Encountered error -102: Unable to connect to a debugger.
Hi!
Recently, I tried putting my nrf9160dk into SYSTEM OFF mode. The code instantly puts it into SYSTEM OFF mode and waits for a gpio interrupt. The problem however is that the code for some reason does not work and the board is stuck in SYSTEM OFF mode. So i tried reflashing it but when i use west flash i get this error:
[error] [ Client] - Encountered error -102: Command read_device_info executed for 136 milliseconds with result -102
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 33 milliseconds with result -102
Failed to read device memories.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program /home/raytoningu/flox_zephyr_workspace/ws/apps/deepsleep_test/build/zephyr/merged.hex --sectorerase --verify -f NRF91 --snr 960083536
If i try things like nrfjprog --recover i get a similar error:
[error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 674 milliseconds with result -102
ERROR: Unable to connect to a debugger.
I know that the board is stuck in deepsleep since the measured current is around 2 microampere. What can I do to reset the board?
    This was the command
    nrfutil device erase --serial-number 960083536
    It also cannot be erased using the Programmer tool.
    Thank you for additional information.
    Which specific version of the nrf9160-dk device do you use?
    Can you elaborate on this? Please provide detailed information about your application and the steps you took to put your device to SYSTEM OFF mode.
    Dejan
    So basically the code is setting the card into SYSTEM OFF with these lines:
    nrf_modem_lib_init();
    lte_lc_power_off();
    k_sleep(K_MSEC(1000));
    NRF_REGULATORS->SYSTEMOFF = 1;
    Before this i also set a wakeup interrupt pin with:
    nrf_gpio_cfg_input(NRF_DT_GPIOS_TO_PSEL(INPUT_PIN_NODE, gpios),
    			   NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_sense_set(NRF_DT_GPIOS_TO_PSEL(INPUT_PIN_NODE, gpios),
    		       NRF_GPIO_PIN_SENSE_LOW);
    My suspicion is that since i have no delays, as soon as i wake up the board it's probably quickly going into SYSTEM OFF mode again.
    prj.conf:
    CONFIG_PM_DEVICE=y
    CONFIG_GPIO=y
    CONFIG_CRC=y
    CONFIG_POWEROFF=y
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    CONFIG_NRF_MODEM_LIB=y
    Ray
  • Hi Ray,
    Can you provide full log when running the commands shown below?
    Recover command
    nrfutil device recover --serial-number <device_serial_number> --x-family nrf91 --json-pretty --log-output stdout --log-level trace
    Erase command
    nrfutil device erase --serial-number <device_serial_number> --all --x-family nrf91 --json-pretty --log-output stdout --log-level trace
    Dejan
  • Hi, Here are the full logs for both the commands:
    nrfutil device recover --serial-number 960083536  --x-family nrf91 --json-pretty --log-output stdout --log-level trace
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "nrfutil-device (version = 2.7.6, platform = x86_64-unknown-linux-gnu) invoked with recover --serial-number 960083536 --x-family nrf91 --json-pretty --log-output stdout --log-level trace ",
        "timestamp": "2024-12-04T08:55:25.464Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be /home/raytoningu/.nrfutil/lib/nrfutil-device",
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "Starting parent process watchdog, current parent process ID: 5678",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] C API function: get_version_list",
        "timestamp": "2024-12-04T08:55:26.588Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[devkit] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED",
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "[ProbeLib] [2024-12-04 08:55:27.218731Z] Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 7.94i",
        "timestamp": "2024-12-04T08:55:27.218Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] open",
        "timestamp": "2024-12-04T08:55:27.225Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] start",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger",
        "timestamp": "2024-12-04T08:55:27.549Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] open",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] just_check_family",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] open_dll",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command open executed for 10 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:27.557Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] jlink_dll_version",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode",
        "timestamp": "2024-12-04T08:55:27.559Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] dll_version",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command open executed for 8 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] dll_version",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:27.560Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] close",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] close",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command close executed for 11 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:27.569Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] terminate",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command close executed for 11 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 19 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] Child process terminated with result 0",
        "timestamp": "2024-12-04T08:55:27.580Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Executed 4 commands for 21 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:27.581Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[boardController] C API function: get_version_list",
        "timestamp": "2024-12-04T08:55:27.594Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[boardController] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "operation to get devices for : Ok(\"{\\\"family\\\":\\\"NRF91_FAMILY\\\",\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"recover\\\"},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "Operations required by a device to do: {\"recover\"}",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Checking future_status of enumerate_task_status",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Waiting for enumeration to complete",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate::enumerate_task: Start",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate",
        "timestamp": "2024-12-04T08:55:27.595Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: enumerate",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: Found device: /sys/devices/pci0000:00/0000:00:14.0/usb1",
