How to compile keil's project by eclipse
AS i am trying to utilize GCC for more than 32 KB code size, i use Eclipse which provides more friendly interface. However, i am still experiencing some setting issues.
That i installed thoese software on Win7 32bit
  • coreutils-5.3.0
  • make-3.81
  • eclipse-cpp-kepler-SR2-win32
  • gcc-arm-none-eabi-4_9-2015q3-20150921-win32
Then following Nordic tutorial(devzone.nordicsemi.com/.../) to set up the environment.
First I try to compile SDK exsample from Nordic,and it works. Now,I want to compile keil's project which is created before. But I have no ideal to let keil's project into eclipse and be compiled by armgcc.
Should I make a makefile or something else? and how to do it?
Does anyone have any ideal about that?
Thanks for your helping
  • Perhaps, since you've had so many issues with Eclipse, you should try this devzone.nordicsemi.com/.../ instead. That imports keil projects which you then just have to modify slightly. And it has a better debug interface than Eclipse and is generally a more suitable product.
  • Do note that while the SES evaluation mode has no code size limit, you will still need to buy a license for commercial use. This means if you are working on a project that does not include plans to buy software licenses for IDEs, then using SES may not be an option either.
  • Can't say I agree that Eclipse "provides more friendly interface" than Keil?!
    Anyhow, I don't know of any automatic converter/importer - so you'll just have to do it manually.
    So that's a matter of going through all the settings in the Keil project, and making the corresponding entries in your Eclipse project.
    Note that the Keil project is a plain text file - so you can inspect in a text editor, search it, and copy stuff - to save some manual re-typing. It is actually an XML structure; so it helps if you have an editor that can understand XML - Notepad++ is one such...
  • New thread on the same subject:
  • Hi, I also needed to convert Keil project to Eclipse. I was very annoyed after doing it the same conversions over and over again, therefore I made a special tool for it. I use it for converting STMCube projects to Eclipse and it works great! It also works with NXP MCUs.
    www.ulozto.cz/.../keil2gcc-1-04-zip
