Running nrfutil 91 modem-firmware-upgrade on Raspberry Pi,
I want to run nrfutil 91 modem-firmware-upgrade --firmware "$FIRMWARE_PATH_1" --serial-number "$SERIAL_NUMBER" on Raspberry Pi,
unfortunately. The version that can be installed is only 5.2.0
So the commands are different. From the version 7.12 command set
I searched the ןמאקרמקא and came across the following set of commands:
nrfutil dfu serial -pkg $FIRMWARE_PATH_1 --serial-number $SERIAL_NUMBER
I found the serial number with the help of the command
nrfjprog -i
801013667
But the response for my commands
nrfutil dfu serial -pkg mfw_nrf91x1_2.0.1.zip -snr 801013667
I get:
File "/home/user/Projects/Data/nrfVevv/bin/nrfutil", line 8, in <module>
sys.exit(cli())
File "/home/user/Projects/Data/nrfVevv/lib/python3.11/site-packages/click/core.py", line 829, in __call__
return self.main(*args, **kwargs)
File "/home/user/Projects/Data/nrfVevv/lib/python3.11/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/home/user/Projects/Data/nrfVevv/lib/python3.11/site-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/user/Projects/Data/nrfVevv/lib/python3.11/site-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/user/Projects/Data/nrfVevv/lib/python3.11/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/home/user/Projects/Data/nrfVevv/lib/python3.11/site-packages/nordicsemi/__main__.py", line 1041, in serial
do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, serial_number, True,
File "/home/user/Projects/Data/nrfVevv/lib/python3.11/site-packages/nordicsemi/__main__.py", line 938, in do_serial
raise NordicSemiException("A device with serial number %s is not connected." % serial_number)
pc_ble_driver_py.exceptions.NordicSemiException: A device with serial number 801013667 is not connected.
I would appreciate help on how to complete the task.
Thank you very much
