Segger Studio update 7.22 to 8.14 causes exit error 0x1
FormerMember
FormerMember
I have updated finally Segger Studio from version 7.22 to 8.14. Now I cannot compile the project. It ends with below error:
Build failed, exit status 0x1
Is something needed to make it working?
  • FormerMember
    0 FormerMember
    And also echo build command line:
    "/Applications/SEGGER/SEGGER Embedded Studio 8.14a/bin/emBuild" "/Applications/SEGGER/SEGGER Embedded Studio 8.14a/source/arm_segger_studio_auto.emProject" -config "V7EM FPv4-SP-D16 THUMB LE Hard Balanced WCHAR32 EnumMinSize Release" -project all -lock "/Applications/SEGGER/SEGGER Embedded Studio 8.14a/lib/V7EM FPv4-SP-D16 THUMB LE Hard Balanced WCHAR32 EnumMinSize Release build.lck"
  • Hi
    We advice against using newer versions of SEGGER Embedded Studio than what the SDK version you're using have been tested with. nRF5 SDK v17.1.0 was production tested with SES v5.42a, and is the one I would recommend that you use. Some newer versions should be fine as well, but the very latest versions (I don't remember the exact version number) have proved to have some issues, so if your v7.22 works as expected I would recommend using that one on your end, or roll back to v5.42a.
    Simon
