nRF Connect for Desktop v5.0.2, programmer v4.4.1, rust-panic on startup
I recently purchased an nrf52840 dongle.
In nRF Connect for Desktop (v5.0.2) and with or without the device attached, Programmer (v4.4.1) starts with a rust-panic error:
10:09:46.533	thread '<unnamed>' panicked at src\usb-lister-rs\src\windows.rs:1160:5: assertion `left == right` failed left: 14 right: 68 note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
10:09:46.533	thread '<unnamed>' panicked at library\panic_unwind\src\seh.rs:290:8: Rust panics cannot be copied stack backtrace:
10:09:46.536	0: 0x7ffd4a7ddbfd - <unknown> 1: 0x7ffd4a7d3e29 - <unknown> 2: 0x7ffd4a7dc361 - <unknown> 3: 0x7ffd4a7dd9d6 - <unknown> 4: 0x7ffd4a7df3c8 - <unknown> 5: 0x7ffd4a7df076 - <unknown> 6: 0x7ffd4a7df8f8 - <unknown>
10:09:46.537	7: 0x7ffd4a7df779 - <unknown> 8: 0x7ffd4a7de2ef - <unknown> 9: 0x7ffd4a7df468 - <unknown> 10: 0x7ffd4a94a874 - nrfdl_wait_timed_async_task_complete 11: 0x7ffd4a7fae6c - <unknown>
10:09:46.542	12: 0x7ffdbfe422b1 - <unknown> 13:
10:09:46.542	0x7ffdbfe42008 - <unknown> 14: 0x7ffdbfe42529 - __ExceptionPtrCurrentException 15: 0x7ffd4a952e6f - nrfdl_wait_timed_async_task_complete
10:09:46.543	16: 0x7ffdbfed4160 - _CxxFrameHandler4 17
10:09:46.544	: 0x7ffdbfed2572 - <unknown>
10:09:46.548	18: 0x7ffde57f4a26 - RtlCaptureContext2 19: 0x7ffd4a90c6cf - <unknown>
10:09:46.548	20: 0x7ffd4a8ea1c3 - <unknown> 21: 0x7ffd4a90d382 - <unknown> 22: 0x7ffd4a910953 - <unknown> 23: 0x7ffd4a8eaad4 - <unknown> 24: 0x7ffd4a8e9588 - <unknown> 25: 0x7ffdbfe52ab9 - Concurrency::details::_Schedule_chore
10:09:46.548	26: 0x7ffde57b289a - RtlHashUnicodeString 27: 0x7ffde5785e66 - RtlClearThreadWorkOnBehalfTicket
10:09:46.550	28: 0x7ffde435257d - BaseThreadInitThunk 29: 0x7ffde57aaf28 - RtlUserThreadStart
10:09:46.551	thread '<unnamed>' panicked at library\panic_unwind\src\seh.rs:290:8: Rust panics cannot be copied stack backtrace: 0: 0x7ffd4a7ddbfd - <unknown> 1: 0x7ffd4a7d3e29 - <unknown> 2: 0x7ffd4a7dc361 - <unknown> 3: 0x7ffd4a7dd9d6 - <unknown> 4: 0x7ffd4a7df3c8 - <unknown> 5: 0x7ffd4a7df076 - <unknown> 6: 0x7ffd4a7df8f8 - <unknown> 7: 0x7ffd4a7df779 -
10:09:46.551	<unknown> 8: 0x7ffd4a7de2ef - <unknown> 9: 0x7ffd4a7df468 - <unknown> 10: 0x7ffd4a94a874 - nrfdl_wait_timed_async_task_complete 11: 0x7ffd4a7fae6c - <unknown> 12: 0x7ffdbfe422b1 - <unknown> 13: 0x7ffdbfe92add - std::basic_ostream<unsigned short,std::char_traits<unsigned short> >::write 14:
10:09:46.551	0x7ffdbfed4160 - _CxxFrameHandler4 15: 0x7ffdbfed2572 - <unknown> 16: 0x7ffde57f4a26 - RtlCaptureContext2 17: 0x7ffdbfe42008 - <unknown> 18: 0x7ffdbfe42529 - __ExceptionPtrCurrentException 19: 0x7ffd4a952e6f - nrfdl_wait_timed_async_task_complete 20: 0x7ffdbfed4160 - _CxxFrameHandler4 21: 0x7ffdbfed2572 - <unknown> 22: 0x7ffde57f4a26 - RtlCaptureContext2 23: 0x7ffd4a90c6cf - <unknown>
10:09:46.551	24: 0x7ffd4a8ea1c3 - <unknown> 25: 0x7ffd4a90d382 - <unknown> 26: 0x7ffd4a910953 - <unknown> 27: 0x7ffd4a8eaad4 - <unknown> 28: 0x7ffd4a8e9588 - <unknown> 29: 0x7ffdbfe52ab9 - Concurrency::details::_Schedule_chore 30: 0x7ffde57b289a - RtlHashUnicodeString 31: 0x
10:09:46.551	7ffde5785e66 - RtlClearThreadWorkOnBehalfTicket 32: 0x7ffde435257d - BaseThreadInitThunk 33: 0x7ffde57aaf28 - RtlUserThreadStart fatal runtime error: Rust panics must be rethrown
