Bluetooth wont initialize with custom board based on nRF5340dk
I am working on creating a custom board based off the nrf5340dk_nrf5340 board
I am following the tutorial here
https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-3-adding-custom-board-support/topic/exercise-2-5/
I have an application that functions properly when I build it for the nrf5340dk_nrf5340. However when building for my custom board(which is a direct copy of nrf5340dk_nrf5340), the program runs but the Bluetooth fails to initialize.
[00:00:01.455,780] <err> bt_hci_driver: Endpoint binding failed with -11
[00:00:01.463,165] <err> bt_hci_core: HCI driver open failed (-11)
In both cases I am running off the same hardware nrf5340dk_nrf5340
  • Hello again,
    I see now that I was perhaps I was a bit too quick in my previous response. So your custom board is essentially a copy of the 53DK, but is the only difference here, so I guess we can rule out the SW from being the culprit.
    I assume you missed something when creating the custom board. Good thing you sent it to me.
    So comparing it to the 5340DK board files, it seems you missed a few files. I assume you've checked that those are okay to skip? And in rxcb_nrf5340_cpuapp.dts there seems to be a typo:
    I see you are not enabling trustzone here but I guess that is fine.
    Here in rxcb_nrf5340_cpunet.dts there is another typo:
    Could you try fixing these typos?
    Regards, and have a good week-end,
    Elfving
  • Hello Elfving,
    Thank you again for the prompt response!
    So I believe I do have trustzone enabled, looking at defconfig for both boards, the only difference is the board name
    As for the other typos you mentioned, may I ask which version of the SDK you are comparing the board file with, in the 2.5.3 I have those lines in nrf5340dk are the same.
    I have attached my nrf5340dk board file just as a sanity check.
    nrf5340dk_nrf5340.7z
    Thanks again for the assistance.
  • This time I wasn't that prompt unfortunately.
    Could you try this on your side?
    2804.rxcb_nrf5340.7z
    Elfving
  • Hello Elfving,
    The assistance is greatly appreciated! Ill give it a go today and report back with what I see.
    Best,
    -Chasen
  • Hello Elfving,
    Best,
    -Chasen
