Failed to open flash area ID 2 (image 0 slot 1): -19, cannot continue
We're seeing an error that only happens after a cold reboot (unplugging the battery and replugging it) and it happens inside the bootloader while trying to open the secondary flash area in the external flash. I think. If I change the bootloader code inside `bootloader/mcuboot/boot/bootutil/src/loader.c` to reset Nordic instead of panicking, it's recovering fine (i.e. calling NVIC_SystemReset() instead of FIH_PANIC)
I'm using w25q64 for flash and QSPI to communicate with the flash.
The error message is:
E: Failed to open flash area ID 2 (image 0 slot 1): -19, cannot continue
I'm using the following DTS overlay:
chosen {
nordic,pm-ext-flash = &w25q64;
&qspi {
status = "okay";
pinctrl-0 = <&qspi_default>;
pinctrl-1 = <&qspi_sleep>;
w25q64: w25q6435f@0 {
compatible = "nordic,qspi-nor";
reg = <0>;
sck-frequency = <8000000>;
jedec-id = [ef 40 17];
sfdp-bfp = [
e5 20 f9 ff ff ff ff 03 44 eb 08 6b 08 3b 42 bb
fe ff ff ff ff ff 00 00 ff ff 40 eb 0c 20 0f 52
10 d8 00 00 36 02 a6 00 82 ea 14 c4 e9 63 76 33
7a 75 7a 75 f7 a2 d5 5c 19 f7 4d ff e9 30 f8 80
size = <67108864>;
has-dpd;
t-enter-dpd = <10000>;
t-exit-dpd = <35000>;
Any pointers would be much appreciated.
  • Here is the log I get for comparison (tested on nRF5340 DK). Notice that the "QSPI NOR INIT in bootloader" message is printed before the boot banner.
    E: QSPI NOR INIT in bootloader
    D: RDSR 40 QE 1 need 1: no-change
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=bad, swap_type=0x1, copy_done=0x2, image_ok=0x2
    I: Boot source: none
    I: Image index: 0, Swap type: none
    I: Bootloader chainload address offset: 0xc000
    E: QSPI NOR INIT in applicationlot
    Starting Bluetooth Peripheral LBS example
    I: 2 Sectors of 4096 bytes
    I: alloc wra: 0, fe8
    I: data wra: 0, 0
    I: HW Platform: Nordic Semiconductor (0x0002)
    I: HW Variant: nRF53x (0x0003)
    I: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    I: No ID address. App must call settings_load()
    Bluetooth initialized
    Is CONFIG_BOOT_BANNER=y enabled in your mcuboot build? I don't see the boot banner in your output either.
    My mcuboot .config
    # MCUboot-specific configuration options
    # CONFIG_BOOT_USE_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_MCUBOOT_SCRATCH=0x1e000
    CONFIG_PM_PARTITION_SIZE_MCUBOOT_PAD=0x200
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0xc000
    CONFIG_MCUBOOT_NRF_CLEANUP_PERIPHERAL=y
    # CONFIG_MCUBOOT_NRF_CLEANUP_NONSECURE_RAM is not set
    CONFIG_BOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem"
    CONFIG_BOOT_ERASE_PROGRESSIVELY=y
    # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    CONFIG_MCUBOOT_CLEANUP_UNUSABLE_SECONDARY=y
    CONFIG_MCUBOOT=y
    CONFIG_BOOT_USE_MBEDTLS=y
    CONFIG_NRFXLIB_CRYPTO=y
    # CONFIG_NRF_CC310_BL is not set
    # MCUBoot settings
    # CONFIG_SINGLE_APPLICATION_SLOT is not set
    # CONFIG_BOOT_SIGNATURE_TYPE_NONE is not set
    CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
    CONFIG_BOOT_SIGNATURE_TYPE_RSA_LEN=2048
    # CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256 is not set
    # CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
    CONFIG_MCUBOOT_CLEANUP_ARM_CORE=y
    CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
    # CONFIG_BOOT_HW_KEY is not set
    CONFIG_BOOT_VALIDATE_SLOT0=y
    CONFIG_BOOT_PREFER_SWAP_MOVE=y
    # CONFIG_BOOT_SWAP_USING_SCRATCH is not set
    # CONFIG_BOOT_UPGRADE_ONLY is not set
    CONFIG_BOOT_SWAP_USING_MOVE=y
    # CONFIG_BOOT_DIRECT_XIP is not set
    # CONFIG_BOOT_RAM_LOAD is not set
    # CONFIG_BOOT_BOOTSTRAP is not set
    # CONFIG_BOOT_SWAP_SAVE_ENCTLV is not set
    CONFIG_BOOT_ENCRYPTION_SUPPORT=y
    # CONFIG_BOOT_ENCRYPT_IMAGE is not set
    CONFIG_BOOT_MAX_IMG_SECTORS=256
    CONFIG_BOOT_SHARE_BACKEND_DISABLED=y
    # CONFIG_BOOT_SHARE_BACKEND_EXTERNAL is not set
    CONFIG_BOOT_FIH_PROFILE_OFF=y
    # CONFIG_BOOT_FIH_PROFILE_LOW is not set
    # CONFIG_BOOT_FIH_PROFILE_MEDIUM is not set
    # CONFIG_BOOT_FIH_PROFILE_HIGH is not set
    CONFIG_BOOT_USB_DFU_NO=y
    # CONFIG_BOOT_USB_DFU_WAIT is not set
    # CONFIG_BOOT_USB_DFU_GPIO is not set
    # CONFIG_BOOT_USE_BENCH is not set
    # CONFIG_MCUBOOT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_LOG_LEVEL_WRN is not set
    CONFIG_MCUBOOT_LOG_LEVEL_INF=y
    # CONFIG_MCUBOOT_LOG_LEVEL_DBG is not set
    # CONFIG_MCUBOOT_LOG_LEVEL_DEFAULT is not set
    CONFIG_MCUBOOT_LOG_LEVEL=3
    CONFIG_MCUBOOT_LOG_THREAD_STACK_SIZE=768
    # CONFIG_MCUBOOT_INDICATION_LED is not set
    # CONFIG_MCUBOOT_SERIAL is not set
    # CONFIG_BOOT_INTR_VEC_RELOC is not set
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    CONFIG_BOOT_WATCHDOG_FEED=y
    # CONFIG_MCUBOOT_ACTION_HOOKS is not set
    # end of MCUBoot settings
    CONFIG_MCUBOOT_DEVICE_SETTINGS=y
    # Zephyr configuration options
    CONFIG_MULTITHREADING=y
    CONFIG_USB_DEVICE_PRODUCT="MCUBOOT"
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    # CONFIG_SPI is not set
    CONFIG_BOARD="nrf5340dk_nrf5340_cpuapp"
    CONFIG_FLASH_LOAD_SIZE=0x40000
    CONFIG_SRAM_SIZE=448
    CONFIG_FLASH_LOAD_OFFSET=0x10000
    CONFIG_HEAP_MEM_POOL_SIZE=0
    CONFIG_NUM_IRQS=69
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_SOC="nRF5340_CPUAPP_QKAA"
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_CLOCK_CONTROL=y
    CONFIG_PINCTRL=y
    # CONFIG_WATCHDOG is not set
    CONFIG_ROM_START_OFFSET=0
    # CONFIG_RESET is not set
    CONFIG_GPIO=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_FPU is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_MEMC is not set
    CONFIG_MBEDTLS=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_TINYCRYPT is not set
    CONFIG_SERIAL=y
    CONFIG_MAIN_STACK_SIZE=10240
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_USE_DT_CODE_PARTITION=y
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_IDLE_STACK_SIZE=320
    # CONFIG_PM_DEVICE is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_MP_MAX_NUM_CPUS=1
    # Devicetree Info
    CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
    CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (/home/vidarbe/ncs/v2.5.0/nrf)
    # CONFIG_MBOX is not set
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    # CONFIG_INIT_STACKS is not set
    # CONFIG_MBEDTLS_ENABLE_HEAP is not set
    # Nordic nRF Connect
    CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # CONFIG_NRF700X_RADIO_TEST_COMBO is not set
    # Image build variants
    CONFIG_NCS_MCUBOOT_IN_BUILD=y
    # end of Image build variants
    CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=4
    # Subsystems
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    CONFIG_IS_BOOTLOADER_IMG=y
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    # BLE over nRF RPC
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
    CONFIG_FOTA_DL_TIMEOUT_MIN=15
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_FOTA_POLL is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=0
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=0
    # CONFIG_NRF_CLOUD_COAP is not set
    # Send shadow info sections on initial connect (MQTT/CoAP)
    # end of Send shadow info sections on initial connect (MQTT/CoAP)
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=0
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=0
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=26
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=0
    # CONFIG_MPSL_PIN_DEBUG is not set
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
    CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@50000000/qspi@2b000/mx25r6435f@0"
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=67108864
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=0
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # CONFIG_MBEDTLS_MEMORY_DEBUG is not set
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CBC_MAC is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_SM3 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD2 is not set
    # CONFIG_PSA_WANT_ALG_MD4 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_FFDH is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # end of nRF Security
    # CONFIG_NET_CORE_MONITOR is not set
    # Audio Module
    # CONFIG_AUDIO_MODULE_TEST is not set
    CONFIG_AUDIO_MODULE_NAME_SIZE=20
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_MODULE_LOG_LEVEL=0
    # end of Audio Module
    # CONFIG_TRUSTED_STORAGE is not set
    # end of Subsystems
    # CONFIG_WPA_SUPP is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=0
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=0
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # Binary libraries
    # CONFIG_BT_LL_ACS_NRF53 is not set
    # Log levels
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_INF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_DBG is not set
    CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_HCI_VSC_LOG_LEVEL=0
    # end of Log levels
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    CONFIG_FPROTECT=y
    # CONFIG_FPROTECT_APP is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_MODEM_INFO is not set
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y
    CONFIG_FATAL_ERROR_LOG_LEVEL=0
    # CONFIG_SMS is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/home/vidarbe/ncs/v2.5.0/nrf)
    # mcuboot (/home/vidarbe/ncs/v2.5.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_SIGN_IMAGES=y
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/home/vidarbe/ncs/v2.5.0/bootloader/mcuboot)
    # mbedtls (/home/vidarbe/ncs/v2.5.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_MBEDTLS_BUILTIN=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=1500
    # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    CONFIG_MBEDTLS_LOG_LEVEL=0
    # CONFIG_MBEDTLS_DEBUG is not set
    # CONFIG_MBEDTLS_TEST is not set
    CONFIG_MBEDTLS_INIT=y
    # CONFIG_MBEDTLS_ZEPHYR_ENTROPY is not set
    CONFIG_APP_LINK_WITH_MBEDTLS=y
    # PSA RNG support
    # end of PSA RNG support
    # PSA key type support
    # end of PSA key type support
    # PSA AEAD support
    # end of PSA AEAD support
    # PSA MAC support
    # end of PSA MAC support
    # PSA Hash support
    # end of PSA Hash support
    # PSA Cipher support
    # end of PSA Cipher support
    # PSA Key agreement support
    # end of PSA Key agreement support
    # PSA Key derivation support
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # Elliptic Curve type support
    # end of Elliptic Curve type support
    # end of PSA Asymmetric support
    # end of mbedtls (/home/vidarbe/ncs/v2.5.0/modules/crypto/mbedtls)
    # trusted-firmware-m (/home/vidarbe/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_BOARD="/home/vidarbe/ncs/v2.5.0/zephyr/modules/trusted-firmware-m/nordic_nrf/nrf5340_cpuapp"
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (/home/vidarbe/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (/home/vidarbe/ncs/v2.5.0/modules/lib/cjson)
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (/home/vidarbe/ncs/v2.5.0/modules/lib/cjson)
    # azure-sdk-for-c (/home/vidarbe/ncs/v2.5.0/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (/home/vidarbe/ncs/v2.5.0/modules/lib/azure-sdk-for-c)
    # cirrus-logic (/home/vidarbe/ncs/v2.5.0/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (/home/vidarbe/ncs/v2.5.0/modules/hal/cirrus-logic)
    # openthread (/home/vidarbe/ncs/v2.5.0/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (/home/vidarbe/ncs/v2.5.0/modules/lib/openthread)
    # memfault-firmware-sdk (/home/vidarbe/ncs/v2.5.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (/home/vidarbe/ncs/v2.5.0/modules/lib/memfault-firmware-sdk)
    # canopennode (/home/vidarbe/ncs/v2.5.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (/home/vidarbe/ncs/v2.5.0/modules/lib/canopennode)
    # chre (/home/vidarbe/ncs/v2.5.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (/home/vidarbe/ncs/v2.5.0/modules/lib/chre)
    # lz4 (/home/vidarbe/ncs/v2.5.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (/home/vidarbe/ncs/v2.5.0/modules/lib/lz4)
    # nanopb (/home/vidarbe/ncs/v2.5.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (/home/vidarbe/ncs/v2.5.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (/home/vidarbe/ncs/v2.5.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (/home/vidarbe/ncs/v2.5.0/modules/lib/zscilib)
    # cmsis (/home/vidarbe/ncs/v2.5.0/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (/home/vidarbe/ncs/v2.5.0/modules/hal/cmsis)
    # cmsis-dsp (/home/vidarbe/ncs/v2.5.0/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (/home/vidarbe/ncs/v2.5.0/modules/lib/cmsis-dsp)
    # cmsis-nn (/home/vidarbe/ncs/v2.5.0/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (/home/vidarbe/ncs/v2.5.0/modules/lib/cmsis-nn)
    # fatfs (/home/vidarbe/ncs/v2.5.0/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (/home/vidarbe/ncs/v2.5.0/modules/fs/fatfs)
    # hal_nordic (/home/vidarbe/ncs/v2.5.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_QSPI_LOG is not set
    # CONFIG_NRFX_WDT_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE0=y
    # CONFIG_NRFX_GPIOTE1 is not set
    # CONFIG_NRFX_I2S0 is not set
    # CONFIG_NRFX_IPC is not set
    # CONFIG_NRFX_NFCT is not set
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QDEC1 is not set
    CONFIG_NRFX_QSPI=y
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    # CONFIG_NRFX_SPIM4 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TWIM0 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBREG is not set
    CONFIG_NRFX_WDT=y
    CONFIG_NRFX_WDT0=y
    CONFIG_NRFX_WDT1=y
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of hal_nordic (/home/vidarbe/ncs/v2.5.0/modules/hal/nordic)
    CONFIG_ZEPHYR_ST_MODULE=y
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # liblc3 (/home/vidarbe/ncs/v2.5.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (/home/vidarbe/ncs/v2.5.0/modules/lib/liblc3)
    # littlefs (/home/vidarbe/ncs/v2.5.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/home/vidarbe/ncs/v2.5.0/modules/fs/littlefs)
    # loramac-node (/home/vidarbe/ncs/v2.5.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (/home/vidarbe/ncs/v2.5.0/modules/lib/loramac-node)
    # lvgl (/home/vidarbe/ncs/v2.5.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (/home/vidarbe/ncs/v2.5.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # picolibc (/home/vidarbe/ncs/v2.5.0/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (/home/vidarbe/ncs/v2.5.0/modules/lib/picolibc)
    # segger (/home/vidarbe/ncs/v2.5.0/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (/home/vidarbe/ncs/v2.5.0/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (/home/vidarbe/ncs/v2.5.0/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (/home/vidarbe/ncs/v2.5.0/modules/lib/uoscore-uedhoc)
    # zcbor (/home/vidarbe/ncs/v2.5.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (/home/vidarbe/ncs/v2.5.0/modules/lib/zcbor)
    # nrfxlib (/home/vidarbe/ncs/v2.5.0/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    # end of nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # CONFIG_CC3XX_HW_MUTEX_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_LC3_PLC_DISABLED is not set
    CONFIG_LC3_ENC_CHAN_MAX=1
    CONFIG_LC3_DEC_CHAN_MAX=1
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/home/vidarbe/ncs/v2.5.0/nrfxlib)
    # connectedhomeip (/home/vidarbe/ncs/v2.5.0/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (/home/vidarbe/ncs/v2.5.0/modules/lib/matter)
    # find-my (/home/vidarbe/ncs/v2.5.0/find-my)
    # CONFIG_FMNA is not set
    CONFIG_ZEPHYR_FIND_MY_MODULE=y
    # end of find-my (/home/vidarbe/ncs/v2.5.0/find-my)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=8192
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL=0
    CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=6
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD_REVISION=""
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF5340DK_NRF5340_CPUAPP=y
    # CONFIG_BOARD_NRF5340DK_NRF5340_CPUAPP_NS is not set
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC_APP=y
    CONFIG_BOARD_ENABLE_DCDC_NET=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    # CONFIG_BOARD_ENABLE_CPUNET is not set
    # end of Board Options
    # CONFIG_SOC_SERIES_APOLLO4X is not set
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32A50X is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_GD32L23X is not set
    # CONFIG_SOC_SERIES_PSOC_60 is not set
    # CONFIG_SOC_SERIES_PSOC_61 is not set
    # CONFIG_SOC_SERIES_PSOC_62 is not set
    # CONFIG_SOC_SERIES_PSOC_63 is not set
    # CONFIG_SOC_SERIES_PSOC_64 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    CONFIG_SOC_SERIES_NRF53X=y
    # CONFIG_SOC_SERIES_NRF54HX is not set
    # CONFIG_SOC_SERIES_NRF54LX is not set
    # CONFIG_SOC_SERIES_NRF91X is not set
    CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT=0x4000
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT=0x2000
    # CONFIG_SOC_SERIES_NPCX4 is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M46X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32K3XX is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RA4M1 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_RENESAS_RZT2M is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32GG12B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32BG22 is not set
    # CONFIG_SOC_SERIES_EFR32BG27 is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_EFR32MG24 is not set
    # CONFIG_SOC_SERIES_STM32C0X is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H5X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WBAX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_SERIES_AM62X_M4 is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_GPIO_INIT_PRIORITY=40
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_NFCT=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_OSCILLATORS=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_REGULATORS=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_SOC_NRF5340_CPUNET_QKAA is not set
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
    CONFIG_SOC_NRF53_RTC_PRETICK=y
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
    CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
    # CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
    CONFIG_SOC_DCDC_NRF53X_APP=y
    CONFIG_SOC_DCDC_NRF53X_NET=y
    CONFIG_SOC_DCDC_NRF53X_HV=y
    CONFIG_SOC_ENABLE_LFXO=y
    # CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_LFXO_CAP_INT_6PF is not set
    CONFIG_SOC_LFXO_CAP_INT_7PF=y
    # CONFIG_SOC_LFXO_CAP_INT_9PF is not set
    CONFIG_SOC_HFXO_CAP_DEFAULT=y
    # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF_ENABLE_CACHE=y
    # CONFIG_NRF53_SYNC_RTC is not set
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=0
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF53X=y
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
    CONFIG_ARM_ON_EXIT_CPU_IDLE=y
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=0
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=0
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=0
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # CONFIG_POLL is not set
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_CACHE is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=0
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CLOCK_CONTROL_NPCX_SUPP_APB4=y
    # CONFIG_CLOCK_CONTROL_NPCX_SUPP_FIU1 is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=0
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_COUNTER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    # CONFIG_ENTROPY_GENERATOR is not set
    # CONFIG_ESPI is not set
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_JESD216=y
    CONFIG_FLASH=y
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    CONFIG_FLASH_LOG_LEVEL_DBG=y
    # CONFIG_FLASH_LOG_LEVEL_DEFAULT is not set
    CONFIG_FLASH_LOG_LEVEL=4
    # CONFIG_FLASH_JESD216_API is not set
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_SOC_FLASH_NRF=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=41
    # CONFIG_NORDIC_QSPI_NOR_XIP is not set
    CONFIG_NORDIC_QSPI_NOR_TIMEOUT_MS=500
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=0
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HWINFO is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=0
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
    CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
    CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MDIO is not set
    # CONFIG_MFD is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=0
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=0
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    # CONFIG_SMBUS is not set
    # CONFIG_SYSCON is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_NRF_GRTC_TIMER is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=0
    # CONFIG_NRF_USBD_COMMON is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=0
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    CONFIG_MINIMAL_LIBC=y
    # CONFIG_PICOLIBC is not set
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    CONFIG_COMMON_LIBC_STRNLEN=y
    CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y
    CONFIG_MINIMAL_LIBC_MALLOC=y
    CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=-2
    CONFIG_MINIMAL_LIBC_CALLOC=y
    CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
    # CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
    CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y
    # CONFIG_MINIMAL_LIBC_RAND is not set
    CONFIG_MINIMAL_LIBC_TIME=y
    # CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    # CONFIG_CRC is not set
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # OS Support Library
    # CONFIG_FDTABLE is not set
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    # CONFIG_MPSC_PBUF is not set
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    CONFIG_REBOOT=y
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    # CONFIG_UTF8 is not set
    # CONFIG_CBPRINTF_COMPLETE is not set
    CONFIG_CBPRINTF_NANO=y
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_LIBC_SUBSTS=y
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=0
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_POSIX_API is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL=0
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_COND_LOG_LEVEL=0
    # CONFIG_EVENTFD is not set
    # CONFIG_FNMATCH is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_KEY_LOG_LEVEL=0
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL=0
    # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_LOG_LEVEL=0
    CONFIG_SEM_VALUE_MAX=32767
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=0
    # CONFIG_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_TIMER_LOG_LEVEL=0
    # CONFIG_TIMER is not set
    CONFIG_MAX_TIMER_COUNT=5
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_ACPI_HID_LEN_MAX=12
    CONFIG_LIBGCC_RTLIB=y
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    # CONFIG_BT is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_FCB is not set
    # CONFIG_NVS is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    # CONFIG_LOG_MODE_DEFERRED is not set
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    CONFIG_LOG_MODE_MINIMAL=y
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    CONFIG_LOG_DEFAULT_LEVEL=0
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    # end of Processing
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    # end of Misc
    # CONFIG_LOG_OUTPUT is not set
    # end of Logging
    CONFIG_MEM_ATTR=y
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NET_BUF is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    CONFIG_COMPILER_FREESTANDING=y
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    CONFIG_FORTIFY_SOURCE_NONE=y
    # CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    CONFIG_BUILD_OUTPUT_META=y
    # CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    Edit: When CONFIG_BOOT_BANNER is enabled, the CONFIG_EARLY_CONSOLE symbol will be selected. So, if BOOT_BANNER is not enabled in the bootloader, that likely explains why you are not seeing log messages from the driver in the bootloader.