        "timestamp": "2024-12-04T08:55:27.600Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: USB information: serial_number=0000:00:14.0, product_id=0x0002, vendor_id=0x1d6b, product=xHCI Host Controller, manufacturer=Linux 5.15.0-125-generic xhci-hcd",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: Found device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-1",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: USB information: serial_number=000960083536, product_id=0x1055, vendor_id=0x1366, product=J-Link, manufacturer=SEGGER",
        "timestamp": "2024-12-04T08:55:27.601Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: Found device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-10",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: USB information: serial_number=00e04c000001, product_id=0x3529, vendor_id=0x13d3, product=Bluetooth Radio , manufacturer=Realtek ",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: Found device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-4",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: USB information: serial_number=20100201396000000, product_id=0x0129, vendor_id=0x0bda, product=USB2.0-CRW, manufacturer=Generic",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: Found device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-5",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: USB information: serial_number= , product_id=0x5a11, vendor_id=0x13d3, product=USB2.0 VGA UVC WebCam, manufacturer=Azurewave",
        "timestamp": "2024-12-04T08:55:27.602Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: Found device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-6",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: USB information: serial_number=S6XNNS0TB06263R, product_id=0x4001, vendor_id=0x04e8, product=PSSD T7, manufacturer=Samsung",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: Found device: /sys/devices/pci0000:00/0000:00:14.0/usb2",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: USB information: serial_number=0000:00:14.0, product_id=0x0003, vendor_id=0x1d6b, product=xHCI Host Controller, manufacturer=Linux 5.15.0-125-generic xhci-hcd",
        "timestamp": "2024-12-04T08:55:27.603Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 1 and serial number: 'S6XNNS0TB06263R'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 2 and serial number: '20100201396000000'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 3 and serial number: '0000:00:14.0'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 4 and serial number: '000960083536'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 5 and serial number: '00e04c000001'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 6 and serial number: ' '",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 7 and serial number: '0000:00:14.0'",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate::enumerate_task: After async_lister->enumerate",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] C API function: enumerate",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] enumerate: Inspecting device with ID 7",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] enumerate: Inspecting device with ID 6",
        "timestamp": "2024-12-04T08:55:27.606Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] enumerate: Inspecting device with ID 5",
        "timestamp": "2024-12-04T08:55:27.608Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] enumerate: Inspecting device with ID 4",
        "timestamp": "2024-12-04T08:55:27.610Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[devkit] enumerate: Device with ID 4 has board version PCA10090",
        "timestamp": "2024-12-04T08:55:27.611Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] enumerate: Inspecting device with ID 3",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] enumerate: Inspecting device with ID 2",
        "timestamp": "2024-12-04T08:55:27.612Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] enumerate: Inspecting device with ID 1",
        "timestamp": "2024-12-04T08:55:27.614Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'devkit' took 11 ms",
        "timestamp": "2024-12-04T08:55:27.615Z"
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "[ProbeLib] [2024-12-04 08:55:27.616026Z] Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 7.94i",
        "timestamp": "2024-12-04T08:55:27.616Z"
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "[ProbeLib] [2024-12-04 08:55:27.627210Z] Found 1 attached J-Link devices",
        "timestamp": "2024-12-04T08:55:27.627Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'Probe' took 11 ms",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] JLinkPlugin::enumerate",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:27.632Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:27.635Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command open executed for 7 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:27.641Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] enum_emu_snr",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:27.645Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command open executed for 5 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] enum_emu_snr",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 8 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:27.649Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] Found 1 J-Link devices connected",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:27.655Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 8 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T08:55:27.660Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command close executed for 10 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:27.665Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 23 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:27.676Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Executed 4 commands for 26 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'jlink' took 61 ms",
        "timestamp": "2024-12-04T08:55:27.688Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[boardController] C API function: enumerate",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[boardController] Found 7 HID devices.",
        "timestamp": "2024-12-04T08:55:27.689Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'BOARDCONTROLLER' took 0 ms",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[serialport] Linux serialport enumerate.",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[serialport] get_lister_item: sys_path = /sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/tty/ttyACM0",
