How to configure Settings API to work on a specific partition defined in the pm_static.yaml file
I'm trying to get the settings api working with multiple partitions using little FS. Some of the implementation is specific to Nordic and was hoping to get an example of how to do it with the pm_static.yaml. The fs subsystem is working, but I'm not sure how to configure the settings_storage partition to be used for settings.
I have this in my pm_static.yaml:
littlefs_storage:
  address: 0x0
  region: external_flash
lvgl_raw_partition:
  address: 0x200000
settings_storage:
  address: 0x400000
This is how I am trying to initialize it. I know it's incomplete but am having trouble getting to the next steps.
#define STORAGE_PARTITION	storage_partition
#define STORAGE_PARTITION_ID	FIXED_PARTITION_ID(STORAGE_PARTITION)
struct settings_handler my_conf = {
    .name = "foo",
    .h_set = foo_settings_set
static int setting_manager_load_cb(const char *name, size_t len,
                            settings_read_cb read_cb, void *cb_arg)
    LOG_DBG("Loading setting %s", name);
SETTINGS_STATIC_HANDLER_DEFINE(settings_app_handler, SETTINGS_PATH, NULL,
                               setting_manager_load_cb, NULL, NULL);
void setting_manager_init()
    LOG_DBG("Initializing setting manager");
    int rc;
    rc = settings_subsys_init();
	if (rc) {
		LOG_ERR("settings subsys initialization: fail (err %d)", rc);
		return;
    LOG_DBG("Settings subsystem initialized, loading...");
    //settings_register(&my_conf);
    settings_load();
    LOG_DBG("Settings loaded");
    //foo_val++;
    //settings_save_one("foo/bar", &foo_val, sizeof(foo_val));
    //printk("foo: %d\n", foo_val);
The log entries when running are:
<dbg> setting_manager: setting_manager_init: Initializing setting manager
<dbg> setting_manager: setting_manager_init: Settings subsystem initialized, loading...
<err> fs: file open error (-2)
I saw these threads on the topic,
  • Executing "ninja partition_manager_report" under the build folder would show the memory layout, as my figure in the previous reply. My example is already enabled External Flash/Settings/MCUBoot as the memory layout indicates.
  • I get:
    (3.8.0) xxx build % ninja partition_manager_report
    zsh: command not found: ninja
    Also prints are:
    I: littlefs partition at /lfs1
    I: LittleFS version 2.5, disk version 2.0
    I: FS at flash-controller@39000:0xf8000 is 8 0x1000-byte blocks with 512 cycle
    I: sizes: rd 16 ; pr 16 ; ca 64 ; la 32
    I: Automount /lfs1 succeeded
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    Sample program to r/w files on littlefs
    Area 0 at 0xf8000 on flash-controller@39000 for 32768 bytes
    /lfs1 automounted
    /lfs1: bsize = 16 ; frsize = 4096 ; blocks = 8 ; bfree = 5
    Wouldn't there be more blocks?
    How do you have settings running without something like this in the prj.conf:
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_RUNTIME=y
    CONFIG_SETTINGS_FS=y
    CONFIG_SETTINGS_FS_DIR="/lfs/settings"
    CONFIG_SETTINGS_FS_FILE="/lfs/settings/run"
    or MCUBoot without:
    # Enable MCUboot and FOTA
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="mcuboot/root-rsa-2048.pem"
    Could you build the code with sysbuild (--sysbuild)?
    west command:
    west build -p -b nrf5340dk_nrf5340_cpuapp -d build_nrf5340dk_nrf5340_cpuapp --sysbuild  && west flash --build-dir build_nrf5340dk_nrf5340_cpuapp --recover
    The output log would look like this:
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Image index: 0, Swap type: none
    I: Bootloader chainload address offset: 0xc000
    I: littlefs partition at /lfs1slot
    I: FS at mx25r6435f@0:0x200000 is 512 0x1000-byte blocks with 512 cycle
    Area 8 at 0x200000 on mx25r6435f@0 for 2097152 bytes
    /lfs1 automounted
    /lfs1: bsize = 16 ; frsize = 4096 ; blocks = 512 ; bfree = 509
    Listing dir /lfs1 ...
