我想了解 NRF5340 Application Core 和 Network Core Shared Memory 的工作原理
Hi Xunard,
The nRF5340 SoC contains two Arm Cortex-M33 processor cores - an Application core and a Network core. These cores can communicate with each other through shared memory. The shared memory is accessible by both cores, allowing them to exchange data. The Application core memory is mapped to the Network core memory map, and the Network core can access and use the Application core memory for shared memory communication.
It's important to note that while the Application core can access all Network core memory, the reverse is not true. The Network core cannot execute code directly from the Application core flash or access QSPI XIP memories. See the RF5340 Product Specification.
In the nRF Connect SDK, you can use Interprocessor Communication (IPC) for inter-core communication between the two cores. Communication between the application core and the network core happens through a shared memory area. The application core memory is mapped to the network core memory map. This means that the network core can access and use the application core memory for shared memory communication. See the nRF Connect SDK Documentation.
Amanda H.
hi Amanda H
Is there a recommended routine? I'd like to know how you can communicate between the two cores
I found the IPC Service routine, do I need to create an IPC service if the network kernel and the application kernel share memory with each other?
You can use the HCI IPC for the netcore and BLE applications on the appcore. See Protocols and use cases for the nRF5340 DK.