        "timestamp": "2024-12-04T08:55:27.700Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[serialport] get_lister_item: devnode = /dev/ttyACM0",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[serialport] parent syspath: /sys/devices/pci0000:00/0000:00:14.0/usb1",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[serialport] set container ID: /sys/devices/pci0000:00/0000:00:14.0/usb1",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[serialport] get_lister_item: sys_path = /sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/tty/ttyACM1",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[serialport] get_lister_item: devnode = /dev/ttyACM1",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:27.701Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[serialport] get_lister_item: sys_path = /sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.4/tty/ttyACM2",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[serialport] get_lister_item: devnode = /dev/ttyACM2",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[serialport] try to map FTDI to segger device",
        "timestamp": "2024-12-04T08:55:27.710Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[serialport] serialport enumerate update device: '000960083536'",
        "timestamp": "2024-12-04T08:55:27.711Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'serialport' took 21 ms",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'sdfu' took 0 ms",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'mcuBoot' took 0 ms",
        "timestamp": "2024-12-04T08:55:27.712Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[broken] BrokenPlugin::enumerate",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'broken' took 0 ms",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Found device with serial number: '0000:00:14.0'",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Found device with serial number: ' '",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Found device with serial number: '00e04c000001'",
        "timestamp": "2024-12-04T08:55:27.713Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Found device with serial number: '000960083536'",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: device registered to device list",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Found device with serial number: '20100201396000000'",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Found device with serial number: 'S6XNNS0TB06263R'",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Finished in 118 ms",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Completed waiting for enumeration",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: done",
      "type": "task_begin",
      "data": {
        "task": {
          "id": "cd4403c6f4804c56bc3a6a76e5d0dbc7",
          "description": "Recover 960083536",
          "name": "recover",
          "data": {
            "serialNumber": "000960083536"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] C API function: supports_device_operations",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[ProbeLib] [2024-12-04 08:55:27.713611Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[ProbeLib] [2024-12-04 08:55:27.713648Z] Target device family nRF91 is provided, using that to determine if probe-plugin should be used",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[ProbeLib] [2024-12-04 08:55:27.713655Z] Device family nRF91 not NRF54H/NRF54L, not supported by probe-plugin",
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "Loaded plugin /home/raytoningu/.nrfutil/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl; starting to resolve symbols",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] NRFDL::JLinkPlugin::JLinkPLugin()",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] Initializing the J-Link debug probe for device {\"devkit\":{\"boardVersion\":\"PCA10090\",\"deviceFamily\":\"NRF91_FAMILY\"},\"id\":4,\"probe\":{},\"serialNumber\":\"000960083536\",\"serialPorts\":[{\"comName\":\"/dev/ttyACM0\",\"manufacturer\":\"SEGGER\",\"path\":\"/dev/ttyACM0\",\"productId\":\"1055\",\"serialNumber\":\"000960083536\",\"vcom\":0,\"vendorId\":\"1366\"},{\"comName\":\"/dev/ttyACM1\",\"manufacturer\":\"SEGGER\",\"path\":\"/dev/ttyACM1\",\"productId\":\"1055\",\"serialNumber\":\"000960083536\",\"vcom\":1,\"vendorId\":\"1366\"},{\"comName\":\"/dev/ttyACM2\",\"manufacturer\":\"SEGGER\",\"path\":\"/dev/ttyACM2\",\"productId\":\"1055\",\"serialNumber\":\"000960083536\",\"vcom\":2,\"vendorId\":\"1366\"}],\"traits\":{\"boardController\":false,\"broken\":false,\"devkit\":true,\"jlink\":true,\"mcuBoot\":false,\"modem\":true,\"nordicDfu\":false,\"nordicUsb\":false,\"seggerUsb\":true,\"serialPorts\":true,\"usb\":true},\"usb\":{\"device\":{\"address\":6,\"busNumber\":1,\"descriptor\":{\"bDescriptorType\":1,\"bcdDevice\":256,\"idProduct\":4181,\"idVendor\":4966}},\"manufacturer\":\"SEGGER\",\"osDevicePath\":\"/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1\",\"product\":\"J-Link\",\"serialNumber\":\"000960083536\"},\"usbIdentifier\":\"/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1\"} with serial number: 000960083536",
        "timestamp": "2024-12-04T08:55:27.714Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] Opening J-Link DLL",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][000960083536] open",
        "timestamp": "2024-12-04T08:55:27.719Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][000960083536] start",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] jprog progress event disabled",
        "timestamp": "2024-12-04T08:55:27.722Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Logger sink registered in Segger backend logger",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] Logger sink registered in JLink logger",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][000960083536] open",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][000960083536] just_check_family",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] open_dll",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] No J-Link DLL path was provided. Attempting to auto detect.",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Command open executed for 6 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:27.726Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][000960083536] connect_to_emu_with_snr",
