Encountered error -102: Unable to connect to a debugger.
Hi!
Recently, I tried putting my nrf9160dk into SYSTEM OFF mode. The code instantly puts it into SYSTEM OFF mode and waits for a gpio interrupt. The problem however is that the code for some reason does not work and the board is stuck in SYSTEM OFF mode. So i tried reflashing it but when i use west flash i get this error:
[error] [ Client] - Encountered error -102: Command read_device_info executed for 136 milliseconds with result -102
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 33 milliseconds with result -102
Failed to read device memories.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program /home/raytoningu/flox_zephyr_workspace/ws/apps/deepsleep_test/build/zephyr/merged.hex --sectorerase --verify -f NRF91 --snr 960083536
If i try things like nrfjprog --recover i get a similar error:
[error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 674 milliseconds with result -102
ERROR: Unable to connect to a debugger.
I know that the board is stuck in deepsleep since the measured current is around 2 microampere. What can I do to reset the board?
  • Hi Ray,
    Thank you for additional logs. We will review them. I expect to get back to you tomorrow or during next week.
    Dejan
  • Hi Ray,
    We see that the error happens very early thus preventing nrfjprog and nrfutil to work properly. Since your firmware sleeps for 1 second, there might be just enough time for you to potentially run "nrfjprog --halt" right after you power the board to block the firmware from going to SYSTEM OFF. If this works, you should be able to run "nrfjprog --erase" and "nrfjprog --recover" commands.
    To prevent the board from setting SYSTEM OFF, you could try to run the script
    #!/bin/bash
    while true; do
       nrfjprog --halt
    done
    without any boards connected, and then connecting the board could potentially work.
    Dejan
    I tried your helpful tip however it unfortunately still didn't work. I started the script before connecting the board and the log is continuously saying that it doesn't find a debugger (as it should) but as soon as i connect the board i get the same error as the title of this thread again. Here is the log just before and after i connect the board.
    ERROR: No debuggers were discovered.
    [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 518 milliseconds with result -102
    [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 164 milliseconds with result -102
    Do you think it's bricked?
    Best,
    Ray
  • Hi Ray,
    There is a chapter in the documentation which specifies what needs to be done before entering SYSTEM OFF mode. Have you fulfilled all mentioned preconditions for entering SYSTEM OFF mode?
    Dejan
  • I finally found the problem... The shunt/jumper at p22 on the nrf9160DK was off since i wanted to measure the current. Putting it back on resolved it and i can now flash the board like normal. Thanks for all the help!
