FLASH overflow issue + nrf5340 + DFU external flash
Working with the NRF5340-nrf7002 and the W25Q16RV flash memory in our project.
  • Initially, I configured an 8MB(W25Q64RV) external flash without issues and tested DFU-FOTA which is working as expected. However, after switching to the 2MB W25Q16RV flash, I’ve encountered a flash memory overflow.
  • When configuring the project to use the 2MB W25Q16RV flash, the linker reports a FLASH region overflowed by 736 bytes:
Here I share build i suspect
CMake Warning at C:/ncs/v2.6.1/nrf/modules/mcuboot/CMakeLists.txt:382 (message):
          --- WARNING: Using default MCUBoot key, it should not ---
          --- be used for production.                           ---
      CMake Warning at C:/ncs/v2.6.1/nrf/cmake/partition_manager.cmake:79 (message):
          --- WARNING: Using a bootloader without pm_static.yml.            ---
          --- There are cases where a deployed product can consist of       ---
          --- multiple images, and only a subset of these images can be     ---
          --- upgraded through a firmware update mechanism. In such cases,  ---
          --- the upgradable images must have partitions that are static    ---
          --- and are matching the partition map used by the bootloader     ---
          --- programmed onto the device.                                   ---
  C:/ncs/v2.6.1/zephyr/cmake/modules/kernel.cmake:248 (include)
  C:/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
  C:/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  C:/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:9 (find_package)
Dropping partition 'nvs_storage' since its size is 0.
Dropping partition 'nonsecure_storage' since it is empty.
CMake Warning at C:/ncs/v2.6.1/nrf/cmake/partition_manager.cmake:601 (message):
  Could not find memory mapped address for XIP.  Generated update hex files
  will not have the correct base address.  Hence they can not be programmed
  directly to the external flash
c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 736 bytes
  • The project works fine with an 8MB flash, but not with the 2MB flash, even though the external flash is only used for FOTA image downloads.
  • I need guidance on whether this overflow issue is due to the flash configuration or another underlying cause.
  • Could you please provide insights on the correct configuration for the W25Q16RV flash to resolve the overflow issue?
  • Any recommendations or adjustments to ensure the 2MB flash works without overflow.
  • Hi Amanda,
    Are you using the static partition?
    No, I'm not using the static partition. The partiton.yml which I have attached is automatically generated partition only.
    Here I share the conf and overlay files.
    board/nrf7002dk_nrf5340_cpuapp_ns.conf
    # General
    CONFIG_POSIX_CLOCK=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_LOG_BUFFER_SIZE=3072
    CONFIG_HEAP_MEM_POOL_SIZE=81920
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_LOG=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_HW_ID_LIBRARY_SOURCE_NET_MAC=y
    # Optimize Wi-Fi stack to save some memory
    CONFIG_NRF700X_RX_NUM_BUFS=16
    CONFIG_NRF700X_MAX_TX_AGGREGATION=4
    # Zephyr NET Connection Manager connectivity layer.
    CONFIG_L2_WIFI_CONNECTIVITY=y
    CONFIG_L2_WIFI_CONNECTIVITY_AUTO_DOWN=n
    CONFIG_L2_WIFI_CONNECTIVITY_AUTO_CONNECT=n
    # Wi-Fi
    CONFIG_WIFI=y
    CONFIG_WIFI_NRF700X=y
    CONFIG_WIFI_NRF700X_LOG_LEVEL_ERR=y
    CONFIG_WIFI_MGMT_EXT=y
    CONFIG_WIFI_CREDENTIALS=y
    # Shell
    CONFIG_SHELL=y
    CONFIG_SHELL_STACK_SIZE=6144
    # WPA
    CONFIG_WPA_SUPP=y
    CONFIG_WPA_SUPP_LOG_LEVEL_ERR=y
    # NET sockets
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_NET_TCP_WORKQ_STACK_SIZE=2048
    CONFIG_NET_UDP=y
    CONFIG_NET_DHCPV4=y
    CONFIG_NET_DHCPV6=y
    CONFIG_NET_CONTEXT_SNDTIMEO=y
    CONFIG_NET_CONTEXT_RCVTIMEO=y
    CONFIG_NET_TCP=y
    CONFIG_NET_NATIVE=y
    CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
    # DNS
    CONFIG_DNS_RESOLVER=y
    CONFIG_NET_SOCKETS_DNS_TIMEOUT=30000
    # TLS
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS=y
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_HEAP_SIZE=81920
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
    CONFIG_TLS_CREDENTIALS_BACKEND_PROTECTED_STORAGE=y
    # Optimize TF-M
    CONFIG_TFM_PROFILE_TYPE_SMALL=y
    CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0xc000
    CONFIG_PM_PARTITION_SIZE_TFM=0x1fe00
    # CONFIG_PM_PARTITION_SIZE_TFM=0x20000
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    # Serial Peripheral Interface (SPI)
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    # CONFIG_SPI_NOR_SFDP_DEVICETREE=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # Bootloader and FOTA related configurations
    # MCUBOOT
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    # Image manager
    CONFIG_IMG_MANAGER=y
    CONFIG_STREAM_FLASH=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # Download client (needed by AWS FOTA)
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_4096=y
    proj.conf
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_CONNECTION_MANAGER=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_IPV6=y
