What is the possible reason that LED1 blinks and LED2 does not light up when the nRF5340 Audio source is operating?
I have read and understood the source code, but I am not sure what causes the above phenomenon.
LED1 blinks blue when the gateway is streaming, LED2 lights up when sync has been achieved. So the scenario where LED1 is blinking and LED2 is off is when the gateway is streaming and sync has not been achieved. See the LED overview here: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/applications/nrf5340_audio/doc/user_interface.html#leds
Maria
What causes a gateway to be out of sync while streaming?
This will depend on your application mode and the stream parameters. You can get some information from the device logs.
Which NCS version are you using?
Which mode are you running the audio application in?
Maria
The version of ncs is 2.5.0.
It is running in release mode.
In debug mode, the following error occurs when building.
The error is as follows:
←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe '-BC:\Users\TSP_M1\nrf5340_audio\build\dev_headset\build_debug' -GNinja -DBOARD=nrf5340_audio_dk_nrf5340_cpuapp -DCONFIG_AUDIO_DEV=1 '-SC:\Users\TSP_M1\nrf5340_audio'
←[0mTraceback (most recent call last):
File "buildprog.py", line 439, in <module>
__main()
File "buildprog.py", line 421, in __main
__build_module(build_cfg, options)
File "buildprog.py", line 167, in __build_module
raise Exception("cmake error: " + str(ret_val))
Exception: cmake error: 1
Do you get any errors or warnings before "-- Configuring incomplete, errors occurred!"? The last part is quite generic and I think the actual error is printed before in the build log.
List all the output from the build.
C:\Users\TSP_M1\nrf5340_audio\tools\buildprog>python buildprog.py -c both -b debug -d both
| snr | snr conn | device | only reboot | core app programmed | core net programmed |
| 1050188709 | True | headset | Not selected | Selected TBD | Selected TBD |
| 1050198852 | True | gateway | Not selected | Selected TBD | Selected TBD |
| 1000 | False | headset | Not selected | Selected TBD | Selected TBD |
Invoking build step
Net core uses precompiled hex
Run: west build C:\Users\TSP_M1\nrf5340_audio -b nrf5340_audio_dk_nrf5340_cpuapp -d C:\Users\TSP_M1\nrf5340_audio\build\dev_headset\build_debug -DCONFIG_AUDIO_DEV=1
-- Application: C:/Users/TSP_M1/nrf5340_audio
-- CMake version: 3.20.5
-- Using NCS Toolchain 2.5.20231017.848171396279 for building. (C:/ncs/toolchains/c57af46cb7/cmake)
CMake Deprecation Warning at C:/ncs/v2.5.0/zephyr/cmake/modules/FindDeprecated.cmake:121 (message):
'PYTHON_PREFER' variable is deprecated. Please use Python3_EXECUTABLE
instead.
C:/ncs/v2.5.0/zephyr/cmake/modules/python.cmake:16 (find_package)
C:/ncs/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:46 (find_package)
-- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.5.0/zephyr/.cache
-- Zephyr version: 3.4.99 (C:/ncs/v2.5.0/zephyr)
-- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
-- Board: nrf5340_audio_dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.5.0/zephyr/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Users/TSP_M1/nrf5340_audio/build/dev_headset/build_debug/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Users/TSP_M1/nrf5340_audio/build/dev_headset/build_debug/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Users/TSP_M1/nrf5340_audio/build/dev_headset/build_debug/zephyr/dts.cmake
Parsing C:/Users/TSP_M1/nrf5340_audio/Kconfig
Loaded configuration 'C:/ncs/v2.5.0/zephyr/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/Users/TSP_M1/nrf5340_audio/prj.conf'
Merged configuration 'C:/Users/TSP_M1/nrf5340_audio/build/dev_headset/build_debug/zephyr/misc/generated/extra_kconfig_options.conf'
error: BT_AUDIO_TX (defined at
C:/Users/TSP_M1/nrf5340_audio\src/bluetooth\bt_stream/broadcast\Kconfig.defaults:86,
C:/Users/TSP_M1/nrf5340_audio\src/bluetooth\bt_stream/unicast\Kconfig.defaults:113,
C:/Users/TSP_M1/nrf5340_audio\src/bluetooth\bt_stream/unicast\Kconfig.defaults:183,
C:/ncs/v2.5.0/zephyr/subsys/bluetooth/host\../audio/Kconfig:28,
subsys/bluetooth\host\../audio/Kconfig:28) is assigned in a configuration file, but is not directly
user-configurable (has no prompt). It gets its value indirectly from other symbols. See
docs.zephyrproject.org/.../kconfig.html and/or look up BT_AUDIO_TX in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
CMake Error at C:/ncs/v2.5.0/zephyr/cmake/modules/kconfig.cmake:348 (message):
command failed with return code: 1
C:/ncs/v2.5.0/nrf/cmake/modules/kconfig.cmake:29 (include)
__main()
We will continue with figuring out the sync issue in this case when the build issue is resolved in this other case: About DeviceTree and Overlay files
