Issue with Stereo Sound from External Codec on nRF5340 DK (SDK v2.6.2)
Hello Team,
I am experiencing an issue with the sound output from an external codec connected to the nRF5340 DK. Currently, the sound is in mono, but my goal is to achieve stereo sound for both the left and right channels.
I read in an article that the configuration may need to be edited to enable stereo output from the external codec. I am using SDK v2.6.2 and would appreciate any guidance or suggestions on how to adjust the configuration to resolve this issue.
Thank you for your support!
Abdulmohaimen Algamoudi
    Thanks for you support.
    I'm still having issues with the application. I followed the steps in this articel, but once the Bluetooth connection starts, an error occurs, this is what i can read from the serial port:
    *** Booting nRF Connect SDK v3.5.99-ncs1-2 ***
    HL [00:00:00.270,782] <inf> board_version: Compatible board/HW version found: 1.0.0
    HL [00:00:00.296,264] <inf> fw_info:
             nRF5340 Audio nRF5340 Audio DK cpuapp
             NCS base version: 2.6.2
             Cmake run : Wed Oct 16 05:48:09 2024
    HL [00:00:00.296,264] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.296,295] <inf> fw_info: HEADSET left device
    HL [00:00:00.316,284] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 5.4 (0x0d), Revision 8591
    HL [00:00:00.316,497] <inf> bt_mgmt: Local identity addr: F0:D2:8E:F5:33:C2 (random)
    HL [00:00:00.321,716] <inf> bt_mgmt_adv: Local addr: 75:BB:5D:CD:F8:B7 (random)
    HL [00:00:00.321,807] <inf> bt_mgmt_adv: Adv directed to: D3:C8:9D:D1:BE:66 (random).
    HL [00:00:00.322,418] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:00:00.795,715] <inf> bt_mgmt: Connected: D3:C8:9D:D1:BE:66 (random)
    HL [00:00:00.795,745] <inf> main: Connected
    HL [00:00:00.796,142] <inf> bt_mgmt_adv: RPA (Resolvable Private Address) expired.
    HL [00:00:00.796,234] <inf> bt_mgmt_adv: Local addr: 75:BB:5D:CD:F8:B7 (random)
    HL [00:00:01.036,132] <inf> main: Security changed
    HL [00:00:01.036,407] <wrn> bt_gatt: Device is not subscribed to characteristic
    HL [00:00:01.036,407] <wrn> bt_pacs: PACS notify failed: -22
    HL [00:00:03.036,743] <inf> bt_content_ctrl_media: Discovery of MCS finished
    HL [00:00:05.196,624] <inf> unicast_server: LC3 codec config for sink:
    HL [00:00:05.196,655] <inf> unicast_server:     Frequency: 24000 Hz
    HL [00:00:05.196,655] <inf> unicast_server:     Duration: 10000 us
    HL [00:00:05.196,655] <inf> unicast_server:     Channel allocation: 0x1
    HL [00:00:05.196,655] <inf> unicast_server:     Octets per frame: 60 (48000 bps)
    HL [00:00:05.196,655] <inf> unicast_server:     Frames per SDU: 1
    HL [00:00:05.198,211] <inf> unicast_server: LC3 codec config for source:
    HL [00:00:05.198,242] <inf> unicast_server:     Frequency: 24000 Hz
    HL [00:00:05.198,242] <inf> unicast_server:     Duration: 10000 us
    HL [00:00:05.198,242] <inf> unicast_server:     Channel allocation: 0x1
    HL [00:00:05.198,242] <inf> unicast_server:     Octets per frame: 60 (48000 bps)
