nRF5340 Missing Disconnect Event (Supervision Timeout)
I have a nRF5340 using hci_ipc that has the following features:
  • Central Role + Scanning (Multi-connection to nRF52840 peripherals)
  • Peripheral Role
  • QoS Channel Scanning
  • Nordic Uart (Server + Client)
I am missing bluetooth supervision timeout events with the nRF53 with both ncs 2.7.0 and the upstream Zephyr BLE stack. (No disconnected callback using the Softdevice).
Problem Flow from Central perspective:
1) Scan and connect
2) Subscribe to NUS (cached handles - no discovery)
3) MTU Exchange
4) Send NUS data back and forth (~1.2Kb DTLS handshake)
5) Disconnect Peripheral with pending Central NUS GATT write (breakpoint peripheral nrf52 / power off / reset)
6) Observe no supervision timeout (4s) [This event expected, but doesn't happen]
7) Observe GATT write error 30s later
8) GATT error cleans up nus subscription, manually issue disconnect here
9) Observe no .disconnected callback
Setups used:
1) Initially we were on NCS 2.7.0 with the included hci_ipc using the ipc_radio sample with a few upstream network (not bluetooth) related cherrypicks. We had problems with this configuration missing disconnect events.
2) Now we're on a heavily cherrypicked SDK to get as close to Zephyr main upstream Bluetooth stack (from the last couple days) & the newest nrfx-lib softdevice+hci_ipc. We still had problems with this.
3) With the heavily cherrypicked SDK, we enabled SPLIT_SW_LL and do not miss these supervision timeout events with the same application code.
I am curious what layer these disconnect events are supposed to get propagated through `zephyr/drivers/bluetooth/ipc/ipc.c` when using `hci_ipc`.
I have not yet been able to make a minimum viable example, but am working towards this.
I made a Zephyr discord post regarding this on #nordic for additional context, which I tried to summarize here.
https://discord.com/channels/720317445772017664/883445320812466209/1283513590606860318
Let me know if I can provide additional information,
Jeff
  • Hi Jeff,
    Thank you. I’m able to reproduce the issue now. It seems the developers were powering the kit on and off but likely missed the critical window you described. They will test again following your instructions.
    --Vidar
  • Vidar,
    Congrats to the team on getting v2.9.0 across the finish line for nRF54, cool stuff. :)
    Glad you were able to reproduce it -- has there been any more news on this from the devs?
    We're back on the SoftDevice Controller after a couple upstream sagas, so this problem is again our biggest blocker for production.
    P.S. Happy Holidays!
    --Jeff
  • Jeff,
    Thank you! This case has been on my mind lately, but I haven't had any updates to share as the team has not had a chance to revisit the issue yet. I understand this is a blocker for you and I think it is very unfortunate that we still have not been able to provide a solution. Since we will have reduced staffing during christmas due to public holidays, I’m afraid it is not realistic that we will come to a conclusion before new year. But one of the developers said they would have another look at this tomorrow so I will let you know if there are any new findings.
    --Vidar
  • Thanks Vidar!
    Hope you and the Nordic team had a great holiday season.
    Yesterday we started more mitigations, but ended up causing more issues than we solved.
    (Looking for RSSI dithering of attached peripherals to plateau for >10s due to a missed disconnect, and forcing a system reboot)
    On our end we're going to work to get the kinks out of our mitigation, but we're experiencing this issue in all of our units.
    Happy to assist in any way possible to hopefully get a proper root cause and solution.
    --Jeff
  • Jeff,
    Thank you! I hope you got some time off as well. The developers are able to reproduce the issue now with the project you provided and they have set aside time to investigate further. I will try to update you as soon as there is any progress or relay any requests they may have.
    --Vidar
