nRF5340 Missing Disconnect Event (Supervision Timeout)
I have a nRF5340 using hci_ipc that has the following features:
  • Central Role + Scanning (Multi-connection to nRF52840 peripherals)
  • Peripheral Role
  • QoS Channel Scanning
  • Nordic Uart (Server + Client)
I am missing bluetooth supervision timeout events with the nRF53 with both ncs 2.7.0 and the upstream Zephyr BLE stack. (No disconnected callback using the Softdevice).
Problem Flow from Central perspective:
1) Scan and connect
2) Subscribe to NUS (cached handles - no discovery)
3) MTU Exchange
4) Send NUS data back and forth (~1.2Kb DTLS handshake)
5) Disconnect Peripheral with pending Central NUS GATT write (breakpoint peripheral nrf52 / power off / reset)
6) Observe no supervision timeout (4s) [This event expected, but doesn't happen]
7) Observe GATT write error 30s later
8) GATT error cleans up nus subscription, manually issue disconnect here
9) Observe no .disconnected callback
Setups used:
1) Initially we were on NCS 2.7.0 with the included hci_ipc using the ipc_radio sample with a few upstream network (not bluetooth) related cherrypicks. We had problems with this configuration missing disconnect events.
2) Now we're on a heavily cherrypicked SDK to get as close to Zephyr main upstream Bluetooth stack (from the last couple days) & the newest nrfx-lib softdevice+hci_ipc. We still had problems with this.
3) With the heavily cherrypicked SDK, we enabled SPLIT_SW_LL and do not miss these supervision timeout events with the same application code.
I am curious what layer these disconnect events are supposed to get propagated through `zephyr/drivers/bluetooth/ipc/ipc.c` when using `hci_ipc`.
I have not yet been able to make a minimum viable example, but am working towards this.
I made a Zephyr discord post regarding this on #nordic for additional context, which I tried to summarize here.
https://discord.com/channels/720317445772017664/883445320812466209/1283513590606860318
Let me know if I can provide additional information,
Jeff
  • Vidar,
    I think there's a small misunderstanding.
    The Central device wrongly stays in a "connected state" when the link should have been terminated due to missing Link Layer packets.
    1) Central connects to peripheral
    2) DTLS over NUS until handshake is completed. NUS data stops. Only thing going is LL packets.
    3) Battery is pulled on peripheral device (proxy for real world disconnect due to range)
    4) Supervision timeout does not hit after 6 seconds. Wait around 30s-1 minute at this point.
    5) Battery is replaced, device advertises (with same address)
    6) Central tries to reconnect to the device but bt_conn_le_create fails with -22 because bt_conn_exists_le fails and prints "<wrn> ble_conn: Found valid connection (0x2000f540) with address F1:61:8:6E:9A:B2 (random) in connected state.
    This prevents reconnecting to the peripheral device because internally there is still a conn found by bt_conn_lookup_addr_le where the state is still connected in some combination of the host/controller, even though it has not gotten any connection LL packets past the supervision timeout.
    The nRF52 peripheral correctly gets the supervision timeout in all real world (non-battery-pull) cases.
    I appreciate the suggestions, and some methods like failing a GATT write from the controller might cause a disconnect after a timeout (30s, but recently configurable iirc), but we're in a bluetooth proximity tethering application that requires being fast acting, so actually getting the supervision timeout disconnected event is ideal.
    Happy to clarify further, also available on the Zephyr Discord (Jeff Welder) if that line of communication proves more efficient,
    --Jeff
  • Jeff,
    I was wondering what prompted the central to reconnect when it still believed it was connected to the peripheral. However, I had a single link GAP central in mind when I asked this. For a multi-link central, you would continue scanning after the connection has been established, so I think this part makes sense now.
    As a workaround, would it make sense to check if you already have a valid connection for a given address before calling bt_conn_le_create()? This seems like an easy way to detect a missed disconnect event. You could then call bt_conn_disconnect() on the stale connection object to attempt to free it before establishing the connection again.
