Questions about Nordic Distance Measurement library sample
The hardware I use is nrf52840Dongle, using nrf_dm sample for development.
There are a few problems:
1. I have 8 devices, all within communication range, 4 as base stations and 3 as tags. The base station is the reflector, which is achieved by commenting this code:
//if (peer_supported_test(info->addr)) {
I want to let the tag be the initiator only。What do I need to change?
2. I found that the tag sometimes only tests with certain base stations, and I want to test the tag with each base station, so that the measurement data of the tag is relatively average. Is there any better implementation method?
3. Test the two boards separately, and find that the measurement data can be output once per second when the distance is close. When the distance becomes longer, the output data will become slower. What parameters do you need to change?
Looking forward to your reply.
Regards
     I understand the parameters in this way, and I don't know if my understanding is correct.
    For multiple device measurements, is it a one-time synchronization followed by device by device measurements?
    I'm not sure TIMESLOT meant the pink arrow part or the blue arrow part.
    I have solved the problem of imbalanced output data. But now I run into another problem, I find that the number of outputs becomes less as time goes on, what might be the cause of this?
    I found similar questions in this ticker, but couldn't find the answer.
    devzone.nordicsemi.com/.../nrfconnect-sdk-nrf_dm-example-with-dedicated-roles-with-several-reflectors-and-one-initiator-degrades-with-time
  • Hi.
    Have you looked at the documentation describing the nRF Distance Measurement sample and how to use the Distance Measurement Library?
    Is this what you figured out yourself?
    There are several parameters deciding how fast output will be ready. Distance is one of these parameters so it is natural that it requires more time as the distance increases. If you've set CONFIG_DM_HIGH_PRECISION_CALC=y and can sacrifice precision for a higher output data rate, you can set it =n, as described in CONFIG_DM_MIN_TIME_BETWEEN_TIMESLOTS_US.
    Could you please point to the source of this figure?
    Mathias
  • Hi.
    Mathias
    1、I've looked at the documentation, but I haven't found an answer on how to just set as a scanner;
    2、 For the balance issue, I refer to the practice of other tickets and make limits in the application;
    3、I'll try to test the parameters you suggested,CONFIG_DM_HIGH_PRECISION_CALC=n;
    4、This figure was drawn by me based on the official document, and it is what I understand, but I don't know if it is correct or not. I don't quite understand what TIMESLOT means;
    5、The device distance remains the same, Over time, the frequency of ranging decreases.Any suggestions on this issue?
    Best regards
