Hi, I have an issue I can't understand. I'm getting the TRICKLETIMEOUT (Trickle timer timeout) ERROR 64 from my nPM1300.
If I understand correctly:
1. Trickle charging happens when the battery voltage is below 2.9 (or 2.5V).
2. If the battery voltage is >2.9V, it should leave the Trickle charging state quite fast after "Battery detected state" in the Product Specification 6.2.1 Charging cycle
3. TRICKLETIMEOUT happens IF the battery voltage does not exceed 2.9 (or 2.5V) after 10 minutes (tOUTTRICKLE Trickle charging timeout - 10min).
The problem is that my battery is at about 4V, and nPM1300 is never leaving the Trickle charging state.
Here is a log after a hard reset of nPM1300 (you don't see the error 64 it's not yet generated), but if I wait eventually I'll get the log ERROR 64, which means TRICKLETIMEOUT ERROR.
You can also see in the log at one point I remove the VBUS, in order to see the true voltage of the battery, that it's not <2.9V.
[00:00:00.000,427] <dbg> qspi_nor: configure_chip: RDSR 40 QE 1 need 1: no-change [00:00:00.000,518] <dbg> qspi_nor: qspi_nor_init: Runtime power management enabled [00:00:00.611,633] <inf> fs_nvs: 8 Sectors of 4096 bytes [00:00:00.611,694] <inf> fs_nvs: alloc wra: 4, f18 [00:00:00.611,694] <inf> fs_nvs: data wra: 4, b40 [00:00:01.103,424] <err> bosch_bsec: bme68x_get_data error! [00:00:01.917,572] <inf> littlefs: littlefs partition at /lvgl_lfs [00:00:01.917,633] <inf> littlefs: LittleFS version 2.5, disk version 2.0 [00:00:01.918,212] <inf> littlefs: FS at mx25u51245g@0:0x0 is 512 0x1000-byte blocks with 512 cycle [00:00:01.918,243] <inf> littlefs: sizes: rd 512 ; pr 512 ; ca 512 ; la 4096 [00:00:01.922,882] <inf> littlefs: Automount /lvgl_lfs succeeded *** Booting nRF Connect SDK v3.5.99-ncs1 *** [00:00:02.575,134] <wrn> zsw_pmic: nRF Fuel Gauge version: 0.9.2 [00:00:09.502,960] <dbg> main: run_input_work: Input worker code: 307 [00:00:12.578,277] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.984, I: -0.020, T: -273.15, [00:00:12.578,277] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.76, TTE: nan, TTF: nan [00:00:12.578,308] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:00:22.578,338] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 4.003, I: -0.020, T: -273.15, [00:00:22.578,369] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.78, TTE: nan, TTF: nan [00:00:22.578,369] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:00:32.578,399] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.999, I: -0.020, T: -273.15, [00:00:32.578,399] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.79, TTE: nan, TTF: 0 [00:00:32.578,430] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:00:42.578,460] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.984, I: -0.020, T: -273.15, [00:00:42.578,491] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.81, TTE: nan, TTF: 0 [00:00:42.578,491] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:00:52.578,521] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.989, I: -0.020, T: -273.15, [00:00:52.578,552] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.83, TTE: nan, TTF: nan [00:00:52.578,552] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:01:02.578,582] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.999, I: -0.020, T: -273.15, [00:01:02.578,613] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.84, TTE: nan, TTF: nan [00:01:02.578,613] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:01:06.366,546] <dbg> zsw_pmic: event_callback: Event detected [00:01:06.366,577] <dbg> zsw_pmic: event_callback: VBUS removed [00:01:12.578,643] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.994, I: -0.020, T: -273.15, [00:01:12.578,643] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.86, TTE: nan, TTF: 0 [00:01:12.578,674] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:01:17.673,004] <dbg> zsw_pmic: event_callback: Event detected [00:01:17.673,034] <dbg> zsw_pmic: event_callback: VBUS detected [00:01:19.729,003] <inf> zsw_power_manager: Enter inactive [00:01:22.579,467] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.979, I: -0.020, T: -273.15, [00:01:22.579,498] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.87, TTE: nan, TTF: nan [00:01:22.579,528] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:01:32.579,528] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.994, I: -0.020, T: -273.15, [00:01:32.579,589] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.89, TTE: nan, TTF: 0 [00:01:32.579,620] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:01:42.579,650] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.979, I: -0.020, T: -273.15, [00:01:42.579,681] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.90, TTE: nan, TTF: 0 [00:01:42.579,711] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:01:52.579,742] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.989, I: -0.020, T: -273.15, [00:01:52.579,772] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.92, TTE: nan, TTF: nan [00:01:52.579,803] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:02:02.579,833] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 4.003, I: -0.020, T: -273.15, [00:02:02.579,864] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 65.94, TTE: nan, TTF: nan [00:02:02.579,895] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0
Longer log with error 64 detected:
[00:00:00.000,427] <dbg> qspi_nor: configure_chip: RDSR 40 QE 1 need 1: no-change [00:00:00.000,518] <dbg> qspi_nor: qspi_nor_init: Runtime power management enabled [00:00:00.695,922] <inf> fs_nvs: 8 Sectors of 4096 bytes [00:00:00.695,983] <inf> fs_nvs: alloc wra: 0, fb8 [00:00:00.695,983] <inf> fs_nvs: data wra: 0, 30 [00:00:01.743,316] <inf> littlefs: littlefs partition at /lvgl_lfs [00:00:01.743,377] <inf> littlefs: LittleFS version 2.5, disk version 2.0 [00:00:01.743,957] <inf> littlefs: FS at mx25u51245g@0:0x0 is 512 0x1000-byte blocks with 512 cycle [00:00:01.743,988] <inf> littlefs: sizes: rd 512 ; pr 512 ; ca 512 ; la 4096 [00:00:01.745,269] <inf> littlefs: Automount /lvgl_lfs succeeded *** Booting nRF Connect SDK v3.5.99-ncs1 *** [00:00:01.759,918] <wrn> zsw_pmic: nRF Fuel Gauge version: 0.9.2 [00:00:11.763,183] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:00:11.763,183] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.15, TTE: nan, TTF: nan [00:00:11.763,214] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:00:12.389,373] <dbg> main: run_input_work: Input worker code: 307 [00:00:21.763,244] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.020, T: -273.15, [00:00:21.763,244] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.16, TTE: nan, TTF: 0 [00:00:21.763,275] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:00:31.763,305] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: -0.020, T: -273.15, [00:00:31.763,305] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.18, TTE: nan, TTF: 0 [00:00:31.763,336] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:00:41.763,366] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: -0.020, T: -273.15, [00:00:41.763,366] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.19, TTE: nan, TTF: 0 [00:00:41.763,397] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:00:43.936,004] <inf> zsw_power_manager: Enter inactive [00:00:51.764,160] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: -0.019, T: -273.15, [00:00:51.764,221] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.21, TTE: nan, TTF: nan [00:00:51.764,221] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:01:00.104,644] <dbg> main: run_input_work: Input worker code: 304 [00:01:00.104,675] <inf> zsw_power_manager: Enter active [00:01:01.805,633] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: -0.020, T: -273.15, [00:01:01.805,633] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.22, TTE: nan, TTF: nan [00:01:01.805,664] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:01:01.876,708] <dbg> main: run_input_work: Input worker code: 307 [00:01:11.805,664] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.020, T: -273.15, [00:01:11.805,694] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.24, TTE: nan, TTF: nan [00:01:11.805,694] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:01:21.805,725] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: -0.020, T: -273.15, [00:01:21.805,725] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.26, TTE: nan, TTF: 0 [00:01:21.805,755] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:01:21.877,471] <inf> zsw_power_manager: Enter inactive [00:01:31.806,518] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: -0.019, T: -273.15, [00:01:31.806,579] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.27, TTE: nan, TTF: nan [00:01:31.806,610] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:01:41.806,610] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:01:41.806,671] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.29, TTE: nan, TTF: nan [00:01:41.806,701] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:01:51.806,701] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:01:51.806,762] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.30, TTE: nan, TTF: 0 [00:01:51.806,762] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:02:01.806,823] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:02:01.806,854] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.32, TTE: nan, TTF: nan [00:02:01.806,884] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:02:11.806,884] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: -0.020, T: -273.15, [00:02:11.806,945] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.33, TTE: nan, TTF: nan [00:02:11.806,976] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:02:21.807,037] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:02:21.807,067] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.35, TTE: nan, TTF: 0 [00:02:21.807,098] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:02:31.807,067] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:02:31.807,128] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.36, TTE: nan, TTF: 0 [00:02:31.807,128] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:02:41.807,189] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:02:41.807,220] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.38, TTE: nan, TTF: nan [00:02:41.807,250] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:02:51.807,250] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:02:51.807,312] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.40, TTE: nan, TTF: 0 [00:02:51.807,312] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:03:01.807,373] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.925, I: -0.019, T: -273.15, [00:03:01.807,403] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.41, TTE: nan, TTF: nan [00:03:01.807,434] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:03:11.807,464] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: -0.019, T: -273.15, [00:03:11.807,495] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.43, TTE: nan, TTF: nan [00:03:11.807,525] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:03:21.807,525] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:03:21.807,586] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.44, TTE: nan, TTF: 0 [00:03:21.807,586] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:03:31.807,617] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:03:31.807,678] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.46, TTE: nan, TTF: 0 [00:03:31.807,678] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:03:41.807,739] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: -0.019, T: -273.15, [00:03:41.807,769] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.47, TTE: nan, TTF: nan [00:03:41.807,800] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:03:51.807,830] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:03:51.807,861] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.49, TTE: nan, TTF: 0 [00:03:51.807,891] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:04:01.807,983] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:04:01.808,013] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.50, TTE: nan, TTF: nan [00:04:01.808,044] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:04:05.731,781] <inf> zsw_power_manager: Watch enterted stationary state [00:04:11.808,044] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: -0.019, T: -273.15, [00:04:11.808,074] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.52, TTE: nan, TTF: nan [00:04:11.808,105] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:04:21.808,135] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:04:21.808,166] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.53, TTE: nan, TTF: nan [00:04:21.808,197] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:04:31.808,258] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: -0.019, T: -273.15, [00:04:31.808,288] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.55, TTE: nan, TTF: nan [00:04:31.808,319] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:04:41.808,288] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:04:41.808,349] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.56, TTE: nan, TTF: 0 [00:04:41.808,349] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:04:51.808,410] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:04:51.808,441] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.58, TTE: nan, TTF: nan [00:04:51.808,471] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:05:01.808,532] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: -0.019, T: -273.15, [00:05:01.808,563] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.59, TTE: nan, TTF: nan [00:05:01.808,593] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:05:11.808,563] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:05:11.808,624] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.61, TTE: nan, TTF: 0 [00:05:11.808,624] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:05:21.808,685] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:05:21.808,715] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.62, TTE: nan, TTF: 31434 [00:05:21.808,746] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:05:31.808,776] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:05:31.808,807] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.64, TTE: nan, TTF: 31431 [00:05:31.808,837] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:05:41.808,837] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:05:41.808,868] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.65, TTE: nan, TTF: 0 [00:05:41.808,898] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:05:51.808,959] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: -0.020, T: -273.15, [00:05:51.808,990] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.67, TTE: nan, TTF: 31441 [00:05:51.809,020] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:06:01.809,020] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:06:01.809,051] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.68, TTE: nan, TTF: 0 [00:06:01.809,082] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:06:11.809,143] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.020, T: -273.15, [00:06:11.809,173] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.70, TTE: nan, TTF: 31435 [00:06:11.809,204] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:06:21.809,173] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:06:21.809,234] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.71, TTE: nan, TTF: 0 [00:06:21.809,265] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:06:31.809,326] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:06:31.809,387] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.73, TTE: nan, TTF: nan [00:06:31.809,387] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:06:41.809,417] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:06:41.809,478] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.74, TTE: nan, TTF: 31469 [00:06:41.809,478] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:06:51.809,478] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:06:51.809,539] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.76, TTE: nan, TTF: 0 [00:06:51.809,539] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:07:01.809,600] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.020, T: -273.15, [00:07:01.809,661] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.77, TTE: nan, TTF: 31482 [00:07:01.809,661] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:07:11.809,661] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:07:11.809,722] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.79, TTE: nan, TTF: 0 [00:07:11.809,722] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:07:21.809,814] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:07:21.809,844] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.80, TTE: nan, TTF: nan [00:07:21.809,875] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:07:31.809,844] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:07:31.809,906] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.82, TTE: nan, TTF: 0 [00:07:31.809,936] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:07:41.809,997] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:07:41.810,028] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.83, TTE: nan, TTF: nan [00:07:41.810,058] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:07:51.810,028] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:07:51.810,089] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.85, TTE: nan, TTF: 0 [00:07:51.810,089] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:08:01.810,150] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.925, I: -0.020, T: -273.15, [00:08:01.810,211] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.86, TTE: nan, TTF: 31549 [00:08:01.810,211] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:08:11.810,241] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:08:11.810,272] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.88, TTE: nan, TTF: 31562 [00:08:11.810,302] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 9, Error: 0 [00:08:21.810,211] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.945, I: 0.000, T: -273.15, [00:08:21.810,272] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.89, TTE: nan, TTF: nan [00:08:21.810,302] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:08:31.810,363] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:08:31.810,424] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.89, TTE: nan, TTF: nan [00:08:31.810,424] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 9, Error: 0 [00:08:41.810,455] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.984, I: -0.230, T: -273.15, [00:08:41.810,516] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 51.89, TTE: nan, TTF: 66 [00:08:41.810,546] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:08:51.810,546] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:08:51.810,577] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.08, TTE: nan, TTF: nan [00:08:51.810,607] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:09:01.810,638] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:09:01.810,668] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.09, TTE: nan, TTF: 0 [00:09:01.810,699] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:09:11.810,729] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:09:11.810,760] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.11, TTE: nan, TTF: nan [00:09:11.810,791] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:09:21.810,791] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:09:21.810,852] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.12, TTE: nan, TTF: 0 [00:09:21.810,882] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:09:31.810,913] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:09:31.810,974] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.13, TTE: nan, TTF: nan [00:09:31.811,004] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:09:41.811,004] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.925, I: -0.020, T: -273.15, [00:09:41.811,065] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.15, TTE: nan, TTF: nan [00:09:41.811,096] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:09:51.811,096] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:09:51.811,157] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.16, TTE: nan, TTF: 0 [00:09:51.811,157] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:10:01.811,187] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:10:01.811,248] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.18, TTE: nan, TTF: nan [00:10:01.811,279] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:10:11.811,279] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:10:11.811,340] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.19, TTE: nan, TTF: 0 [00:10:11.811,340] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:10:21.811,370] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:10:21.811,431] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.21, TTE: nan, TTF: nan [00:10:21.811,462] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:10:31.811,462] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:10:31.811,523] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.22, TTE: nan, TTF: 0 [00:10:31.811,523] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:10:41.811,553] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:10:41.811,614] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.24, TTE: nan, TTF: nan [00:10:41.811,645] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 9, Error: 0 [00:10:51.811,676] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 4.003, I: -0.226, T: -273.15, [00:10:51.811,706] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.24, TTE: nan, TTF: nan [00:10:51.811,737] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:11:01.811,737] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:11:01.811,798] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.42, TTE: nan, TTF: 0 [00:11:01.811,828] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:11:11.811,828] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:11:11.811,859] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.43, TTE: nan, TTF: nan [00:11:11.811,889] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:11:21.811,889] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:11:21.811,950] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.45, TTE: nan, TTF: 0 [00:11:21.811,981] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:11:31.812,011] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:11:31.812,042] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.46, TTE: nan, TTF: nan [00:11:31.812,072] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 9, Error: 0 [00:11:41.812,103] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.999, I: -0.229, T: -273.15, [00:11:41.812,133] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.46, TTE: nan, TTF: nan [00:11:41.812,164] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:11:51.812,194] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:11:51.812,225] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.65, TTE: nan, TTF: 0 [00:11:51.812,255] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:12:01.812,286] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:12:01.812,316] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.66, TTE: nan, TTF: nan [00:12:01.812,347] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:12:11.812,377] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:12:11.812,408] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.67, TTE: nan, TTF: 0 [00:12:11.812,438] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:12:21.812,469] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:12:21.812,530] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.69, TTE: nan, TTF: nan [00:12:21.812,530] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:12:31.812,622] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:12:31.812,683] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.70, TTE: nan, TTF: 11809 [00:12:31.812,683] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:12:41.812,683] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:12:41.812,744] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.72, TTE: nan, TTF: 0 [00:12:41.812,744] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:12:51.812,835] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:12:51.812,866] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.73, TTE: nan, TTF: nan [00:12:51.812,896] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:13:01.812,896] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:13:01.812,957] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.74, TTE: nan, TTF: 15012 [00:13:01.812,988] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:13:11.812,957] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:13:11.813,018] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.76, TTE: nan, TTF: 0 [00:13:11.813,018] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:13:21.813,110] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:13:21.813,140] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.77, TTE: nan, TTF: nan [00:13:21.813,171] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:13:31.813,171] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:13:31.813,232] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.79, TTE: nan, TTF: 17346 [00:13:31.813,262] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:13:41.813,232] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:13:41.813,293] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.80, TTE: nan, TTF: 0 [00:13:41.813,293] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:13:51.813,385] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:13:51.813,415] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.82, TTE: nan, TTF: nan [00:13:51.813,446] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:14:01.813,446] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.920, I: -0.020, T: -273.15, [00:14:01.813,476] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.83, TTE: nan, TTF: 19125 [00:14:01.813,507] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:14:11.813,476] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:14:11.813,537] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.85, TTE: nan, TTF: 0 [00:14:11.813,568] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:14:21.813,629] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:14:21.813,690] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.86, TTE: nan, TTF: nan [00:14:21.813,720] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:14:31.813,720] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:14:31.813,751] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.88, TTE: nan, TTF: 20512 [00:14:31.813,781] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:14:41.813,751] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:14:41.813,812] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.89, TTE: nan, TTF: 0 [00:14:41.813,842] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:14:51.813,873] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:14:51.813,934] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.90, TTE: nan, TTF: nan [00:14:51.813,934] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:15:01.813,995] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.920, I: -0.020, T: -273.15, [00:15:01.814,025] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.92, TTE: nan, TTF: 21632 [00:15:01.814,056] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:15:11.814,086] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.920, I: -0.020, T: -273.15, [00:15:11.814,117] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.93, TTE: nan, TTF: 21936 [00:15:11.814,147] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:15:21.814,117] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:15:21.814,178] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.95, TTE: nan, TTF: 0 [00:15:21.814,208] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:15:31.814,270] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:15:31.814,300] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.96, TTE: nan, TTF: nan [00:15:31.814,331] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:15:41.814,270] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.935, I: 0.000, T: -273.15, [00:15:41.814,331] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.98, TTE: nan, TTF: nan [00:15:41.814,331] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:15:51.814,392] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:15:51.814,453] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.98, TTE: nan, TTF: 0 [00:15:51.814,483] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:16:01.814,514] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.901, I: -0.019, T: -273.15, [00:16:01.814,544] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 52.99, TTE: nan, TTF: nan [00:16:01.814,575] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:16:11.814,575] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.020, T: -273.15, [00:16:11.814,636] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.01, TTE: nan, TTF: nan [00:16:11.814,666] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:16:21.814,666] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:16:21.814,727] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.02, TTE: nan, TTF: nan [00:16:21.814,758] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:16:31.814,758] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:16:31.814,819] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.04, TTE: nan, TTF: 0 [00:16:31.814,819] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:16:41.814,849] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:16:41.814,910] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.05, TTE: nan, TTF: 0 [00:16:41.814,910] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:16:51.814,941] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:16:51.815,002] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.07, TTE: nan, TTF: nan [00:16:51.815,032] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:17:01.815,032] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:17:01.815,063] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.08, TTE: nan, TTF: nan [00:17:01.815,093] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:17:11.815,124] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:17:11.815,155] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.09, TTE: nan, TTF: 0 [00:17:11.815,185] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:17:21.815,216] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:17:21.815,246] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.11, TTE: nan, TTF: 0 [00:17:21.815,277] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:17:31.815,307] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.020, T: -273.15, [00:17:31.815,338] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.12, TTE: nan, TTF: 0 [00:17:31.815,368] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:17:41.815,399] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:17:41.815,429] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.14, TTE: nan, TTF: nan [00:17:41.815,460] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:17:51.815,490] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.920, I: -0.020, T: -273.15, [00:17:51.815,551] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.15, TTE: nan, TTF: nan [00:17:51.815,551] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:18:01.815,582] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:18:01.815,643] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.17, TTE: nan, TTF: nan [00:18:01.815,643] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:18:11.815,673] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:18:11.815,704] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.18, TTE: nan, TTF: 0 [00:18:11.815,734] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:18:21.815,795] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:18:21.815,856] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.20, TTE: nan, TTF: nan [00:18:21.815,856] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:18:31.815,887] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:18:31.815,948] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.21, TTE: nan, TTF: nan [00:18:31.815,948] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:18:41.815,979] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.930, I: -0.019, T: -273.15, [00:18:41.816,009] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.22, TTE: nan, TTF: nan [00:18:41.816,040] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:18:51.816,070] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.920, I: -0.020, T: -273.15, [00:18:51.816,131] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.24, TTE: nan, TTF: nan [00:18:51.816,131] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:19:01.816,162] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:19:01.816,223] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.25, TTE: nan, TTF: nan [00:19:01.816,223] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:19:11.816,253] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.916, I: -0.020, T: -273.15, [00:19:11.816,284] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.27, TTE: nan, TTF: 0 [00:19:11.816,314] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:19:21.816,345] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.906, I: -0.019, T: -273.15, [00:19:21.816,406] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.28, TTE: nan, TTF: nan [00:19:21.816,436] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:19:31.816,436] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.911, I: -0.019, T: -273.15, [00:19:31.816,497] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.30, TTE: nan, TTF: nan [00:19:31.816,528] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 0 [00:19:41.816,528] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.920, I: -0.020, T: -273.15, [00:19:41.816,589] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.31, TTE: nan, TTF: nan [00:19:41.816,589] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 5, Error: 0 [00:19:48.305,938] <dbg> zsw_pmic: event_callback: Event detected [00:19:48.305,969] <err> zsw_pmic: Charging error [00:19:51.816,619] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.920, I: -0.020, T: -273.15, [00:19:51.816,650] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.33, TTE: nan, TTF: 0 [00:19:51.816,680] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:20:01.816,650] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: 0.000, T: -273.15, [00:20:01.816,680] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:20:01.816,711] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:20:11.816,711] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: 0.000, T: -273.15, [00:20:11.816,772] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:20:11.816,772] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:20:21.816,802] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: 0.000, T: -273.15, [00:20:21.816,864] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:20:21.816,864] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:20:31.816,894] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:20:31.816,955] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:20:31.816,955] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:20:41.816,986] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:20:41.817,047] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:20:41.817,047] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:20:51.817,077] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:20:51.817,138] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:20:51.817,138] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:21:01.817,169] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:21:01.817,230] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:21:01.817,230] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:21:11.817,260] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:21:11.817,321] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:21:11.817,352] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:21:21.817,382] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: 0.000, T: -273.15, [00:21:21.817,413] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:21:21.817,443] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:21:31.817,474] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:21:31.817,504] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:21:31.817,535] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:21:41.817,565] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:21:41.817,596] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:21:41.817,626] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:21:51.817,657] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:21:51.817,718] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:21:51.817,718] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:22:01.817,749] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:22:01.817,779] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:22:01.817,810] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:22:11.817,840] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:22:11.817,901] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:22:11.817,901] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:22:21.817,932] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:22:21.817,993] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:22:21.817,993] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:22:31.818,023] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:22:31.818,084] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:22:31.818,084] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:22:41.823,272] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:22:41.823,303] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:22:41.823,333] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:22:51.823,364] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.891, I: 0.000, T: -273.15, [00:22:51.823,394] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:22:51.823,425] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64 [00:23:01.823,455] <dbg> zsw_pmic: zsw_pmic_get_full_state: V: 3.896, I: 0.000, T: -273.15, [00:23:01.823,486] <dbg> zsw_pmic: zsw_pmic_get_full_state: SoC: 53.34, TTE: nan, TTF: nan [00:23:01.823,516] <dbg> zsw_pmic: zsw_pmic_get_full_state: Status: 0, Error: 64
Overlay:
Using nRF Connect 2.6 and MCU nRF5340