    HL [00:00:05.198,242] <inf> unicast_server:     Frames per SDU: 1
    HL [00:00:05.277,343] <inf> main: Presentation delay 10000 us is set by initiator
    HL [00:00:05.277,374] <inf> main: Presentation delay 10000 us is set by initiator
    HL [00:00:05.562,866] <inf> unicast_server: Stream 0x2000fbfc started
    HL [00:00:05.567,749] <err> sw_codec_lc3: LC3 dec ch: 1 already initialized
    HL [00:00:05.567,749] <err> audio_system: Failed to set up codec
    HL [00:00:05.567,749] <err> audio_system: ERR_CHK Err_code: [-120] @ line: 398
    HL [00:00:05.567,779] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000004  r2/a3:  0x00000003
    HL [00:00:05.567,779] <err> os: r3/a4:  0x0005914f r12/ip:  0x20002b00 r14/lr:  0x000591d9
    HL [00:00:05.567,779] <err> os:  xpsr:  0x41100000
    HL [00:00:05.567,779] <err> os: s[ 0]:  0x20001530  s[ 1]:  0x00059373  s[ 2]:  0xffffff88  s[ 3]:  0x00000004
    HL [00:00:05.567,810] <err> os: s[ 4]:  0x200128a0  s[ 5]:  0x20012880  s[ 6]:  0xffffff88  s[ 7]:  0x20012880
    HL [00:00:05.567,810] <err> os: s[ 8]:  0x200128a0  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x000593bf
    HL [00:00:05.567,840] <err> os: s[12]:  0x20004a88  s[13]:  0x00069b3c  s[14]:  0xffffff88  s[15]:  0x0000018e
    HL [00:00:05.567,840] <err> os: fpscr:  0x00000000
    HL [00:00:05.567,840] <err> os: Faulting instruction address (r15/pc): 0x00004536
    HL [00:00:05.567,840] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    HL [00:00:05.567,871] <err> os: Current thread: 0x20001de8 (LE_AUDIO_MSG_SUB)
    HL [00:00:05.567,871] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
    My goal is to implement walkie-talkie functionality with stereo sound using an external codec (with on microphones).
    Could you assist me with this?
    Thanks in Advance
    Abdulmohaimen
  • Hi Abdulmohaimen,
    If your server needs to decode 2 channels, please try adding Kconfig option - CONFIG_LC3_DEC_CHAN_MAX=2.
    Dejan
  • Hi Dejen,
    I have added the necessary Kconfig option to the prj.conf file. However, once the Bluetooth connection starts, the following error occurs:
    HL [00:00:00.272,918] <inf> board_version: Compatible board/HW version found: 1.0.0
    HL [00:00:00.298,614] <inf> fw_info:
             Cmake run : Sun Oct 20 17:27:13 2024
    HL [00:00:00.298,614] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.298,614] <inf> fw_info: HEADSET left device
    HL [00:00:00.318,389] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 5.4 (0x0d), Revision 8591
    HL [00:00:00.318,572] <inf> bt_mgmt: Local identity addr: F0:D2:8E:F5:33:C2 (random)
    HL [00:00:00.323,944] <inf> bt_mgmt_adv: Local addr: 4B:F2:BB:74:22:A1 (random)
    HL [00:00:00.324,035] <inf> bt_mgmt_adv: Adv directed to: D3:C8:9D:D1:BE:66 (random).
    HL [00:00:00.324,645] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:00:00.782,989] <inf> bt_mgmt: Connected: D3:C8:9D:D1:BE:66 (random)
    HL [00:00:00.783,020] <inf> main: Connected
    HL [00:00:00.783,569] <inf> bt_mgmt_adv: RPA (Resolvable Private Address) expired.
