I am working on nrf52832 based custom board which is configured to work as BLE peripheral and central. Peripherals like GPIO, SAADC, I2C, Timer and RTC are also configured. The RTC is configured to generate interrupt on a specific time interval. On that interrupt value of few sensors are read which is interfaced via SAADC and I2C. Rest of the time the device will go to system ON sleep to reduce power consumption. A GPIO based sensor is also configured to generate interrupt in both sleep and awake states. So when an RTC interrupt is occurred, SAADC, I2C and Timer peripherals are initialized and read the sensor values. Then the peripherals are de initialized and goes to sleep. I have checked the current consumption in sleep state using nRF power profiler and is about 700 micro Amps. But it's too high. I want to reduce this to below 100 micro Amps. Is it possible?
In sleep mode only GPIO and RTC are initialized and al other peripherals are de initialized. I am attaching my main code here.
/* Includes */
/* Standard includes*/
#include <stdint.h>
#include <stdio.h>
#include <string.h>
/* SDK includes */
#include "boards.h"
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "ble.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_conn_state.h"
#include "nrf_fstorage.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_hci.h"
#include "ble_lbs_c.h"
#include "ble_lbs.h"
#include "nrf_drv_timer.h"
#include "nrf_delay.h"
#include "nrf_drv_rtc.h"
#include "nrf_drv_clock.h"
#include "nrf_drv_gpiote.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_twi.h"
/* Macro Definitions */
#define DEVICE_NAME "TEST" /**< Name of device used for advertising. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms). This value corresponds to 187.5 ms. */
#define APP_ADV_DURATION BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED /**< The advertising duration set to 0 (Unlimited advertizing) */
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that identifies the SoftDevice BLE configuration. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Priority of the application BLE event handler. */
#define DB_DISCOVERY_INSTANCE_CNT 2 /**< Number of DB Discovery instances. */
#define TWI_INSTANCE_ID 1
#define BUTTON 06
#define LED_BLUE 11
#define LED_RED 0x08
#define MPU6050_SCL 19
#define MPU6050_SDA 17
#define BAT_VOLT NRF_SAADC_INPUT_AIN7
#define COMPARE_COUNTERTIME (15UL)
/* Define objects */
NRF_BLE_GQ_DEF(m_ble_gatt_queue, NRF_SDH_BLE_CENTRAL_LINK_COUNT, NRF_BLE_GQ_QUEUE_SIZE);/**< BLE GATT Queue instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWRS_DEF(m_qwr, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning module instance. */
BLE_LBS_C_DEF(m_ble_lbs_c); /**< Main structure used by the LBS client module. */
BLE_LBS_DEF(m_lbs); /**< LED Button Service instance. */
/* Define Variables */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded scan data. */
static const nrf_drv_twi_t i2c_master = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID); /* Declare I2C instance */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = m_enc_scan_response_data,
/**@brief Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t m_scan_param =
.active = 0x01,
.interval = NRF_BLE_SCAN_SCAN_INTERVAL,
.window = NRF_BLE_SCAN_SCAN_WINDOW,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
.timeout = NRF_BLE_SCAN_SCAN_DURATION,
.scan_phys = BLE_GAP_PHY_1MBPS,
.extended = true,
uint8_t target_dev_addr[6]; /**< Array to store target device address (Reversed) */
uint8_t conn_handle_periph; /**< Handle of the current connection from BLE central. */
uint8_t conn_handle_centra; /**< Handle of the current connection from BLE peripheral. */
uint8_t read_sensor_flag;
/**< Get Compare event COMPARE_TIME seconds after the counter starts from 0. */
const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(2); /**< Declaring an instance of nrf_drv_rtc for RTC0. */
/* Built-in Function definitions */
/**@brief Function for handling asserts in the SoftDevice.
* @details This function is called in case of an assert in the SoftDevice.
* @warning This handler is an example only and is not meant for the final product. You need to analyze
* how your product is supposed to react in case of assert.
* @param[in] line_num Line number of the failing assert call.
* @param[in] p_file_name File name of the failing assert call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the LED Button Service client errors.
