Problem with Multirole + NUS
I am currently using nrf52840, nRF5_SDK_17.1.0_ddde560, and the ble_app_multirole_lesc example file.
I have successfully removed the HRS and button Bluetooth connections from the example file.
However, I encountered errors when adding NUS to the program.
Below are the programs I have added or modified, as well as the error information.
#include "ble_nus.h"
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_PERIPHERAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_QWR_DEF(m_qwr);                      /**< Context for the Queued Write module.*/
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
uint8_t data_buffer[242];
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    uint32_t err_code;
static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
        if (m_qwr.conn_handle == BLE_CONN_HANDLE_INVALID)
            ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, conn_handle);
static void on_ble_evt(uint16_t conn_handle, ble_evt_t const * p_ble_evt)
    char        passkey[BLE_GAP_PASSKEY_LEN + 1];
    uint16_t    role = ble_conn_state_role(conn_handle);
		ret_code_t err_code;
    pm_handler_secure_on_connection(p_ble_evt);
        case BLE_GAP_EVT_CONNECTED:
            m_connected_peers[conn_handle].is_connected = true;
            m_connected_peers[conn_handle].address = p_ble_evt->evt.gap_evt.params.connected.peer_addr;
//            multi_qwr_conn_handle_assign(conn_handle);
            memset(&m_connected_peers[conn_handle], 0x00, sizeof(m_connected_peers[0]));
            NRF_LOG_INFO("%s: BLE_GAP_EVT_SEC_PARAMS_REQUEST", nrf_log_push(roles_str[role]));
						// Pairing not supported
        case BLE_GAP_EVT_PASSKEY_DISPLAY:
            memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, BLE_GAP_PASSKEY_LEN);
            passkey[BLE_GAP_PASSKEY_LEN] = 0x00;
            NRF_LOG_INFO("%s: BLE_GAP_EVT_PASSKEY_DISPLAY: passkey=%s match_req=%d",
                         nrf_log_push(roles_str[role]),
                         nrf_log_push(passkey),
                         p_ble_evt->evt.gap_evt.params.passkey_display.match_request);
            if (p_ble_evt->evt.gap_evt.params.passkey_display.match_request)
                on_match_request(conn_handle, role);
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
            NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_KEY_REQUEST", nrf_log_push(roles_str[role]));
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            NRF_LOG_INFO("%s: BLE_GAP_EVT_LESC_DHKEY_REQUEST", nrf_log_push(roles_str[role]));
         case BLE_GAP_EVT_AUTH_STATUS:
             NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
            ret_code_t err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys);
        } break;
            // No implementation needed.
static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
            NRF_LOG_INFO("PERIPHERAL: Connected, handle %d.", p_ble_evt->evt.gap_evt.conn_handle);
//            bsp_board_led_off(PERIPHERAL_ADVERTISING_LED);
//            bsp_board_led_on(PERIPHERAL_CONNECTED_LED);
            NRF_LOG_INFO("PERIPHERAL: Disconnected, handle %d, reason 0x%x.",
                         p_ble_evt->evt.gap_evt.params.disconnected.reason);
        case BLE_GATTC_EVT_TIMEOUT:
            NRF_LOG_DEBUG("PERIPHERAL: GATT Client Timeout.");
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_DEBUG("PERIPHERAL: GATT Server Timeout.");
static void bsp_event_handler(bsp_event_t event)
    switch (event)
			case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
	err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
services_init();
for (;;)
				data_buffer[0] =  0x0A;
				data_buffer[1] =  0x0B;
				data_buffer[2] =  0x0C;
				uint16_t length = 242;
                uint32_t err_code = ble_nus_data_send(&m_nus, (uint8_t *)data_buffer, &length, m_conn_handle);
				APP_ERROR_CHECK(err_code); // ..\..\..\main.c:1407
				idle_state_handle();
Error:
<error> app: ERROR 5 [NRF_ERROR_NOT_FOUND] at ..\..\..\main.c:1407
PC at: 0x000332C1
<error> app: End of error report