    HL [00:00:00.783,660] <inf> bt_mgmt_adv: Local addr: 4B:F2:BB:74:22:A1 (random)
    HL [00:00:01.063,781] <inf> main: Security changed
    HL [00:00:01.064,025] <wrn> bt_gatt: Device is not subscribed to characteristic
    HL [00:00:01.064,025] <wrn> bt_pacs: PACS notify failed: -22
    HL [00:00:02.984,405] <inf> bt_content_ctrl_media: Discovery of MCS finished
    HL [00:00:04.904,266] <inf> unicast_server: LC3 codec config for sink:
    HL [00:00:04.904,296] <inf> unicast_server:     Frequency: 24000 Hz
    HL [00:00:04.904,296] <inf> unicast_server:     Duration: 10000 us
    HL [00:00:04.904,296] <inf> unicast_server:     Channel allocation: 0x1
    HL [00:00:04.904,296] <inf> unicast_server:     Octets per frame: 60 (48000 bps)
    HL [00:00:04.904,296] <inf> unicast_server:     Frames per SDU: 1
    HL [00:00:04.905,883] <inf> unicast_server: LC3 codec config for source:
    HL [00:00:04.905,883] <inf> unicast_server:     Frequency: 24000 Hz
    HL [00:00:04.905,883] <inf> unicast_server:     Duration: 10000 us
    HL [00:00:04.905,883] <inf> unicast_server:     Channel allocation: 0x1
    HL [00:00:04.905,914] <inf> unicast_server:     Octets per frame: 60 (48000 bps)
    HL [00:00:04.905,914] <inf> unicast_server:     Frames per SDU: 1
    HL [00:00:04.984,985] <inf> main: Presentation delay 10000 us is set by initiator
    HL [00:00:04.985,015] <inf> main: Presentation delay 10000 us is set by initiator
    HL [00:00:05.270,507] <inf> unicast_server: Stream 0x2000fbf8 started
    DAC L gain 112
    DAC R gain 112
    HL [00:00:05.281,433] <wrn> le_audio_rx: Not in streaming state, throwing data: 1
    HL [00:00:05.295,318] <wrn> audio_datapath: Data received, total under-runs: 6
    HL [00:00:05.296,325] <wrn> audio_datapath: I2S RX overrun. Single msg
    HL [00:00:05.303,680] <inf> unicast_server: Stream 0x2000fc1c started
    HL [00:00:05.306,304] <wrn> audio_datapath: I2S RX continuing stream
    HL [00:00:05.307,739] <err> sw_codec_select: Unsupported channel mode for encoder: 0
    HL [00:00:05.307,739] <err> audio_system: Encode failed
    HL [00:00:05.307,739] <err> audio_system: ERR_CHK Err_code: [-19] @ line: 172
    HL [00:00:05.307,769] <err> os: r0/a1:  0x00000003  r1/a2:  0x0000000b  r2/a3:  0x0000000a
    HL [00:00:05.307,769] <err> os: r3/a4:  0x0005901d r12/ip:  0x20002bd0 r14/lr:  0x000590a7
    HL [00:00:05.307,769] <err> os:  xpsr:  0x61000000
    HL [00:00:05.307,769] <err> os: s[ 0]:  0x000000ac  s[ 1]:  0xffff0200  s[ 2]:  0xaaaa0200  s[ 3]:  0x01000003
    HL [00:00:05.307,800] <err> os: s[ 4]:  0xaaaaaaaa  s[ 5]:  0xaaaaaaaa  s[ 6]:  0xaaaaaaaa  s[ 7]:  0xaaaaaaaa
    HL [00:00:05.307,800] <err> os: s[ 8]:  0xaaaaaaaa  s[ 9]:  0xaaaaaaaa  s[10]:  0xaaaaaaaa  s[11]:  0xaaaaaaaa
    HL [00:00:05.307,800] <err> os: s[12]:  0xaaaaaaaa  s[13]:  0xaaaaaaaa  s[14]:  0xaaaaaaaa  s[15]:  0xaaaaaaaa
    HL [00:00:05.307,800] <err> os: fpscr:  0xaaaaaaaa
    HL [00:00:05.307,830] <err> os: Faulting instruction address (r15/pc): 0x00003f32
    HL [00:00:05.307,830] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    HL [00:00:05.307,861] <err> os: Current thread: 0x20001ff8 (ENCODER)
    HL [00:00:05.307,861] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
    I would like to mention again that my goal is to achieve walkie-talkie-style stereo sound with headsets connected to the DA7212 hardware codec. Before making the modifications, I was able to hear mono sound from the external codec.
    Could you please assist in resolving this issue?
    Thanks in advance
    Besr regardes
  • Hi Abdulmohaimen,
    You could try to debug your application using tools mentioned in debugging lesson in the nRF Connect SDK Intermediate course.
    Dejan
  • Hey Dejans,
    Thank you for your support, and I apologize for the delay. I have been working hard to resolve the issue.
    I have tried the provided code, but unfortunately, it does not work.
