What is the possible reason that LED1 blinks and LED2 does not light up when the nRF5340 Audio source is operating?
I have read and understood the source code, but I am not sure what causes the above phenomenon.
List all the output from the build.
C:\Users\TSP_M1\nrf5340_audio\tools\buildprog>python buildprog.py -c both -b debug -d both
| snr | snr conn | device | only reboot | core app programmed | core net programmed |
| 1050188709 | True | headset | Not selected | Selected TBD | Selected TBD |
| 1050198852 | True | gateway | Not selected | Selected TBD | Selected TBD |
| 1000 | False | headset | Not selected | Selected TBD | Selected TBD |
Invoking build step
Net core uses precompiled hex
Run: west build C:\Users\TSP_M1\nrf5340_audio -b nrf5340_audio_dk_nrf5340_cpuapp -d C:\Users\TSP_M1\nrf5340_audio\build\dev_headset\build_debug -DCONFIG_AUDIO_DEV=1
-- Application: C:/Users/TSP_M1/nrf5340_audio
-- CMake version: 3.20.5
-- Using NCS Toolchain 2.5.20231017.848171396279 for building. (C:/ncs/toolchains/c57af46cb7/cmake)
CMake Deprecation Warning at C:/ncs/v2.5.0/zephyr/cmake/modules/FindDeprecated.cmake:121 (message):
'PYTHON_PREFER' variable is deprecated. Please use Python3_EXECUTABLE
instead.
C:/ncs/v2.5.0/zephyr/cmake/modules/python.cmake:16 (find_package)
C:/ncs/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:46 (find_package)
-- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.5.0/zephyr/.cache
-- Zephyr version: 3.4.99 (C:/ncs/v2.5.0/zephyr)
-- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
-- Board: nrf5340_audio_dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.5.0/zephyr/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Users/TSP_M1/nrf5340_audio/build/dev_headset/build_debug/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Users/TSP_M1/nrf5340_audio/build/dev_headset/build_debug/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Users/TSP_M1/nrf5340_audio/build/dev_headset/build_debug/zephyr/dts.cmake
Parsing C:/Users/TSP_M1/nrf5340_audio/Kconfig
Loaded configuration 'C:/ncs/v2.5.0/zephyr/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/Users/TSP_M1/nrf5340_audio/prj.conf'
Merged configuration 'C:/Users/TSP_M1/nrf5340_audio/build/dev_headset/build_debug/zephyr/misc/generated/extra_kconfig_options.conf'
error: BT_AUDIO_TX (defined at
C:/Users/TSP_M1/nrf5340_audio\src/bluetooth\bt_stream/broadcast\Kconfig.defaults:86,
C:/Users/TSP_M1/nrf5340_audio\src/bluetooth\bt_stream/unicast\Kconfig.defaults:113,
C:/Users/TSP_M1/nrf5340_audio\src/bluetooth\bt_stream/unicast\Kconfig.defaults:183,
C:/ncs/v2.5.0/zephyr/subsys/bluetooth/host\../audio/Kconfig:28,
subsys/bluetooth\host\../audio/Kconfig:28) is assigned in a configuration file, but is not directly
user-configurable (has no prompt). It gets its value indirectly from other symbols. See
docs.zephyrproject.org/.../kconfig.html and/or look up BT_AUDIO_TX in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
CMake Error at C:/ncs/v2.5.0/zephyr/cmake/modules/kconfig.cmake:348 (message):
command failed with return code: 1
C:/ncs/v2.5.0/nrf/cmake/modules/kconfig.cmake:29 (include)
←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe '-BC:\Users\TSP_M1\nrf5340_audio\build\dev_headset\build_debug' -GNinja -DBOARD=nrf5340_audio_dk_nrf5340_cpuapp -DCONFIG_AUDIO_DEV=1 '-SC:\Users\TSP_M1\nrf5340_audio'
←[0mTraceback (most recent call last):
File "buildprog.py", line 439, in <module>
__main()
File "buildprog.py", line 421, in __main
__build_module(build_cfg, options)
File "buildprog.py", line 167, in __build_module
raise Exception("cmake error: " + str(ret_val))
Exception: cmake error: 1
We will continue with figuring out the sync issue in this case when the build issue is resolved in this other case: About DeviceTree and Overlay files
