Dynamically change Matter ICD Kconfig parameters
I have a Matter over thread temperature sensor, and low energy consumption is very crucial for me. Therefore, I'm using the Nrf2.7.0 SDK ICD LIT KConfig options and I found out unwanted behavior during commissioning.
My Kconfig options are:
CONFIG_CHIP_ENABLE_ICD_SUPPORT=y
CONFIG_CHIP_ICD_IDLE_MODE_DURATION=100
CONFIG_CHIP_ICD_ACTIVE_MODE_DURATION=5000
CONFIG_CHIP_ICD_SLOW_POLL_INTERVAL=30000
CONFIG_CHIP_ICD_FAST_POLLING_INTERVAL=3000
CONFIG_CHIP_ICD_ACTIVE_MODE_THRESHOLD=5000
CONFIG_CHIP_ICD_LIT_SUPPORT=y
CONFIG_CHIP_ICD_CHECK_IN_SUPPORT=y
CONFIG_CHIP_ICD_CLIENTS_PER_FABRIC=5
CONFIG_CHIP_ICD_UAT_SUPPORT=y
1. Commissioning fails when I set the `CONFIG_CHIP_ICD_IDLE_MODE_DURATION`value to a high duration. I experimentally tried multiple values and found the threshold to be 100 seconds. When setting a lower value, the commissioning passes without any problem, however I couldn't commission the device with a higher value than 100 seconds. I'm using an Apple HomePod mini as a thread border router.
2. Because I want to achieve as low energy consumption as possible, I set `CONFIG_CHIP_ICD_ACTIVE_MODE_DURATION` to 5000 ms and `CONFIG_CHIP_ICD_FAST_POLLING_INTERVAL` to 3000 ms. With these settings, I'm satisfied with the energy consumption, but the commissioning duration increased to approximately 4 minutes from the previous ~30 seconds when using the default values (300, 200).
Is there any way to solve these issues? I think setting different values when the device is in
DeviceConnectedBLE would solve the problem, but I find this post devzone.nordicsemi.com/.../can-the-compile-time-parameters-required-to-put-matter-device-into-sleep-mode-be-changed-in-run-time where it's mentioned it's not possible.
    The IdleModeDuration, ActiveModeDuration, and ActiveModeThreshold attributes have "Fixed Quality" according to the Matter specification, denoted by the "F" under Quality in the attributes list. Attributes with fixed quality are read-only and have a fixed value that never changes. Thus, these attributes cannot be changed during runtime.
    Have you tested with chip-tool as the Matter controller and OpenThread Border Router, and do you see the same behavior as with the Apple HomePod mini?
    Marte