    I also tested the  code mentioned in this tickt, and I was able to achieve stereo sound with CIS. However, there are some limitations, such as only one data channel (left) being transmitted
    the log outputs of the gateway:
    *** Booting Zephyr OS build v3.3.99-ncs1-2 ***
    GW [00:00:00.258,178] <inf> fw_info:
             NCS base version: 2.4.2
             Cmake run : Sun Nov 24 16:33:29 2024
    GW [00:00:00.258,209] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.258,209] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.268,829] <inf> board_version: Compatible board/HW version found: 1.0.0
    GW [00:00:00.306,579] <wrn> bt_hci_core: Controller to host flow control not supported
    GW [00:00:00.309,722] <inf> bt_hci_core: No ID address. App must call settings_load()
    GW [00:00:00.309,783] <inf> ble: MAC: 00:00:00:00:00:00 (public)
    GW [00:00:00.310,363] <inf> ble: Controller version: 3349
    GW [00:00:00.312,103] <inf> bt_hci_core: Identity: FF:0B:F2:D9:88:E8 (random)
    GW [00:00:00.312,133] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
    GW [00:00:00.312,133] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
    GW [00:00:00.402,526] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:00.404,632] <inf> cis_gateway: Scanning successfully started
    GW [00:00:00.725,189] <inf> cis_gateway: Connected: D7:4A:8E:D1:8F:D7 (random)
    GW [00:00:01.416,992] <inf> cis_gateway: All headsets connected
    GW [00:00:02.537,963] <inf> cis_gateway: LEFT sink stream configured
    GW [00:00:02.937,042] <inf> ble_audio_services: VCS discover finished
    GW [00:00:04.217,895] <inf> cis_gateway: LEFT source stream configured
    GW [00:00:04.297,241] <inf> cis_gateway: Enable stream 0x20002b9c
    GW [00:00:04.297,912] <inf> cis_gateway: Enable stream 0x2000297c
    GW [00:00:04.657,867] <inf> cis_gateway: Stream 0x2000297c started
    GW [00:00:04.681,427] <wrn> bt_hci_core: opcode 0x2061 status 0x0c
    GW [00:00:04.690,856] <wrn> bt_hci_core: opcode 0x2061 status 0x0c
    GW [00:00:04.897,399] <inf> cis_gateway: Stream 0x20002b9c started
    The log outputs of the Headset:
    HL [00:00:00.259,368] <inf> fw_info:
             Cmake run : Sun Nov 24 16:31:16 2024
    HL [00:00:00.259,368] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.259,368] <inf> fw_info: HEADSET left device
    HL [00:00:00.270,019] <inf> board_version: Compatible board/HW version found: 1.0.0
    HL [00:00:00.307,800] <wrn> bt_hci_core: Controller to host flow control not supported
    HL [00:00:00.310,882] <inf> bt_hci_core: No ID address. App must call settings_load()
    HL [00:00:00.310,974] <inf> ble: MAC: 00:00:00:00:00:00 (public)
    HL [00:00:00.311,523] <inf> ble: Controller version: 3349
    HL [00:00:00.313,079] <inf> bt_hci_core: Identity: D7:4A:8E:D1:8F:D7 (random)
    HL [00:00:00.313,110] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
    HL [00:00:00.313,110] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
    HL [00:00:00.406,707] <inf> cis_headset: Set direct advertising to FF:0B:F2:D9:88:E8 (random)
    HL [00:00:00.407,409] <inf> cis_headset: Advertising successfully started
    HL [00:00:03.134,887] <inf> cis_headset: Connected: FF:0B:F2:D9:88:E8 (random)
    HL [00:00:04.907,409] <inf> cis_headset: LC3 codec config for sink:
    HL [00:00:04.907,440] <inf> cis_headset:        Frequency: 48000 Hz
    HL [00:00:04.907,440] <inf> cis_headset:        Frame Duration: 10000 us
    HL [00:00:04.907,470] <inf> cis_headset:        Channel allocation: 0x1
    HL [00:00:04.907,470] <inf> cis_headset:        Octets per frame: 80 (64000 bps)
    HL [00:00:04.907,470] <inf> cis_headset:        Frames per SDU: 1
    HL [00:00:06.586,669] <inf> cis_headset: LC3 codec config for source:
    HL [00:00:06.586,700] <inf> cis_headset:        Frequency: 48000 Hz
    HL [00:00:06.586,700] <inf> cis_headset:        Frame Duration: 10000 us
    HL [00:00:06.586,700] <inf> cis_headset:        Channel allocation: 0x1
    HL [00:00:06.586,700] <inf> cis_headset:        Octets per frame: 80 (64000 bps)
    HL [00:00:06.586,730] <inf> cis_headset:        Frames per SDU: 1
    HL [00:00:06.667,053] <inf> streamctrl: Presentation delay 10000 us is set by initiator
    HL [00:00:06.667,083] <inf> streamctrl: Presentation delay 10000 us is set by initiator
    HL [00:00:07.032,989] <inf> cis_headset: Stream 0x2000ce40 started
    DAC L gain 112
    DAC R gain 112
    HL [00:00:07.102,600] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:00:07.105,560] <wrn> audio_datapath: Data received, total underruns: 54
    HL [00:00:07.146,575] <wrn> audio_datapath: Data received, total underruns: 55
    HL [00:00:07.187,561] <wrn> audio_datapath: Data received, total underruns: 56
    HL [00:00:07.202,575] <inf> audio_datapath: Drft comp state: INIT
    HL [00:00:07.203,582] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:00:07.266,540] <inf> cis_headset: Stream 0x2000ce64 started
    HL [00:00:07.303,588] <inf> audio_datapath: Drft comp state: OFFSET
    HL [00:00:07.685,821] <inf> audio_datapath: Drft comp state: LOCKED
    HL [00:00:07.692,657] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:07.802,917] <inf> audio_datapath: Pres comp state: WAIT
    HL [00:00:07.942,718] <inf> audio_datapath: Pres comp state: INIT
    HL [00:00:07.952,697] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:08.062,927] <inf> audio_datapath: Pres comp state: LOCKED
    HL [00:00:08.666,046] <inf> ble_audio_services: Discovery of MCS finished
    One of the problems I am currently facing is that the gateway cannot reconnect to the headset after it has been turned off. To re-establish the connection, I have to press the reset button.
