I have a device which advertises some services, I want to discover those services and write to those characteristics. However I can only find one service and not multiple.
I have the following code that registers one service:
static void db_discovery_init(void) { uint32_t err_code = ble_db_discovery_init(db_disc_handler); APP_ERROR_CHECK(err_code); ble_uuid_t auth_uuid; ble_uuid128_t auth_base_uuid = {{0xa0, 0xde, 0xbc, 0x9a, 0x78, 0x56, 0x34, 0x13, 0x78, 0x56, 0x34, 0x12, 0x78, 0x56, 0x34, 0x13}}; auth_uuid.type = 1; auth_uuid.uuid = 0x5678; err_code = sd_ble_uuid_vs_add(&auth_base_uuid, &auth_uuid.type); if (err_code != NRF_SUCCESS) { NRF_LOG_INFO("err: %d\n", err_code); return; } err_code = ble_db_discovery_evt_register(&auth_uuid); APP_ERROR_CHECK(err_code); }
But I also have the following service that I want to discover:
ble_uuid128_t other_service_base_uuid = {{0xf3, 0xde, 0xbc, 0x9a, 0x78, 0x56, 0x34, 0x13, 0x78, 0x56, 0x34, 0x12, 0x78, 0x56, 0x34, 0x13}}; which has the same 0x5678 uuid as the other.
I'm thinking maybe there is a way to register a service based on the full uuid, rather than two bytes.
I use sdk 12.3.0 for my nrf51802 with s130.