* @param[in] nrf_error Error code containing information about what went wrong.
static void lbs_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the Heart Rate Service Client
* Running Speed and Cadence Service Client.
static void service_error_handler(uint32_t nrf_error)
/**@brief Function for handling errors from the Connection Parameters module.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
ret_code_t err_code;
ble_gap_evt_adv_report_t const * p_adv = p_scan_evt->params.filter_match.p_adv_report;
ble_gap_scan_params_t const * p_scan_param = p_scan_evt->p_scan_params;
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_FILTER_MATCH: // Found peripheral with mac id mathing with target_dev_addr
// Initiate connection.
err_code = sd_ble_gap_connect(&p_adv->peer_addr,
p_scan_param,
&m_scan.conn_params,
APP_BLE_CONN_CFG_TAG);
} break;
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
/**@brief Handles events coming from the LED Button service central module.
Data coming from connecetd peripheral device to this central device
static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
switch (p_lbs_c_evt->evt_type)
case BLE_LBS_C_EVT_DISCOVERY_COMPLETE: // lbs service discovered on connected peripheral
err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c,
p_lbs_c_evt->conn_handle,
&p_lbs_c_evt->params.peer_db);
// LED Button service discovered. Enable notification of Button.
err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
} break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
case BLE_LBS_C_EVT_BUTTON_NOTIFICATION: // Data received from connected peripheral
} break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
// No implementation needed.
/**@brief Function for initialization the scanning and setting the filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = false;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_ADDR_FILTER, false);
if (target_dev_addr[0] != 0)
err_code = nrf_ble_scan_all_filter_remove(&m_scan);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, target_dev_addr);
/**@brief Function for assigning new connection handle to available instance of QWR module.
* @param[in] conn_handle New connection handle.
static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
for (uint32_t i = 0; i < NRF_SDH_BLE_TOTAL_LINK_COUNT; i++)
if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID)
ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], conn_handle);
/**@brief Function for initializing the scanning.
static void scan_start(void)
if (!nrf_fstorage_is_busy(NULL))
err_code = nrf_ble_scan_start(&m_scan);
/**@brief Function for initializing the advertising.
static void advertize_start(void)
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
/**@brief Function for stopping the scanning.
void scan_stop(void)
nrf_ble_scan_stop();
/**@brief Function for stopping the advertising.
void advertize_stop(void)
err_code = sd_ble_gap_adv_stop(m_adv_handle);
/**@brief Function for handling BLE events from the central application.
* @details This function parses scanning reports and initiates a connection to peripherals when a
* target UUID is found. It updates the status of LEDs used to report the central application
* activity.
* @param[in] p_ble_evt Bluetooth stack event.
static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
// For readability.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
// Upon connection, check which peripheral has connected (HR or RSC), initiate DB
// discovery, update LEDs status and resume scanning if necessary. */
case BLE_GAP_EVT_CONNECTED:
err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
conn_handle_centra = p_gap_evt->conn_handle;
err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
} break;
// Upon disconnection, reset the connection handle of the peer which disconnected, update
// the LEDs status and start scanning again.
scan_start();
} break;
case BLE_GAP_EVT_TIMEOUT:
// We have not specified a timeout for scanning, so only connection attemps can timeout.
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accept parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
} break;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
} break;
case BLE_GATTS_EVT_TIMEOUT:
} break;
/**@brief Function for handling BLE events from peripheral applications.
* @details Updates the status LEDs used to report the activity of the peripheral applications.
static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
// Assign connection handle to the QWR module.
multi_qwr_conn_handle_assign(p_ble_evt->evt.gap_evt.conn_handle);
conn_handle_periph = p_ble_evt->evt.gap_evt.conn_handle;
advertize_start();
} break;
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
} break;
case BLE_ADV_EVT_IDLE:
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
} break;
/**@brief Function for checking whether a bluetooth stack event is an advertising timeout.
static bool ble_evt_is_advertising_timeout(ble_evt_t const * p_ble_evt)
return (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_SET_TERMINATED);
* @param[in] p_context Unused.
uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
uint16_t role = ble_conn_state_role(conn_handle);
// Based on the role this device plays in the connection, dispatch to the right handler.
if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt))
on_ble_peripheral_evt(p_ble_evt);
else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
on_ble_central_evt(p_ble_evt);
/**@brief LED Button client initialization.
static void lbs_c_init(void)
ble_lbs_c_init_t lbs_c_init_obj;
lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
lbs_c_init_obj.p_gatt_queue = &m_ble_gatt_queue;
lbs_c_init_obj.error_handler = lbs_error_handler;
err_code = ble_lbs_c_init(&m_ble_lbs_c, &lbs_c_init_obj);
* @details Initializes the SoftDevice and the BLE event interrupts.