    GW [00:00:00.256,622] <inf> fw_info:
    GW [00:00:00.256,652] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.256,652] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.267,272] <inf> board_version: Compatible board/HW version found: 1.0.0
    GW [00:00:00.305,145] <wrn> bt_hci_core: Controller to host flow control not supported
    GW [00:00:00.308,258] <inf> bt_hci_core: No ID address. App must call settings_load()
    GW [00:00:00.308,319] <inf> ble: MAC: 00:00:00:00:00:00 (public)
    GW [00:00:00.308,898] <inf> ble: Controller version: 3349
    GW [00:00:00.310,424] <inf> bt_hci_core: Identity: FF:0B:F2:D9:88:E8 (random)
    GW [00:00:00.310,455] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0d15, manufacturer 0x07e8
    GW [00:00:00.310,485] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
    GW [00:00:00.403,228] <inf> cis_gateway: Scanning successfully started
    GW [00:00:00.604,553] <inf> cis_gateway: Connected: 49:EF:87:0B:C2:BA (random)
    GW [00:00:01.575,439] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:01.576,202] <inf> cis_gateway: Scanning successfully started
    GW [00:00:02.135,437] <wrn> cis_gateway: Connection not found
    GW [00:00:02.135,437] <err> cis_gateway: Unknown connection, should not reach here
    GW [00:00:02.149,871] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:02.150,024] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:02.150,604] <inf> cis_gateway: Scanning successfully started
    GW [00:00:02.372,070] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:02.372,192] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:02.372,863] <inf> cis_gateway: Scanning successfully started
    GW [00:00:02.474,884] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:02.475,036] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:02.475,616] <inf> cis_gateway: Scanning successfully started
    GW [00:00:02.572,875] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:02.573,028] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:02.573,577] <inf> cis_gateway: Scanning successfully started
    GW [00:00:02.615,356] <wrn> cis_gateway: Connection not found
    GW [00:00:02.615,386] <err> cis_gateway: Unknown connection, should not reach here
    GW [00:00:02.673,645] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:02.673,797] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:02.674,560] <inf> cis_gateway: Scanning successfully started
    GW [00:00:02.793,609] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:02.793,792] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:02.794,555] <inf> cis_gateway: Scanning successfully started
    GW [00:00:02.891,998] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:02.892,150] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:02.892,883] <inf> cis_gateway: Scanning successfully started
    GW [00:00:03.007,904] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:03.008,056] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:03.008,636] <inf> cis_gateway: Scanning successfully started
    GW [00:00:03.109,130] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:03.109,283] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:03.109,893] <inf> cis_gateway: Scanning successfully started
    GW [00:00:03.209,899] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:03.210,052] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:03.210,632] <inf> cis_gateway: Scanning successfully started
    GW [00:00:03.419,921] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:03.420,074] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:03.420,623] <inf> cis_gateway: Scanning successfully started
    GW [00:00:03.629,272] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:03.629,425] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:03.630,187] <inf> cis_gateway: Scanning successfully started
    GW [00:00:03.732,025] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:03.732,177] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:03.732,910] <inf> cis_gateway: Scanning successfully started
    GW [00:00:03.837,585] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:03.837,738] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:03.838,500] <inf> cis_gateway: Scanning successfully started
    GW [00:00:03.946,136] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:03.946,258] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:03.946,929] <inf> cis_gateway: Scanning successfully started
    GW [00:00:04.052,032] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:04.052,185] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:04.052,917] <inf> cis_gateway: Scanning successfully started
    GW [00:00:04.161,071] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:04.161,224] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:04.161,926] <inf> cis_gateway: Scanning successfully started
    GW [00:00:04.372,070] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:04.372,192] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:04.372,955] <inf> cis_gateway: Scanning successfully started
    GW [00:00:04.487,640] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:04.487,792] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:04.488,555] <inf> cis_gateway: Scanning successfully started
    GW [00:00:04.588,012] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:04.588,165] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:04.588,928] <inf> cis_gateway: Scanning successfully started