        "timestamp": "2024-12-04T08:55:27.727Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T08:55:27.732Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Set batch mode",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] dll_version",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command open executed for 4 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][000960083536] connect_to_emu_with_snr",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] is_connected_to_emu",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] connect_to_emu_with_snr",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_enum_emu_snr",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_get_num_emus",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_connect_to_emu_with_snr",
        "timestamp": "2024-12-04T08:55:27.742Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_connect_to_emu_without_snr",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Segger logging enabled.",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] Firmware: J-Link OB-K22-NordicSemi compiled Oct 30 2023 12:12:53",
        "timestamp": "2024-12-04T08:55:27.782Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] Hardware: V1.00",
        "timestamp": "2024-12-04T08:55:27.802Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] S/N: 960083536",
        "timestamp": "2024-12-04T08:55:27.803Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] OEM: SEGGER",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] Bootloader: 2018 Aug 07",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] USB speed mode: Full speed (12 MBit/s)",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] TELNET listener socket opened on port 19021",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] WEBSRV WEBSRV_Init(): Starting webserver thread(s)",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] WEBSRV Webserver running on local port 19080",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] Looking for J-Link GUI Server exe at: /opt/SEGGER/JLink/JLinkGUIServerExe ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] Forking J-Link GUI Server: /opt/SEGGER/JLink/JLinkGUIServerExe ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Command connect_to_emu_with_snr executed for 374 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:28.101Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][000960083536] read_device_family",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] Failed to connect to J-Link GUI Server. ",
        "timestamp": "2024-12-04T08:55:28.105Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 323.039ms returns \"O.K.\"  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_HasError()  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_Lock()  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_ExecCommand(\"SetRestartOnClose = 0\", ...).   ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.007ms returns 0x01  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_ExecCommand(\"DisableFlashDL\", ...).   ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.004ms returns 0x00  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T08:55:28.106Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_ExecCommand(\"ExcludeFlashCacheRange 0x0-0xFFFFFFFF\", ...).   ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.003ms returns 0x00  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_SetHookUnsecureDialog  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_SetHookUnsecureDialog(...)",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.031ms returns 0  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_TIF_Select(JLINKARM_TIF_SWD)  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.509ms returns 0x00  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_GetSpeedInfo()  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] 72000000 Hz / n, n >= 36",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.030ms  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Connected emulator supports SWD speeds up to 2000kHz",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_SetSpeed(2000)  ",
        "timestamp": "2024-12-04T08:55:28.107Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.062ms  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_GetSpeed()  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.012ms returns 2000  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] SWD clock set to 2000kHz",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_GetSN()  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.012ms returns 960083536  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.014ms  ",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][000960083536] read_device_family",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command connect_to_emu_with_snr executed for 374 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_IsOpen()  ",
        "timestamp": "2024-12-04T08:55:28.108Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.020ms returns 0x01  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] read_debug_port_idr",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] read_debug_port_register",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_read_debug_port_register",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] coresight_configure",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_GetHWStatus(...)  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.161ms returns 0  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_CORESIGHT_Configure()  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 101.931ms returns 0  ",
        "timestamp": "2024-12-04T08:55:28.206Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_select_debug_port_register",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Select AP 255, DP Bank 0, AP Bank 255",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.608ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_abort_debug_action",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Attempting to clear any configuration errors in debug port before closing connection. ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ",
        "timestamp": "2024-12-04T08:55:28.207Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.554ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.540ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.541ms returns -1  ",
        "timestamp": "2024-12-04T08:55:28.216Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.509ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.501ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.476ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.477ms returns -1  ",
        "timestamp": "2024-12-04T08:55:28.217Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.502ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.495ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.472ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.482ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.539ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.526ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.491ms returns -1  ",