10:09:46.701	Error: Subprocess C:\Users\by_co\AppData\Roaming\nrfconnect\nrfutil-sandboxes\device\2.5.0\bin\nrfutil-device.exe failed with unexpected exit code Some(-1073740791)
10:09:46.706	Using nrfutil-device version: 2.5.0
10:09:46.706	Using nrf-device-lib version: 0.17.26
This is on a w11 system.  j-link j-tag-load, rtt client, remote server, etc with v7.98b are installed. I'm not seeing python errors, but for what it's worth, v3.11 is installed. Any ideas what I have missed installing or what paths need to be updated?
Thank you!
  • Hi
    Regarding this nRF52840 Dongle you have, how does it behave when plugging it into the computer on your end? Does it show up as DFU Bootloader in the nRF Programmer or with some other name? If you have programmed it already it might be running in its application mode, in which case you will need to hold the side-mounted reset button while plugging the Dongle into your computer to put it back into the DFU bootloader mode that lets it communicate through USB with the nRF Connect application. If that's not it I will have to ask the devs about this error, as I can't say it's something I've seen before.
    Simon
  • Hi Simon!
    Yes, I can get the dongle into DFU bootloader mode (red light approximately 1hz).  nRF Connect for Desktop has options for Bluetooth Low Energy, Direct Test Mode, RSSI Viewer, Serial Terminal, and Power Profiler all see the device.  Quick Start sees the device and reports "not supported yet". Programmer crashes with the error message above and does not see the device. My first post left off a couple line of the initial crash text (in case that is useful).
    12:03:41.734	Initialising nrfutil module: device
    12:03:43.053	Using nrfutil-device core version: 7.13.0
    12:03:43.408	thread '<unnamed>' panicked at src\usb-lister-rs\src\windows.rs:1160:5: assertion `left == right` failed left: 14 right: 68 note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
    12:03:43.408	thread '<unnamed>' panicked at library\panic_unwind\src\seh.rs:290:8: Rust panics cannot be copied stack backtrace:
    12:03:43.411	0: 0x7ffd9770dbfd - <unknown> 1: 0x
    If it is useful, the device ID is DCF7B348AB3D
    The programmer crashes either with no device, with a device not in DFU bootloader mode, and when in DFU bootloader mode (seems to make no difference, ... Programmer is just not happy software :-) )
    Thank you for the help!
  • Just to confirm, I -do- have nrf-command-line-tools-10.24.2-x64 installed and it is listed in both the system and my person path variables.
  • Okay, thank you for the explanation, I will need to take this onward with the nRF Connect for Desktop devs then. I'll let you know when I hear back from them. In the mean time you could try uninstalling the Programmer app and make sure the folder C:\Users\<YOUR USERNAME>\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer is removed entirely before reinstalling the app.
    Simon
  • One suggestion that came up. Can you try upgrading your nrfutil-device version to v2.5.4. Note that this is different from the nrfutil-device core version. You can do so by running nrfutil upgrade in the command line in the folder where nrfutil is located. It should upgrade to v2.5.4 by itself with no further inputs required.
    Simon