    GW [00:00:04.692,962] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:04.693,084] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:04.693,664] <inf> cis_gateway: Scanning successfully started
    GW [00:00:04.804,138] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:04.804,290] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:04.804,962] <inf> cis_gateway: Scanning successfully started
    GW [00:00:04.913,696] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:04.913,879] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:04.914,611] <inf> cis_gateway: Scanning successfully started
    GW [00:00:05.131,286] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:05.131,439] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:05.132,049] <inf> cis_gateway: Scanning successfully started
    GW [00:00:05.233,703] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:05.233,886] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:05.234,619] <inf> cis_gateway: Scanning successfully started
    GW [00:00:05.346,527] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:05.346,679] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:05.347,351] <inf> cis_gateway: Scanning successfully started
    GW [00:00:05.550,994] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:05.551,116] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:05.551,727] <inf> cis_gateway: Scanning successfully started
    GW [00:00:05.652,008] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:05.652,130] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:05.652,709] <inf> cis_gateway: Scanning successfully started
    GW [00:00:05.772,125] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:05.772,247] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:05.772,979] <inf> cis_gateway: Scanning successfully started
    GW [00:00:05.873,413] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:05.873,565] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:05.874,298] <inf> cis_gateway: Scanning successfully started
    GW [00:00:05.972,106] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:05.972,259] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:05.972,991] <inf> cis_gateway: Scanning successfully started
    GW [00:00:06.080,535] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:06.080,657] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:06.081,329] <inf> cis_gateway: Scanning successfully started
    GW [00:00:06.178,802] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:06.178,924] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:06.179,687] <inf> cis_gateway: Scanning successfully started
    GW [00:00:06.281,127] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:06.281,280] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:06.282,012] <inf> cis_gateway: Scanning successfully started
    GW [00:00:06.394,012] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:06.394,165] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:06.394,744] <inf> cis_gateway: Scanning successfully started
    GW [00:00:06.603,546] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:06.603,698] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:06.604,370] <inf> cis_gateway: Scanning successfully started
    GW [00:00:06.708,038] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:06.708,190] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:06.708,770] <inf> cis_gateway: Scanning successfully started
    GW [00:00:06.811,676] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:06.811,859] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:06.812,591] <inf> cis_gateway: Scanning successfully started
    GW [00:00:06.913,757] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:06.913,909] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:06.914,642] <inf> cis_gateway: Scanning successfully started
    GW [00:00:07.033,142] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:07.033,264] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:07.034,027] <inf> cis_gateway: Scanning successfully started
    GW [00:00:07.124,237] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:07.124,359] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:07.125,030] <inf> cis_gateway: Scanning successfully started
    GW [00:00:07.233,795] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:07.233,947] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:07.234,680] <inf> cis_gateway: Scanning successfully started
    GW [00:00:07.452,056] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:07.452,209] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:07.452,758] <inf> cis_gateway: Scanning successfully started
    GW [00:00:07.548,614] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:07.548,736] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:07.549,407] <inf> cis_gateway: Scanning successfully started
    GW [00:00:07.652,160] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:07.652,313] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:07.653,045] <inf> cis_gateway: Scanning successfully started
    GW [00:00:07.753,814] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:07.753,967] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:07.754,699] <inf> cis_gateway: Scanning successfully started
    GW [00:00:07.972,198] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:07.972,320] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:07.973,052] <inf> cis_gateway: Scanning successfully started
    GW [00:00:08.073,822] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:08.073,974] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:08.074,707] <inf> cis_gateway: Scanning successfully started
