Modem shell testing for DECT NR+
I'm running into an issue with the "modem shell for NR+" application on a pair of nrf9131ek evaluation kits. The local sales rep. suggested that I reach out to Nordic Support.
The modem firmware (mfw-nr+_nrf91x1_1.0.1.zip) and application (mosh-dect-phy-0.7.0-fmac-nrf9131ek.hex) flashed successfully. However, the set auto channel selection & beacon_start commands show as unknown / not found.
mosh:~$ dect sett -c 0 --b_del_channel 0 --b_ul_channel 0 --b_name sink -s yes
Unknown option. See usage:
Usage: dect sett <options>
mosh:~$ dect beacn_start
beacn_start: subcommand not found
I was able to set the correct DECT band set.
mosh:~$ dect sett -r
Common settings:
  network id (32bit).............................305419896 (0x12345678)
  transmitter id (long RD ID)....................38 (0x00000026)
  short RD ID....................................26775 (0x6897)
  band number....................................9
Common RSSI scanning settings:
  ch access: RSSI scan (msecs) per ch............2010
  ch access: RSSI scan busy (dBm):...............signal level > -72
  ch access: RSSI scan possible (dBm):...........-72 >= signal level > -85
  ch access: RSSI scan free (dBm):...............signal level <= -85
Scheduler common settings:
  scheduling offset/delay (us).............................10000
Common HARQ settings:
  Modem init HARQ process count............................4
  Modem init HARQ RX buffer expiry time (in microseconds)..2500000
  HARQ feedback RX delay (subslots)........................4
  HARQ feedback RX duration (subslots).....................18
  HARQ feedback TX delay (subslots)........................4
mosh:~$
Is there a more updated version of the model shell application that supports these commands? Thanks.
Ravi
