Power consumption after system power off nrf51822
I would like to ask you about help. I have very simple task that I send state of 2 switches in advertisement packet (2 bytes) for some fixed time period. After that chip will go to system power off, but power consumption is about 400uA. I use UART for debug, ADC for battery monitoring and a few pins... I think nothing special. What I read here the consumption should be lower and system power should switch off automatically everything.
Here is my quick code. Can someone check it?
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <nrf_drv_adc.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "app_button.h"
#include "app_scheduler.h"
#include "app_timer_appsh.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp.h"
#include "sensorsim.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#if (NRF_SD_BLE_API_VERSION == 3)
#define NRF_BLE_MAX_MTU_SIZE            GATT_MTU_SIZE_DEFAULT                       /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */
#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
#define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#if BUTTONS_NUMBER < 2
#error "Not enough resources"
#define BUTTON_ID_1                0   /**< ID of the button used to change the readiness to sleep. */
#define BUTTON_ID_2                1   // ID of the button
#define HIGH_ACCURACY_ADC_ENABLE        0               //Set to 1 to enable high accuracy ADC sampling (use HFCLK crystal while sampling). Set to 0 for lowest current consumption.
#define NRF_LOGGING_ENABLED             1               //Set as 1 to enable logging on UART, otherwise set as 0. Comment out to enable low current consumption
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS           1200
#define ADC_PRE_SCALING_COMPENSATION            3
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS          270
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)    ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / 1023) * ADC_PRE_SCALING_COMPENSATION)
#define ADC_BUFFER_SIZE                 1               //Size of buffer for ADC samples. Buffer size should be multiple of number of adc channels located.
#define DEVICE_NAME                     "BLE"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      5                                         /**< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(2000, APP_TIMER_PRESCALER) /**< Battery level measurement interval (ticks). */
#define TLACITKO_LEVEL_MEAS_INTERVAL    APP_TIMER_TICKS(100, APP_TIMER_PRESCALER)
#define BLIK_LEVEL_MEAS_INTERVAL        APP_TIMER_TICKS(500, APP_TIMER_PRESCALER) // blikani diody pri advertisovani
#define DELAY_5 5
#define DELAY_10 10
#define DELAY_100 100
#define BATTERY_LEVEL_INCREMENT         1                                          /**< Increment between each simulated battery level measurement. */
#define SCHED_MAX_EVENT_DATA_SIZE       MAX(APP_TIMER_SCHED_EVT_SIZE, \
                                            BLE_STACK_HANDLER_SCHED_EVT_SIZE)                     /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE                 20                                         /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE                10                                                        /**< Maximum number of events in the scheduler queue. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
#define APP_ADV_FAST_INTERVAL           0x0028                                                    /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL           0x0C80                                                    /**< Slow advertising interval (in units of 0.625 ms. This value corrsponds to 2 seconds). */
#define APP_ADV_FAST_TIMEOUT            5 //doba kratkeho advertisovani, doba kdy cip advertisuje v kratkem intervalu                                                      /**< The duration of the fast advertising period (in seconds). */
#define APP_ADV_SLOW_TIMEOUT            1 //doba kdy cip advertisuje v dlouhem intervalu (2sec), pak se advertisovani vypne a nelze se pripojit
                                                      // flag pro kontrolu zapnuti timeru pro necinosti koncaku do modu sleep
ble_advdata_t _advdata;
uint8_t _stateSwitch1Data = 0xFF;
uint8_t _stateSwitch2Data = 0xFF;
uint8_t _stateBattery = 0x00;
uint32_t _stateSwitchOld1 = 1;
uint32_t _stateSwitchOld2 = 1;
APP_TIMER_DEF(m_battery_timer_id);
APP_TIMER_DEF(tlacitko_timer_id);
APP_TIMER_DEF(blik_timer_id);
static nrf_adc_value_t                  adc_buffer[ADC_BUFFER_SIZE];                /**< ADC buffer. */
static nrf_drv_adc_channel_t            m_channel_config = NRF_DRV_ADC_DEFAULT_CHANNEL(NRF_ADC_CONFIG_INPUT_2); /**< Channel instance. Default configuration used. */
static uint8_t                          adc_event_counter = 0;
static uint8_t                          number_of_adc_channels;
void advertising_init();
static void buttons_init();
//Function for assert macro callback.