    GW [00:00:08.168,762] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:08.168,945] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:08.169,677] <inf> cis_gateway: Scanning successfully started
    GW [00:00:08.273,803] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:08.273,986] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:08.274,719] <inf> cis_gateway: Scanning successfully started
    GW [00:00:08.492,218] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:08.492,340] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:08.493,072] <inf> cis_gateway: Scanning successfully started
    GW [00:00:08.593,841] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:08.593,994] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:08.594,726] <inf> cis_gateway: Scanning successfully started
    GW [00:00:08.692,199] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:08.692,352] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:08.693,084] <inf> cis_gateway: Scanning successfully started
    GW [00:00:08.800,903] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:08.801,025] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:08.801,757] <inf> cis_gateway: Scanning successfully started
    GW [00:00:08.913,116] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:08.913,238] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:08.913,848] <inf> cis_gateway: Scanning successfully started
    GW [00:00:09.445,343] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:09.445,465] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:09.446,105] <inf> cis_gateway: Scanning successfully started
    GW [00:00:09.652,252] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:09.652,374] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:09.653,137] <inf> cis_gateway: Scanning successfully started
    GW [00:00:09.751,220] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:09.751,373] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:09.752,105] <inf> cis_gateway: Scanning successfully started
    GW [00:00:10.161,163] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:10.161,315] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:10.161,895] <inf> cis_gateway: Scanning successfully started
    GW [00:00:10.271,789] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:10.271,942] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:10.272,705] <inf> cis_gateway: Scanning successfully started
    GW [00:00:10.369,934] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:10.370,086] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:10.370,819] <inf> cis_gateway: Scanning successfully started
    GW [00:00:10.472,229] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:10.472,381] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:10.473,144] <inf> cis_gateway: Scanning successfully started
    GW [00:00:10.683,166] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:10.683,319] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:10.683,898] <inf> cis_gateway: Scanning successfully started
    GW [00:00:10.792,846] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:10.792,999] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:10.793,731] <inf> cis_gateway: Scanning successfully started
    GW [00:00:10.900,573] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:10.900,726] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:10.901,489] <inf> cis_gateway: Scanning successfully started
    GW [00:00:11.000,579] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:11.000,732] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:11.001,464] <inf> cis_gateway: Scanning successfully started
    GW [00:00:11.111,267] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:11.111,419] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:11.112,182] <inf> cis_gateway: Scanning successfully started
    GW [00:00:11.203,430] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:11.203,552] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:11.204,162] <inf> cis_gateway: Scanning successfully started
    GW [00:00:11.313,934] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:11.314,086] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:11.314,819] <inf> cis_gateway: Scanning successfully started
    GW [00:00:11.528,259] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:11.528,411] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:11.529,174] <inf> cis_gateway: Scanning successfully started
    GW [00:00:11.633,911] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:11.634,094] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:11.634,796] <inf> cis_gateway: Scanning successfully started
    GW [00:00:11.733,215] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:11.733,337] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:11.733,947] <inf> cis_gateway: Scanning successfully started
