nRF52840 dk does not advertise
Hello, I am going through the Bluetooth Low Energy Fundamentals provided by Nordic.
My nrf 52840 dk could function fine after lesson1, but when I flash my board with the lesson 2 exercise 1 solution, the board does not advertise. Here is the link to the lesson I am referring to.
https://academy.nordicsemi.com/courses/bluetooth-low-energy-fundamentals/lessons/lesson-2-bluetooth-le-advertising/topic/blefund-lesson-2-exercise-1/
I am new to this chip, so I would appreciate it if you would help me out on this.
  • It worked. I was missing that, thanks for pointing it out.
    I have one more question. I have a custom PCB with nrf52840 chip. I want to program it with the nrf52840 dk but not sure how I can do it in VS code. I know I have to make 4 connections ( VCC, GND, SWDIO, and SWDCLK), but other than that not sure how to configure the code to flash the custom PCB.
    Most forums I have seen have used an IDE different from VS code.
    Could you please guide me on how to do it?
    Sincerely,
    MR
  • Hi
    Glad to hear it worked.
    No problem, just follow the instruction from here and then select the DK as target for your application and flash it. It's same if you use VScode or nrfjprog
    Regards
    Runar
  • Thanks for the reply,
    I have a few questions about the info on the provided link.
    1. If I understand correctly, If I short the SB47 bridge, I can use pin 1 to power my external board, but if I do not short the bridge then I need to connect the VCC on my board to pin 1 to detect the external board and target that instead of the onboard SoC right?
    2. Does SH_VTG mean it is the pin that enables the interface MCU to detect the VCC on my external board and target that instead of the onboard SoC on the DK?
    3. I prefer using P20 to program the external board because I do not have a 10-pin connector. However, the default connector used to program the external board is P19, do you know how can I change it so that P20 is used to program the external board?
    4. If I want to use P20 to program the external board, then I need to connect  SH_VTG, SH_SWDIO, SH_SWDCLK, and SH_GND_DETECTon the DK to VCC, SWDIO, SWCLK, and GND on my external board, respectively right?
    5. It said that the VDD  is 3 V on the DK, on my board VCC is 3.3 V this mismatch won't cause that much of a problem, right?
  • Hi
    1. Correct.
    2-4. Please see this image for how you should connect a custom board to your DK to program it:
    5. It should most likely be okay, but we can't 100% guarantee that the flashing procedure will be done correctly if the voltages don't match.
    Simon
  • Thank you for your help
    I just had three quick questions, and I would appreciate it if you could answer them.
    1.VDD in P20 is to power up the external board?
    2. So far I have been programming the DK and to flash the external board I don’t need to make any software configuration changes in VS code right?
    3. If no additional software configurations are needed to program the external board, then which device tree would be referenced? I guess the SoC device tree, right?