  • Now I see something similar to what you're seeing, however, I'm still not seeing it working.
    Cold boot
    E: QSPI NOR INIT in bootloader
    E: JEDEC id [00 00 00] expect [ef 40 17]
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    I: Starting bootloader
    I: About to open flash area ID 4 (image 0 slot 0)
    I: About to open flash area ID 2 (image 0 slot 1)
    E: QSPI NOR INIT in bootloaderD 2 (image 0 slot 1): -19, cannot continue
    Warm boot
    D: RDSR 00 QE 0 need 0: no-change
    I: Image index: 0, Swap type: none
    I: About to open flash area ID 1 (image 1 slot 0)
    I: About to open flash area ID 8 (image 1 slot 1)
    I: Image index: 1, Swap type: none
    I: Bootloader chainload address offset: 0x10000
    I: Jumping to the first image slot
    -- [00:00:00.001,129] <err> qspi_nor: QSPI NOR INIT in application
    GW [00:00:01.001,434] <dbg> qspi_nor: configure_chip: RDSR 00 QE 0 need 0: no-change
  • Thanks. This shows that it's failing to read the JEDEC id from the Winbond flash on cold boot. Can you post the zephyr.dts and .config file for mcuboot and the application (located in build/mcuboot/zephyr and build/zephyr)?
  • build/zephyr/.config
    CONFIG_NRF5340_AUDIO=y
    CONFIG_AUDIO_DEV=2
    CONFIG_TRANSPORT_BIS=y
    # CONFIG_TRANSPORT_CIS is not set
    CONFIG_BT_CAP_INITIATOR=y
    CONFIG_BT_DEVICE_APPEARANCE=2181
    CONFIG_BT_ISO_BROADCASTER=y
    CONFIG_BT_BAP_BROADCAST_SOURCE=y
    CONFIG_BT_ISO_TX_BUF_COUNT=2
    CONFIG_BT_BAP_BROADCAST_SRC_STREAM_COUNT=2
    CONFIG_BT_ISO_MAX_CHAN=2
    CONFIG_BT_AUDIO_TX=y
    CONFIG_LC3_BITRATE=96000
    CONFIG_LC3_ENC_CHAN_MAX=2
    CONFIG_REBOOT=y
    CONFIG_MAIN_THREAD_PRIORITY=10
    CONFIG_MAIN_STACK_SIZE=1600
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_THREAD_NAME=y
    CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE=y
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    CONFIG_BT=y
    CONFIG_BOARD_ENABLE_CPUNET=y
    CONFIG_ZBUS=y
    CONFIG_ZBUS_RUNTIME_OBSERVERS=y
    CONFIG_ZBUS_MSG_SUBSCRIBER=y
    CONFIG_SENSOR=y
    CONFIG_REGULATOR=y
    CONFIG_CONTIN_ARRAY=y
    CONFIG_NRFX_I2S0=y
    CONFIG_PCM_MIX=y
    CONFIG_PSCM=y
    CONFIG_DATA_FIFO=y
    CONFIG_NRFX_CLOCK=y
    CONFIG_I2C=y
    CONFIG_FPU=y
    CONFIG_FPU_SHARING=y
    CONFIG_DISK_DRIVERS=y
    CONFIG_DISK_DRIVER_SDMMC=y
    CONFIG_SPI=y
    CONFIG_ADC=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    CONFIG_FILE_SYSTEM=y
    CONFIG_FAT_FILESYSTEM_ELM=y
    CONFIG_FS_FATFS_LFN=y
    CONFIG_FS_FATFS_EXFAT=y
    CONFIG_FS_FATFS_MAX_LFN=255
    CONFIG_WATCHDOG=y
    CONFIG_TASK_WDT=y
    CONFIG_NRFX_TIMER1=y
    CONFIG_NRFX_DPPI=y
    # Audio
    # CONFIG_AUDIO_FRAME_DURATION_7_5_MS is not set
    CONFIG_AUDIO_FRAME_DURATION_10_MS=y
    CONFIG_AUDIO_FRAME_DURATION_US=10000
    CONFIG_AUDIO_MIN_PRES_DLY_US=4000
    CONFIG_AUDIO_MAX_PRES_DLY_US=60000
    # CONFIG_AUDIO_SAMPLE_RATE_16000_HZ is not set
    # CONFIG_AUDIO_SAMPLE_RATE_24000_HZ is not set
    CONFIG_AUDIO_SAMPLE_RATE_48000_HZ=y
    CONFIG_AUDIO_SAMPLE_RATE_HZ=48000
    CONFIG_AUDIO_BIT_DEPTH_16=y
    # CONFIG_AUDIO_BIT_DEPTH_32 is not set
    CONFIG_AUDIO_BIT_DEPTH_BITS=16
    CONFIG_AUDIO_BIT_DEPTH_OCTETS=2
    # CONFIG_AUDIO_SOURCE_USB is not set
    CONFIG_AUDIO_SOURCE_I2S=y
    CONFIG_AUDIO_HEADSET_CHANNEL_RUNTIME=y
    # CONFIG_AUDIO_HEADSET_CHANNEL_COMPILE_TIME is not set
    CONFIG_AUDIO_TEST_TONE=y
    CONFIG_AUDIO_MUTE=y
    # SW Codec
    CONFIG_SW_CODEC_LC3=y
    # CONFIG_SW_CODEC_PLC_DISABLED is not set
    # LC3
    CONFIG_LC3_BITRATE_MAX=96000
    CONFIG_LC3_BITRATE_MIN=32000
    CONFIG_SW_CODEC_LC3_T2_SOFTWARE=y
    # end of LC3
    # end of SW Codec
    # Stream
    CONFIG_BUF_BLE_RX_PACKET_NUM=5
    # CONFIG_WALKIE_TALKIE_DEMO is not set
    # CONFIG_MONO_TO_ALL_RECEIVERS is not set
    # end of Stream
    # Log levels
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_SYSTEM_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_SYSTEM_LOG_LEVEL=3
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_OFF is not set
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_ERR is not set
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_WRN is not set
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_INF is not set
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_DBG is not set
    CONFIG_SW_CODEC_SELECT_LOG_LEVEL_DEFAULT=y
    CONFIG_SW_CODEC_SELECT_LOG_LEVEL=3
    # CONFIG_STREAMCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_STREAMCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_STREAMCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_STREAMCTRL_LOG_LEVEL_INF is not set
    # CONFIG_STREAMCTRL_LOG_LEVEL_DBG is not set
    CONFIG_STREAMCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAMCTRL_LOG_LEVEL=3
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_DATAPATH_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_DATAPATH_LOG_LEVEL=3
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL=3
    # end of Log levels
    # Thread priorities
    CONFIG_ENCODER_THREAD_PRIO=3
    CONFIG_AUDIO_DATAPATH_THREAD_PRIO=4
    CONFIG_BUTTON_MSG_SUB_THREAD_PRIO=5
    CONFIG_LE_AUDIO_MSG_SUB_THREAD_PRIO=5
    CONFIG_CONTENT_CONTROL_MSG_SUB_THREAD_PRIO=5
    # end of Thread priorities
    # Stack sizes
    CONFIG_ENCODER_STACK_SIZE=11000
    CONFIG_AUDIO_DATAPATH_STACK_SIZE=7600
    CONFIG_BUTTON_MSG_SUB_STACK_SIZE=2048
    CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE=2048
    CONFIG_CONTENT_CONTROL_MSG_SUB_STACK_SIZE=1024
    # end of Stack sizes
    # Zbus
    CONFIG_BUTTON_MSG_SUB_QUEUE_SIZE=4
    CONFIG_CONTENT_CONTROL_MSG_SUB_QUEUE_SIZE=4
    # end of Zbus
    # end of Audio
    CONFIG_BT_AUDIO=y
    CONFIG_BT_DEVICE_NAME="Nordic"
    CONFIG_BT_ECC=y
    CONFIG_BT_EXT_ADV=y
    CONFIG_BT_ATT_PREPARE_COUNT=1
    # Bluetooth
    # BT management
    CONFIG_BT_ATT_ENFORCE_FLOW=y
    CONFIG_BT_HCI_VS_EXT=y
    # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
    # Controller config
    # nRF21540
    # CONFIG_NRF_21540_MAIN_TX_POWER_0DBM is not set
    CONFIG_NRF_21540_MAIN_TX_POWER_10DBM=y
    # CONFIG_NRF_21540_MAIN_TX_POWER_20DBM is not set
    CONFIG_NRF_21540_MAIN_DBM=10
    # CONFIG_NRF_21540_PRI_ADV_TX_POWER_0DBM is not set
    CONFIG_NRF_21540_PRI_ADV_TX_POWER_10DBM=y
    # CONFIG_NRF_21540_PRI_ADV_TX_POWER_20DBM is not set
    CONFIG_NRF_21540_PRI_ADV_DBM=10
    # end of nRF21540
    # Log level
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL=3
    # end of Log level
    # end of Controller config
    # Power control
    CONFIG_BLE_LE_POWER_CONTROL_ENABLED=y
    # CONFIG_WDT_CTLR is not set
    CONFIG_BLE_CONN_TX_POWER_0DBM=y
    # CONFIG_BLE_CONN_TX_POWER_NEG_1DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_2DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_3DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_4DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_5DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_6DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_7DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_8DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_12DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_16DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_20DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_40DBM is not set
    CONFIG_BLE_CONN_TX_POWER_DBM=0
    CONFIG_BLE_ADV_TX_POWER_0DBM=y
    # CONFIG_BLE_ADV_TX_POWER_NEG_1DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_2DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_3DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_4DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_5DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_6DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_7DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_8DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_12DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_16DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_20DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_40DBM is not set
    CONFIG_BLE_ADV_TX_POWER_DBM=0
    # end of Power control
    # Thread priorities
    CONFIG_CTLR_POLL_WORK_Q_PRIO=6
    # DFU
    # Log level
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_DFU_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_DFU_LOG_LEVEL=3
    # end of Log level
    # end of DFU
    # Advertising
    CONFIG_BLE_ACL_PER_ADV_INT_MIN=0x0078
    CONFIG_BLE_ACL_PER_ADV_INT_MAX=0x00A0
    CONFIG_BLE_ACL_EXT_ADV_INT_MIN=0x30
    CONFIG_BLE_ACL_EXT_ADV_INT_MAX=0x40
    CONFIG_EXT_ADV_BUF_MAX=20
    CONFIG_EXT_ADV_UUID_BUF_MAX=20
    # Log level
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_ADV_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_ADV_LOG_LEVEL=3
    # end of Log level
    # end of Advertising
    CONFIG_BT_BACKGROUND_SCAN_INTERVAL=32
    CONFIG_BT_BACKGROUND_SCAN_WINDOW=32
    CONFIG_BT_SCAN_WITH_IDENTITY=y
    # Scanning
    CONFIG_SCAN_MODE_PASSIVE=y
    # CONFIG_SCAN_MODE_ACTIVE is not set
    # Connection
    CONFIG_BLE_ACL_CONN_INTERVAL=32
    CONFIG_BLE_ACL_SLAVE_LATENCY=0
    CONFIG_BLE_ACL_SUP_TIMEOUT=100
    # end of Connection
    # Log level
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_SCAN_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_SCAN_LOG_LEVEL=3
    # end of Log level
    # end of Scanning
    # Log level
    # CONFIG_BT_MGMT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_LOG_LEVEL=3
    # end of Log level
    # end of BT management
    # Bluetooth audio
    CONFIG_BT_BUF_ACL_RX_SIZE=255
    CONFIG_BT_AUDIO_CODEC_CFG_MAX_METADATA_SIZE=80
    # Broadcast
    CONFIG_BT_AUDIO_BROADCAST_CONFIGURABLE=y
    # CONFIG_BT_BAP_BROADCAST_16_2_1 is not set
    # CONFIG_BT_BAP_BROADCAST_24_2_1 is not set
    # CONFIG_BT_BAP_BROADCAST_16_2_2 is not set
    # CONFIG_BT_BAP_BROADCAST_24_2_2 is not set
    CONFIG_BT_AUDIO_BROADCAST_NAME="NRF5340_BROADCASTER"
    CONFIG_BT_AUDIO_BROADCAST_NAME_ALT="NRF5340_BROADCASTER_ALT"
    # CONFIG_BT_AUDIO_USE_BROADCAST_NAME_ALT is not set
    # CONFIG_BT_AUDIO_BROADCAST_ENCRYPTED is not set
    CONFIG_BT_AUDIO_BROADCAST_ENCRYPTION_KEY="NRF5340_BIS_DEMO"
    # CONFIG_BT_AUDIO_USE_BROADCAST_ID_RANDOM is not set
    CONFIG_BT_AUDIO_BROADCAST_ID_FIXED=0x123456
    CONFIG_BT_AUDIO_BROADCAST_PARENTAL_RATING=0x00
    # CONFIG_BT_AUDIO_BROADCAST_IMMEDIATE_FLAG is not set
    CONFIG_AURACAST=y
    CONFIG_BT_AUDIO_BITRATE_BROADCAST_SRC=96000
    # Log levels
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_OFF is not set
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_ERR is not set
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_WRN is not set
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_INF is not set
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_DBG is not set
    CONFIG_BROADCAST_SOURCE_LOG_LEVEL_DEFAULT=y
    CONFIG_BROADCAST_SOURCE_LOG_LEVEL=3
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_OFF is not set
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_ERR is not set
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_WRN is not set
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_INF is not set
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_DBG is not set
    CONFIG_BROADCAST_SINK_LOG_LEVEL_DEFAULT=y
    CONFIG_BROADCAST_SINK_LOG_LEVEL=3
    # end of Log levels
    # end of Broadcast
    CONFIG_BT_GATT_CLIENT=y
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    # CONFIG_BT_SMP is not set
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    # CONFIG_BT_AUTO_PHY_UPDATE is not set
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_NVS_LOG_LEVEL=3
    # CONFIG_BT_AUDIO_PACKING_INTERLEAVED is not set
    CONFIG_BT_AUDIO_PREF_SAMPLE_RATE_VALUE=0x08
    CONFIG_BT_AUDIO_PREF_SAMPLE_RATE_48KHZ=y
    # CONFIG_BT_AUDIO_PREF_SAMPLE_RATE_24KHZ is not set
    # CONFIG_BT_AUDIO_PREF_SAMPLE_RATE_16KHZ is not set
    # QoS
    CONFIG_BT_AUDIO_PRESENTATION_DELAY_US=10000
    CONFIG_BT_AUDIO_MAX_TRANSPORT_LATENCY_MS=20
    CONFIG_BT_AUDIO_RETRANSMITS=2
    # end of QoS
    # end of Bluetooth audio
    # BT renderer
    # Volume
    CONFIG_BT_AUDIO_VOL_DEFAULT=195
    CONFIG_BT_AUDIO_VOL_STEP_SIZE=16
    # Log level
    # CONFIG_BT_REND_VOL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_REND_VOL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_REND_VOL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_REND_VOL_LOG_LEVEL_INF is not set
    # CONFIG_BT_REND_VOL_LOG_LEVEL_DBG is not set
    CONFIG_BT_REND_VOL_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_REND_VOL_LOG_LEVEL=3
    # end of Log level
    # end of Volume
    # Log level
    # CONFIG_BT_REND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_REND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_REND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_REND_LOG_LEVEL_INF is not set
    # CONFIG_BT_REND_LOG_LEVEL_DBG is not set
    CONFIG_BT_REND_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_REND_LOG_LEVEL=3
    # end of Log level
    # end of BT renderer
    # Content control
    # Media
    # Log level
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_DBG is not set
    CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL=3
    # end of Log level
    # end of Media
    # Log level
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_DBG is not set
    CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_CONTENT_CTRL_LOG_LEVEL=3
    # end of Log level
    # end of Content control
    # Log levels
    # CONFIG_BLE_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_LOG_LEVEL_INF is not set
    # CONFIG_BLE_LOG_LEVEL_DBG is not set
    CONFIG_BLE_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_LOG_LEVEL=3
    # end of Log levels
    # Testing
    # CONFIG_TESTING_BLE_ADDRESS_RANDOM is not set
    # end of Testing
    # end of Bluetooth
    # Drivers
    # Thread priorities
    CONFIG_CS47L63_THREAD_PRIO=5
    # Stack sizes
    CONFIG_CS47L63_STACK_SIZE=700
    # Log levels
    # CONFIG_CS47L63_LOG_LEVEL_OFF is not set
    # CONFIG_CS47L63_LOG_LEVEL_ERR is not set
    # CONFIG_CS47L63_LOG_LEVEL_WRN is not set
    # CONFIG_CS47L63_LOG_LEVEL_INF is not set
    # CONFIG_CS47L63_LOG_LEVEL_DBG is not set
    CONFIG_CS47L63_LOG_LEVEL_DEFAULT=y
    CONFIG_CS47L63_LOG_LEVEL=3
    # end of Log levels
    # end of Drivers
    CONFIG_USB_DEVICE_STACK=y
    CONFIG_NET_BUF=y
    # CONFIG_USB_DEVICE_AUDIO is not set
    CONFIG_USB_DEVICE_VID=0x2FE3
    CONFIG_USB_DEVICE_PID=0x0100
    CONFIG_USB_DEVICE_PRODUCT="USB-DEV"
    CONFIG_USB_DEVICE_MANUFACTURER="ZEPHYR"
    CONFIG_USB_DRIVER_LOG_LEVEL=3
    CONFIG_USB_DEVICE_LOG_LEVEL=3
    # Modules
    CONFIG_BUTTON_DEBOUNCE_MS=50
    CONFIG_AUDIO_SYNC_TIMER_USES_RTC=y
    # Power measurement
    CONFIG_POWER_MEAS_INTERVAL_MS=8500
    # CONFIG_POWER_MEAS_START_ON_BOOT is not set
    # end of Power measurement
    # I2S
    CONFIG_I2S_LRCK_FREQ_HZ=48000
    CONFIG_I2S_CH_NUM=2
    # end of I2S
    # Log levels
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_AUDIO_USB_LOG_LEVEL=3
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL=3
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_HW_CODEC_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_HW_CODEC_LOG_LEVEL=3
    # CONFIG_MODULE_LED_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_LED_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_LED_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_LED_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_LED_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_LED_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_LED_LOG_LEVEL=3
    # CONFIG_MODULE_POWER_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_POWER_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_POWER_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_POWER_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_POWER_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_POWER_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_POWER_LOG_LEVEL=3
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_SD_CARD_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_SD_CARD_LOG_LEVEL=3
    # CONFIG_MODULE_SD_CARD_PLAYBACK_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_SD_CARD_PLAYBACK_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_SD_CARD_PLAYBACK_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_SD_CARD_PLAYBACK_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_SD_CARD_PLAYBACK_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_SD_CARD_PLAYBACK_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_SD_CARD_PLAYBACK_LOG_LEVEL=3
    # CONFIG_MODULE_NRF5340_AUDIO_DK_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_NRF5340_AUDIO_DK_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_NRF5340_AUDIO_DK_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_NRF5340_AUDIO_DK_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_NRF5340_AUDIO_DK_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_NRF5340_AUDIO_DK_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_NRF5340_AUDIO_DK_LOG_LEVEL=3
    # end of Log levels
    # Thread priorities
    CONFIG_POWER_MEAS_THREAD_PRIO=6
    CONFIG_BUTTON_PUBLISH_THREAD_PRIO=5
    CONFIG_VOLUME_MSG_SUB_THREAD_PRIO=5
    # Stack sizes
    CONFIG_POWER_MEAS_STACK_SIZE=1152
    CONFIG_BUTTON_PUBLISH_STACK_SIZE=450
    CONFIG_VOLUME_MSG_SUB_STACK_SIZE=768
    # Zbus
    CONFIG_VOLUME_MSG_SUB_QUEUE_SIZE=4
    # end of Zbus
    # CONFIG_SD_CARD_PLAYBACK is not set
    # end of Modules
    CONFIG_NRFX_NVMC=y
    # Utils
    # FIFO
    CONFIG_FIFO_FRAME_SPLIT_NUM=10
    CONFIG_FIFO_TX_FRAME_COUNT=3
    CONFIG_FIFO_RX_FRAME_COUNT=2
    # end of FIFO
    # Log levels
    # CONFIG_BOARD_VERSION_LOG_LEVEL_OFF is not set
    # CONFIG_BOARD_VERSION_LOG_LEVEL_ERR is not set
    # CONFIG_BOARD_VERSION_LOG_LEVEL_WRN is not set
    # CONFIG_BOARD_VERSION_LOG_LEVEL_INF is not set
    # CONFIG_BOARD_VERSION_LOG_LEVEL_DBG is not set
    CONFIG_BOARD_VERSION_LOG_LEVEL_DEFAULT=y
    CONFIG_BOARD_VERSION_LOG_LEVEL=3
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_OFF is not set
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_ERR is not set
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_WRN is not set
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_INF is not set
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_DBG is not set
    CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_DEFAULT=y
    CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL=3
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_OFF is not set
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_ERR is not set
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_WRN is not set
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_INF is not set
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_DBG is not set
    CONFIG_ERROR_HANDLER_LOG_LEVEL_DEFAULT=y
    CONFIG_ERROR_HANDLER_LOG_LEVEL=3
    # CONFIG_FW_INFO_LOG_LEVEL_OFF is not set
    # CONFIG_FW_INFO_LOG_LEVEL_ERR is not set
    # CONFIG_FW_INFO_LOG_LEVEL_WRN is not set
    # CONFIG_FW_INFO_LOG_LEVEL_INF is not set
    # CONFIG_FW_INFO_LOG_LEVEL_DBG is not set
    CONFIG_FW_INFO_LOG_LEVEL_DEFAULT=y
    CONFIG_FW_INFO_LOG_LEVEL=3
    # end of Log levels
    # end of Utils
    CONFIG_AUDIO_DFU=2
    # CONFIG_B0N_MINIMAL is not set
    # CONFIG_NCS_SAMPLE_EMPTY_NET_CORE_CHILD_IMAGE is not set
    CONFIG_AUDIO_DFU_ENABLE=y
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_ZCBOR=y
    CONFIG_MCUMGR=y
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_GRP_OS_TASKSTAT=y
    CONFIG_MCUMGR_GRP_STAT=y
    CONFIG_MCUMGR_GRP_IMG=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=1024
    CONFIG_IMG_MANAGER=y
    CONFIG_STREAM_FLASH=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_MCUMGR_TRANSPORT_BT=y
    CONFIG_BT_L2CAP_TX_MTU=247
    CONFIG_BT_BUF_ACL_TX_SIZE=501
    CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=6
    CONFIG_THREAD_MONITOR=y
    CONFIG_STATS=y
    CONFIG_STATS_NAMES=y
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    # CONFIG_BT_DEVICE_NAME_GATT_WRITABLE is not set
    CONFIG_BT_DEVICE_NAME_MAX=30
    CONFIG_UPDATEABLE_IMAGE_NUMBER=2