    GW [00:00:11.849,884] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:11.850,036] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:11.850,769] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.046,508] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.046,661] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.047,241] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.153,961] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.154,113] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.154,846] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.371,215] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.371,368] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.371,948] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.473,968] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.474,121] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.474,884] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.572,326] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.572,479] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.573,242] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.673,980] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.674,133] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.674,865] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.773,223] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.773,376] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.773,956] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.879,486] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.879,608] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.880,218] <inf> cis_gateway: Scanning successfully started
    GW [00:00:12.985,260] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:12.985,382] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:12.985,992] <inf> cis_gateway: Scanning successfully started
    GW [00:00:13.092,346] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:13.092,498] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:13.093,231] <inf> cis_gateway: Scanning successfully started
    GW [00:00:13.190,551] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:13.190,673] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:13.191,253] <inf> cis_gateway: Scanning successfully started
    GW [00:00:13.401,947] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:13.402,130] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:13.402,862] <inf> cis_gateway: Scanning successfully started
    GW [00:00:13.510,955] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:13.511,108] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:13.511,871] <inf> cis_gateway: Scanning successfully started
    GW [00:00:13.611,938] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:13.612,091] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:13.612,854] <inf> cis_gateway: Scanning successfully started
    GW [00:00:13.713,989] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:13.714,172] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:13.714,935] <inf> cis_gateway: Scanning successfully started
    GW [00:00:13.932,373] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:13.932,525] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:13.933,258] <inf> cis_gateway: Scanning successfully started
    GW [00:00:14.026,306] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:14.026,428] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:14.027,038] <inf> cis_gateway: Scanning successfully started
    GW [00:00:14.133,270] <wrn> cis_gateway: Create ACL connection failed: -12
    GW [00:00:14.133,422] <inf> cis_gateway: All bonded slots filled, will not accept new devices
    GW [00:00:14.134,002] <inf> cis_gateway: Scanning successfully started
    GW [00:00:14.350,280] <wrn> cis_gateway: Create ACL connection failed: -12
    I would now like to achieve a stable CIS connection with both channels (left and right) being transmitted. After that, I aim to implement it using a newer SDK version (I am currently using v2.4.2).
    I have tried the approach mentioned in this tickt, but when I add CONFIG_BT_MAX_CONN=2_ to the prj.conf file, I encounter the following error from the gateway:
    GW [00:00:00.256,500] <inf> fw_info:
             Cmake run : Sun Nov 24 16:46:32 2024
    GW [00:00:00.256,530] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.256,530] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.267,150] <inf> board_version: Compatible board/HW version found: 1.0.0
    GW [00:00:00.305,236] <wrn> bt_hci_core: Controller to host flow control not supported
    GW [00:00:00.308,349] <inf> bt_hci_core: No ID address. App must call settings_load()
    GW [00:00:00.308,441] <inf> ble: MAC: 00:00:00:00:00:00 (public)
    GW [00:00:00.308,990] <inf> ble: Controller version: 3349
    GW [00:00:00.312,133] <inf> bt_hci_core: Identity: E4:C0:9C:97:EF:97 (random)
    GW [00:00:00.312,133] <inf> bt_hci_core: HCI: version 5.GW [00:00:00.312,164] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x0d15
    GW [00:00:00.313,842] <inf> bt_settings: Saving ID
    GW [00:00:00.400,390] <err> cis_gateway: Failed to create unicast group: -22
    GW [00:00:00.400,390] <err> streamctrl: Failed to enable LE Audio
    GW [00:00:00.400,421] <err> streamctrl: ERR_CHK Err_code: [-22] @ line: 467
    GW [00:00:00.400,421] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000005  r2/a3:  0x00000004
    GW [00:00:00.400,421] <err> os: r3/a4:  0x0006a3ff r12/ip:  0x20019140 r14/lr:  0x0006a489
    GW [00:00:00.400,451] <err> os:  xpsr:  0x49100000
    GW [00:00:00.400,451] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    GW [00:00:00.400,451] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    GW [00:00:00.400,451] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    GW [00:00:00.400,482] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
    GW [00:00:00.400,482] <err> os: fpscr:  0x00000000
    GW [00:00:00.400,482] <err> os: Faulting instruction address (r15/pc): 0x00006736
    GW [00:00:00.400,512] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    GW [00:00:00.400,543] <err> os: Current thread: 0x200051b0 (main)
    GW [00:00:00.400,543] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
    Should you require further details, I am happy to assist.
    Many thanks in advance; I truly appreciate your assistance.