// * @brief ADC interrupt handler.
static void adc_event_handler(nrf_drv_adc_evt_t const * p_event)
uint16_t adc_result_millivolts;
uint8_t  adc_result_percent;
    if (p_event->type == NRF_DRV_ADC_EVT_DONE)
        if(NRF_LOGGING_ENABLED)
            uint32_t i;
            for (i = 0; i < p_event->data.done.size; i++)
                adc_result_millivolts = ADC_RESULT_IN_MILLI_VOLTS(p_event->data.done.p_buffer[i]);          //Transform the average ADC value into millivolts value
                adc_result_percent = battery_level_in_percent(adc_result_millivolts);          //Transform the millivolts value into battery level percent.
                _stateBattery = adc_result_percent;
            adc_event_counter++;
        APP_ERROR_CHECK(nrf_drv_adc_buffer_convert(adc_buffer,ADC_BUFFER_SIZE));
//Function for handling advertising errors.
static void ble_advertising_error_handler(uint32_t nrf_error)
    printf("error - ble_advertising_error_handler\r\n");
//Function for handling the Battery measurement timer timeout.
void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    nrf_gpio_pin_set(2);
    nrf_delay_us(DELAY_10);
    nrf_drv_adc_sample();
    nrf_gpio_pin_clear(LED_2);
    nrf_gpio_pin_clear(1);
void tlacitko_level_meas_timeout_handler(void * p_context)
    uint32_t ret;
    bool zmena = false;
    nrf_gpio_pin_set(4);
    nrf_gpio_pin_set(5);
    nrf_delay_us(DELAY_5);
    ret = nrf_gpio_pin_read(6);
    nrf_gpio_pin_clear(4);
    nrf_gpio_pin_clear(5);
    if(ret != _stateSwitchOld1)
        zmena = true;
        if(ret != 0)
            _stateSwitch1Data = 0x01;
    _stateSwitchOld1 = ret;
    nrf_gpio_pin_set(7);
    nrf_gpio_pin_set(8);
    ret = nrf_gpio_pin_read(9);
    nrf_gpio_pin_clear(7);
    nrf_gpio_pin_clear(8);
    if(ret != _stateSwitchOld2)
        zmena = true;
        if(ret != 0)
            _stateSwitch2Data = 0x01;
    _stateSwitchOld2 = ret;
    if(zmena)
        advertising_init();
    printf("stav1: %d, stav2: %d\r\n",_stateSwitch1Data,_stateSwitch2Data);
void blik_level_meas_timeout_handler(void * p_context)
    nrf_gpio_pin_toggle(LED_1);
 //ADC initialization.
static void adc_config(void)
    ret_code_t ret_code;
    //Initialize ADC
    nrf_drv_adc_config_t config = NRF_DRV_ADC_DEFAULT_CONFIG;
    ret_code = nrf_drv_adc_init(&config, adc_event_handler);
    APP_ERROR_CHECK(ret_code);
    nrf_drv_adc_channel_enable(&m_channel_config);
    number_of_adc_channels = 1;    //Set equal to the number of configured ADC channels, for the sake of UART output.
//Function for the GAP initialization.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    if(err_code != 0)
    printf("error - sd_ble_gap_device_name_set\r\n");
    if(err_code != 0)
    printf("error - sd_ble_gap_ppcp_set\r\n");
//Function for putting the chip into sleep mode.
    uint32_t err_code;
    app_uart_close();
    nrf_drv_adc_channel_disable(&m_channel_config);// vypnuti ADC prevodniku
    nrf_drv_adc_uninit();//uninicializace prevodniku
    app_timer_stop_all();// vypnuti vsech timeru
    app_timer_stop(m_battery_timer_id);
    app_timer_stop(blik_timer_id);
    app_timer_stop(tlacitko_timer_id);
    nrf_gpio_pin_clear(LED_1);
    if(err_code != 0)
    printf("error - sd_power_system_off\r\n");
//Function for the Timer initialization.
static void timers_init(void)
    uint32_t err_code;
    // Initialize timer module, making it use the scheduler.