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    CONFIG_SPI_NOR_CS_WAIT_DELAY=5
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_MCUMGR_GRP_ZBASIC=y
    CONFIG_MCUMGR_GRP_ZBASIC_STORAGE_ERASE=y
    CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    # Logging
    # CONFIG_MAIN_LOG_LEVEL_OFF is not set
    # CONFIG_MAIN_LOG_LEVEL_ERR is not set
    # CONFIG_MAIN_LOG_LEVEL_WRN is not set
    # CONFIG_MAIN_LOG_LEVEL_INF is not set
    # CONFIG_MAIN_LOG_LEVEL_DBG is not set
    CONFIG_MAIN_LOG_LEVEL_DEFAULT=y
    CONFIG_MAIN_LOG_LEVEL=3
    # CONFIG_NRF5340_AUDIO_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF5340_AUDIO_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF5340_AUDIO_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF5340_AUDIO_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF5340_AUDIO_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF5340_AUDIO_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF5340_AUDIO_COMMON_LOG_LEVEL=3
    CONFIG_PRINT_STACK_USAGE_MS=5000
    # end of Logging
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    CONFIG_ADC_INIT_PRIORITY=50
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    CONFIG_BOARD="nrf5340_audio_dk_nrf5340_cpuapp"
    CONFIG_FLASH_LOAD_SIZE=0x40000
    CONFIG_SRAM_SIZE=448
    CONFIG_FLASH_LOAD_OFFSET=0x10000
    CONFIG_MBOX_NRFX_IPC=y
    CONFIG_HEAP_MEM_POOL_SIZE=4096
    # CONFIG_BT_CTLR is not set
    CONFIG_NUM_IRQS=69
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_SOC="nRF5340_CPUAPP_QKAA"
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_CLOCK_CONTROL=y
    CONFIG_PINCTRL=y
    CONFIG_ROM_START_OFFSET=0
    # CONFIG_RESET is not set
    CONFIG_GPIO=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_MEMC is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    CONFIG_TINYCRYPT=y
    CONFIG_SERIAL=y
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_USE_DT_CODE_PARTITION=y
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_TASK_WDT_HW_FALLBACK_DELAY=20
    # CONFIG_PM_DEVICE is not set
    CONFIG_BT_USER_PHY_UPDATE=y
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_MP_MAX_NUM_CPUS=1
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_I2S_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF21540_FEM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF21540_FEM_SPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_USB_AUDIO_HS_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/nrf)
    CONFIG_MBOX=y
    CONFIG_NEWLIB_LIBC_NANO=y
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_LOG_BUFFER_SIZE=1024
    CONFIG_INIT_STACKS=y
    # Nordic nRF Connect
    CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # CONFIG_NRF700X_RADIO_TEST_COMBO is not set
    CONFIG_NCS_SAMPLE_HCI_IPC_CHILD_IMAGE=y
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
    CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
    CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16
    CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_VALIDATION=y
    # Subsystems
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # CONFIG_NRF53_ENFORCE_IMAGE_VERSION_EQUALITY is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_MAX_CONN=2
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1024
    CONFIG_BT_RX_STACK_SIZE=2048
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_SCAN is not set
    # CONFIG_BT_CONN_CTX is not set
    CONFIG_BT_EXT_ADV_MAX_ADV_SET=1
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    # CONFIG_BT_DIS is not set
    # end of Bluetooth Services
    # BLE over nRF RPC
    CONFIG_BT_DRIVERS=y
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
    CONFIG_BT_PER_ADV=y
    # CONFIG_BT_PER_ADV_RSP is not set
    # CONFIG_BT_PER_ADV_SYNC is not set
    # CONFIG_BT_PER_ADV_SYNC_RSP is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_ACL_RX_COUNT=6
    CONFIG_BT_BUF_EVT_RX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_HCI_VS_EVT is not set
    # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
    # CONFIG_BT_HCI_VS_EXT_DETECT is not set
    # CONFIG_BT_HCI_MESH_EXT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_LOG is not set
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_DEBUG_MONITOR_RTT is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=1300
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_LONG_WQ_INIT_PRIO=50
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=1
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_MESH is not set
    CONFIG_BT_AUDIO_NOTIFY_RETRY_DELAY=20
    # CONFIG_BT_BAP_UNICAST_SERVER is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT is not set
    CONFIG_BT_AUDIO_CODEC_CFG_MAX_DATA_SIZE=19
    CONFIG_BT_AUDIO_CODEC_CAP_MAX_DATA_SIZE=19
    CONFIG_BT_AUDIO_CODEC_CAP_MAX_METADATA_SIZE=4
    CONFIG_BT_BAP_BROADCAST_SRC_SUBGROUP_COUNT=1
    CONFIG_BT_BAP_BROADCAST_SRC_COUNT=1
    # CONFIG_BT_BAP_SCAN_DELEGATOR is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT is not set
    CONFIG_BT_BAP_STREAM=y
    CONFIG_BT_BAP_DEBUG_STREAM_SEQ_NUM=y
    # CONFIG_BT_PAC_SNK is not set
    # CONFIG_BT_PAC_SRC is not set
    # CONFIG_BT_ASCS is not set
    CONFIG_BT_VOCS_MAX_INSTANCE_COUNT=0
    CONFIG_BT_VOCS_CLIENT_MAX_INSTANCE_COUNT=0
    CONFIG_BT_AICS_MAX_INSTANCE_COUNT=0
    CONFIG_BT_AICS_CLIENT_MAX_INSTANCE_COUNT=0
    # CONFIG_BT_VCP_VOL_REND is not set
    # CONFIG_BT_VCP_VOL_CTLR is not set
    # CONFIG_BT_MICP_MIC_DEV is not set
    # CONFIG_BT_MICP_MIC_CTLR is not set
    # CONFIG_BT_CSIP_SET_MEMBER is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR is not set
    # CONFIG_BT_TBS is not set
    # CONFIG_BT_TBS_CLIENT_GTBS is not set
    # CONFIG_BT_TBS_CLIENT_TBS is not set
    # CONFIG_BT_MCC is not set
    # CONFIG_BT_HAS_CLIENT is not set
    # CONFIG_BT_MPL is not set
    # CONFIG_MCTL is not set
    CONFIG_BT_CAP=y
    # CONFIG_BT_TMAP is not set
    CONFIG_BT_TMAP_LOG_LEVEL=3
    CONFIG_BT_TMAP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_TMAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_INF is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_DBG is not set
    CONFIG_BT_AUDIO_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_AUDIO_LOG_LEVEL=3
    CONFIG_BT_HOST_CRYPTO=y
    CONFIG_BT_HOST_CRYPTO_PRNG=y
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=8
    CONFIG_BT_CONN_TX_MAX=4
    # CONFIG_BT_CONN_PARAM_ANY is not set
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    # CONFIG_BT_REMOTE_INFO is not set
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    CONFIG_BT_L2CAP_RESCHED_MS=1000
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    CONFIG_BT_GATT_AUTO_RESUBSCRIBE=y
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    CONFIG_BT_GATT_DYNAMIC_DB=y
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    # CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
    # CONFIG_BT_GATT_AUTO_UPDATE_MTU is not set
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
    # CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set
    CONFIG_BT_MAX_PAIRED=0
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    CONFIG_BT_EXT_SCAN_BUF_SIZE=229
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_DF is not set
    # CONFIG_BT_TINYCRYPT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    CONFIG_DFU_TARGET=y
    CONFIG_DFU_TARGET_MCUBOOT=y
    CONFIG_DFU_TARGET_STREAM=y
    # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set
    CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y
    CONFIG_DFU_TARGET_LOG_LEVEL=3
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
    CONFIG_FOTA_DL_TIMEOUT_MIN=15
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_FOTA_POLL is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_COAP is not set
    # Send shadow info sections on initial connect (MQTT/CoAP)
    # end of Send shadow info sections on initial connect (MQTT/CoAP)
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # CONFIG_SHELL_IPC is not set
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_ANY_SUPPORT=y
    CONFIG_MPSL_FEM_NRF21540_GPIO_SUPPORT=y
    CONFIG_MPSL_FEM_NCS_SUPPORTED_FEM_USED=y
    CONFIG_MPSL_FEM_PIN_FORWARDER=y
    CONFIG_MPSL_FEM_NRF21540_GPIO=y
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=26
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
    CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x6000
    # CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL is not set
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
    CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@50000000/qspi@2b000/w25q6435f@0"
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=67108864
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CBC_MAC is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_SM3 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD2 is not set
    # CONFIG_PSA_WANT_ALG_MD4 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_FFDH is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # end of nRF Security
    # CONFIG_NET_CORE_MONITOR is not set
    # Audio Module
    # CONFIG_AUDIO_MODULE is not set
    # CONFIG_AUDIO_MODULE_TEST is not set
    CONFIG_AUDIO_MODULE_NAME_SIZE=20
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_MODULE_LOG_LEVEL=3
    # end of Audio Module
    # CONFIG_TRUSTED_STORAGE is not set
    # end of Subsystems
    # CONFIG_WPA_SUPP is not set
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # Binary libraries
    # CONFIG_BT_LL_ACS_NRF53 is not set
    # Log levels
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_INF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_DBG is not set
    CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_HCI_VSC_LOG_LEVEL=3
    # end of Log levels
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_INFO is not set
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_MODEM_SLM is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_OFF is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_ERR is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_WRN is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_INF is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_DBG is not set
    CONFIG_CONTIN_ARRAY_LOG_LEVEL_DEFAULT=y
    CONFIG_CONTIN_ARRAY_LOG_LEVEL=3
    # CONFIG_PCM_MIX_LOG_LEVEL_OFF is not set
    # CONFIG_PCM_MIX_LOG_LEVEL_ERR is not set
    # CONFIG_PCM_MIX_LOG_LEVEL_WRN is not set
    # CONFIG_PCM_MIX_LOG_LEVEL_INF is not set
    # CONFIG_PCM_MIX_LOG_LEVEL_DBG is not set
    CONFIG_PCM_MIX_LOG_LEVEL_DEFAULT=y
    CONFIG_PCM_MIX_LOG_LEVEL=3
    CONFIG_TONE=y
    # CONFIG_TONE_LOG_LEVEL_OFF is not set
    # CONFIG_TONE_LOG_LEVEL_ERR is not set
    # CONFIG_TONE_LOG_LEVEL_WRN is not set
    # CONFIG_TONE_LOG_LEVEL_INF is not set
    # CONFIG_TONE_LOG_LEVEL_DBG is not set
    CONFIG_TONE_LOG_LEVEL_DEFAULT=y
    CONFIG_TONE_LOG_LEVEL=3
    # CONFIG_PSCM_LOG_LEVEL_OFF is not set
    # CONFIG_PSCM_LOG_LEVEL_ERR is not set
    # CONFIG_PSCM_LOG_LEVEL_WRN is not set
    # CONFIG_PSCM_LOG_LEVEL_INF is not set
    # CONFIG_PSCM_LOG_LEVEL_DBG is not set
    CONFIG_PSCM_LOG_LEVEL_DEFAULT=y
    CONFIG_PSCM_LOG_LEVEL=3
    # CONFIG_DATA_FIFO_LOG_LEVEL_OFF is not set
    # CONFIG_DATA_FIFO_LOG_LEVEL_ERR is not set
    # CONFIG_DATA_FIFO_LOG_LEVEL_WRN is not set
    # CONFIG_DATA_FIFO_LOG_LEVEL_INF is not set
    # CONFIG_DATA_FIFO_LOG_LEVEL_DBG is not set
    CONFIG_DATA_FIFO_LOG_LEVEL_DEFAULT=y
    CONFIG_DATA_FIFO_LOG_LEVEL=3
    # CONFIG_FEM_AL_LIB is not set
    CONFIG_SAMPLE_RATE_CONVERTER=y
    # CONFIG_SAMPLE_RATE_CONVERTER_LOG_LEVEL_OFF is not set
    # CONFIG_SAMPLE_RATE_CONVERTER_LOG_LEVEL_ERR is not set
    # CONFIG_SAMPLE_RATE_CONVERTER_LOG_LEVEL_WRN is not set
    # CONFIG_SAMPLE_RATE_CONVERTER_LOG_LEVEL_INF is not set
    # CONFIG_SAMPLE_RATE_CONVERTER_LOG_LEVEL_DBG is not set
    CONFIG_SAMPLE_RATE_CONVERTER_LOG_LEVEL_DEFAULT=y
    CONFIG_SAMPLE_RATE_CONVERTER_LOG_LEVEL=3
    # CONFIG_SAMPLE_RATE_CONVERTER_FILTER_TEST is not set
    CONFIG_SAMPLE_RATE_CONVERTER_FILTER_SIMPLE=y
    CONFIG_SAMPLE_RATE_CONVERTER_MAX_FILTER_SIZE=72
    CONFIG_SAMPLE_RATE_CONVERTER_BLOCK_SIZE_MAX=480
    CONFIG_SAMPLE_RATE_CONVERTER_BIT_DEPTH_16=y
    # CONFIG_SAMPLE_RATE_CONVERTER_BIT_DEPTH_32 is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_BH1749 is not set
    # CONFIG_SENSOR_SIM is not set
    # CONFIG_SENSOR_STUB is not set
    # CONFIG_PMW3360 is not set
    # CONFIG_PAW3212 is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # CONFIG_IPC_UART is not set
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/nrf)
    # mcuboot (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/bootloader/mcuboot)
    # MCUboot
    CONFIG_SIGN_IMAGES=y
    # CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
    # CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set
    # CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set
    CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y
    # CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
    CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
    CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=y
    # end of MCUboot
    # CONFIG_XIP_SPLIT_IMAGE is not set
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/bootloader/mcuboot)
    # mbedtls (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    # PSA RNG support
    # end of PSA RNG support
    # PSA key type support
    # end of PSA key type support
    # PSA AEAD support
    # end of PSA AEAD support
    # PSA MAC support
    # end of PSA MAC support
    # PSA Hash support
    # end of PSA Hash support
    # PSA Cipher support
    # end of PSA Cipher support
    # PSA Key agreement support
    # end of PSA Key agreement support
    # PSA Key derivation support
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # Elliptic Curve type support
    # end of Elliptic Curve type support
    # end of PSA Asymmetric support
    # end of mbedtls (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/crypto/mbedtls)
    # trusted-firmware-m (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_BOARD="/Users/amirlazarovich/workspace/sond/firmware/thirdparty/zephyr/modules/trusted-firmware-m/nordic_nrf/nrf5340_cpuapp"
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cjson)
    # azure-sdk-for-c (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/azure-sdk-for-c)
    # cirrus-logic (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/cirrus-logic)
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/cirrus-logic)
    # openthread (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/openthread)
    # memfault-firmware-sdk (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/memfault-firmware-sdk)
    # canopennode (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/canopennode)
    # chre (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/chre)
    # lz4 (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/lz4)
    # nanopb (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/zscilib)
    # cmsis (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/cmsis)
    # cmsis-dsp (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    CONFIG_CMSIS_DSP=y
    # Instruction Set
    # Features
    # CONFIG_CMSIS_DSP_LOOPUNROLL is not set
    # CONFIG_CMSIS_DSP_ROUNDING is not set
    # CONFIG_CMSIS_DSP_MATRIXCHECK is not set
    # CONFIG_CMSIS_DSP_AUTOVECTORIZE is not set
    CONFIG_CMSIS_DSP_FLOAT16=y
    # end of cmsis-dsp (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cmsis-dsp)
    # cmsis-nn (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cmsis-nn)
    # fatfs (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/fs/fatfs)
    # hal_nordic (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_I2S_LOG is not set
    # CONFIG_NRFX_IPC_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_POWER_LOG is not set
    # CONFIG_NRFX_PRS_LOG is not set
    # CONFIG_NRFX_PWM_LOG is not set
    # CONFIG_NRFX_QSPI_LOG is not set
    # CONFIG_NRFX_RTC_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # CONFIG_NRFX_TIMER_LOG is not set
    # CONFIG_NRFX_TWIM_LOG is not set
    # CONFIG_NRFX_UARTE_LOG is not set
    # CONFIG_NRFX_USBREG_LOG is not set
    # CONFIG_NRFX_WDT_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE0=y
    # CONFIG_NRFX_GPIOTE1 is not set
    CONFIG_NRFX_I2S=y
    CONFIG_NRFX_IPC=y
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_PDM is not set
    CONFIG_NRFX_POWER=y
    CONFIG_NRFX_PWM=y
    CONFIG_NRFX_PWM0=y
    CONFIG_NRFX_PWM1=y
    CONFIG_NRFX_PWM2=y
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QDEC1 is not set
    CONFIG_NRFX_QSPI=y
    CONFIG_NRFX_RTC=y
    CONFIG_NRFX_RTC0=y
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    CONFIG_NRFX_SPIM=y
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    CONFIG_NRFX_SPIM4=y
    # CONFIG_NRFX_SYSTICK is not set
    CONFIG_NRFX_TIMER=y
    CONFIG_NRFX_TIMER0=y
    CONFIG_NRFX_TIMER2=y
    CONFIG_NRFX_TWIM=y
    # CONFIG_NRFX_TWIM0 is not set
    CONFIG_NRFX_TWIM1=y
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    CONFIG_NRFX_UARTE=y
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    CONFIG_NRFX_UARTE2=y
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_UARTE_CONFIG_SKIP_GPIO_CONFIG is not set
    # CONFIG_NRFX_UARTE_CONFIG_SKIP_PSEL_CONFIG is not set
    # CONFIG_NRFX_UARTE_CONFIG_TX_LINK is not set
    # CONFIG_NRFX_UARTE_CONFIG_RX_CACHE_ENABLED is not set
    CONFIG_NRFX_USBREG=y
    CONFIG_NRFX_WDT=y
    CONFIG_NRFX_WDT0=y
    # CONFIG_NRFX_WDT1 is not set
    # Peripheral Resource Sharing module
    CONFIG_NRFX_PRS=y
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    CONFIG_NRFX_PRS_BOX_2=y
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of hal_nordic (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/nordic)
    CONFIG_ZEPHYR_ST_MODULE=y
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # liblc3 (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # CONFIG_LIBLC3 is not set
    # end of liblc3 (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/liblc3)
    # littlefs (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/fs/littlefs)
    # loramac-node (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/loramac-node)
    # lvgl (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # picolibc (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/picolibc)
    # segger (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    CONFIG_SEGGER_RTT_SECTION_NONE=y
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # end of segger (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/uoscore-uedhoc)
    # zcbor (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR_CANONICAL is not set
    # CONFIG_ZCBOR_STOP_ON_ERROR is not set
    # CONFIG_ZCBOR_VERBOSE is not set
    CONFIG_ZCBOR_MAX_STR_LEN=256
    # end of zcbor (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/zcbor)
    # nrfxlib (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    # end of nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # CONFIG_CC3XX_HW_MUTEX_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # Encoder sample rates
    # end of Encoder sample rates
    # Decoder sample rates
    # end of Decoder sample rates
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/nrfxlib)
    # connectedhomeip (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/matter)
    CONFIG_LIBMETAL=y
    CONFIG_LIBMETAL_SRC_PATH="libmetal"
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    CONFIG_OPENAMP=y
    CONFIG_OPENAMP_SRC_PATH="open-amp"
    CONFIG_OPENAMP_MASTER=y
    CONFIG_OPENAMP_SLAVE=y
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    CONFIG_TINYCRYPT_SHA256=y
    CONFIG_TINYCRYPT_SHA256_HMAC=y
    CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
    # CONFIG_TINYCRYPT_ECC_DH is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    CONFIG_TINYCRYPT_AES_CMAC=y
    CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS="--quiet"
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE=""
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="0.0.0+0"
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    # On board MCUboot operation mode
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
    # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
