nrf52 spi always faults out
i use nrf52 DK as master and configure ads1292 breakout as slave. I have try the loopback example which works properly. I write the sample spi code based on spi_master_with_slave example to read the value of the specific register in the ads1292. what happen is that the CS ,SCL,MOSI signal are all correct, but the MiSO signal is always wrong. image description yellow color is sclk,green color is miso, blue one is mosi,pink one is cs. no matter what register i read, the green signal (miso)is always like that. I attached my code as follow。 main.txt
the pin setting is changed like following:
#define SPIM0_SCK_PIN   25  // SPI clock GPIO pin number.
#define SPIM0_MOSI_PIN  23  // SPI Master Out Slave In GPIO pin number.
#define SPIM0_MISO_PIN  24  // SPI Master In Slave Out GPIO pin number.
#define SPIM0_SS_PIN    22  // SPI Slave Select GPIO pin number.'
please help me!
  • well what's wrong? Is that the only thing you're sending to it, just a read register? How do you know the answer isn't zero which is what you're getting? Have you sent enough configuration commands to start it converting?
    The trace looks fine, you're just getting zero back. Try some different commands which you know will return something other than zero.