        "timestamp": "2024-12-04T08:55:28.218Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.492ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.478ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.457ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.464ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.465ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T08:55:28.219Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.479ms returns -1  ",
        "timestamp": "2024-12-04T08:55:28.226Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.467ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.468ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T08:55:28.227Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.474ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.499ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.519ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.560ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.494ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.498ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T08:55:28.228Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.527ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.545ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.486ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.490ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "ERROR",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Encountered error -102: Command read_device_family executed for 125 milliseconds with result -102",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.451ms returns -1  ",
        "timestamp": "2024-12-04T08:55:28.236Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.119ms  ",
      "type": "log",
      "data": {
        "level": "ERROR",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] An unknown error.",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command read_device_family executed for 125 milliseconds with result -102",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][000960083536] close",
        "timestamp": "2024-12-04T08:55:28.237Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.012ms returns 0x01  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] close",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] disconnect_from_emu",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_disconnect_from_emu",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] is_connected_to_device",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_IsConnected()  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.008ms returns FALSE  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_is_debug_region_powered",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.461ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.471ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.489ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T08:55:28.238Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 1.446ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.456ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.449ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.481ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.459ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.525ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.454ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T08:55:28.239Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.508ms returns -1  ",
        "timestamp": "2024-12-04T08:55:28.247Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.442ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.447ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.444ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.566ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.505ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.535ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.547ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.452ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.593ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T08:55:28.248Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.510ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.458ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.512ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.469ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.507ms returns -1  ",
        "timestamp": "2024-12-04T08:55:28.257Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.475ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.548ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Ignore exception An unknown error.",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.038ms  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_Close()  ",
        "timestamp": "2024-12-04T08:55:28.267Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Segger Backend closed.",
        "timestamp": "2024-12-04T08:55:28.277Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][000960083536] nRF family DLL closed",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Command close executed for 51 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:28.278Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][000960083536] terminate",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Command terminate executed for 0 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command close executed for 51 milliseconds with result 0",
        "timestamp": "2024-12-04T08:55:28.287Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command terminate executed for 0 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Executed 5 commands for 554 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Worker process exited with code: 0",
        "timestamp": "2024-12-04T08:55:28.299Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Tried to wait on already ended process: wait error: No child processes",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Child process terminated with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Executed 5 commands for 556 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "~async_task id: 1733302527713842",
        "timestamp": "2024-12-04T08:55:28.315Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Task 1733302527713842 is already completed",
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "~plugin_container(0x557972212800): close plugin dll at path: /home/raytoningu/.nrfutil/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl",
      "type": "task_end",
      "data": {
        "task": {
          "name": "recover",
          "data": {
        "message": "Failed to recover 960083536, [jlink] JLINKARM_DLL_ERROR",
