I followed the course to enable MCUBOOT over BLE it is successful for the project peripheral_lbs but not my application.
uart log;
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: none
E: Image in the primary slot is not valid!
E: Unable to find bootable image
build log:
Building peripheral west build --build-dir /home/longqi/peripheral/build /home/longqi/peripheral --pristine --board nrf52833dk_nrf52833 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/home/longqi/peripheral -Dmcuboot_OVERLAY_CONFIG=/home/longqi/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf -Dmcuboot_secondary_app_OVERLAY_CONFIG=/home/longqi/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf -DCONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=y -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DCONFIG_SEGGER_DEBUGMON=y -DCACHED_CONF_FILE=/home/longqi/peripheral/prj.conf -DDTC_OVERLAY_FILE=/home/longqi/peripheral/nrf52833dk_nrf52833.overlay -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /home/longqi/peripheral -- CMake version: 3.21.0 -- Found Python3: /home/longqi/ncs/toolchains/2be090971e/usr/local/bin/python3.9 (found suitable version "3.9.18", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /home/longqi/.cache/zephyr -- Zephyr version: 3.5.99 (/home/longqi/ncs/v2.6.1/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf52833dk_nrf52833 -- Found host-tools: zephyr 0.16.5 (/home/longqi/ncs/toolchains/2be090971e/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/home/longqi/ncs/toolchains/2be090971e/opt/zephyr-sdk) -- Found Dtc: /home/longqi/ncs/toolchains/2be090971e/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6") -- Found BOARD.dts: /home/longqi/ncs/v2.6.1/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts -- Found devicetree overlay: /home/longqi/peripheral/nrf52833dk_nrf52833.overlay -- Generated zephyr.dts: /home/longqi/peripheral/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: /home/longqi/peripheral/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /home/longqi/peripheral/build/zephyr/dts.cmake Parsing /home/longqi/ncs/v2.6.1/zephyr/Kconfig Loaded configuration '/home/longqi/ncs/v2.6.1/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig' Merged configuration '/home/longqi/peripheral/prj.conf' Merged configuration '/home/longqi/peripheral/build/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/home/longqi/peripheral/build/zephyr/.config' Kconfig header saved to '/home/longqi/peripheral/build/zephyr/include/generated/autoconf.h' -- Found GnuLd: /home/longqi/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /home/longqi/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /home/longqi/ncs/v2.6.1/zephyr/subsys/bluetooth/host/CMakeLists.txt:100 (message): CONFIG_BT_FIXED_PASSKEY is enabled A fixed passkey is easy to deduce during the pairing procedure, do not use in production. CMake Warning at /home/longqi/ncs/v2.6.1/nrf/samples/common/mcumgr_bt_ota_dfu/CMakeLists.txt:14 (message): MCUmgr Bluetooth OTA DFU: suboptimal configuration of Bluetooth Controller buffers. Consider using optimal values defined in the /home/longqi/ncs/v2.6.1/nrf/samples/common/mcumgr_bt_ota_dfu/Kconfig file for CONFIG_BT_BUF_ACL_TX_SIZE, CONFIG_BT_BUF_ACL_RX_SIZE and CONFIG_BT_CTLR_DATA_LENGTH_MAX options CMake Warning at /home/longqi/ncs/v2.6.1/nrf/samples/common/mcumgr_bt_ota_dfu/CMakeLists.txt:27 (message): MCUmgr Bluetooth OTA DFU: suboptimal configuration of Bluetooth Host buffers. Consider using optimal values defined in the /home/longqi/ncs/v2.6.1/nrf/samples/common/mcumgr_bt_ota_dfu/Kconfig file for CONFIG_BT_BUF_ACL_TX_SIZE, CONFIG_BT_BUF_ACL_RX_SIZE and CONFIG_BT_L2CAP_TX_MTU options -- Found Python3: /home/longqi/ncs/toolchains/2be090971e/usr/local/bin/python3.9 (found version "3.9.18") found components: Interpreter === child image mcuboot - begin === loading initial cache file /home/longqi/peripheral/build/mcuboot/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /home/longqi/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr -- CMake version: 3.21.0 -- Found Python3: /home/longqi/ncs/toolchains/2be090971e/usr/local/bin/python3.9 (found suitable version "3.9.18", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /home/longqi/.cache/zephyr -- Zephyr version: 3.5.99 (/home/longqi/ncs/v2.6.1/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf52833dk_nrf52833 -- Found host-tools: zephyr 0.16.5 (/home/longqi/ncs/toolchains/2be090971e/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/home/longqi/ncs/toolchains/2be090971e/opt/zephyr-sdk) -- Found Dtc: /home/longqi/ncs/toolchains/2be090971e/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6") -- Found BOARD.dts: /home/longqi/ncs/v2.6.1/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts -- Found devicetree overlay: /home/longqi/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr/app.overlay -- Generated zephyr.dts: /home/longqi/peripheral/build/mcuboot/zephyr/zephyr.dts -- Generated devicetree_generated.h: /home/longqi/peripheral/build/mcuboot/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /home/longqi/peripheral/build/mcuboot/zephyr/dts.cmake Parsing /home/longqi/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr/Kconfig Loaded configuration '/home/longqi/ncs/v2.6.1/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig' Merged configuration '/home/longqi/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr/prj.conf' Merged configuration '/home/longqi/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf' Merged configuration '/home/longqi/peripheral/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/home/longqi/peripheral/build/mcuboot/zephyr/.config' Kconfig header saved to '/home/longqi/peripheral/build/mcuboot/zephyr/include/generated/autoconf.h' -- Found GnuLd: /home/longqi/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /home/longqi/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /home/longqi/ncs/v2.6.1/nrf/lib/flash_patch/CMakeLists.txt:8 (message): ---------------------------------------------------------- --- WARNING: To maintain the integrity of secure boot, --- --- enable CONFIG_DISABLE_FLASH_PATCH in production. --- ---------------------------------------------------------- -- Using ccache: /home/longqi/ncs/toolchains/2be090971e/usr/bin/ccache MCUBoot bootloader key file: /home/longqi/ncs/v2.6.1/bootloader/mcuboot/root-rsa-2048.pem -- Configuring done -- Generating done -- Build files have been written to: /home/longqi/peripheral/build/mcuboot === child image mcuboot - end === CMake Warning at /home/longqi/ncs/v2.6.1/nrf/modules/mcuboot/CMakeLists.txt:382 (message): --------------------------------------------------------- --- WARNING: Using default MCUBoot key, it should not --- --- be used for production. --- --------------------------------------------------------- -- Using ccache: /home/longqi/ncs/toolchains/2be090971e/usr/bin/ccache CMake Warning at /home/longqi/ncs/v2.6.1/nrf/cmake/partition_manager.cmake:79 (message): --------------------------------------------------------------------- --- WARNING: Using a bootloader without pm_static.yml. --- --- There are cases where a deployed product can consist of --- --- multiple images, and only a subset of these images can be --- --- upgraded through a firmware update mechanism. In such cases, --- --- the upgradable images must have partitions that are static --- --- and are matching the partition map used by the bootloader --- --- programmed onto the device. --- --------------------------------------------------------------------- Call Stack (most recent call first): /home/longqi/ncs/v2.6.1/zephyr/cmake/modules/kernel.cmake:248 (include) /home/longqi/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake:138 (include) /home/longqi/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /home/longqi/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:4 (find_package) -- Configuring done -- Generating done -- Build files have been written to: /home/longqi/peripheral/build -- west build: building application [1/274] Preparing syscall dependency handling [5/274] Generating include/generated/version.h -- Zephyr version: 3.5.99 (/home/longqi/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1 [1/271] Preparing syscall dependency handling [4/271] Generating include/generated/version.h -- Zephyr version: 3.5.99 (/home/longqi/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1 [271/271] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 32670 B 48 KB 66.47% RAM: 23808 B 128 KB 18.16% IDT_LIST: 0 GB 32 KB 0.00% [256/274] Building C object CMakeFiles/app.dir/src/main.c.obj /home/longqi/peripheral/src/main.c:192:13: warning: 'device_name_set' defined but not used [-Wunused-function] 192 | static void device_name_set(uint8_t *name, uint8_t length) | ^~~~~~~~~~~~~~~ [266/274] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 229048 B 232960 B 98.32% RAM: 60564 B 128 KB 46.21% IDT_LIST: 0 GB 32 KB 0.00% [269/274] Generating ../../zephyr/app_update.bin image.py: sign the payload [271/274] Generating ../../zephyr/app_signed.hex image.py: sign the payload [272/274] Generating ../../zephyr/app_test_update.hex image.py: sign the payload [274/274] Generating zephyr/merged.hex * Terminal will be reused by tasks, press any key to close it.
prj.conf
# Increased stack due to settings API usage CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_BT=y # Enable logging CONFIG_LOG=y CONFIG_BT_SMP=y CONFIG_BT_SIGNING=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_DIS=y CONFIG_BT_ATT_PREPARE_COUNT=5 CONFIG_BT_PRIVACY=n CONFIG_BT_DEVICE_NAME="p1" CONFIG_BT_DEVICE_APPEARANCE=833 CONFIG_BT_DEVICE_NAME_DYNAMIC=y CONFIG_BT_DEVICE_NAME_MAX=65 CONFIG_BT_DIS_MANUF="xnergy" CONFIG_BT_DIS_MODEL="phoenix" CONFIG_BT_KEYS_OVERWRITE_OLDEST=y CONFIG_BT_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y CONFIG_BT_PERIPHERAL_PREF_MIN_INT=8 CONFIG_BT_PERIPHERAL_PREF_MAX_INT=8 CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=200 CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y CONFIG_BT_BUF_ACL_RX_SIZE=251 CONFIG_BT_BUF_ACL_TX_SIZE=251 CONFIG_BT_BUF_CMD_TX_SIZE=255 CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255 CONFIG_BT_L2CAP_TX_MTU=247 CONFIG_BT_USER_DATA_LEN_UPDATE=y CONFIG_BT_CTLR_DATA_LENGTH_MAX=251 CONFIG_BT_MAX_CONN=2 CONFIG_BT_FIXED_PASSKEY=y CONFIG_UART_CONSOLE=n CONFIG_RTT_CONSOLE=y CONFIG_SERIAL=y CONFIG_UART_ASYNC_API=y CONFIG_MAIN_STACK_SIZE=2048 CONFIG_SENSOR=y CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