    The flow control bug we attempted to address in v2.8.0 should only occur when the stack needs to wait on resources (buffers) to be freed and is not expected to happen during low BLE traffic.
    Vidar
  • Vidar,
    I appreciate the suggestions, but both the central and peripheral are multi-connection. Unfortunately due to this topology, just because the peripheral is advertising again does not mean that the central missed a disconnect event.
    The connection pointer needs to have the correct state. I don't know how the supervision timeout does not get processed when almost nothing besides scanning is happening.
    For the time being we're using the Split LL again, but ideally we move back to Nordic for a more familiar path to SIG certification.
    --Jeff
  • Jeff,
    It is surprising that this occurs when almost nothing is happening besides scanning. The issues we found earlier would only occur during high BLE activity. I have reported this as new issue internally. I also found out that we already include tests that simulate sudden disconnects by resetting the peer device. However, it seems we are not able to replicate the same conditions seen with your application.
    Vidar
  • Vidar,
    My colleague was able to create a barebones sample to demonstrate this missing disconnect.
    We modified your sample in these ways-
    Peripheral:
    On send enabled (this is after MTU update), we send 1000 bytes of zeros.
    Central responds with 1000 bytes of ones.
    Repeats sending ones/twos/threes.
    After we receive the last packet, we update the connection interval parameters and go idle.
    Central:
    Switch to IPC_RADIO
    No auto connect on filter match
    Vendor specific connection event report is enabled
    Scanning is only disabled while connecting (code in main.c does not support multiple connections, but it is modeled after our application)
    Inside the zip is a readme.
    Central was a nRF5340dk
    Peripheral was a nRF52840dk
    MissingDisconnectModifiedSamples.zip
    [00:00:23.747,192] <dbg> bt_conn: tx_notify_process: conn 0x200018c8
    [00:00:23.747,222] <dbg> bt_conn: tx_notify_process: tx 0x2000297c cb 0 user_data 0
    [00:00:23.747,222] <dbg> bt_conn: tx_free: 0x2000297c
    -- NOT ORIGINAL LOG --
    -- BEGIN WINDOW WHERE I TURN OFF POWER TO 52840DK PERIPHERAL --
    [00:00:23.747,253] <dbg> bt_conn: tx_notify_process: raise TX IRQ
    [00:00:23.747,283] <dbg> bt_conn: bt_conn_tx_processor: start
    [00:00:23.747,283] <dbg> bt_conn: bt_conn_tx_processor: no connection wants to do stuff
    [00:00:24.047,241] <dbg> bt_conn: bt_conn_ref: handle 10 ref 2 -> 3
    [00:00:24.047,271] <dbg> bt_conn: bt_conn_unref: handle 10 ref 3 -> 2
    -- END WINDOW --
    -- IF DISCONNECTED, TURN ON AND TRY AGAIN, VARY WHEN POWER IS TURNED OFF IN THIS WINDOW --
    -- IF UNABLE TO REPRODUCE, TRY SLIGHTLY BEFORE OR AFTER WINDOW--
    [00:09:06.285,400] <inf> central_uart: Filters matched. Address: D4:BC:F8:83:7F:87 (random) connectable: 1
    [00:09:06.285,583] <dbg> bt_conn: bt_conn_tx_processor: start
    [00:09:06.285,583] <dbg> bt_conn: bt_conn_tx_processor: no connection wants to do stuff
    [00:09:06.289,550] <dbg> bt_conn: bt_conn_ref: handle 10 ref 2 -> 3
    [00:09:06.289,672] <wrn> bt_conn: Found valid connection (0x200018c8) with address D4:BC:F8:83:7F:87 (random) in connected state
    [00:09:06.289,672] <dbg> bt_conn: bt_conn_unref: handle 10 ref 3 -> 2
    [00:09:06.289,703] <dbg> bt_conn: conn_le_create_common_checks: Conn check failed: ACL connection already exists.
    [00:09:06.289,703] <err> central_uart: bt_conn_le_create failed (err -22)
    --Jeff