    # end of On board MCUboot operation mode
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=8192
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL=3
    CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=6
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD_REVISION=""
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF5340_AUDIO_DK_NRF5340_CPUAPP=y
    # CONFIG_BOARD_NRF5340_AUDIO_DK_NRF5340_CPUAPP_NS is not set
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    CONFIG_DOMAIN_CPUNET_BOARD="nrf5340_audio_dk_nrf5340_cpunet"
    # end of Board Options
    # CONFIG_SOC_SERIES_APOLLO4X is not set
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32A50X is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_GD32L23X is not set
    # CONFIG_SOC_SERIES_PSOC_60 is not set
    # CONFIG_SOC_SERIES_PSOC_61 is not set
    # CONFIG_SOC_SERIES_PSOC_62 is not set
    # CONFIG_SOC_SERIES_PSOC_63 is not set
    # CONFIG_SOC_SERIES_PSOC_64 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    CONFIG_SOC_SERIES_NRF53X=y
    # CONFIG_SOC_SERIES_NRF54HX is not set
    # CONFIG_SOC_SERIES_NRF54LX is not set
    # CONFIG_SOC_SERIES_NRF91X is not set
    CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT=0x4000
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT=0x2000
    # CONFIG_SOC_SERIES_NPCX4 is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M46X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32K3XX is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RA4M1 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_RENESAS_RZT2M is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32GG12B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32BG22 is not set
    # CONFIG_SOC_SERIES_EFR32BG27 is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_EFR32MG24 is not set
    # CONFIG_SOC_SERIES_STM32C0X is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H5X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WBAX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_SERIES_AM62X_M4 is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_GPIO_INIT_PRIORITY=40
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_I2S0=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_NFCT=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_OSCILLATORS=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_PWM1=y
    CONFIG_HAS_HW_NRF_PWM2=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_REGULATORS=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TIMER0=y
    CONFIG_HAS_HW_NRF_TIMER1=y
    CONFIG_HAS_HW_NRF_TIMER2=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_UARTE3=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_SOC_NRF5340_CPUNET_QKAA is not set
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
    CONFIG_SOC_NRF53_RTC_PRETICK=y
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
    CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
    # CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
    CONFIG_SOC_DCDC_NRF53X_APP=y
    CONFIG_SOC_DCDC_NRF53X_NET=y
    CONFIG_SOC_DCDC_NRF53X_HV=y
    CONFIG_SOC_ENABLE_LFXO=y
    # CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_LFXO_CAP_INT_6PF is not set
    CONFIG_SOC_LFXO_CAP_INT_7PF=y
    # CONFIG_SOC_LFXO_CAP_INT_9PF is not set
    CONFIG_SOC_HFXO_CAP_DEFAULT=y
    # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF_ENABLE_CACHE=y
    CONFIG_NRF53_SYNC_RTC=y
    # CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_INF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set
    CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT=y
    CONFIG_SYNC_RTC_LOG_LEVEL=3
    CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1
    CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y
    CONFIG_NRF53_SYNC_RTC_IPM_OUT=7
    CONFIG_NRF53_SYNC_RTC_IPM_IN=8
    CONFIG_IPM_MSG_CH_8_ENABLE=y
    CONFIG_IPM_MSG_CH_8_RX=y
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF53X=y
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
    CONFIG_ARM_ON_EXIT_CPU_IDLE=y
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP_HARDABI=y
    # CONFIG_FP_SOFTABI is not set
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    CONFIG_CORTEX_M_DWT=y
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    CONFIG_THREAD_MAX_NAME_LEN=32
    CONFIG_INSTRUMENT_THREAD_SWITCHING=y
    CONFIG_THREAD_RUNTIME_STATS=y
    # CONFIG_THREAD_RUNTIME_STATS_USE_TIMING_FUNCTIONS is not set
    CONFIG_SCHED_THREAD_USAGE=y
    # CONFIG_SCHED_THREAD_USAGE_ANALYSIS is not set
    CONFIG_SCHED_THREAD_USAGE_ALL=y
    CONFIG_SCHED_THREAD_USAGE_AUTO_ENABLE=y
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # CONFIG_ADC_ASYNC is not set
    # CONFIG_ADC_LOG_LEVEL_OFF is not set
    # CONFIG_ADC_LOG_LEVEL_ERR is not set
    # CONFIG_ADC_LOG_LEVEL_WRN is not set
    # CONFIG_ADC_LOG_LEVEL_INF is not set
    # CONFIG_ADC_LOG_LEVEL_DBG is not set
    CONFIG_ADC_LOG_LEVEL_DEFAULT=y
    CONFIG_ADC_LOG_LEVEL=3
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # Bluetooth HCI Driver Options
    # CONFIG_BT_H4 is not set
    # CONFIG_BT_H5 is not set
    # CONFIG_BT_RPMSG is not set
    CONFIG_BT_HCI_IPC=y
    # CONFIG_BT_SPI is not set
    # CONFIG_BT_STM32_IPM is not set
    # CONFIG_BT_ESP32 is not set
    # CONFIG_BT_B91 is not set
    # CONFIG_BT_PSOC6_BLESS is not set
    # CONFIG_BT_NO_DRIVER is not set
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=256
    # CONFIG_CACHE is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CLOCK_CONTROL_NPCX_SUPP_APB4=y
    # CONFIG_CLOCK_CONTROL_NPCX_SUPP_FIU1 is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    CONFIG_RTT_CONSOLE=y
    CONFIG_RTT_TX_RETRY_CNT=2
    CONFIG_RTT_TX_RETRY_DELAY_MS=2
    # CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_COUNTER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVER_RAM is not set
    # CONFIG_DISK_DRIVER_FLASH is not set
    CONFIG_SD_INIT_PRIORITY=90
    CONFIG_SDMMC_VOLUME_NAME="SD"
    # CONFIG_SDMMC_LOG_LEVEL_OFF is not set
    # CONFIG_SDMMC_LOG_LEVEL_ERR is not set
    # CONFIG_SDMMC_LOG_LEVEL_WRN is not set
    # CONFIG_SDMMC_LOG_LEVEL_INF is not set
    # CONFIG_SDMMC_LOG_LEVEL_DBG is not set
    CONFIG_SDMMC_LOG_LEVEL_DEFAULT=y
    CONFIG_SDMMC_LOG_LEVEL=3
    # CONFIG_DISK_DRIVER_MMC is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    # CONFIG_ENTROPY_GENERATOR is not set
    # CONFIG_ESPI is not set
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_JESD216=y
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    CONFIG_FLASH_LOG_LEVEL_DBG=y
    # CONFIG_FLASH_LOG_LEVEL_DEFAULT is not set
    CONFIG_FLASH_LOG_LEVEL=4
    # CONFIG_FLASH_JESD216_API is not set
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_SOC_FLASH_NRF=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=41
    # CONFIG_NORDIC_QSPI_NOR_XIP is not set
    CONFIG_NORDIC_QSPI_NOR_TIMEOUT_MS=500
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    CONFIG_HWINFO=y
    # CONFIG_HWINFO_LOG_LEVEL_OFF is not set
    # CONFIG_HWINFO_LOG_LEVEL_ERR is not set
    # CONFIG_HWINFO_LOG_LEVEL_WRN is not set
    # CONFIG_HWINFO_LOG_LEVEL_INF is not set
    # CONFIG_HWINFO_LOG_LEVEL_DBG is not set
    CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
    CONFIG_HWINFO_LOG_LEVEL=3
    CONFIG_HWINFO_NRF=y
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C_STATS is not set
    # CONFIG_I2C_CALLBACK is not set
    # CONFIG_I2C_RTIO is not set
    # CONFIG_I2C_DW_LPSS_DMA is not set
    # CONFIG_I2C_TARGET is not set
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_NRFX_TWIM=y
    CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
    CONFIG_I2C_INIT_PRIORITY=50
    # CONFIG_I2C_LOG_LEVEL_OFF is not set
    # CONFIG_I2C_LOG_LEVEL_ERR is not set
    # CONFIG_I2C_LOG_LEVEL_WRN is not set
    # CONFIG_I2C_LOG_LEVEL_INF is not set
    # CONFIG_I2C_LOG_LEVEL_DBG is not set
    CONFIG_I2C_LOG_LEVEL_DEFAULT=y
    CONFIG_I2C_LOG_LEVEL=3
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
    CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
    CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    CONFIG_MBOX_INIT_PRIORITY=40
    # CONFIG_MBOX_LOG_LEVEL_OFF is not set
    # CONFIG_MBOX_LOG_LEVEL_ERR is not set
    # CONFIG_MBOX_LOG_LEVEL_WRN is not set
    # CONFIG_MBOX_LOG_LEVEL_INF is not set
    # CONFIG_MBOX_LOG_LEVEL_DBG is not set
    CONFIG_MBOX_LOG_LEVEL_DEFAULT=y
    CONFIG_MBOX_LOG_LEVEL=3
    # CONFIG_MDIO is not set
    # CONFIG_MFD is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    CONFIG_PWM=y
    # CONFIG_PWM_LOG_LEVEL_OFF is not set
    # CONFIG_PWM_LOG_LEVEL_ERR is not set
    # CONFIG_PWM_LOG_LEVEL_WRN is not set
    # CONFIG_PWM_LOG_LEVEL_INF is not set
    # CONFIG_PWM_LOG_LEVEL_DBG is not set
    CONFIG_PWM_LOG_LEVEL_DEFAULT=y
    CONFIG_PWM_LOG_LEVEL=3
    CONFIG_PWM_INIT_PRIORITY=50
    # CONFIG_PWM_CAPTURE is not set
    CONFIG_PWM_NRFX=y
    CONFIG_REGULATOR_THREAD_SAFE_REFCNT=y
    # CONFIG_REGULATOR_LOG_LEVEL_OFF is not set
    # CONFIG_REGULATOR_LOG_LEVEL_ERR is not set
    # CONFIG_REGULATOR_LOG_LEVEL_WRN is not set
    # CONFIG_REGULATOR_LOG_LEVEL_INF is not set
    # CONFIG_REGULATOR_LOG_LEVEL_DBG is not set
    CONFIG_REGULATOR_LOG_LEVEL_DEFAULT=y
    CONFIG_REGULATOR_LOG_LEVEL=3
    # CONFIG_REGULATOR_NXP_VREF is not set
    CONFIG_REGULATOR_NXP_VREF_INIT_PRIORITY=45
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # CONFIG_SENSOR_LOG_LEVEL_OFF is not set
    # CONFIG_SENSOR_LOG_LEVEL_ERR is not set
    # CONFIG_SENSOR_LOG_LEVEL_WRN is not set
    # CONFIG_SENSOR_LOG_LEVEL_INF is not set
    # CONFIG_SENSOR_LOG_LEVEL_DBG is not set
    CONFIG_SENSOR_LOG_LEVEL_DEFAULT=y
    CONFIG_SENSOR_LOG_LEVEL=3
    CONFIG_SENSOR_INIT_PRIORITY=90
    # CONFIG_SENSOR_ASYNC_API is not set
    # CONFIG_SENSOR_INFO is not set
    # Device Drivers
    # CONFIG_ICM42688_DECODER is not set
    CONFIG_VCMP_IT8XXX2_INIT_PRIORITY=90
    CONFIG_TMP112_FULL_SCALE_RUNTIME=y
    CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    CONFIG_UART_ASYNC_API=y
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_ASYNC_TX_CACHE_SIZE=8
    CONFIG_UART_0_ASYNC=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_0_NRF_HW_ASYNC=y
    # CONFIG_UART_0_NRF_ASYNC_LOW_POWER is not set
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=0
    CONFIG_UART_3_ASYNC=y
    CONFIG_UART_3_ENHANCED_POLL_OUT=y
    # CONFIG_UART_3_NRF_PARITY_BIT is not set
    CONFIG_UART_3_NRF_TX_BUFFER_SIZE=32
    # CONFIG_UART_3_NRF_HW_ASYNC is not set
    # CONFIG_UART_3_NRF_ASYNC_LOW_POWER is not set
    # CONFIG_SMBUS is not set
    CONFIG_SPI_ASYNC=y
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=70
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_STATS is not set
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=3
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_SPIM=y
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_SYSCON is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_NRF_GRTC_TIMER is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    CONFIG_USB_DEVICE_DRIVER=y
    # CONFIG_USB_DC_HAS_HS_SUPPORT is not set
    CONFIG_USB_DEVICE_REMOTE_WAKEUP=y
    CONFIG_USB_NRFX=y
    CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
    CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=1024
    CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=0
    # CONFIG_USB_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_USB_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_USB_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_USB_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_USB_DRIVER_LOG_LEVEL_DBG is not set
    CONFIG_USB_DRIVER_LOG_LEVEL_DEFAULT=y
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    CONFIG_NRF_USBD_COMMON=y
    CONFIG_NRF_USBD_ISO_IN_ZLP=y
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    CONFIG_WDT_DISABLE_AT_BOOT=y
    # CONFIG_WDT_LOG_LEVEL_OFF is not set
    # CONFIG_WDT_LOG_LEVEL_ERR is not set
    # CONFIG_WDT_LOG_LEVEL_WRN is not set
    # CONFIG_WDT_LOG_LEVEL_INF is not set
    CONFIG_WDT_LOG_LEVEL_DBG=y
    # CONFIG_WDT_LOG_LEVEL_DEFAULT is not set
    CONFIG_WDT_LOG_LEVEL=4
    CONFIG_WDT_NRFX=y
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    # CONFIG_PICOLIBC is not set
    CONFIG_NEWLIB_LIBC=y
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_MALLOC is not set
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
    # CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    CONFIG_CRC=y
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # OS Support Library
    # CONFIG_FDTABLE is not set
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    # CONFIG_UTF8 is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_POSIX_API is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL=3
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_COND_LOG_LEVEL=3
    # CONFIG_EVENTFD is not set
    # CONFIG_FNMATCH is not set
    # CONFIG_POSIX_FS is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_KEY_LOG_LEVEL=3
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL=3
    # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_LOG_LEVEL=3
    CONFIG_SEM_VALUE_MAX=32767
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=3
    # CONFIG_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_TIMER_LOG_LEVEL=3
    # CONFIG_TIMER is not set
    CONFIG_MAX_TIMER_COUNT=5
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_ACPI_HID_LEN_MAX=12
    CONFIG_LIBGCC_RTLIB=y
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER is not set
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    CONFIG_BT_ISO=y
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    CONFIG_BT_ISO_BROADCAST=y
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    CONFIG_BT_ISO_TX_FRAG_COUNT=2
    CONFIG_BT_ISO_TX_MTU=251
    CONFIG_BT_ISO_RX_BUF_COUNT=1
    CONFIG_BT_ISO_RX_MTU=251
    # CONFIG_BT_ISO_TEST_PARAMS is not set
    CONFIG_BT_ISO_MAX_BIG=1
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # Published Audio Capabilities (PAC) options
    # end of Published Audio Capabilities (PAC) options
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # end of Bluetooth Host
    # CONFIG_BT_SHELL is not set
    # CONFIG_BT_EAD is not set
    CONFIG_BT_LOG=y
    # Bluetooth logging
    CONFIG_BT_LOG_LEGACY=y
    # Bluetooth legacy logging options
    # CONFIG_BT_DEBUG_HCI_DRIVER is not set
    # [DEPRECATED] Audio
    # CONFIG_BT_DEBUG_AICS is not set
    # CONFIG_BT_DEBUG_AICS_CLIENT is not set
    # CONFIG_BT_BAP_DEBUG_STREAM is not set
    # CONFIG_BT_DEBUG_BAP_BROADCAST_SOURCE is not set
    # CONFIG_BT_DEBUG_CAP_INITIATOR is not set
    # CONFIG_BT_DEBUG_CSIP_SET_MEMBER is not set
    # CONFIG_BT_DEBUG_CSIP_SET_COORDINATOR is not set
    # CONFIG_BT_DEBUG_HAS is not set
    # CONFIG_BT_DEBUG_MCS is not set
    # CONFIG_BT_DEBUG_MCC is not set
    # CONFIG_MCTL_DEBUG is not set
    # CONFIG_BT_DEBUG_MICP_MIC_DEV is not set
    # CONFIG_BT_DEBUG_MICP_MIC_CTLR is not set
    # CONFIG_BT_DEBUG_MPL is not set
    # CONFIG_BT_DEBUG_TBS is not set
    # CONFIG_BT_DEBUG_TBS_CLIENT is not set
    # CONFIG_BT_DEBUG_VCP_VOL_REND is not set
    # CONFIG_BT_DEBUG_VCP_VOL_CTLR is not set
    # CONFIG_BT_DEBUG_VOCS is not set
    # CONFIG_BT_DEBUG_VOCS_CLIENT is not set
    # end of [DEPRECATED] Audio
    # [DEPRECATED] Others
    # CONFIG_BT_DEBUG_ATT is not set
    # CONFIG_BT_DEBUG_GATT is not set
    # CONFIG_BT_DEBUG_L2CAP is not set
    # CONFIG_BT_DEBUG_DF is not set
    # CONFIG_BT_DEBUG_HCI_CORE is not set
    # CONFIG_BT_DEBUG_CONN is not set
    # CONFIG_BT_DEBUG_ISO is not set
    # CONFIG_BT_DEBUG_SERVICE is not set
    # end of [DEPRECATED] Others
    # [DEPRECATED] BR/EDR
    # end of [DEPRECATED] BR/EDR
    # [DEPRECATED] Mesh
    # CONFIG_BT_MESH_DEBUG is not set
    # CONFIG_BT_MESH_DEBUG_NET is not set
    # CONFIG_BT_MESH_DEBUG_RPL is not set
    # CONFIG_BT_MESH_DEBUG_TRANS is not set
    # CONFIG_BT_MESH_DEBUG_BEACON is not set
    # CONFIG_BT_MESH_DEBUG_CRYPTO is not set
    # CONFIG_BT_MESH_DEBUG_KEYS is not set
    # CONFIG_BT_MESH_DEBUG_PROV is not set
    # CONFIG_BT_MESH_DEBUG_PROVISIONER is not set
    # CONFIG_BT_MESH_DEBUG_PROV_DEVICE is not set
    # CONFIG_BT_MESH_DEBUG_ACCESS is not set
    # CONFIG_BT_MESH_DEBUG_MODEL is not set
    # CONFIG_BT_MESH_DEBUG_ADV is not set
    # CONFIG_BT_MESH_DEBUG_LOW_POWER is not set
    # CONFIG_BT_MESH_DEBUG_FRIEND is not set
    # CONFIG_BT_MESH_DEBUG_CFG is not set
    # end of [DEPRECATED] Mesh
    # [DEPRECATED] Services
    # CONFIG_BT_DEBUG_OTS_CLIENT is not set
    # end of [DEPRECATED] Services
    # end of Bluetooth legacy logging options
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_LOG_LEVEL_INF is not set
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_RPA_LOG_LEVEL=3
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
    # Audio
    CONFIG_BT_AICS_LOG_LEVEL=3
    CONFIG_BT_AICS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AICS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AICS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AICS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AICS_LOG_LEVEL_INF is not set
    # CONFIG_BT_AICS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AICS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AICS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_STREAM_LOG_LEVEL=3
    CONFIG_BT_BAP_STREAM_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INHERIT=y
    CONFIG_BT_AUDIO_CODEC_LOG_LEVEL=3
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INF is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ASCS_LOG_LEVEL=3
    CONFIG_BT_ASCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ASCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL=3
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL=3
    CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL=3
    CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_ISO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_ISO_LOG_LEVEL=3
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL=3
    CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_INITIATOR_LOG_LEVEL=3
    CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_COMMANDER_LOG_LEVEL=3
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_COMMANDER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_STREAM_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_STREAM_LOG_LEVEL=3
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HAS_LOG_LEVEL=3
    CONFIG_BT_HAS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_HAS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HAS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HAS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MCS_LOG_LEVEL=3
    CONFIG_BT_MCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MCC_LOG_LEVEL=3
    CONFIG_BT_MCC_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MCC_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MCC_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MCC_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MCC_LOG_LEVEL_INF is not set
    # CONFIG_BT_MCC_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MCC_LOG_LEVEL_DEFAULT is not set
    CONFIG_MCTL_LOG_LEVEL=3
    CONFIG_MCTL_LOG_LEVEL_INHERIT=y
    # CONFIG_MCTL_LOG_LEVEL_OFF is not set
    # CONFIG_MCTL_LOG_LEVEL_ERR is not set
    # CONFIG_MCTL_LOG_LEVEL_WRN is not set
    # CONFIG_MCTL_LOG_LEVEL_INF is not set
    # CONFIG_MCTL_LOG_LEVEL_DBG is not set
    # CONFIG_MCTL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL=3
    CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL=3
    CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INF is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MPL_LOG_LEVEL=3
    CONFIG_BT_MPL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MPL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_PACS_LOG_LEVEL=3
    CONFIG_BT_PACS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_PACS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_PACS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_PACS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_PACS_LOG_LEVEL_INF is not set