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for initializing the GAP.
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device, including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.min_conn_interval = m_scan.conn_params.min_conn_interval;
gap_conn_params.max_conn_interval = m_scan.conn_params.max_conn_interval;
gap_conn_params.slave_latency = m_scan.conn_params.slave_latency;
gap_conn_params.conn_sup_timeout = m_scan.conn_params.conn_sup_timeout;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_CONN_HANDLE_INVALID; // Start upon connection.
cp_init.disconnect_on_fail = true;
cp_init.evt_handler = NULL; // Ignore events.
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for handling database discovery events.
* @details This function is a callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function forwards the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_db_discovery_t const * p_db = (ble_db_discovery_t *)p_evt->params.p_db_instance;
ble_lbs_on_db_disc_evt(&m_ble_lbs_c, p_evt);
if (p_evt->evt_type == BLE_DB_DISCOVERY_AVAILABLE) {
* @brief Database discovery initialization.
static void db_discovery_init(void)
ble_db_discovery_init_t db_init;
memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
db_init.evt_handler = db_disc_handler;
db_init.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_db_discovery_init(&db_init);
/**@brief Function for handling Queued Write module errors.
* @details A pointer to this function is passed to each service that may need to inform the
* application about an error.
* @param[in] nrf_error Error code that contains information about what went wrong.
/**@brief Function for handling write events to the LED characteristic.
Data coming from connecetd Central device to this peripheral device
* @param[in] p_lbs Instance of LED Button Service to which the write applies.
* @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
/**@brief Function for initializing services that are be used by the application.
* @details Initialize the Heart Rate, Battery and Device Information services.
ble_lbs_init_t init;
// Initialize Queued Write Module instances.
err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init);
// Initialize LBS.
init.led_write_handler = led_write_handler;
err_code = ble_lbs_init(&m_lbs, &init);
ble_conn_state_init();
/**@brief Function for initializing the advertising functionality.
ble_advdata_t advdata;
ble_advdata_t srdata;
ble_gap_adv_params_t adv_params;
ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = true;
advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
memset(&srdata, 0, sizeof(srdata));
srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
srdata.uuids_complete.p_uuids = adv_uuids;
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
// Start advertising.
memset(&adv_params, 0, sizeof(adv_params));
adv_params.p_peer_addr = NULL;
adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
adv_params.interval = APP_ADV_INTERVAL;
adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
adv_params.duration = APP_ADV_DURATION;
adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
/**@brief Function for initializing logging.
static void log_init(void)
/**@brief Function for handling the idle state (main loop). If there is no pending log operation,
then sleeps until the next event occurs.
nrf_pwr_mgmt_run();
/**@brief Function for initializing the timer.
static void timer_init(void)
/* User defined Static Function definitions */
/** @brief: Function for handling the RTC0 interrupts.
* Triggered on TICK and COMPARE0 match.
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
if (int_type == NRF_DRV_RTC_INT_COMPARE0)
read_sensor_flag = 1;
// Reset compare value for the next interrupt
uint32_t cc_value = nrf_drv_rtc_counter_get(&rtc) + (COMPARE_COUNTERTIME * 8);
nrf_drv_rtc_cc_set(&rtc, 0, cc_value, true);
else if (int_type == NRF_DRV_RTC_INT_TICK)
/** @brief Function initialization and configuration of RTC driver instance.
static void rtc_config(void)
uint32_t err_code;
//Initialize RTC instance
nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
config.prescaler = 4095;
err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
//Enable tick event & interrupt
// nrf_drv_rtc_tick_enable(&rtc,true);
//Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true);
//Power on RTC instance
nrf_drv_rtc_enable(&rtc);
/** @brief Function de-initialization of RTC driver instance.
