CONFIG_TFM_ITS_ENCRYPTED=y seems broken on 2.6.x
Using the sample PSA Protected Storage on the nrf5340 DK with NCS v2.6.1 (and v2.5.2). My prj.conf contains these settings:
# Copyright (c) 2021 Nordic Semiconductor ASA
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_BUILD_WITH_TFM=y
CONFIG_TFM_PROFILE_TYPE_MEDIUM=y
# this settings makes the nrf53 rebooting whole the time on NCS v2.6.x :-(
CONFIG_TFM_LOG_LEVEL_SILENCE=n
CONFIG_TFM_SPM_LOG_LEVEL_DEBUG=y
CONFIG_TFM_EXCEPTION_INFO_DUMP=y
CONFIG_LOG_MODE_IMMEDIATE=y
I flash the sample provisioning_image first. Next I flash the PSA PS storage sample build with v2.6.x. With v.2.6.x I see TF-M logging indicating constant rebooting. Here's the output from TF-M, UART0. There's no logging on UART1:
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
The UICR->APPROTECT register is now configured to deny debugging access for the network core!
Success!
Writing random Hardware Unique Keys to the KMU.
Success
[Sec Thread] Secure image initializing!
TF-M isolation level is: 0x00000001
Booting TF-M v2.0.0
Creating an empty ITS flash layout.
Creating an empty PS flash layout.
[INF][Crypto] Provisioning entropy seed... [Sec Thread] Secure image initializing!
Booting TF-M v2.0.0
Booting TF-M v2.0.0
... continues repeating like this ...
With NCS v2.5.2 I do not see any logging on UART0 but UART1 shows correct output from the application:
[00:00:00.410,369] <inf> provisioning_image: Successfully verified PSA lifecycle state ASSEMBLY!
[00:00:00.410,430] <inf> provisioning_image: Successfully switched to PSA lifecycle state PROVISIONING!
[00:00:00.410,430] <inf> provisioning_image: Generating random HUK keys (including MKEK)
[00:00:00.473,571] <inf> provisioning_image: Writing the identity key to KMU
[00:00:00.473,602] <wrn> identity_key: WARNING: Using a dummy identity key not meant for production!
[00:00:00.474,700] <inf> provisioning_image: Success!
*** Booting nRF Connect SDK v2.5.2 ***
Protected Storage sample started.
PSA Protected Storage API Version 1.0
Writing data to UID1: The quick brown fox jumps over the lazy dog
Info on data stored in UID1:
- Size: 44
- Capacity: 0x 1
- Flags: 0x 0
Read and compare data stored in UID1
Data stored in UID1: The quick brown fox jumps over the lazy dog
Overwriting data stored in UID1: Lorem ipsum dolor sit amet
Writing data to UID2 with overwrite protection: The quick brown fox jumps over the lazy dog
Attempting to write 'Lorem ipsum dolor sit amet' to UID2
Got expected error (PSA_ERROR_NOT_PERMITTED) when writing to protected UID
Removing UID1
Should I add another setting(s) when building with v2.6.x to make CONFIG_TFM_ITS_ENCRYPTED work at runtime? I have been trying lots of different settings already last couple of days.
There likely is no release test case to verify the usage of CONFIG_TFM_ITS_ENCRYPTED at runtime on real hardware (if so, one should not have released v2.6.x). If there is no test case, how can one guarantee that CONFIG_TFM_ITS_ENCRYPTED is actually "encrypting" even in NCS v2.5.2? And that there will be no regression introduced in later versions? Might the test case be missing from the upstream TF-M project? I could add an issue in their github repo?
Thank you!
francis
    Which board do you use?
    Can you show logs after flashing provisioning_image sample (in both NCS v2.5.2 and NCS v2.6.1) to both nrf5340-dk and your custom board (if it is not nrf5340-dk)?
    Dejan
  • Hello Dejan,
    Thank you for looking into this. The board is the nrf5340 DK.
    The provision image is compiled with NCS v2.6.1 only. It is each time flashed before running the PSA PS sample.
    The PSA PS sample is compiled with v2.6.1 (also tried v2.6.0) which fails showing the expected application output.
    If compiled with 2.5.2 it succeeds.
    The logging of the provision image is shown above with the output of a successful run of the PSA PS sample compiled for v2.5.2. This logging is also shown in case of next flashing PSA PS sample compiled with v2.6.1. For completeness it is here:
    [00:00:00.452,850] <inf> provisioning_image: Successfully verified PSA lifecycle state ASSEMBLY!
    [00:00:00.452,911] <inf> provisioning_image: Successfully switched to PSA lifecycle state PROVISIONING!
    [00:00:00.452,911] <inf> provisioning_image: Generating random HUK keys (including MKEK)
    [00:00:00.516,082] <inf> provisioning_image: Writing the identity key to KMU
    [00:00:00.516,113] <wrn> identity_key: WARNING: Using a dummy identity key not meant for production!
    [00:00:00.517,211] <inf> provisioning_image: Success!
    There's no further output on UART1 while on UART0, I insert it again, it seems stuck in a bootup loop:
    Booting TF-M v2.0.0
    [INF][Crypto] Provisioning entropy seed... *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    Success!
    Success
    Booting TF-M v2.0.0
    Booting TF-M v2.0.0
    Booting TF-M v2.0.0
    Booting TF-M v2.0.0
    Booting TF-M v2.0.0
    Does this clarify my question?
    francis
  • Hello Dejan,
    Could you verify the issue on your side as well? If so, is there a workaround or do you miss some information? Thanks.
    francis
  • Hi Francis,
    I have reproduced reported behavior. I will look more into this during next week. I expect to get back to you by the end of next week.
    Dejan
  • Hi Francis,
    I will get back to you by the end of next week.
    Dejan