    # CONFIG_BT_PACS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_PACS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_TBS_LOG_LEVEL=3
    CONFIG_BT_TBS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_TBS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TBS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TBS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TBS_LOG_LEVEL_INF is not set
    # CONFIG_BT_TBS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TBS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_TBS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VCP_VOL_REND_LOG_LEVEL=3
    CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INF is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL=3
    CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INF is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VOCS_LOG_LEVEL=3
    CONFIG_BT_VOCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VOCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VOCS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # end of Audio
    # Others
    CONFIG_BT_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ATT_LOG_LEVEL=3
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_GATT_LOG_LEVEL=3
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_L2CAP_LOG_LEVEL=3
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_EAD_LOG_LEVEL_INHERIT=y
    CONFIG_BT_EAD_LOG_LEVEL=3
    # CONFIG_BT_EAD_LOG_LEVEL_OFF is not set
    # CONFIG_BT_EAD_LOG_LEVEL_ERR is not set
    # CONFIG_BT_EAD_LOG_LEVEL_WRN is not set
    # CONFIG_BT_EAD_LOG_LEVEL_INF is not set
    # CONFIG_BT_EAD_LOG_LEVEL_DBG is not set
    # CONFIG_BT_EAD_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_DF_LOG_LEVEL=3
    CONFIG_BT_DF_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_DF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_DF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_DF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_DF_LOG_LEVEL_INF is not set
    # CONFIG_BT_DF_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DF_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SETTINGS_LOG_LEVEL=3
    CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL=2
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN=y
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CONN_LOG_LEVEL=3
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ISO_LOG_LEVEL=3
    CONFIG_BT_ISO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_KEYS_LOG_LEVEL=3
    CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SMP_LOG_LEVEL=3
    CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SMP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SERVICE_LOG_LEVEL=3
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CTLR_ISOAL_LOG_LEVEL=3
    CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INF is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_DEFAULT is not set
    # end of Others
    # BR/EDR
    CONFIG_BT_RFCOMM_LOG_LEVEL=3
    CONFIG_BT_RFCOMM_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_RFCOMM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_INF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HFP_HF_LOG_LEVEL=3
    CONFIG_BT_HFP_HF_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HFP_HF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_INF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AVDTP_LOG_LEVEL=3
    CONFIG_BT_AVDTP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AVDTP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_INF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_A2DP_LOG_LEVEL=3
    CONFIG_BT_A2DP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_A2DP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_INF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SDP_LOG_LEVEL=3
    CONFIG_BT_SDP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SDP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SDP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SDP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DEFAULT is not set
    # end of BR/EDR
    # Mesh
    CONFIG_BT_MESH_LOG_LEVEL=3
    CONFIG_BT_MESH_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_NET_LOG_LEVEL=3
    CONFIG_BT_MESH_NET_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_NET_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_RPL_LOG_LEVEL=3
    CONFIG_BT_MESH_RPL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_TRANS_LOG_LEVEL=3
    CONFIG_BT_MESH_TRANS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_BEACON_LOG_LEVEL=3
    CONFIG_BT_MESH_BEACON_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_KEYS_LOG_LEVEL=3
    CONFIG_BT_MESH_KEYS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROV_LOG_LEVEL=3
    CONFIG_BT_MESH_PROV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL=3
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL=3
    CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL=3
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_MODEL_LOG_LEVEL=3
    CONFIG_BT_MESH_MODEL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_DFU_LOG_LEVEL=3
    CONFIG_BT_MESH_DFU_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ADV_LOG_LEVEL=3
    CONFIG_BT_MESH_ADV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL=3
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL=3
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROXY_LOG_LEVEL=3
    CONFIG_BT_MESH_PROXY_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL=3
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CDB_LOG_LEVEL=3
    CONFIG_BT_MESH_CDB_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CFG_LOG_LEVEL=3
    CONFIG_BT_MESH_CFG_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DEFAULT is not set
    # end of Mesh
    # Services
    # CONFIG_BT_BAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_BAS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_BAS_LOG_LEVEL=3
    # CONFIG_BT_HRS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HRS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HRS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HRS_LOG_LEVEL_INF is not set
    # CONFIG_BT_HRS_LOG_LEVEL_DBG is not set
    CONFIG_BT_HRS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_HRS_LOG_LEVEL=3
    # CONFIG_BT_TPS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TPS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TPS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TPS_LOG_LEVEL_INF is not set
    # CONFIG_BT_TPS_LOG_LEVEL_DBG is not set
    CONFIG_BT_TPS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_TPS_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_IAS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_IAS_LOG_LEVEL=3
    CONFIG_BT_OTS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_OTS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_OTS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_OTS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_OTS_LOG_LEVEL_INF is not set
    # CONFIG_BT_OTS_LOG_LEVEL_DBG is not set
    CONFIG_BT_OTS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_OTS_LOG_LEVEL=3
    # end of Services
    # end of Bluetooth logging
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    CONFIG_THREAD_ANALYZER=y
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_OFF is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_ERR is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_WRN is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_INF is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_DBG is not set
    CONFIG_THREAD_ANALYZER_LOG_LEVEL_DEFAULT=y
    CONFIG_THREAD_ANALYZER_LOG_LEVEL=3
    CONFIG_THREAD_ANALYZER_USE_LOG=y
    # CONFIG_THREAD_ANALYZER_USE_PRINTK is not set
    CONFIG_THREAD_ANALYZER_ISR_STACK_USAGE=y
    CONFIG_THREAD_ANALYZER_RUN_UNLOCKED=y
    # CONFIG_THREAD_ANALYZER_AUTO is not set
    # end of System Monitoring Options
    # Debugging Options
    CONFIG_DEBUG=y
    CONFIG_STACK_USAGE=y
    CONFIG_STACK_SENTINEL=y
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    CONFIG_DEBUG_INFO=y
    CONFIG_EXCEPTION_STACK_TRACE=y
    CONFIG_DEBUG_THREAD_INFO=y
    CONFIG_DEBUG_COREDUMP=y
    # CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING is not set
    CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION=y
    # CONFIG_DEBUG_COREDUMP_BACKEND_OTHER is not set
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
    # CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_LINKER_RAM is not set
    # end of Debugging Options
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
    CONFIG_IMG_MANAGER_LOG_LEVEL=3
    CONFIG_DISK_ACCESS=y
    # CONFIG_DISK_LOG_LEVEL_OFF is not set
    # CONFIG_DISK_LOG_LEVEL_ERR is not set
    # CONFIG_DISK_LOG_LEVEL_WRN is not set
    # CONFIG_DISK_LOG_LEVEL_INF is not set
    # CONFIG_DISK_LOG_LEVEL_DBG is not set
    CONFIG_DISK_LOG_LEVEL_DEFAULT=y
    CONFIG_DISK_LOG_LEVEL=3
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FS_LOG_LEVEL_OFF is not set
    # CONFIG_FS_LOG_LEVEL_ERR is not set
    # CONFIG_FS_LOG_LEVEL_WRN is not set
    # CONFIG_FS_LOG_LEVEL_INF is not set
    # CONFIG_FS_LOG_LEVEL_DBG is not set
    CONFIG_FS_LOG_LEVEL_DEFAULT=y
    CONFIG_FS_LOG_LEVEL=3
    CONFIG_APP_LINK_WITH_FS=y
    CONFIG_FILE_SYSTEM_MAX_TYPES=2
    CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1
    # CONFIG_FILE_SYSTEM_MKFS is not set
    # ELM FAT file system settings
    # CONFIG_FS_FATFS_READ_ONLY is not set
    CONFIG_FS_FATFS_MKFS=y
    CONFIG_FS_FATFS_MOUNT_MKFS=y
    CONFIG_FS_FATFS_MAX_ROOT_ENTRIES=512
    CONFIG_FS_FATFS_NUM_FILES=4
    CONFIG_FS_FATFS_NUM_DIRS=4
    # CONFIG_FS_FATFS_LFN_MODE_BSS is not set
    CONFIG_FS_FATFS_LFN_MODE_STACK=y
    # CONFIG_FS_FATFS_LFN_MODE_HEAP is not set
    CONFIG_FS_FATFS_FF_USE_LFN=2
    CONFIG_FS_FATFS_CODEPAGE=437
    CONFIG_FS_FATFS_MAX_SS=512
    CONFIG_FS_FATFS_MIN_SS=512
    CONFIG_FS_FATFS_WINDOW_ALIGNMENT=1
    # CONFIG_FS_FATFS_REENTRANT is not set
    # end of ELM FAT file system settings
    # CONFIG_FILE_SYSTEM_LITTLEFS is not set
    # CONFIG_FILE_SYSTEM_EXT2 is not set
    # CONFIG_EXT2_LOG_LEVEL_OFF is not set
    # CONFIG_EXT2_LOG_LEVEL_ERR is not set
    # CONFIG_EXT2_LOG_LEVEL_WRN is not set
    # CONFIG_EXT2_LOG_LEVEL_INF is not set
    # CONFIG_EXT2_LOG_LEVEL_DBG is not set
    CONFIG_EXT2_LOG_LEVEL_DEFAULT=y
    CONFIG_EXT2_LOG_LEVEL=3
    # CONFIG_FCB is not set
    # CONFIG_NVS_LOOKUP_CACHE is not set
    # CONFIG_NVS_LOG_LEVEL_OFF is not set
    # CONFIG_NVS_LOG_LEVEL_ERR is not set
    # CONFIG_NVS_LOG_LEVEL_WRN is not set
    # CONFIG_NVS_LOG_LEVEL_INF is not set
    # CONFIG_NVS_LOG_LEVEL_DBG is not set
    CONFIG_NVS_LOG_LEVEL_DEFAULT=y
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    CONFIG_IPC_SERVICE=y
    CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
    CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
    CONFIG_IPC_SERVICE_RPMSG=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
    # CONFIG_IPC_SERVICE_ICMSG is not set
    # CONFIG_IPC_SERVICE_ICMSG_ME is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set
    CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_IPC_SERVICE_LOG_LEVEL=3
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    CONFIG_LOG_TAG_MAX_LEN=2
    CONFIG_LOG_TAG_DEFAULT="--"
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_FS is not set
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
    # CONFIG_LOG_BACKEND_SWO is not set
    CONFIG_LOG_BACKEND_UART=y
    # CONFIG_LOG_BACKEND_UART_ASYNC is not set
    CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
    CONFIG_LOG_BACKEND_UART_AUTOSTART=y
    CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_DOMAIN_ID=0
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_LOG_LEVEL=3
    # CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set
    # CONFIG_MCUMGR_MGMT_HANDLER_USER_DATA is not set
    CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y
    CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y
    # CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set
    # CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set
    # SMP Client
    # CONFIG_SMP_CLIENT is not set
    # end of SMP Client
    # Command Handlers
    # CONFIG_MCUMGR_GRP_FS is not set
    # CONFIG_MCUMGR_GRP_IMG_USE_HEAP_FOR_FLASH_IMG_CONTEXT is not set
    CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER=2
    # CONFIG_MCUMGR_GRP_IMG_VERBOSE_ERR is not set
    CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY=y
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_ANY is not set
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_ERASE_PENDING is not set
    # CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD is not set
    # CONFIG_MCUMGR_GRP_IMG_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
    # CONFIG_MCUMGR_GRP_IMG_FRUGAL_LIST is not set
    # CONFIG_MCUMGR_GRP_IMG_VERSION_CMP_USE_BUILD_NUMBER is not set
    # CONFIG_MCUMGR_GRP_IMG_MUTEX is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL=3
    CONFIG_MCUMGR_GRP_OS_RESET_MS=250
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_ONLY_SUPPORTED_STATS=y
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_USE_THREAD_NAME_FOR_NAME=y
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT_USE_THREAD_IDX_FOR_NAME is not set
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT_USE_THREAD_PRIO_FOR_NAME is not set
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_MAX_NUM_THREADS=50
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_THREAD_NAME_LEN=32
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_SIGNED_PRIORITY=y
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT_STACK_INFO is not set
    CONFIG_MCUMGR_GRP_OS_ECHO=y
    # CONFIG_MCUMGR_GRP_OS_INFO is not set
    CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL=3
    CONFIG_MCUMGR_GRP_STAT_MAX_NAME_LEN=32
    # CONFIG_MCUMGR_GRP_STAT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_STAT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_STAT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_STAT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_STAT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_STAT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_STAT_LOG_LEVEL=3
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL=3
    # end of Command Handlers
    # Transports and Transport Related Configuration Options
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=2048
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3
    CONFIG_MCUMGR_TRANSPORT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE=8
    CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=8
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL=3
    CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MIN_INT=6
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MAX_INT=9
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_LATENCY=0
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_TIMEOUT=42
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RESTORE_TIME=5000
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RETRY_TIME=1000
    # end of Transports and Transport Related Configuration Options
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SHELL is not set
    # Storage
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    CONFIG_STREAM_FLASH_ERASE=y
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAM_FLASH_LOG_LEVEL=3
    # end of Storage
    CONFIG_TASK_WDT_CHANNELS=5
    CONFIG_TASK_WDT_HW_FALLBACK=y
    CONFIG_TASK_WDT_MIN_TIMEOUT=500
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    CONFIG_TIMING_FUNCTIONS=y
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_USB_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_USB_DEVICE_LOG_LEVEL_WRN is not set
    # CONFIG_USB_DEVICE_LOG_LEVEL_INF is not set
    # CONFIG_USB_DEVICE_LOG_LEVEL_DBG is not set
    CONFIG_USB_DEVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_USB_DEVICE_SN="0123456789ABCDEF"
    # CONFIG_USB_COMPOSITE_DEVICE is not set
    CONFIG_USB_MAX_NUM_TRANSFERS=4
    CONFIG_USB_DEVICE_BLUETOOTH_BIG_BUF=y
    CONFIG_USB_REQUEST_BUFFER_SIZE=128
    CONFIG_USB_MAX_ALT_SETTING=8
    CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
    # CONFIG_USB_DEVICE_SOF is not set
    # CONFIG_USB_DEVICE_BOS is not set
    # CONFIG_USB_DEVICE_OS_DESC is not set
    CONFIG_USB_SELF_POWERED=y
    CONFIG_USB_MAX_POWER=50
    # CONFIG_USB_WORKQUEUE is not set
    # USB CDC ACM Class support
    # end of USB CDC ACM Class support
    # CONFIG_USB_MASS_STORAGE is not set
    # CONFIG_USB_DEVICE_BLUETOOTH is not set
    # CONFIG_USB_DEVICE_BT_H4 is not set
    # CONFIG_USB_DEVICE_LOOPBACK is not set
    # USB Device Networking support
    # CONFIG_USB_DEVICE_NETWORK_ECM is not set
    # CONFIG_USB_DEVICE_NETWORK_EEM is not set
    # CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
    # end of USB Device Networking support
    # CONFIG_USB_DEVICE_HID is not set
    # CONFIG_USB_DFU_CLASS is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    CONFIG_ZBUS_CHANNELS_SYS_INIT_PRIORITY=5
    # CONFIG_ZBUS_CHANNEL_NAME is not set
    # CONFIG_ZBUS_OBSERVER_NAME is not set
    CONFIG_ZBUS_MSG_SUBSCRIBER_NET_BUF_DYNAMIC=y
    # CONFIG_ZBUS_MSG_SUBSCRIBER_NET_BUF_STATIC is not set
    CONFIG_ZBUS_MSG_SUBSCRIBER_NET_BUF_POOL_SIZE=16
    # CONFIG_ZBUS_ASSERT_MOCK is not set
    # CONFIG_ZBUS_LOG_LEVEL_OFF is not set
    # CONFIG_ZBUS_LOG_LEVEL_ERR is not set
    # CONFIG_ZBUS_LOG_LEVEL_WRN is not set
    # CONFIG_ZBUS_LOG_LEVEL_INF is not set
    # CONFIG_ZBUS_LOG_LEVEL_DBG is not set
    CONFIG_ZBUS_LOG_LEVEL_DEFAULT=y
    CONFIG_ZBUS_LOG_LEVEL=3
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    # CONFIG_SIZE_OPTIMIZATIONS is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    CONFIG_DEBUG_OPTIMIZATIONS=y
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    CONFIG_BUILD_OUTPUT_META=y
    # CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_EXPERIMENTAL=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    build/zephyr/zephyr.dts
    /dts-v1/;
    	#address-cells = < 0x1 >;
    	#size-cells = < 0x1 >;
    	model = "Nordic nRF5340 Audio DK NRF5340 Application";
    	compatible = "nordic,nrf5340-audio-dk-nrf5340-cpuapp";
    	chosen {
    		zephyr,entropy = &cryptocell;
    		zephyr,flash-controller = &flash_controller;
    		zephyr,console = &uart3;
    		zephyr,shell-uart = &uart3;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart3;
    		zephyr,bt-c2h-uart = &uart3;
    		zephyr,bt-hci-ipc = &ipc0;
    		watchdog0 = &wdt0;
    		zephyr,ipc_shm = &sram0_shared;
    		zephyr,sram = &sram0_image;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,sram-secure-partition = &sram0_s;
    		zephyr,sram-non-secure-partition = &sram0_ns;
    		nordic,pm-ext-flash = &w25q64;
    	aliases {
    		rgb1 = &pwm_led_rgb1;
    		rgb2 = &pwm_led_rgb2;
    		botwhite = &pwm_led_bottom_white;
    		coredump-partition = &coredump_partition;
    		iqs = &iqs_ready;
    		watchdog0 = &wdt0;
    	soc {
    		compatible = "nordic,nrf5340-cpuapp-qkaa", "nordic,nrf5340-cpuapp", "nordic,nrf53", "simple-bus";
    		interrupt-parent = < &nvic >;
    		ranges;
    		nvic: interrupt-controller@e000e100 {
    			compatible = "arm,v8m-nvic";
    			reg = < 0xe000e100 0xc00 >;
    			interrupt-controller;
    			#interrupt-cells = < 0x2 >;
    			arm,num-irq-priority-bits = < 0x3 >;
    			phandle = < 0x1 >;
    		systick: timer@e000e010 {
    			compatible = "arm,armv8m-systick";
    			reg = < 0xe000e010 0x10 >;
    			status = "disabled";
    		ficr: ficr@ff0000 {
    			compatible = "nordic,nrf-ficr";
    			reg = < 0xff0000 0x1000 >;
    			#nordic,ficr-cells = < 0x1 >;
    			status = "okay";
    		uicr: uicr@ff8000 {
    			compatible = "nordic,nrf-uicr";
    			reg = < 0xff8000 0x1000 >;
    			status = "okay";
    			nfct-pins-as-gpios;
    		sram0: memory@20000000 {
    			compatible = "mmio-sram";
    			reg = < 0x20000000 0x80000 >;
    		peripheral@50000000 {
    			ranges = < 0x0 0x50000000 0x10000000 >;
    			dcnf: dcnf@0 {
    				compatible = "nordic,nrf-dcnf";
    				reg = < 0x0 0x1000 >;
    				status = "okay";
    			oscillators: oscillator@4000 {
    				compatible = "nordic,nrf-oscillators";
    				reg = < 0x4000 0x1000 >;