    # CONFIG_HEAP_MEM_POOL_SIZE=1024
    CONFIG_FW_INFO=y
    # FOTA library
    CONFIG_FOTA_DOWNLOAD=y
    # Application Upgrade support
    # DFU Target
    CONFIG_DFU_TARGET=y
    # HTTP
    CONFIG_HTTP_PARSER=y
    CONFIG_HTTP_PARSER_URL=y
    # Image manager
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    # Non-volatile Storage
    CONFIG_NVS=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # Default partition for NVS is unused
    CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x0
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
    CONFIG_WIFI_FIXED_MAC_ADDRESS="22:22:22:44:44:44"
    # CONFIG_NRFX_SPIM_LOG=y
    # CONFIG_NRFX_QSPI_LOG=y
    # CONFIG_SPI_LOG_LEVEL_DBG=y
    # CONFIG_SPI_LOG_LEVEL_WRN=y
    board/nrf7002dk_nrf5340_cpuapp_ns.overlay
    // Update chosen node to use w25q32jv as external flash memory
    	chosen {
    		nordic,pm-ext-flash = &w25q32jv;
    // Disable mx25r64
    &mx25r64 {
    	status = "disabled";
    // Enable and configure SPI with W25Q32JV flash memory
    &spi4 {
        status = "okay";
        pinctrl-0 = <&spi4_default>;
        pinctrl-1 = <&spi4_sleep>;
        cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
        w25q32jv: w25q32jv@0 {
            compatible = "jedec,spi-nor";
            reg = <0>;
            spi-max-frequency = <133000000>; // 133 MHz
            jedec-id = [ef 40 16]; // Manufacturer and device ID for W25Q32JV
            sfdp-bfp = [
            e5 20 f9 ff  ff ff ff 01  44 eb 08 6b  08 3b 42 bb
            fe ff ff ff  ff ff 00 00  ff ff 40 eb  0c 20 0f 52
            10 d8 00 00  36 02 a6 00  82 ea 14 c2  e9 63 76 33
            7a 75 7a 75  f7 a2 d5 5c  19 f7 4d ff  e9 30 f8 80
            size = <0x400000>;  // 4 MiB
            has-dpd;
            t-enter-dpd = <10000>;  // 10 µs (10000 ns)
            t-exit-dpd = <30000>;   // 30 µs (30000 ns)
    &spi4_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 8)>,   // P0.08
                    <NRF_PSEL(SPIM_MISO, 0, 10)>, // P0.10
                    <NRF_PSEL(SPIM_MOSI, 0, 9)>;  // P0.09
    &spi4_sleep {
        group1 {
            low-power-enable;
    child image/mcuboot/board/nrf7002dk_nrf5340_cpuapp.conf
    # General
    CONFIG_FLASH=y
    CONFIG_MULTITHREADING=y
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    # MCUBoot and Partition Manager
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
    CONFIG_BOOT_MAX_IMG_SECTORS=2048
    CONFIG_BOOT_ERASE_PROGRESSIVELY=y
    CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
    # Use minimal C library instead of the Picolib
    CONFIG_MINIMAL_LIBC=y
    CONFIG_LOG=y
    CONFIG_LOG_MODE_MINIMAL=y
    child image/mcuboot/board/nrf7002dk_nrf5340_cpuapp.overlay
    	chosen {
    // Disable mx25r64
    &mx25r64 {
    &spi4 {
        status = "okay";
            reg = <0>;
            sfdp-bfp = [
            has-dpd;
    &spi4_default {
        group1 {
    &spi4_sleep {
        group1 {
            low-power-enable;
    Error log we facing "W: Cannot upgrade: not a compatible amount of sectors"
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    I: Starting bootloader
    I: Bootloader chainload address offset: 0x10000
    I: Jumping to the first image slot
    Download client sample started
    HTTP application update sample started
    Using version 1
    if up
    Connecting to network
    uart:~$
    partition
    I need guidance to resolve  "W: Cannot upgrade: not a compatible amount of sectors" error?
    In addition to above issue, Initialy I have found that the child image/board/conf and overlay configuration is not reflected in output file - build/mcuboot. But after 2 to 3 build the config are reflected.
    How can I include those file in build configuration to ensure that the config are included?
    What is the board name you built for? Try to synchronize the name of the board config/overlay files.
    Do you get a different log after synchronizing the name of the board config/overlay files?
    -Amanda H.
  • What is the board name you built for? Try to synchronize the name of the board config/overlay files.
    Board configurations: nrf7002dk_nrf5340_cpuapp_ns
    After change the child_imgae/mcuboot/boards/ conf and coverlay to nrf7002dk_nrf5340_cpuapp_ns and try to build with below configuration.
    Facing compilation error : build_log_1
    Can't able to paste build log here so I have provided in link.
    And als try to build with below configurations
    Facing compilation error : build_log_2
     But I have tried the same code without any changes for 8MB external flash. I didn't face any error like this.
    From your build_log_1, I see the mcuboot uses nrf7002dk_nrf5340_cpuapp as the build target, so the board name for the mcuboot is nrf7002dk_nrf5340_cpuapp. That is the reason it cannot find the SPI in the log. Sorry for the mislead.
    It doesn't need to set the mcuboot board file as the second board configuration, the system would load it automatically according to the board name for the mcuboot.
    You can check out this post regarding the overlay file and this sample.
    -Amanda H.