    [FILE] boot_count (size = 1)
    [FILE] pattern.bin (size = 547)
    /lfs1/boot_count read count:1 (bytes: 1)
    /lfs1/boot_count write new boot count 2: [wr:1]
    ------ FILE: /lfs1/pattern.bin ------
    02 55 55 55 55 55 55 55 03 55 55 55 55 55 55 55
    04 55 55 55 55 55 55 55 05 55 55 55 55 55 55 55
    06 55 55 55 55 55 55 55 07 55 55 55 55 55 55 55
    08 55 55 55 55 55 55 55 09 55 55 55 55 55 55 55
    0a 55 55 55 55 55 55 55 0b 55 55 55 55 55 55 55
    0c 55 55 55 55 55 55 55 0d 55 55 55 55 55 55 55
    0e 55 55 55 55 55 55 55 0f 55 55 55 55 55 55 55
    10 55 55 55 55 55 55 55 11 55 55 55 55 55 55 55
    12 55 55 55 55 55 55 55 13 55 55 55 55 55 55 55
    14 55 55 55 55 55 55 55 15 55 55 55 55 55 55 55
    16 55 55 55 55 55 55 55 17 55 55 55 55 55 55 55
    18 55 55 55 55 55 55 55 19 55 55 55 55 55 55 55
    1a 55 55 55 55 55 55 55 1b 55 55 55 55 55 55 55
    1c 55 55 55 55 55 55 55 1d 55 55 55 55 55 55 55
    1e 55 55 55 55 55 55 55 1f 55 55 55 55 55 55 55
    20 55 55 55 55 55 55 55 21 55 55 55 55 55 55 55
    22 55 55 55 55 55 55 55 23 55 55 55 55 55 55 55
    24 55 55 55 55 55 55 55 25 55 55 55 55 55 55 55
    26 55 55 55 55 55 55 55 27 55 55 55 55 55 55 55
    28 55 55 55 55 55 55 55 29 55 55 55 55 55 55 55
    2a 55 55 55 55 55 55 55 2b 55 55 55 55 55 55 55
    2c 55 55 55 55 55 55 55 2d 55 55 55 55 55 55 55
    2e 55 55 55 55 55 55 55 2f 55 55 55 55 55 55 55
    30 55 55 55 55 55 55 55 31 55 55 55 55 55 55 55
    32 55 55 55 55 55 55 55 33 55 55 55 55 55 55 55
    34 55 55 55 55 55 55 55 35 55 55 55 55 55 55 55
    36 55 55 55 55 55 55 55 37 55 55 55 55 55 55 55
    38 55 55 55 55 55 55 55 39 55 55 55 55 55 55 55
    3a 55 55 55 55 55 55 55 3b 55 55 55 55 55 55 55
    3c 55 55 55 55 55 55 55 3d 55 55 55 55 55 55 55
    3e 55 55 55 55 55 55 55 3f 55 55 55 55 55 55 55
    40 55 55 55 55 55 55 55 41 55 55 55 55 55 55 55
    42 55 55 55 55 55 55 55 43 55 55 55 55 55 55 55
    44 55 55 55 55 55 55 55 45 55 55 55 55 55 55 55
    46 55 ab
    I: /lfs1 unmounted
    /lfs1 unmount: 0
    Executing "ninja partition_manager_report" under the build folder would get the memory layout like this:
    I use non-volatile storage (CONFIG_SETTINGS_NVS) by setting in the nrf5340dk_nrf5340_cpuapp.conf:
    # Copyright (c) 2019 Peter Bigot Consulting, LLC
    # Copyright (c) 2019 Nordic Semiconductor ASA
    # Need this when storage is on flash
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # Need this when storage is on MX25R64
    CONFIG_NORDIC_QSPI_NOR=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # Settings - Used to store real-time device configuration to flash.
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_NVS=y
    CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x200000
    CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL=y
    CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
    CONFIG_PM_PARTITION_SIZE_LITTLEFS=0x200000
    MCUBoot is enabled by SB_CONFIG_BOOTLOADER_MCUBOOT=y in the sysbuild.conf.
  • I'm using the nRF Connect for VS Code. Does the way you're doing it mean the prj.conf and the nrf5340dk_nrf5340_cpuapp.conf are both being used?
    Are you using NVS and LittleFS? I see CONFIG_FILE_SYSTEM_LITTLEFS=y in the prj.conf.
    Running "ninja partition_manager_report" in the build directory is giving me: zsh: command not found: ninja
    Yes.
    The non-volatile storage is used by Setting in that sample.
