Any suggestions?
    Can you share what Wireshark version you have?
    And also have you asked Wireshark support?
    Jonathan
  • I haven't tried Wireshark support because Wireshark appears to be working properly except when trying to communicate to nRF52804DK through /dev/ttyACM0 the second time which seems to be more of a Nordic sniffer issue, and my current guess I am working on opening /dev/ttyACM0 the second time is not working. In particular, I am suspect of devices = UART.find_sniffer() around line 160 in nrf_sniffer_ble.py; I haven't figured out how to set a breakpoint when running from wireshark. import pdb; pdb.set_trace() doesn't work, so I think I have to add a loop and attach with gdb or something like that?
    wireshark version:
    3.6.2 (Git v3.6.2 packaged as 3.6.2-2)
    Compiled (64-bit) using GCC 11.2.0, with Qt 5.15.2, with libpcap, with POSIX
    capabilities (Linux), with libnl 3, with GLib 2.71.2, with zlib 1.2.11, with Lua
    5.2.4, with GnuTLS 3.7.3 and PKCS #11 support, with Gcrypt 1.9.4, with MIT
    Kerberos, with MaxMind DB resolver, with nghttp2 1.43.0, with brotli, with LZ4,
    with Zstandard, with Snappy, with libxml2 2.9.12, with libsmi 0.4.8, with
    QtMultimedia, without automatic updates, with SpeexDSP (using system library),
    with Minizip.
    Running on Linux 6.5.0-28-generic, with 12th Gen Intel(R) Core(TM) i9-12900K
    (with SSE4.2), with 64016 MB of physical memory, with GLib 2.72.4, with zlib
    1.2.11, with Qt 5.15.3, with libpcap 1.10.1 (with TPACKET_V3), with c-ares
    1.18.1, with GnuTLS 3.7.3, with Gcrypt 1.9.4, with nghttp2 1.43.0, with brotli
    1.0.9, with LZ4 1.9.3, with Zstandard 1.4.8, with libsmi 0.4.8, with light
    display mode, without HiDPI, with LC_TYPE=en_US.UTF-8, binary plugins supported
    (19 loaded).
  • You can try to use the nRF_USB connector, talking directly to the nRF and not though the interface controller on the DK.
    Jonathan
  • From the documentation, I have no idea how to "use the nRF_USB connector, talking directly to the nRF and not though the interface controller on the DK". In general, the documentation is very convoluted, and requires many steps that are either not well explained or just hard-to-understand one-liners.
    I do have more info that is pointing to a Nordic bug.
    After running the first capture that works, doing a >lsof /dev/ttyACM0 returns nothing, however the next time a capture is attempted, it fails because a lock file is left behind
    > ls /var/lock
    . .. asound.state.lock LCK..ttyACM0 subsys whoopsie
    /var/lock is a symbolic link to /run/lock
    doing a >c /var/lock/ LCK..ttyACM0 gives the pid of the "locked"? process
    > c /run/lock/LCK..ttyACM0
    656275>
    doing a
    >pg='ps aux | g -v grep | g 656275
    gives:
    <xxx redacted user name xxx>    656275  0.5  0.0      0     0 pts/0    Z    11:46   0:05 [python3] <defunct>
    Now this is interesting, normally to get rid of a defunct process, one uses something like:
    ps -ef | grep defunct | grep -v grep | awk '\''{ print $3 }'\'' | xargs kill -9
    but this kills wireshark?
    If one simply deletes the lock file, then it is now possible to run a new capture.
    Summary: I'm guessing FileLock.py is buggy and needs to be fixed? I don't know the cleanest way to do this and irrespective, any changes I make will be over-written at the next update.
    I'm kind of surprised this hasn't affected others? Could there be unique reason my set up is different as I've just been following guidelines without any customization trying to capture all devices advertising. Still, there are so many poorly documented steps involved, the chances of errors are high, and the debug is difficult as I still can't get breakpoints working when running through wireshark, and I also haven't been successful using logging again when running through wireshark.
    Any suggestions to an alternative for ble sniffing that is simpler and less fragile I could try while waiting for Nordic to fix?
  • Are you using the latest version of the nRF sniffer for Bluetooth?  can be found here: https://www.nordicsemi.com/Products/Development-tools/nRF-Sniffer-for-Bluetooth-LE/Download?lang=en#infotabs
    Could it be that the version you have Which extcap version are you using? Does the nrf_sniffer_ble.sh contain exec before $py3 $script_path/nrf_sniffer_ble.py "$@" (this is one of the differences between nRF Sniffer for Bluetooth LE 4.1.0 and 4.1.1).
    Jonathan