    				status = "okay";
    			regulators: regulator@4000 {
    				compatible = "nordic,nrf-regulators";
    				status = "okay";
    			clock: clock@5000 {
    				compatible = "nordic,nrf-clock";
    				reg = < 0x5000 0x1000 >;
    				interrupts = < 0x5 0x1 >;
    				status = "okay";
    			power: power@5000 {
    				compatible = "nordic,nrf-power";
    				status = "okay";
    				gpregret1: gpregret1@551c {
    					compatible = "nordic,nrf-gpregret";
    					reg = < 0x551c 0x1 >;
    					status = "okay";
    				gpregret2: gpregret2@5520 {
    					reg = < 0x5520 0x1 >;
    					status = "okay";
    			reset: reset-controller@5000 {
    				compatible = "nordic,nrf-reset";
    				status = "okay";
    			ctrlap: ctrlap@6000 {
    				compatible = "nordic,nrf-ctrlapperi";
    				reg = < 0x6000 0x1000 >;
    				status = "okay";
    			i2c0: i2c@8000 {
    				#size-cells = < 0x0 >;
    				reg = < 0x8000 0x1000 >;
    				clock-frequency = < 0x186a0 >;
    				interrupts = < 0x8 0x1 >;
    				easydma-maxcnt-bits = < 0x10 >;
    			spi0: spi@8000 {
    				max-frequency = < 0x7a1200 >;
    			uart0: uart@8000 {
    				status = "okay";
    				label = "UART_0";
    				current-speed = < 0x1c200 >;
    				pinctrl-0 = < &uart0_default >;
    				pinctrl-1 = < &uart0_sleep >;
    			i2c1: i2c@9000 {
    				reg = < 0x9000 0x1000 >;
    				interrupts = < 0x9 0x1 >;
    				status = "okay";
    				zephyr,concat-buf-size = < 0x100 >;
    				pinctrl-0 = < &i2c1_default >;
    				pinctrl-1 = < &i2c1_sleep >;
    			spi1: spi@9000 {
    			uart1: uart@9000 {
    			spi4: fem_spi: spi@a000 {
    				reg = < 0xa000 0x1000 >;
    				interrupts = < 0xa 0x1 >;
    				max-frequency = < 0x1e84800 >;
    				rx-delay-supported;
    				rx-delay = < 0x2 >;
    				status = "okay";
    				pinctrl-0 = < &spi4_default >;
    				pinctrl-1 = < &spi4_sleep >;
    				cs-gpios = < &gpio0 0x16 0x1 >;
    				nrf_radio_fem_spi: nrf21540_fem_spi@0 {
    					compatible = "nordic,nrf21540-fem-spi";
    					status = "okay";
    					reg = < 0x0 >;
    					spi-max-frequency = < 0x7a1200 >;
    			i2c2: i2c@b000 {
    				reg = < 0xb000 0x1000 >;
    				interrupts = < 0xb 0x1 >;
    			spi2: spi@b000 {
    			uart2: uart@b000 {
    				pinctrl-0 = < &uart2_default >;
    				pinctrl-1 = < &uart2_sleep >;
    			i2c3: i2c@c000 {
    				reg = < 0xc000 0x1000 >;
    				interrupts = < 0xc 0x1 >;
    			spi3: spi@c000 {
    			uart3: uart@c000 {
    				status = "okay";
    				pinctrl-0 = < &uart3_default >;
    				pinctrl-1 = < &uart3_sleep >;
    			adc: adc@e000 {
    				compatible = "nordic,nrf-saadc";
    				reg = < 0xe000 0x1000 >;
    				interrupts = < 0xe 0x1 >;
    				#io-channel-cells = < 0x1 >;
    			timer0: timer@f000 {
    				compatible = "nordic,nrf-timer";
    				status = "okay";
    				reg = < 0xf000 0x1000 >;
    				cc-num = < 0x6 >;
    				max-bit-width = < 0x20 >;
    				interrupts = < 0xf 0x1 >;
    				prescaler = < 0x0 >;
    			timer1: timer@10000 {
    				status = "okay";
    				reg = < 0x10000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x10 0x1 >;
    				phandle = < 0x18 >;
    			timer2: timer@11000 {
    				status = "okay";
    				reg = < 0x11000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x11 0x1 >;
    			rtc0: rtc@14000 {
    				compatible = "nordic,nrf-rtc";
    				reg = < 0x14000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x14 0x1 >;
    				clock-frequency = < 0x8000 >;
    				prescaler = < 0x1 >;
    			rtc1: rtc@15000 {
    				reg = < 0x15000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x15 0x1 >;
    			dppic: dppic@17000 {
    				compatible = "nordic,nrf-dppic";
    				reg = < 0x17000 0x1000 >;
    				status = "okay";
    			wdt: wdt0: watchdog@18000 {
    				compatible = "nordic,nrf-wdt";
    				reg = < 0x18000 0x1000 >;
    				interrupts = < 0x18 0x1 >;
    				status = "okay";
    			wdt1: watchdog@19000 {
    				reg = < 0x19000 0x1000 >;
    				interrupts = < 0x19 0x1 >;
    			comp: comparator@1a000 {
    				compatible = "nordic,nrf-comp";
    				reg = < 0x1a000 0x1000 >;
    				interrupts = < 0x1a 0x1 >;
    			egu0: egu@1b000 {
    				compatible = "nordic,nrf-egu";
    				reg = < 0x1b000 0x1000 >;
    				interrupts = < 0x1b 0x1 >;
    				status = "okay";
    			egu1: egu@1c000 {
    				reg = < 0x1c000 0x1000 >;
    				interrupts = < 0x1c 0x1 >;
    				status = "okay";
    			egu2: egu@1d000 {
    				reg = < 0x1d000 0x1000 >;
    				interrupts = < 0x1d 0x1 >;
    				status = "okay";
    			egu3: egu@1e000 {
    				reg = < 0x1e000 0x1000 >;
    				interrupts = < 0x1e 0x1 >;
    				status = "okay";
    			egu4: egu@1f000 {
    				reg = < 0x1f000 0x1000 >;
    				interrupts = < 0x1f 0x1 >;
    				status = "okay";
    			egu5: egu@20000 {
    				reg = < 0x20000 0x1000 >;
    				interrupts = < 0x20 0x1 >;
    				status = "okay";
    			pwm0: pwm@21000 {
    				compatible = "nordic,nrf-pwm";
    				reg = < 0x21000 0x1000 >;
    				interrupts = < 0x21 0x1 >;
    				status = "okay";
    				#pwm-cells = < 0x3 >;
    				pinctrl-0 = < &pwm0_default >;
    				pinctrl-1 = < &pwm0_sleep >;
    				phandle = < 0x1c >;
    			pwm1: pwm@22000 {
    				reg = < 0x22000 0x1000 >;
    				interrupts = < 0x22 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &pwm1_default >;
    				pinctrl-1 = < &pwm1_sleep >;
    				phandle = < 0x1d >;
    			pwm2: pwm@23000 {
    				reg = < 0x23000 0x1000 >;
    				interrupts = < 0x23 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &pwm2_default >;
    				pinctrl-1 = < &pwm2_sleep >;
    				phandle = < 0x1e >;
    			pwm3: pwm@24000 {
    				reg = < 0x24000 0x1000 >;
    				interrupts = < 0x24 0x1 >;
    			pdm0: pdm@26000 {
    				compatible = "nordic,nrf-pdm";
    				reg = < 0x26000 0x1000 >;
    				interrupts = < 0x26 0x1 >;
    			i2s0: i2s@28000 {
    				compatible = "nordic,nrf-i2s";
    				reg = < 0x28000 0x1000 >;
    				interrupts = < 0x28 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &i2s0_default >;
    				pinctrl-1 = < &i2s0_sleep >;
    			mbox: ipc: mbox@2a000 {
    				compatible = "nordic,mbox-nrf-ipc", "nordic,nrf-ipc";
    				reg = < 0x2a000 0x1000 >;
    				tx-mask = < 0xffff >;
    				rx-mask = < 0xffff >;
    				interrupts = < 0x2a 0x1 >;
    				#mbox-cells = < 0x1 >;
    				status = "okay";
    				phandle = < 0x1a >;
    			qspi: qspi@2b000 {
    				compatible = "nordic,nrf-qspi";
    				reg = < 0x2b000 0x1000 >, < 0x10000000 0x10000000 >;
    				reg-names = "qspi", "qspi_mm";
    				interrupts = < 0x2b 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &qspi_default >;
    				pinctrl-1 = < &qspi_sleep >;
    				w25q64: w25q6435f@0 {
    					compatible = "nordic,qspi-nor";
    					reg = < 0x0 >;
    					sck-frequency = < 0x7a1200 >;
    					jedec-id = [ EF 40 17 ];
    					sfdp-bfp = [ E5 20 F9 FF FF FF FF 03 44 EB 08 6B 08 3B 42 BB FE FF FF FF FF FF 00 00 FF FF 40 EB 0C 20 0F 52 10 D8 00 00 36 02 A6 00 82 EA 14 C4 E9 63 76 33 7A 75 7A 75 F7 A2 D5 5C 19 F7 4D FF E9 30 F8 80 ];
    					size = < 0x4000000 >;
    					has-dpd;
    					t-enter-dpd = < 0x2710 >;
    					t-exit-dpd = < 0x88b8 >;
    			nfct: nfct@2d000 {
    				compatible = "nordic,nrf-nfct";
    				reg = < 0x2d000 0x1000 >;
    				interrupts = < 0x2d 0x1 >;
    				status = "okay";
    			mutex: mutex@30000 {
    				compatible = "nordic,nrf-mutex";
    				reg = < 0x30000 0x1000 >;
    				status = "okay";
    			qdec0: qdec@33000 {
    				compatible = "nordic,nrf-qdec";
    				reg = < 0x33000 0x1000 >;
    				interrupts = < 0x33 0x1 >;
    			qdec1: qdec@34000 {
    				reg = < 0x34000 0x1000 >;
    				interrupts = < 0x34 0x1 >;
    			usbd: zephyr_udc0: usbd@36000 {
    				compatible = "nordic,nrf-usbd";
    				reg = < 0x36000 0x1000 >;
    				interrupts = < 0x36 0x1 >;
    				num-bidir-endpoints = < 0x1 >;
    				num-in-endpoints = < 0x7 >;
    				num-out-endpoints = < 0x7 >;
    				num-isoin-endpoints = < 0x1 >;
    				num-isoout-endpoints = < 0x1 >;
    				status = "okay";
    				hs_0: hs_0 {
    					compatible = "usb-audio-hs";
    					mic-feature-mute;
    					mic-channel-l;
    					mic-channel-r;
    					hp-feature-mute;
    					hp-channel-l;
    					hp-channel-r;
    			usbreg: regulator@37000 {
    				compatible = "nordic,nrf-usbreg";
    				reg = < 0x37000 0x1000 >;
    				interrupts = < 0x37 0x1 >;
    				status = "okay";
    			flash_controller: flash-controller@39000 {
    				compatible = "nordic,nrf53-flash-controller";
    				reg = < 0x39000 0x1000 >;
    				partial-erase;
    				flash0: flash@0 {
    					compatible = "soc-nv-flash";
    					erase-block-size = < 0x1000 >;
    					write-block-size = < 0x4 >;
    					reg = < 0x0 0x100000 >;
    					partitions {
    						boot_partition: partition@0 {
    							label = "mcuboot";
    							reg = < 0x0 0x10000 >;
    						slot0_partition: partition@10000 {
    							label = "image-0";
    							reg = < 0x10000 0x40000 >;
    						slot0_ns_partition: partition@50000 {
    							label = "image-0-nonsecure";
    							reg = < 0x50000 0x30000 >;
    						slot1_partition: partition@80000 {
    							label = "image-1";
    							reg = < 0x80000 0x40000 >;
    						slot1_ns_partition: partition@c0000 {
    							label = "image-1-nonsecure";
    							reg = < 0xc0000 0x30000 >;
    						storage_partition: partition@f0000 {
    							label = "storage";
    							reg = < 0xf0000 0xf000 >;
    						coredump_partition: partition@ff000 {
    							label = "coredump_partition";
    							reg = < 0xff000 0x1000 >;
    			kmu: kmu@39000 {
    				compatible = "nordic,nrf-kmu";
    				interrupts = < 0x39 0x1 >;
    				status = "okay";
    			vmc: vmc@81000 {
    				compatible = "nordic,nrf-vmc";
    				reg = < 0x81000 0x1000 >;
    				status = "okay";
    			gpio0: gpio@842500 {
    				compatible = "nordic,nrf-gpio";
    				gpio-controller;
    				reg = < 0x842500 0x300 >;
    				#gpio-cells = < 0x2 >;
    				status = "okay";
    				port = < 0x0 >;
    				gpiote-instance = < &gpiote >;
    				phandle = < 0x8 >;
    			gpio1: gpio@842800 {
    				gpio-controller;
    				reg = < 0x842800 0x300 >;
    				ngpios = < 0x10 >;
    				status = "okay";
    				port = < 0x1 >;
    				phandle = < 0x1b >;
    			ieee802154: ieee802154 {
    				compatible = "nordic,nrf-ieee802154";
    		spu: spu@50003000 {
    			compatible = "nordic,nrf-spu";
    			reg = < 0x50003000 0x1000 >;
    			interrupts = < 0x3 0x1 >;
    			status = "okay";
    		gpiote: gpiote0: gpiote@5000d000 {
    			compatible = "nordic,nrf-gpiote";
    			reg = < 0x5000d000 0x1000 >;
    			interrupts = < 0xd 0x5 >;
    			status = "okay";
    			instance = < 0x0 >;
    			phandle = < 0x17 >;
    		gpiote1: gpiote@4002f000 {
    			reg = < 0x4002f000 0x1000 >;
    			interrupts = < 0x2f 0x5 >;
    			instance = < 0x1 >;
    		cryptocell: crypto@50844000 {
    			compatible = "nordic,cryptocell", "arm,cryptocell-312";
    			reg = < 0x50844000 0x1000 >, < 0x50845000 0x1000 >;
    			reg-names = "wrapper", "core";
    			interrupts = < 0x44 0x1 >;
    			status = "okay";
    	pinctrl: pin-controller {
    		compatible = "nordic,nrf-pinctrl";
    		i2s0_default: i2s0_default {
    			phandle = < 0x13 >;
    			group1 {
    				psels = < 0x13002b >;
    				nordic,drive-mode = < 0x3 >;
    			group2 {
    				psels = < 0xd002d >, < 0xf002c >, < 0x12002e >, < 0x11002f >;
    		i2s0_sleep: i2s0_sleep {
    			phandle = < 0x14 >;
    			group1 {
    				psels = < 0x13002b >, < 0xd002d >, < 0xf002c >, < 0x12002e >, < 0x11002f >;
    				low-power-enable;
    		uart0_default: uart0_default {
    			phandle = < 0x2 >;
    			group1 {
    				psels = < 0x27 >;
    			group2 {
    				psels = < 0x10028 >;
    				bias-pull-up;
    		uart0_sleep: uart0_sleep {
    			phandle = < 0x3 >;
    			group1 {
    				psels = < 0x27 >, < 0x10028 >;
    				low-power-enable;
    		uart2_default: uart2_default {
    			phandle = < 0x9 >;
    			group1 {
    				psels = < 0x1b >;
    			group2 {
    				psels = < 0x10018 >;
    				bias-pull-up;
    		uart2_sleep: uart2_sleep {
    			phandle = < 0xa >;
    			group1 {
    				psels = < 0x1b >, < 0x10018 >;
    				low-power-enable;
    		uart3_default: uart3_default {
    			phandle = < 0xb >;
    			group1 {
    				psels = < 0x5 >;
    		uart3_sleep: uart3_sleep {
    			phandle = < 0xc >;
    			group1 {
    				psels = < 0x5 >;
    				low-power-enable;
    		i2c1_default: i2c1_default {
    			phandle = < 0x4 >;
    			group1 {
    				psels = < 0xc0022 >, < 0xb0023 >;
    		i2c1_sleep: i2c1_sleep {
    			phandle = < 0x5 >;
    			group1 {
    				low-power-enable;
    		pwm0_default: pwm0_default {
    			phandle = < 0xd >;
    			group1 {
    				psels = < 0x160004 >, < 0x170006 >, < 0x180007 >;
    		pwm0_sleep: pwm0_sleep {
    			phandle = < 0xe >;
    			group1 {
    				low-power-enable;
    		pwm1_default: pwm1_default {
    			phandle = < 0xf >;
    			group1 {
    				psels = < 0x160002 >, < 0x170003 >, < 0x18000c >;
    		pwm1_sleep: pwm1_sleep {
    			phandle = < 0x10 >;
    			group1 {
    				low-power-enable;
    		pwm2_default: pwm2_default {
    			phandle = < 0x11 >;
    			group1 {
    				psels = < 0x16001c >;
    		pwm2_sleep: pwm2_sleep {
    			phandle = < 0x12 >;
    			group1 {
    				low-power-enable;
    		spi4_default: spi4_default {
    			phandle = < 0x6 >;
    			group1 {
    				psels = < 0x4000a >, < 0x5000b >;
    			group2 {
    				psels = < 0x60013 >;
    		spi4_sleep: spi4_sleep {
    			phandle = < 0x7 >;
    			group1 {
    				psels = < 0x4000a >, < 0x60013 >, < 0x5000b >;
    				low-power-enable;
    		qspi_default: qspi_default {
    			phandle = < 0x15 >;
    			group1 {
    				psels = < 0x1d0011 >, < 0x1f000d >, < 0x20000e >, < 0x21000f >, < 0x220010 >, < 0x1e0012 >;
    		qspi_sleep: qspi_sleep {
    			phandle = < 0x16 >;
    			group1 {
    				psels = < 0x1d0011 >, < 0x1f000d >, < 0x20000e >, < 0x21000f >, < 0x220010 >;
    				low-power-enable;
    			group2 {
    				psels = < 0x1e0012 >;
    				low-power-enable;
    				bias-pull-up;
    	rng_hci: entropy_bt_hci {
    		compatible = "zephyr,bt-hci-entropy";
    		status = "okay";
    	sw_pwm: sw-pwm {
    		compatible = "nordic,nrf-sw-pwm";
    		generator = < &timer1 >;
    		clock-prescaler = < 0x0 >;
    	cpus {
    		cpu0: cpu@0 {
    			device_type = "cpu";
    			compatible = "arm,cortex-m33f";
    			reg = < 0x0 >;
    			itm: itm@e0000000 {
    				compatible = "arm,armv8m-itm";
    				reg = < 0xe0000000 0x1000 >;
    				swo-ref-frequency = < 0x3d09000 >;
    			mpu: mpu@e000ed90 {
    				compatible = "arm,armv8m-mpu";
    				reg = < 0xe000ed90 0x40 >;
    				arm,num-mpu-regions = < 0x8 >;
    	ipc {
    		ipc0: ipc0 {
    			compatible = "zephyr,ipc-openamp-static-vrings";
    			memory-region = < &sram0_shared >;
    			mboxes = < &mbox 0x0 >, < &mbox 0x1 >;
    			mbox-names = "tx", "rx";
    			role = "host";
    			status = "okay";
    	nrf_radio_fem: nrf21540_fem {
    		compatible = "nordic,nrf21540-fem";
    		tx-en-gpios = < &gpio1 0xe 0x0 >;
    		rx-en-gpios = < &gpio0 0x9 0x0 >;
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led_rgb1: pwm_led_rgb1 {
    			pwms = < &pwm0 0x0 0x1312d00 0x0 >;
    		pwm_led_rgb2: pwm_led_rgb2 {
    			pwms = < &pwm1 0x0 0x1312d00 0x0 >;
    		pwm_led_bottom_white: pwm_led_bottom_white {
    			pwms = < &pwm2 0x0 0x1312d00 0x0 >;
    	reserved-memory {
    		ranges;
    		sram0_image: image@20000000 {
    			reg = < 0x20000000 0x70000 >;
    		sram0_s: image_s@20000000 {
    			reg = < 0x20000000 0x40000 >;
    		sram0_ns: image_ns@20040000 {
    			reg = < 0x20040000 0x30000 >;
    		sram0_shared: memory@20070000 {
    			reg = < 0x20070000 0x10000 >;
    			phandle = < 0x19 >;
    	buttons {
    		compatible = "gpio-keys";
    		iqs_ready: iqs_ready {
    			gpios = < &gpio1 0x5 0x11 >;
    			label = "IQS Ready";
    		iqs_mclr: iqs_mclr {
    			gpios = < &gpio1 0x6 0x11 >;
    			label = "IQS Mem Clear";
    	nrf5340_audio_dk {
    		iso_switch: iso_switch {
    			gpios = < &gpio0 0x19 0x0 >;
    			label = "ISO switch";
    		pull_ctrl: pull_ctrl {
    			gpios = < &gpio1 0x9 0x0 >;
    			label = "Pull CTRL";
    		vchgr_en: vchgr_en {
    			gpios = < &gpio0 0x17 0x0 >;
    			label = "VCharge Enable";
    		vchgr_hi_en: vchgr_hi_en {
    			gpios = < &gpio0 0x1e 0x0 >;
    			label = "VCharge HI Enable";
    		case_rx: case_rx {
    			gpios = < &gpio0 0x18 0x0 >;
    			label = "Case RX";
    		case_tx: case_tx {
    			gpios = < &gpio0 0x1b 0x0 >;
    			label = "Case TX";
    		disp_res_out: disp_res_out {
    			gpios = < &gpio0 0x1f 0x0 >;
    			label = "Display Reset";
    		enable_3v3_out: enable_3v3_out {
    			gpios = < &gpio1 0x4 0x0 >;
    			label = "Enable 3.3 Volt line";
    		esp_enable: esp_enable {
    			gpios = < &gpio0 0x15 0x0 >;
    			label = "ESP Enable";
    		rgb_white: rgb_white {
    			gpios = < &gpio0 0x8 0x1 >;
    			label = "RGB White Switch";
    		rfx_rx_en: rfx_rx_en {
    			label = "RFX RF Enable";
    		rfx_pdn: rfx_pdn {
    			gpios = < &gpio1 0xa 0x0 >;
    			label = "RFX Power Down";
    build/mcuboot/zephyr/.config
    # MCUboot-specific configuration options
    # CONFIG_BOOT_USE_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_MCUBOOT_SCRATCH=0x1e000
    CONFIG_PM_PARTITION_SIZE_MCUBOOT_PAD=0x200
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
    CONFIG_MCUBOOT_NRF_CLEANUP_PERIPHERAL=y
    # CONFIG_MCUBOOT_NRF_CLEANUP_NONSECURE_RAM is not set
    CONFIG_BOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem"
    CONFIG_BOOT_ERASE_PROGRESSIVELY=y
    CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
    CONFIG_BOOT_IMAGE_ACCESS_HOOK_NRF5340=y
    CONFIG_NRF53_MULTI_IMAGE_UPDATE=y
    CONFIG_NRF53_MCUBOOT_PRIMARY_1_RAM_FLASH=y
    CONFIG_NRF53_RAM_FLASH_SIZE=0x40000
    CONFIG_MCUBOOT_CLEANUP_UNUSABLE_SECONDARY=y
    CONFIG_MCUBOOT=y
    CONFIG_BOOT_USE_MBEDTLS=y
    CONFIG_NRFXLIB_CRYPTO=y
    # CONFIG_NRF_CC310_BL is not set
    # MCUBoot settings
    # CONFIG_SINGLE_APPLICATION_SLOT is not set
    # CONFIG_BOOT_SIGNATURE_TYPE_NONE is not set
    CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
    CONFIG_BOOT_SIGNATURE_TYPE_RSA_LEN=2048
    # CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256 is not set
    # CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
    CONFIG_MCUBOOT_CLEANUP_ARM_CORE=y
    CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
    # CONFIG_BOOT_HW_KEY is not set
    CONFIG_BOOT_VALIDATE_SLOT0=y
    CONFIG_BOOT_PREFER_SWAP_MOVE=y
    # CONFIG_BOOT_SWAP_USING_SCRATCH is not set
    CONFIG_BOOT_UPGRADE_ONLY=y
    # CONFIG_BOOT_SWAP_USING_MOVE is not set
    # CONFIG_BOOT_DIRECT_XIP is not set
    # CONFIG_BOOT_RAM_LOAD is not set
    # CONFIG_BOOT_BOOTSTRAP is not set
    # CONFIG_BOOT_SWAP_SAVE_ENCTLV is not set
    CONFIG_BOOT_ENCRYPTION_SUPPORT=y
    # CONFIG_BOOT_ENCRYPT_IMAGE is not set
    CONFIG_BOOT_MAX_IMG_SECTORS=2048
    CONFIG_BOOT_SHARE_BACKEND_DISABLED=y
    # CONFIG_BOOT_SHARE_BACKEND_EXTERNAL is not set
    CONFIG_BOOT_FIH_PROFILE_OFF=y
    # CONFIG_BOOT_FIH_PROFILE_LOW is not set
    # CONFIG_BOOT_FIH_PROFILE_MEDIUM is not set
    # CONFIG_BOOT_FIH_PROFILE_HIGH is not set
    CONFIG_BOOT_USB_DFU_NO=y
    # CONFIG_BOOT_USB_DFU_WAIT is not set
    # CONFIG_BOOT_USB_DFU_GPIO is not set
    # CONFIG_BOOT_USE_BENCH is not set
    # CONFIG_MCUBOOT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_LOG_LEVEL_WRN is not set
    CONFIG_MCUBOOT_LOG_LEVEL_INF=y
    # CONFIG_MCUBOOT_LOG_LEVEL_DBG is not set
    # CONFIG_MCUBOOT_LOG_LEVEL_DEFAULT is not set
    CONFIG_MCUBOOT_LOG_LEVEL=3
    CONFIG_MCUBOOT_LOG_THREAD_STACK_SIZE=768
    # CONFIG_MCUBOOT_INDICATION_LED is not set
    # CONFIG_MCUBOOT_SERIAL is not set
    # CONFIG_BOOT_INTR_VEC_RELOC is not set
    CONFIG_UPDATEABLE_IMAGE_NUMBER=2
    # CONFIG_BOOT_VERSION_CMP_USE_BUILD_NUMBER is not set
    CONFIG_BOOT_WATCHDOG_FEED=y
    # CONFIG_MCUBOOT_ACTION_HOOKS is not set
    # end of MCUBoot settings
    CONFIG_MCUBOOT_DEVICE_SETTINGS=y
    # Zephyr configuration options
