Failed to open flash area ID 2 (image 0 slot 1): -19, cannot continue
We're seeing an error that only happens after a cold reboot (unplugging the battery and replugging it) and it happens inside the bootloader while trying to open the secondary flash area in the external flash. I think. If I change the bootloader code inside `bootloader/mcuboot/boot/bootutil/src/loader.c` to reset Nordic instead of panicking, it's recovering fine (i.e. calling NVIC_SystemReset() instead of FIH_PANIC)
I'm using w25q64 for flash and QSPI to communicate with the flash.
The error message is:
E: Failed to open flash area ID 2 (image 0 slot 1): -19, cannot continue
I'm using the following DTS overlay:
chosen {
nordic,pm-ext-flash = &w25q64;
&qspi {
status = "okay";
pinctrl-0 = <&qspi_default>;
pinctrl-1 = <&qspi_sleep>;
w25q64: w25q6435f@0 {
compatible = "nordic,qspi-nor";
reg = <0>;
sck-frequency = <8000000>;
jedec-id = [ef 40 17];
sfdp-bfp = [
e5 20 f9 ff ff ff ff 03 44 eb 08 6b 08 3b 42 bb
fe ff ff ff ff ff 00 00 ff ff 40 eb 0c 20 0f 52
10 d8 00 00 36 02 a6 00 82 ea 14 c4 e9 63 76 33
7a 75 7a 75 f7 a2 d5 5c 19 f7 4d ff e9 30 f8 80
size = <67108864>;
has-dpd;
t-enter-dpd = <10000>;
t-exit-dpd = <35000>;
Any pointers would be much appreciated.
  • Our flash is on a separate rail from the Nordic and it not powered by the Nordic's VDD. It is powered by a 3.3V supply and a decoupling 0.1 µF capacitor is used to stabilize the voltage.
    I tried to remove sfdp-bfp but it didn't make any difference.
  • Thanks for confirming. It still feels like it must be related to powering of the flash somehow - I can’t think of any other reasons for why it would work after a warm reboot, but not after a cold reboot. I realize it has been asked already, but still wondering if there may be any control signals to enable this rail, or if it turns on at the same time as when nRF is powered on.
    Is it possible to probe the supply pins on the chips with with a scope to troubleshoot this further?
    A workaround to all this could be to patch the bootloader to allow it to boot the main app even if it fails to access the flash on startup assuming it will only happen after a cold boot. But it would be best if we could find the root cause.
  • Unfortunately it doesn't seem like we have an easy way of doing that. I believe that our current workaround is easier and less risky (see my very first message)
    Come to think about it, if we only enable the power in our main code, after the bootloader, i'm not that certain why this fixes our issue if it's related to power.
  • Sorry, I forgot that you already had a workaround in place when I responded. I agree that your approach is easier and is probably a better solution.
    If there is a mechanism that enables power to the flash from the nRF53 (e.g., turning on a regulator switch with a gpio output), then this mechanism must also be enabled in the bootloader to explain the behavior you are observing. Otherwise, I would have expected the flash IC to have remained off after the reboot and just triggered the FIH_PANIC again.
  • My thoughts exactly, however we are not turning on that regulator in the bootloader - it's primarily done in our main Nordic code after the bootloader finished
