NVS sample works depending on used toolchain
I am getting started in a project where I am using the nrf52840 dongle to develop. One of my goals is to keep the toolchain up to date, so I started working with the 2.7.0 SDK and toolchain.
When flashing the .hex file after building, I get the following output:
*** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
[00:00:00.319,793] <dbg> fs_nvs: nvs_recover_last_ate: Recovering last ate from sector 0
[00:00:00.330,535] <dbg> fs_nvs: nvs_add_gc_done_ate: Adding gc done ate at ff0
[00:00:00.334,533] <err> os: ***** BUS FAULT *****
[00:00:00.337,280] <err> os:   Imprecise data bus error
[00:00:00.340,240] <err> os: r0/a1:  0x000faff0  r1/a2:  0x0000ffff  r2/a3:  0x4001e000
[00:00:00.344,635] <err> os: r3/a4:  0x80000000 r12/ip:  0x00000000 r14/lr:  0x00008b9b
[00:00:00.348,968] <err> os:  xpsr:  0x81000000
[00:00:00.351,623] <err> os: Faulting instruction address (r15/pc): 0x00008b44
[00:00:00.355,621] <err> os: >>> ZEPHYR FATAL ERROR 26: Unknown error on CPU 0
[00:00:00.359,588] <err> os: Current thread: 0x200005c8 (unknown)
[00:00:00.363,006] <err> os: Halting system
Other examples that made use of settings and storage using another toolchain worked, so I built the sample again using different toolchains and SDK up until the 2.6.2, and they all worked, I got the folowing output from it:
*** Booting nRF Connect SDK 4040aa0bf581 ***
[00:00:00.317,230] <dbg> fs_nvs: nvs_recover_last_ate: Recovering last ate from sector 1
[00:00:00.327,545] <inf> fs_nvs: 3 Sectors of 4096 bytes
[00:00:00.330,474] <inf> fs_nvs: alloc wra: 1, d18
[00:00:00.333,190] <inf> fs_nvs: data wra: 1, 16c
Id: 1, Address: 192.168.1.1
Id: 2, Key: ff fe fd fc fb fa f9 f8
Id: 3, Reboot_counter: 5
Id: 4, Data: DATA
Id: 5, Longarray: 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 78 79 7a 7b 7c 7d 7e 7f
Reboot counter history: ...5...4...3...2...1...0...400...399...398...397...396...395...394...393...392...391...390...389...388...387...386...385...384...383...382...381...380...379...378...377...376...375...374...373...372...371...370...369...368...367...366...365...364...363...362...361...360...359...358...357...356...355...354...353...352...351...350...349...348...347...346...345...344...343...342...341...340...339...338...337...336...335...334...333...332...331...330...329...328...327...326...325...324...323...322...321...320...319...318...317...316...315...314...313...312...311...310...309...308...307...306...305...304...303...302...301...300...299...298...297...296...295...294...293...292...291...290...289...288...287...286...285...284...283...282...281...280...279...278...277...276...275...274...273...272...271...270...269...268...267...266...265...264...263...262...261...260...259...258...257...256...255...254...253...252...251...250...249...248...247...246...245...244...243...242...241...240...239...238...237...236...235...234...233...232...231...230...229...228...227...226...225...224...223...222...221...220...219...218...217...216...215...214...213...212...211...210...209...208...207...206...205...204...203...202...201...200...199...198...197...196...195...194...193...192...191...190...189...188...187...186...185...184...183...182...181...180...179...178...177...176...175...174...173...172...171...170...169...168...167...166...165...164...163...162...161...160...159...158...157...156...155...154...153...152...151...150...149...148...147...146...145...144...143...142...141...140...139...138...137...136...135...134...133...132...131...130...129...128...127...126...125...124...123...122...121...120...119...118...117...116...115...114...113...112...111...110...109...108...107...106...105...104...103...102...101...100...99...98...97...96...95...94...93...92...91...90...89...88...87...86...85...84...83...82...81...80...79...78...77...76...75...74...73...72...71...70...69...68...67...66...65...64...63...62...61...60...59...58...57...56...55...54...53...52...51...50...49...48...47...46...45...44...43...42...41...40...39...38...37...36...35...34...33...32...31...30...29...28...27...26...25...24...23...22...21...20...19...18...17...16...15...14...13...12...11...10...9...8...7...6...5...4...3...2...1...0
Oldest reboot counter: 0
Rebooting in ...5...4...3...2...1
I went through the .config files that got generated and I could not find anything that seems to have an influence in this behavior.
The sample code was not modified, and the overlay was only modified to get the UART output out of some soldered pins.