    CONFIG_MULTITHREADING=y
    CONFIG_USB_DEVICE_PRODUCT="MCUBOOT"
    CONFIG_MCUBOOT_VERIFY_IMG_ADDRESS=y
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    # CONFIG_SPI is not set
    CONFIG_BOARD="nrf5340_audio_dk_nrf5340_cpuapp"
    CONFIG_FLASH_LOAD_SIZE=0x40000
    CONFIG_SRAM_SIZE=448
    CONFIG_FLASH_LOAD_OFFSET=0x10000
    CONFIG_NUM_IRQS=69
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_SOC="nRF5340_CPUAPP_QKAA"
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_CLOCK_CONTROL=y
    CONFIG_PINCTRL=y
    # CONFIG_WATCHDOG is not set
    CONFIG_ROM_START_OFFSET=0
    # CONFIG_RESET is not set
    CONFIG_GPIO=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_FPU is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_MEMC is not set
    CONFIG_MBEDTLS=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_TINYCRYPT is not set
    CONFIG_SERIAL=y
    CONFIG_MAIN_STACK_SIZE=20480
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_USE_DT_CODE_PARTITION=y
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_IDLE_STACK_SIZE=320
    # CONFIG_PM_DEVICE is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_MP_MAX_NUM_CPUS=1
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_I2S_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF21540_FEM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF21540_FEM_SPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_USB_AUDIO_HS_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_SIM_FLASH_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/nrf)
    # CONFIG_MBOX is not set
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # CONFIG_INIT_STACKS is not set
    # CONFIG_MBEDTLS_ENABLE_HEAP is not set
    # Nordic nRF Connect
    CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    # CONFIG_NRF700X_RADIO_TEST_COMBO is not set
    # Image build variants
    CONFIG_NCS_MCUBOOT_IN_BUILD=y
    # end of Image build variants
    CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16
    # Subsystems
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    CONFIG_IS_BOOTLOADER_IMG=y
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    # BLE over nRF RPC
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    CONFIG_PCD_APP=y
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # CONFIG_PCD_USE_CONSTANTS is not set
    # CONFIG_PCD_LOG_LEVEL_OFF is not set
    # CONFIG_PCD_LOG_LEVEL_ERR is not set
    # CONFIG_PCD_LOG_LEVEL_WRN is not set
    # CONFIG_PCD_LOG_LEVEL_INF is not set
    # CONFIG_PCD_LOG_LEVEL_DBG is not set
    CONFIG_PCD_LOG_LEVEL_DEFAULT=y
    CONFIG_PCD_LOG_LEVEL=1
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
    CONFIG_FOTA_DL_TIMEOUT_MIN=15
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_FOTA_POLL is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=1
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=1
    # CONFIG_NRF_CLOUD_COAP is not set
    # Send shadow info sections on initial connect (MQTT/CoAP)
    # end of Send shadow info sections on initial connect (MQTT/CoAP)
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=1
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_ANY_SUPPORT=y
    CONFIG_MPSL_FEM_NRF21540_GPIO_SUPPORT=y
    CONFIG_MPSL_FEM_NCS_SUPPORTED_FEM_USED=y
    CONFIG_MPSL_FEM_PIN_FORWARDER=y
    CONFIG_MPSL_FEM_NRF21540_GPIO=y
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=1
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=26
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=1
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
    CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@50000000/qspi@2b000/w25q6435f@0"
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=67108864
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=1
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # CONFIG_MBEDTLS_MEMORY_DEBUG is not set
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CBC_MAC is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_SM3 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD2 is not set
    # CONFIG_PSA_WANT_ALG_MD4 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_FFDH is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # end of nRF Security
    # CONFIG_NET_CORE_MONITOR is not set
    # Audio Module
    # CONFIG_AUDIO_MODULE_TEST is not set
    CONFIG_AUDIO_MODULE_NAME_SIZE=20
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_MODULE_LOG_LEVEL=1
    # end of Audio Module
    # CONFIG_TRUSTED_STORAGE is not set
    # end of Subsystems
    # CONFIG_WPA_SUPP is not set
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=1
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # Binary libraries
    # CONFIG_BT_LL_ACS_NRF53 is not set
    # Log levels
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_INF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_DBG is not set
    CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_HCI_VSC_LOG_LEVEL=1
    # end of Log levels
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    CONFIG_FPROTECT=y
    # CONFIG_FPROTECT_APP is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_MODEM_INFO is not set
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y
    CONFIG_FATAL_ERROR_LOG_LEVEL=1
    # CONFIG_SMS is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/nrf)
    # mcuboot (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/bootloader/mcuboot)
    # MCUboot
    CONFIG_SIGN_IMAGES=y
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/bootloader/mcuboot)
    # mbedtls (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_MBEDTLS_BUILTIN=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=1500
    # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    CONFIG_MBEDTLS_LOG_LEVEL=1
    # CONFIG_MBEDTLS_DEBUG is not set
    # CONFIG_MBEDTLS_TEST is not set
    CONFIG_MBEDTLS_INIT=y
    # CONFIG_MBEDTLS_ZEPHYR_ENTROPY is not set
    CONFIG_APP_LINK_WITH_MBEDTLS=y
    # PSA RNG support
    # end of PSA RNG support
    # PSA key type support
    # end of PSA key type support
    # PSA AEAD support
    # end of PSA AEAD support
    # PSA MAC support
    # end of PSA MAC support
    # PSA Hash support
    # end of PSA Hash support
    # PSA Cipher support
    # end of PSA Cipher support
    # PSA Key agreement support
    # end of PSA Key agreement support
    # PSA Key derivation support
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # Elliptic Curve type support
    # end of Elliptic Curve type support
    # end of PSA Asymmetric support
    # end of mbedtls (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/crypto/mbedtls)
    # trusted-firmware-m (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_BOARD="/Users/amirlazarovich/workspace/sond/firmware/thirdparty/zephyr/modules/trusted-firmware-m/nordic_nrf/nrf5340_cpuapp"
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cjson)
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cjson)
    # azure-sdk-for-c (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/azure-sdk-for-c)
    # cirrus-logic (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/cirrus-logic)
    # openthread (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/openthread)
    # memfault-firmware-sdk (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/memfault-firmware-sdk)
    # canopennode (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/canopennode)
    # chre (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/chre)
    # lz4 (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/lz4)
    # nanopb (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/zscilib)
    # cmsis (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/cmsis)
    # cmsis-dsp (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cmsis-dsp)
    # cmsis-nn (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/cmsis-nn)
    # fatfs (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/fs/fatfs)
    # hal_nordic (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_QSPI_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # CONFIG_NRFX_WDT_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE0=y
    # CONFIG_NRFX_GPIOTE1 is not set
    # CONFIG_NRFX_I2S0 is not set
    # CONFIG_NRFX_IPC is not set
    # CONFIG_NRFX_NFCT is not set
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QDEC1 is not set
    CONFIG_NRFX_QSPI=y
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    CONFIG_NRFX_SPIM=y
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    CONFIG_NRFX_SPIM4=y
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TWIM0 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBREG is not set
    CONFIG_NRFX_WDT=y
    CONFIG_NRFX_WDT0=y
    CONFIG_NRFX_WDT1=y
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of hal_nordic (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/hal/nordic)
    CONFIG_ZEPHYR_ST_MODULE=y
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # liblc3 (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/liblc3)
    # littlefs (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/fs/littlefs)
    # loramac-node (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/loramac-node)
    # lvgl (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # picolibc (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/picolibc)
    # segger (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/uoscore-uedhoc)
    # zcbor (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/zcbor)
    # nrfxlib (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    # end of nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # CONFIG_CC3XX_HW_MUTEX_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_LC3_PLC_DISABLED is not set
    CONFIG_LC3_ENC_CHAN_MAX=1
    CONFIG_LC3_DEC_CHAN_MAX=1
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/nrfxlib)
    # connectedhomeip (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (/Users/amirlazarovich/workspace/sond/firmware/thirdparty/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=8192
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL=1
    CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=6
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD_REVISION=""
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF5340_AUDIO_DK_NRF5340_CPUAPP=y
    # CONFIG_BOARD_NRF5340_AUDIO_DK_NRF5340_CPUAPP_NS is not set
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC_APP=y
    CONFIG_BOARD_ENABLE_DCDC_NET=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    # CONFIG_BOARD_ENABLE_CPUNET is not set
    # end of Board Options
    # CONFIG_SOC_SERIES_APOLLO4X is not set
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32A50X is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_GD32L23X is not set
    # CONFIG_SOC_SERIES_PSOC_60 is not set
    # CONFIG_SOC_SERIES_PSOC_61 is not set
    # CONFIG_SOC_SERIES_PSOC_62 is not set
    # CONFIG_SOC_SERIES_PSOC_63 is not set
    # CONFIG_SOC_SERIES_PSOC_64 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    CONFIG_SOC_SERIES_NRF53X=y
    # CONFIG_SOC_SERIES_NRF54HX is not set
    # CONFIG_SOC_SERIES_NRF54LX is not set
    # CONFIG_SOC_SERIES_NRF91X is not set
    CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT=0x4000
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT=0x2000
    # CONFIG_SOC_SERIES_NPCX4 is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M46X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32K3XX is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RA4M1 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_RENESAS_RZT2M is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32GG12B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32BG22 is not set
    # CONFIG_SOC_SERIES_EFR32BG27 is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_EFR32MG24 is not set
    # CONFIG_SOC_SERIES_STM32C0X is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H5X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WBAX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_SERIES_AM62X_M4 is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_GPIO_INIT_PRIORITY=40
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_I2S0=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_NFCT=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_OSCILLATORS=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_PWM1=y
    CONFIG_HAS_HW_NRF_PWM2=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_REGULATORS=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TIMER0=y
    CONFIG_HAS_HW_NRF_TIMER1=y
    CONFIG_HAS_HW_NRF_TIMER2=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_UARTE3=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_SOC_NRF5340_CPUNET_QKAA is not set
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
    CONFIG_SOC_NRF53_RTC_PRETICK=y
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
    CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
    # CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
    CONFIG_SOC_DCDC_NRF53X_APP=y
    CONFIG_SOC_DCDC_NRF53X_NET=y
    CONFIG_SOC_DCDC_NRF53X_HV=y
    CONFIG_SOC_ENABLE_LFXO=y
    # CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_LFXO_CAP_INT_6PF is not set
    CONFIG_SOC_LFXO_CAP_INT_7PF=y
    # CONFIG_SOC_LFXO_CAP_INT_9PF is not set
    CONFIG_SOC_HFXO_CAP_DEFAULT=y
    # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF_ENABLE_CACHE=y
    # CONFIG_NRF53_SYNC_RTC is not set
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=1
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF53X=y
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
    CONFIG_ARM_ON_EXIT_CPU_IDLE=y
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=1
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=1
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=1
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # CONFIG_POLL is not set
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    # CONFIG_KERNEL_MEM_POOL is not set
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_CACHE is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=1
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CLOCK_CONTROL_NPCX_SUPP_APB4=y
    # CONFIG_CLOCK_CONTROL_NPCX_SUPP_FIU1 is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=1
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_COUNTER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    # CONFIG_ENTROPY_GENERATOR is not set
    # CONFIG_ESPI is not set
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_JESD216=y
    CONFIG_FLASH=y
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    CONFIG_FLASH_LOG_LEVEL_DBG=y
    # CONFIG_FLASH_LOG_LEVEL_DEFAULT is not set
    CONFIG_FLASH_LOG_LEVEL=4
    # CONFIG_FLASH_JESD216_API is not set
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_SOC_FLASH_NRF=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
    CONFIG_FLASH_SIMULATOR=y
    CONFIG_FLASH_SIMULATOR_UNALIGNED_READ=y
    CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
    # CONFIG_FLASH_SIMULATOR_SIMULATE_TIMING is not set
    # CONFIG_FLASH_SIMULATOR_STATS is not set
    CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=41
    # CONFIG_NORDIC_QSPI_NOR_XIP is not set
    CONFIG_NORDIC_QSPI_NOR_TIMEOUT_MS=500
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=1
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HWINFO is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=1
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
    CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
    CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MDIO is not set
    # CONFIG_MFD is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=1
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    CONFIG_REGULATOR=y
    CONFIG_REGULATOR_THREAD_SAFE_REFCNT=y
    # CONFIG_REGULATOR_LOG_LEVEL_OFF is not set
    # CONFIG_REGULATOR_LOG_LEVEL_ERR is not set
    # CONFIG_REGULATOR_LOG_LEVEL_WRN is not set
    # CONFIG_REGULATOR_LOG_LEVEL_INF is not set
    # CONFIG_REGULATOR_LOG_LEVEL_DBG is not set
    CONFIG_REGULATOR_LOG_LEVEL_DEFAULT=y
    CONFIG_REGULATOR_LOG_LEVEL=1
    # CONFIG_REGULATOR_NXP_VREF is not set
    CONFIG_REGULATOR_NXP_VREF_INIT_PRIORITY=45
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=1
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_3_ENHANCED_POLL_OUT=y
    # CONFIG_UART_3_NRF_PARITY_BIT is not set
    CONFIG_UART_3_NRF_TX_BUFFER_SIZE=32
    # CONFIG_SMBUS is not set
    # CONFIG_SYSCON is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_NRF_GRTC_TIMER is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=1
    # CONFIG_NRF_USBD_COMMON is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=1
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    CONFIG_MINIMAL_LIBC=y
    # CONFIG_PICOLIBC is not set
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_MALLOC is not set
    CONFIG_COMMON_LIBC_STRNLEN=y
    CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y
    # CONFIG_MINIMAL_LIBC_MALLOC is not set
    # CONFIG_MINIMAL_LIBC_CALLOC is not set
    # CONFIG_MINIMAL_LIBC_REALLOCARRAY is not set
    # CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
    CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y
    # CONFIG_MINIMAL_LIBC_RAND is not set
    CONFIG_MINIMAL_LIBC_TIME=y
    # CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    # CONFIG_CRC is not set
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # OS Support Library
    # CONFIG_FDTABLE is not set
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    # CONFIG_MPSC_PBUF is not set
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    CONFIG_REBOOT=y
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    # CONFIG_UTF8 is not set
    # CONFIG_CBPRINTF_COMPLETE is not set
    CONFIG_CBPRINTF_NANO=y
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_LIBC_SUBSTS=y
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=1
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_POSIX_API is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL=1
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_COND_LOG_LEVEL=1
    # CONFIG_EVENTFD is not set
    # CONFIG_FNMATCH is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_KEY_LOG_LEVEL=1
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL=1
    # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_LOG_LEVEL=1
    CONFIG_SEM_VALUE_MAX=32767
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=1
    # CONFIG_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_TIMER_LOG_LEVEL=1
    # CONFIG_TIMER is not set
    CONFIG_MAX_TIMER_COUNT=5
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_ACPI_HID_LEN_MAX=12
    CONFIG_LIBGCC_RTLIB=y
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    # CONFIG_BT is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    CONFIG_ASSERT_NO_COND_INFO=y
    CONFIG_ASSERT_NO_MSG_INFO=y
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_FCB is not set
    # CONFIG_NVS is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    # CONFIG_LOG_MODE_DEFERRED is not set
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    CONFIG_LOG_MODE_MINIMAL=y
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    CONFIG_LOG_DEFAULT_MINIMAL=y
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    CONFIG_LOG_DEFAULT_LEVEL=1
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    # end of Processing
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    # end of Misc
    # CONFIG_LOG_OUTPUT is not set
    # end of Logging
    CONFIG_MEM_ATTR=y
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NET_BUF is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    CONFIG_COMPILER_FREESTANDING=y
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    CONFIG_FORTIFY_SOURCE_NONE=y
    # CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    CONFIG_NO_RUNTIME_CHECKS=y
    # CONFIG_RUNTIME_ERROR_CHECKS is not set
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    CONFIG_BUILD_OUTPUT_META=y
    # CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    build/mcuboot/zephyr/zephyr.dts
    /dts-v1/;
    	#address-cells = < 0x1 >;
    	#size-cells = < 0x1 >;
    	model = "Nordic nRF5340 Audio DK NRF5340 Application";
    	compatible = "nordic,nrf5340-audio-dk-nrf5340-cpuapp";
    	chosen {
