nRF5340 audio application ZEPHYR FATAL ERROR in NCS v2.7.0
I'm using nRF5340 audio application with nRF Connect SDK v2.7.0 on nrf5340 Audio DK.
I didn't change anything in the sample code but only modifying the NRF5340_AUDIO_TRANSPORT_MODE to change it to bis headset.
When I burned the code, the error always occurred.
Here is the error log.
*** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
HL [00:00:00.267,181] <inf> board_version: Compatible board/HW version found: 1.0.0
HL [00:00:00.291,992] <inf> fw_info:
	 nRHL [00:00:00.292,022] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.292,022] <inf> fw_info: HEADSET left device
HL [00:00:00.319,580] <wrn> bt_hci_core: opcode 0x203a status 0x01
HL [00:00:00.319,580] <wrn> bt_hci_core: Controller does not support 'LE_READ_MAX_ADV_DATA_LEN'. Assuming maximum length is 31 bytes.
HL [00:00:00.356,719] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 5.4 (0x0d), Revision 8699
HL [00:00:00.356,903] <inf> bt_mgmt: Local identity addr: FE:F4:EA:7D:D7:B9 (random)
HL [00:00:00.386,047] <wrn> bt_hci_core: opcode 0x2041 status 0x01
HL [00:00:00.386,077] <err> main: Failed to start scanning
HL [00:00:00.386,077] <err> main: ERR_CHK Err_code: [-5] @ line: 481
HL [00:00:00.386,077] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000009  r2/a3:  0x00000008
HL [00:00:00.386,108] <err> os: r3/a4:  0x00000003 r12/ip:  0x20002848 r14/lr:  0x000530ad
HL [00:00:00.386,108] <err> os:  xpsr:  0x09100000
HL [00:00:00.386,108] <err> os: s[ 0]:  0x20001048  s[ 1]:  0x00053281  s[ 2]:  0x2001c828  s[ 3]:  0x00000004
HL [00:00:00.386,138] <err> os: s[ 4]:  0x2001c830  s[ 5]:  0xfffffffb  s[ 6]:  0x2001c828  s[ 7]:  0x2001c858
HL [00:00:00.386,138] <err> os: s[ 8]:  0x2001c830  s[ 9]:  0xffffffff  s[10]:  0xffffffff  s[11]:  0x000532c5
HL [00:00:00.386,138] <err> os: s[12]:  0x20004570  s[13]:  0x00063240  s[14]:  0xfffffffb  s[15]:  0x000001e1
HL [00:00:00.386,138] <err> os: fpscr:  0x01000003
HL [00:00:00.386,138] <err> os: Faulting instruction address (r15/pc): 0x00003dc8
HL [00:00:00.386,169] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
HL [00:00:00.386,199] <err> os: Current thread: 0x20004570 (main)
HL [00:00:00.386,199] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
I have not encountered this problem when using either NCS v2.6.0 or NCS v2.2.0.
Is there anything else I need to modify in NCS v2.7.0?