    APP_TIMER_APPSH_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, true);
    // Create battery timer.
    err_code = app_timer_create(&m_battery_timer_id,APP_TIMER_MODE_REPEATED,battery_level_meas_timeout_handler);
    if(err_code != 0)
    printf("error - app_timer_create");
    // Create tlacitko timer.
    err_code = app_timer_create(&tlacitko_timer_id,APP_TIMER_MODE_REPEATED,tlacitko_level_meas_timeout_handler);
    if(err_code != 0)
    // Blik timer
    err_code = app_timer_create(&blik_timer_id,APP_TIMER_MODE_REPEATED,blik_level_meas_timeout_handler);
    if(err_code != 0)
//Function for handling advertising events.
    //uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_DIRECTED:
            printf("BLE_ADV_EVT_DIRECTED\r\n");
        case BLE_ADV_EVT_FAST:
            printf("BLE_ADV_EVT_FAST\r\n");
        case BLE_ADV_EVT_SLOW:
            printf("BLE_ADV_EVT_SLOW\r\n");
        case BLE_ADV_EVT_IDLE:
            buttons_init();
            sleep_mode_enter();
//Function for the application's SoftDevice event handler.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            break; // BLE_GAP_EVT_CONNECTED
            break; // BLE_GAP_EVT_DISCONNECTED
            // Pairing not supported
            break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
            break; // BLE_GATTS_EVT_SYS_ATTR_MISSING
        case BLE_GATTC_EVT_TIMEOUT:
            break; // BLE_GATTC_EVT_TIMEOUT
        case BLE_GATTS_EVT_TIMEOUT:
            break; // BLE_GATTS_EVT_TIMEOUT
        case BLE_EVT_USER_MEM_REQUEST:
            err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            break; // BLE_EVT_USER_MEM_REQUEST
        case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
            ble_gatts_evt_rw_authorize_request_t  req;
            ble_gatts_rw_authorize_reply_params_t auth_reply;
            req = p_ble_evt->evt.gatts_evt.params.authorize_request;
            if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                    if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                    auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                    err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                               &auth_reply);
        } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
        case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
            err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                       NRF_BLE_MAX_MTU_SIZE);
            break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
            // No implementation needed.
// Function for dispatching a SoftDevice event to all modules with a SoftDevice
_ble_evt  SoftDevice event.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_nus_on_ble_evt(&m_nus, p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
//Function for dispatching a system event to interested modules.
static void sys_evt_dispatch(uint32_t sys_evt)
    // Dispatch to the Advertising module last, since it will check if there are any
    // pending flash operations in fstorage. Let fstorage process system events first,
    // so that it can report correctly to the Advertising module.
    ble_advertising_on_sys_evt(sys_evt);
//Function for the SoftDevice initialization.
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    if(err_code != 0)
    printf("error - softdevice_enable_get_default_config\r\n");
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
    err_code = softdevice_enable(&ble_enable_params);
    if(err_code != 0)
    printf("error - softdevice_enable\r\n");
    // Subscribe for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    if(err_code != 0)
    printf("error - softdevice_ble_evt_handler_set\r\n");
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
    if(err_code != 0)
    printf("error - softdevice_sys_evt_handler_set\r\n");
//Function for initializing the Advertising functionality.