    		zephyr,entropy = &cryptocell;
    		zephyr,flash-controller = &flash_controller;
    		zephyr,console = &uart3;
    		zephyr,shell-uart = &uart3;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart3;
    		zephyr,bt-c2h-uart = &uart3;
    		zephyr,bt-hci-ipc = &ipc0;
    		watchdog0 = &wdt0;
    		zephyr,ipc_shm = &sram0_shared;
    		zephyr,sram = &sram0_image;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,sram-secure-partition = &sram0_s;
    		zephyr,sram-non-secure-partition = &sram0_ns;
    		nordic,pm-ext-flash = &w25q64;
    	aliases {
    		rgb1 = &pwm_led_rgb1;
    		rgb2 = &pwm_led_rgb2;
    		botwhite = &pwm_led_bottom_white;
    		coredump-partition = &coredump_partition;
    		iqs = &iqs_ready;
    		watchdog0 = &wdt0;
    	soc {
    		compatible = "nordic,nrf5340-cpuapp-qkaa", "nordic,nrf5340-cpuapp", "nordic,nrf53", "simple-bus";
    		interrupt-parent = < &nvic >;
    		ranges;
    		nvic: interrupt-controller@e000e100 {
    			compatible = "arm,v8m-nvic";
    			reg = < 0xe000e100 0xc00 >;
    			interrupt-controller;
    			#interrupt-cells = < 0x2 >;
    			arm,num-irq-priority-bits = < 0x3 >;
    			phandle = < 0x1 >;
    		systick: timer@e000e010 {
    			compatible = "arm,armv8m-systick";
    			reg = < 0xe000e010 0x10 >;
    			status = "disabled";
    		ficr: ficr@ff0000 {
    			compatible = "nordic,nrf-ficr";
    			reg = < 0xff0000 0x1000 >;
    			#nordic,ficr-cells = < 0x1 >;
    			status = "okay";
    		uicr: uicr@ff8000 {
    			compatible = "nordic,nrf-uicr";
    			reg = < 0xff8000 0x1000 >;
    			status = "okay";
    			nfct-pins-as-gpios;
    		sram0: memory@20000000 {
    			compatible = "mmio-sram";
    			reg = < 0x20000000 0x80000 >;
    		peripheral@50000000 {
    			ranges = < 0x0 0x50000000 0x10000000 >;
    			dcnf: dcnf@0 {
    				compatible = "nordic,nrf-dcnf";
    				reg = < 0x0 0x1000 >;
    				status = "okay";
    			oscillators: oscillator@4000 {
    				compatible = "nordic,nrf-oscillators";
    				reg = < 0x4000 0x1000 >;
    				status = "okay";
    			regulators: regulator@4000 {
    				compatible = "nordic,nrf-regulators";
    				status = "okay";
    			clock: clock@5000 {
    				compatible = "nordic,nrf-clock";
    				reg = < 0x5000 0x1000 >;
    				interrupts = < 0x5 0x1 >;
    				status = "okay";
    			power: power@5000 {
    				compatible = "nordic,nrf-power";
    				status = "okay";
    				gpregret1: gpregret1@551c {
    					compatible = "nordic,nrf-gpregret";
    					reg = < 0x551c 0x1 >;
    					status = "okay";
    				gpregret2: gpregret2@5520 {
    					reg = < 0x5520 0x1 >;
    					status = "okay";
    			reset: reset-controller@5000 {
    				compatible = "nordic,nrf-reset";
    				status = "okay";
    			ctrlap: ctrlap@6000 {
    				compatible = "nordic,nrf-ctrlapperi";
    				reg = < 0x6000 0x1000 >;
    				status = "okay";
    			i2c0: i2c@8000 {
    				#size-cells = < 0x0 >;
    				reg = < 0x8000 0x1000 >;
    				clock-frequency = < 0x186a0 >;
    				interrupts = < 0x8 0x1 >;
    				easydma-maxcnt-bits = < 0x10 >;
    			spi0: spi@8000 {
    				max-frequency = < 0x7a1200 >;
    			uart0: uart@8000 {
    				status = "okay";
    				label = "UART_0";
    				current-speed = < 0x1c200 >;
    				pinctrl-0 = < &uart0_default >;
    				pinctrl-1 = < &uart0_sleep >;
    			i2c1: i2c@9000 {
    				reg = < 0x9000 0x1000 >;
    				interrupts = < 0x9 0x1 >;
    				status = "okay";
    				zephyr,concat-buf-size = < 0x100 >;
    				pinctrl-0 = < &i2c1_default >;
    				pinctrl-1 = < &i2c1_sleep >;
    			spi1: spi@9000 {
    			uart1: uart@9000 {
    			spi4: fem_spi: spi@a000 {
    				reg = < 0xa000 0x1000 >;
    				interrupts = < 0xa 0x1 >;
    				max-frequency = < 0x1e84800 >;
    				rx-delay-supported;
    				rx-delay = < 0x2 >;
    				status = "okay";
    				pinctrl-0 = < &spi4_default >;
    				pinctrl-1 = < &spi4_sleep >;
    				cs-gpios = < &gpio0 0x16 0x1 >;
    				nrf_radio_fem_spi: nrf21540_fem_spi@0 {
    					compatible = "nordic,nrf21540-fem-spi";
    					status = "okay";
    					reg = < 0x0 >;
    					spi-max-frequency = < 0x7a1200 >;
    			i2c2: i2c@b000 {
    				reg = < 0xb000 0x1000 >;
    				interrupts = < 0xb 0x1 >;
    			spi2: spi@b000 {
    			uart2: uart@b000 {
    				pinctrl-0 = < &uart2_default >;
    				pinctrl-1 = < &uart2_sleep >;
    			i2c3: i2c@c000 {
    				reg = < 0xc000 0x1000 >;
    				interrupts = < 0xc 0x1 >;
    			spi3: spi@c000 {
    			uart3: uart@c000 {
    				status = "okay";
    				pinctrl-0 = < &uart3_default >;
    				pinctrl-1 = < &uart3_sleep >;
    			adc: adc@e000 {
    				compatible = "nordic,nrf-saadc";
    				reg = < 0xe000 0x1000 >;
    				interrupts = < 0xe 0x1 >;
    				#io-channel-cells = < 0x1 >;
    			timer0: timer@f000 {
    				compatible = "nordic,nrf-timer";
    				status = "okay";
    				reg = < 0xf000 0x1000 >;
    				cc-num = < 0x6 >;
    				max-bit-width = < 0x20 >;
    				interrupts = < 0xf 0x1 >;
    				prescaler = < 0x0 >;
    			timer1: timer@10000 {
    				status = "okay";
    				reg = < 0x10000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x10 0x1 >;
    				phandle = < 0x18 >;
    			timer2: timer@11000 {
    				status = "okay";
    				reg = < 0x11000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x11 0x1 >;
    			rtc0: rtc@14000 {
    				compatible = "nordic,nrf-rtc";
    				reg = < 0x14000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x14 0x1 >;
    				clock-frequency = < 0x8000 >;
    				prescaler = < 0x1 >;
    			rtc1: rtc@15000 {
    				reg = < 0x15000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x15 0x1 >;
    			dppic: dppic@17000 {
    				compatible = "nordic,nrf-dppic";
    				reg = < 0x17000 0x1000 >;
    				status = "okay";
    			wdt: wdt0: watchdog@18000 {
    				compatible = "nordic,nrf-wdt";
    				reg = < 0x18000 0x1000 >;
    				interrupts = < 0x18 0x1 >;
    				status = "okay";
    			wdt1: watchdog@19000 {
    				reg = < 0x19000 0x1000 >;
    				interrupts = < 0x19 0x1 >;
    			comp: comparator@1a000 {
    				compatible = "nordic,nrf-comp";
    				reg = < 0x1a000 0x1000 >;
    				interrupts = < 0x1a 0x1 >;
    			egu0: egu@1b000 {
    				compatible = "nordic,nrf-egu";
    				reg = < 0x1b000 0x1000 >;
    				interrupts = < 0x1b 0x1 >;
    				status = "okay";
    			egu1: egu@1c000 {
    				reg = < 0x1c000 0x1000 >;
    				interrupts = < 0x1c 0x1 >;
    				status = "okay";
    			egu2: egu@1d000 {
    				reg = < 0x1d000 0x1000 >;
    				interrupts = < 0x1d 0x1 >;
    				status = "okay";
    			egu3: egu@1e000 {
    				reg = < 0x1e000 0x1000 >;
    				interrupts = < 0x1e 0x1 >;
    				status = "okay";
    			egu4: egu@1f000 {
    				reg = < 0x1f000 0x1000 >;
    				interrupts = < 0x1f 0x1 >;
    				status = "okay";
    			egu5: egu@20000 {
    				reg = < 0x20000 0x1000 >;
    				interrupts = < 0x20 0x1 >;
    				status = "okay";
    			pwm0: pwm@21000 {
    				compatible = "nordic,nrf-pwm";
    				reg = < 0x21000 0x1000 >;
    				interrupts = < 0x21 0x1 >;
    				status = "okay";
    				#pwm-cells = < 0x3 >;
    				pinctrl-0 = < &pwm0_default >;
    				pinctrl-1 = < &pwm0_sleep >;
    				phandle = < 0x1c >;
    			pwm1: pwm@22000 {
    				reg = < 0x22000 0x1000 >;
    				interrupts = < 0x22 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &pwm1_default >;
    				pinctrl-1 = < &pwm1_sleep >;
    				phandle = < 0x1d >;
    			pwm2: pwm@23000 {
    				reg = < 0x23000 0x1000 >;
    				interrupts = < 0x23 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &pwm2_default >;
    				pinctrl-1 = < &pwm2_sleep >;
    				phandle = < 0x1e >;
    			pwm3: pwm@24000 {
    				reg = < 0x24000 0x1000 >;
    				interrupts = < 0x24 0x1 >;
    			pdm0: pdm@26000 {
    				compatible = "nordic,nrf-pdm";
    				reg = < 0x26000 0x1000 >;
    				interrupts = < 0x26 0x1 >;
    			i2s0: i2s@28000 {
    				compatible = "nordic,nrf-i2s";
    				reg = < 0x28000 0x1000 >;
    				interrupts = < 0x28 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &i2s0_default >;
    				pinctrl-1 = < &i2s0_sleep >;
    			mbox: ipc: mbox@2a000 {
    				compatible = "nordic,mbox-nrf-ipc", "nordic,nrf-ipc";
    				reg = < 0x2a000 0x1000 >;
    				tx-mask = < 0xffff >;
    				rx-mask = < 0xffff >;
    				interrupts = < 0x2a 0x1 >;
    				#mbox-cells = < 0x1 >;
    				status = "okay";
    				phandle = < 0x1a >;
    			qspi: qspi@2b000 {
    				compatible = "nordic,nrf-qspi";
    				reg = < 0x2b000 0x1000 >, < 0x10000000 0x10000000 >;
    				reg-names = "qspi", "qspi_mm";
    				interrupts = < 0x2b 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &qspi_default >;
    				pinctrl-1 = < &qspi_sleep >;
    				w25q64: w25q6435f@0 {
    					compatible = "nordic,qspi-nor";
    					reg = < 0x0 >;
    					sck-frequency = < 0x7a1200 >;
    					jedec-id = [ EF 40 17 ];
    					sfdp-bfp = [ E5 20 F9 FF FF FF FF 03 44 EB 08 6B 08 3B 42 BB FE FF FF FF FF FF 00 00 FF FF 40 EB 0C 20 0F 52 10 D8 00 00 36 02 A6 00 82 EA 14 C4 E9 63 76 33 7A 75 7A 75 F7 A2 D5 5C 19 F7 4D FF E9 30 F8 80 ];
    					size = < 0x4000000 >;
    					has-dpd;
    					t-enter-dpd = < 0x2710 >;
    					t-exit-dpd = < 0x88b8 >;
    			nfct: nfct@2d000 {
    				compatible = "nordic,nrf-nfct";
    				reg = < 0x2d000 0x1000 >;
    				interrupts = < 0x2d 0x1 >;
    				status = "okay";
    			mutex: mutex@30000 {
    				compatible = "nordic,nrf-mutex";
    				reg = < 0x30000 0x1000 >;
    				status = "okay";
    			qdec0: qdec@33000 {
    				compatible = "nordic,nrf-qdec";
    				reg = < 0x33000 0x1000 >;
    				interrupts = < 0x33 0x1 >;
    			qdec1: qdec@34000 {
    				reg = < 0x34000 0x1000 >;
    				interrupts = < 0x34 0x1 >;
    			usbd: zephyr_udc0: usbd@36000 {
    				compatible = "nordic,nrf-usbd";
    				reg = < 0x36000 0x1000 >;
    				interrupts = < 0x36 0x1 >;
    				num-bidir-endpoints = < 0x1 >;
    				num-in-endpoints = < 0x7 >;
    				num-out-endpoints = < 0x7 >;
    				num-isoin-endpoints = < 0x1 >;
    				num-isoout-endpoints = < 0x1 >;
    				status = "okay";
    				hs_0: hs_0 {
    					compatible = "usb-audio-hs";
    					mic-feature-mute;
    					mic-channel-l;
    					mic-channel-r;
    					hp-feature-mute;
    					hp-channel-l;
    					hp-channel-r;
    			usbreg: regulator@37000 {
    				compatible = "nordic,nrf-usbreg";
    				reg = < 0x37000 0x1000 >;
    				interrupts = < 0x37 0x1 >;
    				status = "okay";
    			flash_controller: flash-controller@39000 {
    				compatible = "nordic,nrf53-flash-controller";
    				reg = < 0x39000 0x1000 >;
    				partial-erase;
    				flash0: flash@0 {
    					compatible = "soc-nv-flash";
    					erase-block-size = < 0x1000 >;
    					write-block-size = < 0x4 >;
    					reg = < 0x0 0x100000 >;
    					partitions {
    						boot_partition: partition@0 {
    							label = "mcuboot";
    							reg = < 0x0 0x10000 >;
    						slot0_partition: partition@10000 {
    							label = "image-0";
    							reg = < 0x10000 0x40000 >;
    						slot0_ns_partition: partition@50000 {
    							label = "image-0-nonsecure";
    							reg = < 0x50000 0x30000 >;
    						slot1_partition: partition@80000 {
    							label = "image-1";
    							reg = < 0x80000 0x40000 >;
    						slot1_ns_partition: partition@c0000 {
    							label = "image-1-nonsecure";
    							reg = < 0xc0000 0x30000 >;
    						storage_partition: partition@f0000 {
    							label = "storage";
    							reg = < 0xf0000 0xf000 >;
    						coredump_partition: partition@ff000 {
    							label = "coredump_partition";
    							reg = < 0xff000 0x1000 >;
    			kmu: kmu@39000 {
    				compatible = "nordic,nrf-kmu";
    				interrupts = < 0x39 0x1 >;
    				status = "okay";
    			vmc: vmc@81000 {
    				compatible = "nordic,nrf-vmc";
    				reg = < 0x81000 0x1000 >;
    				status = "okay";
    			gpio0: gpio@842500 {
    				compatible = "nordic,nrf-gpio";
    				gpio-controller;
    				reg = < 0x842500 0x300 >;
    				#gpio-cells = < 0x2 >;
    				status = "okay";
    				port = < 0x0 >;
    				gpiote-instance = < &gpiote >;
    				phandle = < 0x8 >;
    			gpio1: gpio@842800 {
    				gpio-controller;
    				reg = < 0x842800 0x300 >;
    				ngpios = < 0x10 >;
    				status = "okay";
    				port = < 0x1 >;
    				phandle = < 0x1b >;
    			ieee802154: ieee802154 {
    				compatible = "nordic,nrf-ieee802154";
    		spu: spu@50003000 {
    			compatible = "nordic,nrf-spu";
    			reg = < 0x50003000 0x1000 >;
    			interrupts = < 0x3 0x1 >;
    			status = "okay";
    		gpiote: gpiote0: gpiote@5000d000 {
    			compatible = "nordic,nrf-gpiote";
    			reg = < 0x5000d000 0x1000 >;
    			interrupts = < 0xd 0x5 >;
    			status = "okay";
    			instance = < 0x0 >;
    			phandle = < 0x17 >;
    		gpiote1: gpiote@4002f000 {
    			reg = < 0x4002f000 0x1000 >;
    			interrupts = < 0x2f 0x5 >;
    			instance = < 0x1 >;
    		cryptocell: crypto@50844000 {
    			compatible = "nordic,cryptocell", "arm,cryptocell-312";
    			reg = < 0x50844000 0x1000 >, < 0x50845000 0x1000 >;
    			reg-names = "wrapper", "core";
    			interrupts = < 0x44 0x1 >;
    			status = "okay";
    		nordic_ram_flash_controller: nordic_ram-flash-controller@0 {
    			compatible = "zephyr,sim-flash";
    			reg = < 0x0 0xa000 >;
    			erase-value = < 0xff >;
    			flash_sim0: flash_sim@0 {
    				status = "okay";
    				reg = < 0x0 0x40000 >;
    				partitions {
    					slot2_partition: partition@0 {
    						label = "image-2";
    	pinctrl: pin-controller {
    		compatible = "nordic,nrf-pinctrl";
    		i2s0_default: i2s0_default {
    			phandle = < 0x13 >;
    			group1 {
    				psels = < 0x13002b >;
    				nordic,drive-mode = < 0x3 >;
    			group2 {
    				psels = < 0xd002d >, < 0xf002c >, < 0x12002e >, < 0x11002f >;
    		i2s0_sleep: i2s0_sleep {
    			phandle = < 0x14 >;
    			group1 {
    				psels = < 0x13002b >, < 0xd002d >, < 0xf002c >, < 0x12002e >, < 0x11002f >;
    				low-power-enable;
    		uart0_default: uart0_default {
    			phandle = < 0x2 >;
    			group1 {
    				psels = < 0x27 >;
    			group2 {
    				psels = < 0x10028 >;
    				bias-pull-up;
    		uart0_sleep: uart0_sleep {
    			phandle = < 0x3 >;
    			group1 {
    				psels = < 0x27 >, < 0x10028 >;
    				low-power-enable;
    		uart2_default: uart2_default {
    			phandle = < 0x9 >;
    			group1 {
    				psels = < 0x1b >;
    			group2 {
    				psels = < 0x10018 >;
    				bias-pull-up;
    		uart2_sleep: uart2_sleep {
    			phandle = < 0xa >;
    			group1 {
    				psels = < 0x1b >, < 0x10018 >;
    				low-power-enable;
    		uart3_default: uart3_default {
    			phandle = < 0xb >;
    			group1 {
    				psels = < 0x5 >;
    		uart3_sleep: uart3_sleep {
    			phandle = < 0xc >;
    			group1 {
    				psels = < 0x5 >;
    				low-power-enable;
    		i2c1_default: i2c1_default {
    			phandle = < 0x4 >;
    			group1 {
    				psels = < 0xc0022 >, < 0xb0023 >;
    		i2c1_sleep: i2c1_sleep {
    			phandle = < 0x5 >;
    			group1 {
    				low-power-enable;
    		pwm0_default: pwm0_default {
    			phandle = < 0xd >;
    			group1 {
    				psels = < 0x160004 >, < 0x170006 >, < 0x180007 >;
    		pwm0_sleep: pwm0_sleep {
    			phandle = < 0xe >;
    			group1 {
    				low-power-enable;
    		pwm1_default: pwm1_default {
    			phandle = < 0xf >;
    			group1 {
    				psels = < 0x160002 >, < 0x170003 >, < 0x18000c >;
    		pwm1_sleep: pwm1_sleep {
    			phandle = < 0x10 >;
    			group1 {
    				low-power-enable;
    		pwm2_default: pwm2_default {
    			phandle = < 0x11 >;
    			group1 {
    				psels = < 0x16001c >;
    		pwm2_sleep: pwm2_sleep {
    			phandle = < 0x12 >;
    			group1 {
    				low-power-enable;
    		spi4_default: spi4_default {
    			phandle = < 0x6 >;
    			group1 {
    				psels = < 0x4000a >, < 0x5000b >;
    			group2 {
    				psels = < 0x60013 >;
    		spi4_sleep: spi4_sleep {
    			phandle = < 0x7 >;
    			group1 {
    				psels = < 0x4000a >, < 0x60013 >, < 0x5000b >;
    				low-power-enable;
    		qspi_default: qspi_default {
    			phandle = < 0x15 >;
    			group1 {
    				psels = < 0x1d0011 >, < 0x1f000d >, < 0x20000e >, < 0x21000f >, < 0x220010 >, < 0x1e0012 >;
    		qspi_sleep: qspi_sleep {
    			phandle = < 0x16 >;
    			group1 {
    				psels = < 0x1d0011 >, < 0x1f000d >, < 0x20000e >, < 0x21000f >, < 0x220010 >;
    				low-power-enable;
    			group2 {
    				psels = < 0x1e0012 >;
    				low-power-enable;
    				bias-pull-up;
    	rng_hci: entropy_bt_hci {
    		compatible = "zephyr,bt-hci-entropy";
    		status = "okay";
    	sw_pwm: sw-pwm {
    		compatible = "nordic,nrf-sw-pwm";
    		generator = < &timer1 >;
    		clock-prescaler = < 0x0 >;
    	cpus {
    		cpu0: cpu@0 {
    			device_type = "cpu";
    			compatible = "arm,cortex-m33f";
    			reg = < 0x0 >;
    			itm: itm@e0000000 {
    				compatible = "arm,armv8m-itm";
    				reg = < 0xe0000000 0x1000 >;
    				swo-ref-frequency = < 0x3d09000 >;
    			mpu: mpu@e000ed90 {
    				compatible = "arm,armv8m-mpu";
    				reg = < 0xe000ed90 0x40 >;
    				arm,num-mpu-regions = < 0x8 >;
    	ipc {
    		ipc0: ipc0 {
    			compatible = "zephyr,ipc-openamp-static-vrings";
    			memory-region = < &sram0_shared >;
    			mboxes = < &mbox 0x0 >, < &mbox 0x1 >;
    			mbox-names = "tx", "rx";
    			role = "host";
    			status = "okay";
    	nrf_radio_fem: nrf21540_fem {
    		compatible = "nordic,nrf21540-fem";
    		tx-en-gpios = < &gpio1 0xe 0x0 >;
    		rx-en-gpios = < &gpio0 0x9 0x0 >;
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led_rgb1: pwm_led_rgb1 {
    			pwms = < &pwm0 0x0 0x1312d00 0x0 >;
    		pwm_led_rgb2: pwm_led_rgb2 {
    			pwms = < &pwm1 0x0 0x1312d00 0x0 >;
    		pwm_led_bottom_white: pwm_led_bottom_white {
    			pwms = < &pwm2 0x0 0x1312d00 0x0 >;
    	reserved-memory {
    		ranges;
    		sram0_image: image@20000000 {
    			reg = < 0x20000000 0x70000 >;
    		sram0_s: image_s@20000000 {
    			reg = < 0x20000000 0x40000 >;
    		sram0_ns: image_ns@20040000 {
    			reg = < 0x20040000 0x30000 >;
    		sram0_shared: memory@20070000 {
    			reg = < 0x20070000 0x10000 >;
    			phandle = < 0x19 >;
    	buttons {
    		compatible = "gpio-keys";
    		iqs_ready: iqs_ready {
    			gpios = < &gpio1 0x5 0x11 >;
    			label = "IQS Ready";
    		iqs_mclr: iqs_mclr {
    			gpios = < &gpio1 0x6 0x11 >;
    			label = "IQS Mem Clear";
    	nrf5340_audio_dk {
    		iso_switch: iso_switch {
    			gpios = < &gpio0 0x19 0x0 >;
    			label = "ISO switch";
    		pull_ctrl: pull_ctrl {
    			gpios = < &gpio1 0x9 0x0 >;
    			label = "Pull CTRL";
    		vchgr_en: vchgr_en {
    			gpios = < &gpio0 0x17 0x0 >;
    			label = "VCharge Enable";
    		vchgr_hi_en: vchgr_hi_en {
    			gpios = < &gpio0 0x1e 0x0 >;
    			label = "VCharge HI Enable";
    		case_rx: case_rx {
    			gpios = < &gpio0 0x18 0x0 >;
    			label = "Case RX";
    		case_tx: case_tx {
    			gpios = < &gpio0 0x1b 0x0 >;
    			label = "Case TX";
    		disp_res_out: disp_res_out {
    			gpios = < &gpio0 0x1f 0x0 >;
    			label = "Display Reset";
    		enable_3v3_out: enable_3v3_out {
    			gpios = < &gpio1 0x4 0x0 >;
    			label = "Enable 3.3 Volt line";
    		esp_enable: esp_enable {
    			gpios = < &gpio0 0x15 0x0 >;
    			label = "ESP Enable";
    		rgb_white: rgb_white {
    			gpios = < &gpio0 0x8 0x1 >;
    			label = "RGB White Switch";
    		rfx_rx_en: rfx_rx_en {
    			label = "RFX RF Enable";
    		rfx_pdn: rfx_pdn {
    			gpios = < &gpio1 0xa 0x0 >;
    			label = "RFX Power Down";
    Thanks for providing the build files. I have compared them but have not been able to spot anything obvious. When the JEDEC ID read from the chip does not match the ID defined in the devicetree, the QSPI driver will abort the initialization. This is why the bootloader reports -ENODEV (-19) when it later tries to access the secondary slot in external flash.
    Is the Winbond connected directly to the same power rail as VDD from the nRF, or is it power gated? Also, I'm not sure why it would make any difference, but have you tried removing the 'sfdp-bfp' property from your w25q64 node?
    Vidar