        "result": "fail",
        "error": {
          "code": 9,
          "description": "Nrfjlink"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "~plugin_container(0x557972212800): closed plugin dll at path: /home/raytoningu/.nrfutil/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl",
        "timestamp": "2024-12-04T08:55:28.316Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::shutDown()",
    Error: One or more recover tasks failed:
     * 960083536: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
    nrfutil device erase --serial-number 960083536  --x-family nrf91 --json-pretty --log-output stdout --log-level trace
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "nrfutil-device (version = 2.7.6, platform = x86_64-unknown-linux-gnu) invoked with erase --serial-number 960083536 --x-family nrf91 --json-pretty --log-output stdout --log-level trace ",
        "timestamp": "2024-12-04T09:03:04.833Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.834Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "Starting parent process watchdog, current parent process ID: 6265",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.857Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "[ProbeLib] [2024-12-04 09:03:04.857922Z] Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 7.94i",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.862Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.865Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command open executed for 6 milliseconds with result 0",
        "timestamp": "2024-12-04T09:03:04.870Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.875Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command open executed for 4 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.881Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.885Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 14 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.895Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.896Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Executed 4 commands for 17 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.909Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "operation to get devices for : Ok(\"{\\\"family\\\":\\\"NRF91_FAMILY\\\",\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"erase\\\",\\\"option\\\":{\\\"chip_erase_mode\\\":\\\"ERASE_ALL\\\",\\\"qspi_erase_mode\\\":\\\"ERASE_NONE\\\"}},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "Operations required by a device to do: {\"erase\"}",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.917Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.918Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: Found device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-2",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "usb-lister-rs: USB information: serial_number=<unavailable>, product_id=0xc52b, vendor_id=0x046d, product=USB Receiver, manufacturer=Logitech",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.919Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.920Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 1 and serial number: '00e04c000001'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 2 and serial number: '0000:00:14.0'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 3 and serial number: ' '",
        "timestamp": "2024-12-04T09:03:04.921Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 4 and serial number: 'S6XNNS0TB06263R'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 5 and serial number: '0000:00:14.0'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 6 and serial number: '20100201396000000'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 7 and serial number: 'NONE'",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "USBLister: Adding new device with ID 8 and serial number: '000960083536'",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[devkit] enumerate: Inspecting device with ID 8",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[devkit] enumerate: Device with ID 8 has board version PCA10090",
        "timestamp": "2024-12-04T09:03:04.922Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.924Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.925Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.926Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.927Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.929Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'devkit' took 8 ms",
        "timestamp": "2024-12-04T09:03:04.930Z"
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "[ProbeLib] [2024-12-04 09:03:04.930701Z] Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 7.94i",
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "[ProbeLib] [2024-12-04 09:03:04.943439Z] Found 1 attached J-Link devices",
        "timestamp": "2024-12-04T09:03:04.943Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'Probe' took 12 ms",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] open",
        "timestamp": "2024-12-04T09:03:04.949Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] start",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger",
        "timestamp": "2024-12-04T09:03:04.952Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] open",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] just_check_family",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] open_dll",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command open executed for 5 milliseconds with result 0",
        "timestamp": "2024-12-04T09:03:04.956Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode",
        "timestamp": "2024-12-04T09:03:04.962Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] dll_version",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.965Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:04.972Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] close",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] close",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command close executed for 11 milliseconds with result 0",
        "timestamp": "2024-12-04T09:03:04.976Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] terminate",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:04.982Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 22 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0",
        "timestamp": "2024-12-04T09:03:04.993Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] Tried to wait on already ended process: wait error: No child processes",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][Client][-] Child process terminated with result 0",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][-] Executed 4 commands for 24 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'jlink' took 62 ms",
