I use the above function to create a new dataset. When I use SDK 2.3.0, this works perfectly. But when I use SDK 2.6.0 I get the following.
[00:00:06.162,597] <err> os: ***** MPU FAULT ***** [00:00:06.162,628] <err> os: Data Access Violation [00:00:06.162,628] <err> os: MMFAR Address: 0x20013e3c [00:00:06.162,658] <err> os: r0/a1: 0x20013e48 r1/a2: 0x00000000 r2/a3: 0x00000228 [00:00:06.162,689] <err> os: r3/a4: 0x00000000 r12/ip: 0x00000000 r14/lr: 0x0006005b [00:00:06.162,689] <err> os: xpsr: 0x410f0000 [00:00:06.162,719] <err> os: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00000000 [00:00:06.162,719] <err> os: s[ 4]: 0xffffffff s[ 5]: 0xffffffff s[ 6]: 0x00000000 s[ 7]: 0x0002d26f [00:00:06.162,750] <err> os: s[ 8]: 0xffffffff s[ 9]: 0x20003078 s[10]: 0x2000c280 s[11]: 0xffffffff [00:00:06.162,780] <err> os: s[12]: 0xffffffff s[13]: 0x0002edff s[14]: 0xffffffff s[15]: 0xffffffff [00:00:06.162,811] <err> os: fpscr: 0xaaaaaaaa [00:00:06.162,811] <err> os: Faulting instruction address (r15/pc): 0x0002c206 [00:00:06.162,841] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0 [00:00:06.162,902] <err> os: Current thread: 0x200031a8 (shell_uart) [00:00:06.394,195] <err> fatal_error: Resetting system
When I tried
arm-zephyr-eabi-addr2line.exe -e C:\nrfwork\zmhostradiofw\release\zephyr\zephyr.elf -a 0x0002c206
I get ??.?.
I tried adding the following to the prj.conf, but no improvement.
otError cli_cmsn (void *aContext, uint8_t aArgsLength, char *aArgs[]) { . . . otCliOutputFormat ("\n\rCreate new dataset "); error = otDatasetCreateNewNetwork(instance, &aDataset); // create new dataset error = otDatasetConvertToTlvs(&aDataset, &aDatasetTlvs); // SDK 2.6.0 if (error != OT_ERROR_NONE) { otCliOutputFormat ("create new dataset error"); return (error); } otCliOutputFormat ("\n\r active new dataset "); //error = otDatasetSetActive(instance, &aDataset); // active new dataset SDK 2.3.0 error = otDatasetSetActiveTlvs(instance, &aDatasetTlvs); if (error != OT_ERROR_NONE) { otCliOutputFormat ("active new dataset error"); return (error); } . . }
[00:00:08.872,985] <err> os: ***** MPU FAULT ***** [00:00:08.873,016] <err> os: Stacking error (context area might be not valid) [00:00:08.873,046] <err> os: Data Access Violation [00:00:08.873,046] <err> os: MMFAR Address: 0x20013e68 [00:00:08.873,077] <err> os: r0/a1: 0x2000c280 r1/a2: 0xffffffff r2/a3: 0xffffffff [00:00:08.873,077] <err> os: r3/a4: 0x0002edfb r12/ip: 0xffffffff r14/lr: 0xffffffff [00:00:08.873,107] <err> os: xpsr: 0xaaaaaa00 [00:00:08.873,138] <err> os: s[ 0]: 0xaaaaaaaa s[ 1]: 0xaaaaaaaa s[ 2]: 0xaaaaaaaa s[ 3]: 0xaaaaaaaa [00:00:08.873,138] <err> os: s[ 4]: 0xaaaaaaaa s[ 5]: 0xaaaaaaaa s[ 6]: 0xaaaaaaaa s[ 7]: 0xaaaaaaaa [00:00:08.873,168] <err> os: s[ 8]: 0xaaaaaaaa s[ 9]: 0xaaaaaaaa s[10]: 0xaaaaaaaa s[11]: 0xaaaaaaaa [00:00:08.873,199] <err> os: s[12]: 0xaaaaaaaa s[13]: 0xaaaaaaaa s[14]: 0xaaaaaaaa s[15]: 0xaaaaaaaa [00:00:08.873,199] <err> os: fpscr: 0xaaaaaaaa [00:00:08.873,229] <err> os: Faulting instruction address (r15/pc): 0xaaaaaaaa [00:00:08.873,260] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0 [00:00:08.873,291] <err> os: Current thread: 0x200031a8 (shell_uart) [00:00:09.121,612] <err> fatal_error: Resetting system
