nrf9160 & dual MCP251863 CAN
I have a custom board similar to the thingy91.
I use two MCP251863 (same as MCP2518FD with an integrated tranceiver) on the spi3.
schematic
device tree
	model = "custom thingy nRF9160";
	compatible = "nordic,asl01-nrf9160";
	chosen {
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,canbus = &can1;
	buttons {
		compatible = "gpio-keys";
		button0: button_0 {
			gpios = <&gpio0 26 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Button 1";
	leds {
		compatible = "gpio-leds";
		red_led: led_1 {
			gpios = <&gpio0 13 0>;
			label = "RGB red channel";
		green_led: led_2 {
			gpios = <&gpio0 9 0>;
			label = "RGB green channel";
		blue_led: led_3 {
			gpios = <&gpio0 14 0>;
			label = "RGB blue channel";
	pwmleds {
		compatible = "pwm-leds";
		pwm_led0: pwm_led_0 {
			pwms = <&pwm0 0 PWM_MSEC(8) PWM_POLARITY_NORMAL>;
		pwm_led1: pwm_led_1 {
			pwms = <&pwm0 1 PWM_MSEC(8) PWM_POLARITY_NORMAL>;
		pwm_led2: pwm_led_2 {
			pwms = <&pwm0 2 PWM_MSEC(8) PWM_POLARITY_NORMAL>;
	nrf52840_reset: gpio-reset {
		compatible = "nordic,asl01-nrf52840-reset";
		status = "okay";
		gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
	aliases {
		sw0 = &button0;
		led0 = &red_led;
		led1 = &green_led;
		led2 = &blue_led;
		pwm-led0 = &pwm_led0;
		pwm-led1 = &pwm_led1;
		pwm-led2 = &pwm_led2;
		rgb-pwm = &pwm0;
		mcuboot-button0 = &button0;
		mcuboot-led0 = &blue_led;
&adc {
	status = "okay";
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
/* PWM0 is intended for RGB LED control */
&pwm0 {
	status = "okay";
	pinctrl-0 = <&pwm0_default>;
	pinctrl-1 = <&pwm0_sleep>;
&spi3 {
	status = "okay";
	cs-gpios = <&gpio0 0 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&spi3_default>;
	pinctrl-1 = <&spi3_sleep>;
	can1: mcp251xfd@0 {
		compatible = "microchip,mcp251xfd";
		status = "okay";
		spi-max-frequency = <18000000>;
		int-gpios = <&gpio0 31 GPIO_ACTIVE_LOW>;
		reg = <0x0>;
		osc-freq = <40000000>;
		bus-speed-data = <1000000>;
		bus-speed = <500000>; // 500Kbits/s
		sample-point = <875>;
		sample-point-data = <875>;
prj.conf
CONFIG_SPI=y
CONFIG_CAN=y
CONFIG_CAN_FD_MODE=y
CONFIG_CAN_MCP251XFD=y
Q1: how to add both MCP to my device tree ?
Q2: do I add the tranceiver to the device tree, if yes, how to do so ?
Q3: how to enable disble the tranceiver ?
thanks for your time,
    We do not have experience with the CAN support in Zephyr, but from what I can see the CAN API include a device struct pointer as the first parameters (as most other Zephyr driver APIs), so I do not see any fundamental problems with using multiple  MCP251863. Have you tested adding another in the same way as you did with the first, and does it work? If not, what is the problem?