        "timestamp": "2024-12-04T09:03:05.006Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[boardController] Found 15 HID devices.",
        "timestamp": "2024-12-04T09:03:05.009Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'BOARDCONTROLLER' took 2 ms",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.022Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.023Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.024Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.036Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Enumeration for plugin 'serialport' took 27 ms",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.037Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.038Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Found device with serial number: '<unknown>'",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "DeviceLister::enumerate: Finished in 129 ms",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "data": {
        "task": {
          "id": "a4f00aef3a724f5db01b9cd295d30532",
          "description": "Erase 960083536",
          "name": "erase",
          "data": {
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.039Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[ProbeLib] [2024-12-04 09:03:05.039225Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[ProbeLib] [2024-12-04 09:03:05.039245Z] Target device family nRF91 is provided, using that to determine if probe-plugin should be used",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[ProbeLib] [2024-12-04 09:03:05.039248Z] Device family nRF91 not NRF54H/NRF54L, not supported by probe-plugin",
      "type": "log",
      "data": {
        "level": "INFO",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] Initializing the J-Link debug probe for device {\"devkit\":{\"boardVersion\":\"PCA10090\",\"deviceFamily\":\"NRF91_FAMILY\"},\"id\":8,\"probe\":{},\"serialNumber\":\"000960083536\",\"serialPorts\":[{\"comName\":\"/dev/ttyACM0\",\"manufacturer\":\"SEGGER\",\"path\":\"/dev/ttyACM0\",\"productId\":\"1055\",\"serialNumber\":\"000960083536\",\"vcom\":0,\"vendorId\":\"1366\"},{\"comName\":\"/dev/ttyACM1\",\"manufacturer\":\"SEGGER\",\"path\":\"/dev/ttyACM1\",\"productId\":\"1055\",\"serialNumber\":\"000960083536\",\"vcom\":1,\"vendorId\":\"1366\"},{\"comName\":\"/dev/ttyACM2\",\"manufacturer\":\"SEGGER\",\"path\":\"/dev/ttyACM2\",\"productId\":\"1055\",\"serialNumber\":\"000960083536\",\"vcom\":2,\"vendorId\":\"1366\"}],\"traits\":{\"boardController\":false,\"broken\":false,\"devkit\":true,\"jlink\":true,\"mcuBoot\":false,\"modem\":true,\"nordicDfu\":false,\"nordicUsb\":false,\"seggerUsb\":true,\"serialPorts\":true,\"usb\":true},\"usb\":{\"device\":{\"address\":6,\"busNumber\":1,\"descriptor\":{\"bDescriptorType\":1,\"bcdDevice\":256,\"idProduct\":4181,\"idVendor\":4966}},\"manufacturer\":\"SEGGER\",\"osDevicePath\":\"/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1\",\"product\":\"J-Link\",\"serialNumber\":\"000960083536\"},\"usbIdentifier\":\"/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1\"} with serial number: 000960083536",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.044Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.047Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.052Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.057Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command open executed for 5 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.058Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.068Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.098Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.118Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Command connect_to_emu_with_snr executed for 81 milliseconds with result 0",
        "timestamp": "2024-12-04T09:03:05.134Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] J-Link GUI Server info: \"J-Link GUI server V7.94i \" ",
        "timestamp": "2024-12-04T09:03:05.138Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 45.770ms returns \"O.K.\"  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.004ms returns 0x01  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.002ms returns 0x00  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.139Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.017ms returns 0  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.554ms returns 0x00  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.007ms  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.077ms  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.003ms returns 2000  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.003ms returns 960083536  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.004ms  ",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command connect_to_emu_with_snr executed for 81 milliseconds with result 0",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.003ms returns 0x01  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.096ms returns 0  ",
        "timestamp": "2024-12-04T09:03:05.140Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 102.354ms returns 0  ",
        "timestamp": "2024-12-04T09:03:05.240Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.574ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.689ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.241Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.573ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.641ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.588ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.250Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.549ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.251Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.555ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.529ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.595ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.252Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.580ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.616ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.589ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.615ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.253Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.675ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.637ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.666ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.254Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.648ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.260Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.591ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.650ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.261Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.524ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.532ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.262Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.561ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.553ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.546ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.263Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.264Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.682ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.640ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.586ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.265Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.625ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "ERROR",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Encountered error -102: Command read_device_family executed for 132 milliseconds with result -102",
