nRF5340 Missing Disconnect Event (Supervision Timeout)
I have a nRF5340 using hci_ipc that has the following features:
  • Central Role + Scanning (Multi-connection to nRF52840 peripherals)
  • Peripheral Role
  • QoS Channel Scanning
  • Nordic Uart (Server + Client)
I am missing bluetooth supervision timeout events with the nRF53 with both ncs 2.7.0 and the upstream Zephyr BLE stack. (No disconnected callback using the Softdevice).
Problem Flow from Central perspective:
1) Scan and connect
2) Subscribe to NUS (cached handles - no discovery)
3) MTU Exchange
4) Send NUS data back and forth (~1.2Kb DTLS handshake)
5) Disconnect Peripheral with pending Central NUS GATT write (breakpoint peripheral nrf52 / power off / reset)
6) Observe no supervision timeout (4s) [This event expected, but doesn't happen]
7) Observe GATT write error 30s later
8) GATT error cleans up nus subscription, manually issue disconnect here
9) Observe no .disconnected callback
Setups used:
1) Initially we were on NCS 2.7.0 with the included hci_ipc using the ipc_radio sample with a few upstream network (not bluetooth) related cherrypicks. We had problems with this configuration missing disconnect events.
2) Now we're on a heavily cherrypicked SDK to get as close to Zephyr main upstream Bluetooth stack (from the last couple days) & the newest nrfx-lib softdevice+hci_ipc. We still had problems with this.
3) With the heavily cherrypicked SDK, we enabled SPLIT_SW_LL and do not miss these supervision timeout events with the same application code.
I am curious what layer these disconnect events are supposed to get propagated through `zephyr/drivers/bluetooth/ipc/ipc.c` when using `hci_ipc`.
I have not yet been able to make a minimum viable example, but am working towards this.
I made a Zephyr discord post regarding this on #nordic for additional context, which I tried to summarize here.
https://discord.com/channels/720317445772017664/883445320812466209/1283513590606860318
Let me know if I can provide additional information,
Jeff
  • Jeff,
    I understand you’ve been in contact with one of our developers on Discord and found a suitable workaround. So I assume I can consider this ticket resolved for now. Please let me know if that’s not the case. Of course we still need to address the issue in the host or controller to remove the need for this workaround in the first place.
    Workaround:
    Set CONFIG_BT_BUF_CMD_TX_COUNT  >= (CONFIG_BT_BUF_ACL_RX_COUNT + 1) , i.e. CONFIG_BT_BUF_ACL_RX_COUNT=10 and CONFIG_BT_BUF_CMD_TX_COUNT=11 in your ipc_radio.conf
  • Is there any news on this topic? I am facing the same issue of not having the disconnection callback triggered, hence having "Found valid connection with address (random) in connected state" when trying to reconnect again.
    Working on 2.6.0
    The workaround proposed in this comment doesn't work for me
  • Also in the same boat.  Proposed workaround does not work.
    nRF Connect SDK v2.6.1 using nRF5340
    CONFIG_BT_BUF_CMD_TX_COUNT = 10
    CONFIG_BT_BUF_ACL_TX_COUNT = 7
    CONFIG_BT_BUF_ACL_RX_COUNT = 6
    CONFIG_BT_BUF_ACL_[TR]X_SIZE = 136
    attempting to support BLE periph + BLE central + ANT is encouraging me to stick to this version of the code...