    printf("advertising init \r\n");
    uint8_t                adv_flags;
    ble_advdata_manuf_data_t manfdata;
    ble_adv_modes_config_t options;
    uint8_t data[3];
    data[0] = _stateSwitch1Data;
    data[1] = _stateSwitch2Data;
    data[2] = _stateBattery;
    // Build and set advertising data
    memset(&_advdata, 0, sizeof(_advdata));
    adv_flags                       = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    _advdata.name_type               = BLE_ADVDATA_FULL_NAME;//BLE_ADVDATA_SHORT_NAME bylo pouzito
    //_advdata.short_name_len          = 6; // pouziva se jen kdyz je BLE_ADVDATA_SHORT_NAME
    _advdata.include_appearance      = true;
    _advdata.flags                   = adv_flags;
    memset(&manfdata,0,sizeof(manfdata));
    manfdata.company_identifier = 0x1234;// doplnit o ID firmy v-tech
    manfdata.data.size = 3;// velikost poslanych dat (2 byte)
    manfdata.data.p_data = data;//APP_ADV_CUSTOM_DATA;
    _advdata.p_manuf_specific_data = &manfdata;
    memset(&options, 0, sizeof(options));
    options.ble_adv_whitelist_enabled      = true;
    options.ble_adv_directed_enabled       = true;
    options.ble_adv_directed_slow_enabled  = false;
    options.ble_adv_directed_slow_interval = 0;
    options.ble_adv_directed_slow_timeout  = 0;
    options.ble_adv_fast_enabled           = true;
    options.ble_adv_fast_interval          = APP_ADV_FAST_INTERVAL;
    options.ble_adv_fast_timeout           = APP_ADV_FAST_TIMEOUT;
    options.ble_adv_slow_enabled           = false; // zakazan dlouhy interval advertisovani
    options.ble_adv_slow_interval          = APP_ADV_SLOW_INTERVAL;
    options.ble_adv_slow_timeout           = APP_ADV_SLOW_TIMEOUT;
    err_code = ble_advertising_init(&_advdata,NULL,&options,on_adv_evt,ble_advertising_error_handler);
    if(err_code != 0)
    printf("error - ble_advertising_init\r\n");
/**@brief Function for the Event Scheduler initialization.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    ret_code_t ret;
    ret = ble_advertising_start(BLE_ADV_MODE_FAST);
    if(ret != 0)
    printf("error - ble_advertising_start\r\n");
//Function for handling events from the BSP module.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            //sleep_mode_enter();
        case BSP_EVENT_WAKEUP:
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
        case BSP_EVENT_KEY_0:
        case BSP_EVENT_KEY_1:
//Function for handling app_uart events.
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                err_code = ble_nus_string_send(&m_nus, data_array, index);
                    printf("error - ble_nus_string_send\r\n");
                index = 0;
        case APP_UART_FIFO_ERROR:
//[Handling the data received over UART] */
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_DISABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud115200
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    if(err_code != 0)
    printf("error - APP_UART_FIFO_INIT\r\n");
static void timers_start(void)
    uint32_t err_code;
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(tlacitko_timer_id, TLACITKO_LEVEL_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(blik_timer_id, BLIK_LEVEL_MEAS_INTERVAL, NULL);
static void leds_init()
    uint32_t err_code = bsp_init(BSP_INIT_LED,APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
bsp_event_handler);
    if(err_code != 0)
    printf("error - bsp_init = %ld\r\n",err_code);
// Function for initializing buttons and leds.
printf("je tam init\r\n");
    uint32_t err_code = bsp_init(BSP_INIT_BUTTONS,
                                 bsp_event_handler);
    if(err_code != 0)
    err_code = bsp_event_to_button_action_assign(BUTTON_ID_1,
                                                BSP_BUTTON_ACTION_RELEASE,
                                                 BSP_EVENT_KEY_0);
    if(err_code != 0)
    printf("error - bsp_event_to_button_action_assign\r\n");
    err_code = bsp_event_to_button_action_assign(BUTTON_ID_2,
                                                BSP_EVENT_KEY_1);
    if(err_code != 0)
//Function for placing the application in low power state while waiting for events.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
    if(err_code != 0)
    printf("error - sd_app_evt_wait\r\n");
// user button init
void user_button_init(void)
    nrf_gpio_cfg_output(4);
    nrf_gpio_cfg_output(5);
    nrf_gpio_cfg_input(6,NRF_GPIO_PIN_NOPULL);
    nrf_gpio_cfg_output(7);
    nrf_gpio_cfg_output(8);
    nrf_gpio_cfg_input(9,NRF_GPIO_PIN_NOPULL);
// user battery init
void user_battery_init(void)
    nrf_gpio_cfg_input(1,NRF_GPIO_PIN_NOPULL);
    nrf_gpio_cfg_output(2);
/**@brief Application main function.
    // Initialize.
    uart_init();
    timers_init();
    leds_init();
    ble_stack_init();
    scheduler_init();
    gap_params_init();
    adc_config();
    advertising_init();
    user_button_init();
    user_battery_init();
    timers_start();
    advertising_start();
    // Enter main loop.
    for (;;)
        app_sched_execute();
        power_manage();