        "timestamp": "2024-12-04T09:03:05.266Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.557ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.270Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.564ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.271Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.565ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_HasError()  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.272Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.562ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.266ms  ",
      "type": "log",
      "data": {
        "level": "ERROR",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command read_device_family executed for 132 milliseconds with result -102",
        "timestamp": "2024-12-04T09:03:05.273Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] is_connected_to_emu",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.032ms returns 0x01  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_Lock()  ",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.029ms returns FALSE  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.274Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.534ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.558ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.275Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.544ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.628ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.281Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.523ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.530ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.282Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.283Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.634ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.599ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.620ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.284Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.630ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.613ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.515ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.720ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.291Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] ---just_abort_debug_action",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "[jlink] [NRFJPROG][SeggerBackend][000960083536] Attempting to clear any configuration errors in debug port before closing connection. ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ",
        "timestamp": "2024-12-04T09:03:05.292Z"
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.592ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.735ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.556ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.610ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.293Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.597ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.294Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.651ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.559ms returns -1  ",
        "timestamp": "2024-12-04T09:03:05.295Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.531ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.296Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.563ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.302Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.567ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.303Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.581ms returns -1  ",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][JLink][000960083536] - 0.149ms  ",
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.312Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.332Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Command close executed for 67 milliseconds with result 0",
        "timestamp": "2024-12-04T09:03:05.334Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Command close executed for 67 milliseconds with result 0",
        "timestamp": "2024-12-04T09:03:05.342Z"
      "type": "log",
      "data": {
        "level": "TRACE",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Worker][000960083536] Executed 5 commands for 285 milliseconds",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "timestamp": "2024-12-04T09:03:05.353Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "TRACE",
        "message": "[jlink] [NRFJPROG][Client][000960083536] Executed 5 commands for 286 milliseconds",
        "timestamp": "2024-12-04T09:03:05.354Z"
      "type": "log",
      "data": {
        "level": "DEBUG",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "~async_task id: 1733302985039391",
        "timestamp": "2024-12-04T09:03:05.366Z"
      "type": "log",
      "data": {
        "level": "INFO",
        "message": "~plugin_container(0x55c92ecfcc50): close plugin dll at path: /home/raytoningu/.nrfutil/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "~plugin_container(0x55c92ecfcc50): closed plugin dll at path: /home/raytoningu/.nrfutil/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl",
      "type": "log",
      "data": {
        "level": "DEBUG",
        "message": "Task 1733302985039391 is already completed",
      "type": "task_end",
      "data": {
        "task": {
          "name": "erase",
          "data": {
            "serialNumber": "000960083536"
        "message": "Failed to erase 960083536, [jlink] JLINKARM_DLL_ERROR",
        "result": "fail",
        "error": {
          "code": 9,
      "type": "log",
      "data": {
        "level": "TRACE",
        "timestamp": "2024-12-04T09:03:05.367Z"
    Error: One or more erase tasks failed:
    Ray