static void rtc_de_init(void)
nrf_drv_rtc_disable(&rtc);
nrf_drv_rtc_uninit(&rtc);
*@brief function to initialize I2C peripheral in 100khz or 400khz
void I2C_init()
ret_code_t ret;
const nrf_drv_twi_config_t config =
.scl = MPU6050_SCL,
.sda = MPU6050_SDA,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
ret = nrf_drv_twi_init(&i2c_master, &config, NULL, NULL);
if (NRF_SUCCESS == ret)
nrf_drv_twi_enable(&i2c_master);
*@brief function to enable I2C peripheral
void I2C_enable()
*@brief function to disable I2C peripheral
void I2C_disable()
nrf_drv_twi_disable(&i2c_master);
void I2C_uninit()
nrf_drv_twi_uninit(&i2c_master);
* @brief Advertize button handler
static void button_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
static void button_init(void)
nrf_drv_gpiote_init();
nrf_drv_gpiote_in_config_t button_config = GPIOTE_RAW_CONFIG_IN_SENSE_HITOLO(true);
button_config.pull = NRF_GPIO_PIN_NOPULL;
nrf_drv_gpiote_in_init(BUTTON, &button_config, button_handler);
nrf_drv_gpiote_in_event_enable(BUTTON, true);
nrf_gpio_cfg_sense_input(BUTTON, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_NOSENSE);
static void led_init(void)
nrf_drv_gpiote_out_config_t ble_led_pin_config = GPIOTE_CONFIG_OUT_SIMPLE(true);
ble_led_pin_config.init_state = NRF_GPIOTE_INITIAL_VALUE_HIGH;
nrf_drv_gpiote_out_init(LED_BLUE, &ble_led_pin_config);
nrf_drv_gpiote_out_init(LED_RED, &ble_led_pin_config);
nrf_drv_gpiote_out_set(LED_RED);
nrf_drv_gpiote_out_set(LED_BLUE);
static void batVolt_saadc_config(void){
nrfx_saadc_config_t batVolt_config = NRFX_SAADC_DEFAULT_CONFIG;
nrf_saadc_channel_config_t batVotl_ch_config ={
.resistor_p = NRF_SAADC_RESISTOR_DISABLED,
.resistor_n = NRF_SAADC_RESISTOR_DISABLED,
.gain = NRF_SAADC_GAIN1_4,
.reference = NRF_SAADC_REFERENCE_VDD4,
.acq_time = NRF_SAADC_ACQTIME_10US,
.mode = NRF_SAADC_MODE_SINGLE_ENDED,
.burst = NRF_SAADC_BURST_DISABLED,
.pin_p = (nrf_saadc_input_t)(BAT_VOLT),
.pin_n = NRF_SAADC_INPUT_DISABLED
nrf_drv_saadc_init(&batVolt_config,NULL);
nrf_drv_saadc_channel_init(7,&batVotl_ch_config);
static void batVolt_saadc_de_config(void)
nrf_drv_saadc_channel_uninit(7);
nrf_drv_saadc_uninit();
static void led_de_init(void)
nrfx_gpiote_out_task_disable(LED_BLUE);
nrf_drv_gpiote_out_uninit(LED_BLUE);
nrfx_gpiote_out_task_disable(LED_RED);
nrf_drv_gpiote_out_uninit(LED_RED);
/**@brief Function for initializing the application main entry.
// Initialize.
SystemInit();
timer_init();
rtc_config();
power_management_init();
ble_stack_init();
scan_init();
gap_params_init();
gatt_init();
db_discovery_init();
services_init();
advertising_init();
lbs_c_init();
button_init();
// Enter main loop.
for (;;)
idle_state_handle();
if(read_sensor_flag == 0) {
sd_app_evt_wait();
else if(read_sensor_flag == 1) {
led_init();
batVolt_saadc_config();
I2C_init();
Reading Sensor Values
led_de_init();
batVolt_saadc_de_config();
I2C_disable();
I2C_uninit();
read_sensor_flag = 0;
sd_app_evt_wait();
Thanks
Sachin
