Build environment is the nRF SDK Connect for VS Code extension with ncs 2.3.0.
I am trying to accomplish DFU over UART with mcumgr serial console in which primary slot will in internal flash of the development kit and secondary slot is in external flash MX66L1G. I am using static configuration for partition region using partition manager. The sample on which I am working is ncs\v2.3.0\zephyr\samples\subsys\mgmt\mcumgr\smp_svr
Here is my pm_static.yml file and prj.conf
EMPTY_0: address: 0xf000 end_address: 0x11000 placement: before: - mcuboot_pad region: flash_primary size: 0x2000 app: address: 0x11200 end_address: 0x101000 region: flash_primary size: 0xefe00 mcuboot: address: 0x0 end_address: 0xf000 placement: before: - mcuboot_primary region: flash_primary size: 0xf000 mcuboot_pad: address: 0x11000 end_address: 0x11200 placement: align: start: 0x8000 before: - mcuboot_primary_app region: flash_primary size: 0x200 mcuboot_primary_app: address: 0x11200 end_address: 0x101000 orig_span: &id002 - app region: flash_primary size: 0xefe00 span: *id002 mcuboot_primary: address: 0x11000 end_address: 0x101000 orig_span: &id001 - app - mcuboot_pad region: flash_primary size: 0xf0000 span: *id001 mcuboot_secondary: address: 0x0 device: DT_CHOSEN(nordic_pm_ext_flash) end_address: 0xf0000 region: external_flash share_size: - mcuboot_primary size: 0xf0000 mcuboot_secondary_app: address: 0x0 end_address: 0xefe00 orig_span: &id003 - app region: external_flash size: 0xefe00 span: *id003 EMPTY_1: address: 0xf0000 end_address: 0x8000000 region: external_flash size: 0x7f10000 sram_primary: address: 0x20000000 end_address: 0x20020000 region: sram_primary size: 0x20000
# Enable the shell mcumgr transport. CONFIG_SHELL=y CONFIG_SHELL_BACKEND_SERIAL=y CONFIG_MCUMGR_SMP_SHELL=y # mcumgr-cli application doesn't accepts log in the channel it uses CONFIG_SHELL_LOG_BACKEND=n # Enable shell commands. CONFIG_MCUMGR_CMD_SHELL_MGMT=y #Enable MCUboot CONFIG_BOOTLOADER_MCUBOOT=y # Enable mcumgr. CONFIG_MCUMGR=y #Enable flash operations. CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_FPROTECT=y # Enable most core commands. CONFIG_MCUMGR_CMD_IMG_MGMT=y # Enable logging CONFIG_LOG=y CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG=y # Disable debug logging CONFIG_LOG_MAX_LEVEL=4 # DRivers enabled CONFIG_SPI=y #Place MCUboot secondary in external flash CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y CONFIG_NORDIC_QSPI_NOR=y # Ensure an MCUboot-compatible binary is generated. CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_SERIAL=y CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y
I have also created mcuboot.conf and mcuboot.overlay
/* Step 3.5 - Configure button and LED for Serial Recovery */ /{ aliases { mcuboot-button0 = &button1; mcuboot-led0 = &led1; }; };
These are the errors which I am facing while flashing the mcuboot
I am taking reference for DFU over UART from this link of Dev Academy Exercise 1 - DFU over UART - Nordic Developer Academy (nordicsemi.com)
Overlay file for the hardware nrf5340dk_nrf5340dk_cpuapp.overlay
Please help me figure out what is missing in this whole configuration and why am I getting these errors and warnings.
