Regarding the behavior of link
In the link process between Central and Peripheral,
sometimes Link processing does not work correctly and the following log output:
. cis_gateway: Discovery failed: 14
 Please find the attached ppt.
Could you specify what might cause this based on the Log?
This problem happens in SDK 2.3.0, and improved in 2.7.0.
Link err.pptx
We have gotton the logs by EVK.
Is there anything you think might be the cause?
    Which application(s) do you use on your devices?
    Do you use nrf5340_audio-dk on both ends? How many headsets do you use?
    Is your log shown for NCS v2.3.0 or for NCS v2.7.0?
    Please provide full logs from all devices by clicking on Insert -> Image/video/file -> Upload.
    Dejan
  • >Do you use nrf5340_audio-dk on both ends? How many headsets do you use?
    Yes for both ends.
    We use 1 headset vs 1 gateway.
    Please find the attached files.
    These are the Logs gotten by NCS v2.3.0.
    GW [00:13:16.236,083] <wrn> bt_hci_core: opcode 0x206f status 0x0c
    GW [00:13:16.236,297] <wrn> bt_hci_core: opcode 0x206f status 0x12
    GW [00:13:16.236,297] <inf> cis_gateway: Stream 0x200046ec stopped
    GW [00:13:16.237,182] <inf> cis_gateway: Disconnected: E7:F7:B5:23:BC:DE (random) (reason 0x08)
    GW [00:13:16.237,274] <inf> cis_gateway: Stored bonding found: E7:F7:B5:23:BC:DE (random)
    GW [00:13:16.237,274] <inf> cis_gateway: Scanning successfully started
    GW [00:13:16.241,912] <wrn> streamctrl: Problem with sending LE audio data, ret: -140
    GW [00:13:16.488,677] <inf> cis_gateway: Connected: E7:F7:B5:23:BC:DE (random)
    GW [00:13:16.933,319] <inf> cis_gateway: Security changed: level 2
    GW [00:13:17.834,045] <err> cis_gateway: Discovery failed: 14
    GW [00:13:18.433,380] <inf> cis_gateway: Stored bonding found: E7:F7:B5:23:BC:DE (random)
    GW [00:13:18.433,959] <inf> cis_gateway: Scanning successfully started
    GW [00:13:19.033,447] <err> cis_gateway: Discovery failed: 14
    GW [00:13:19.835,510] <wrn> cis_gateway: No sink endpoints found
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0xc000
    HL [00:00:00.006,439] <inf> fw_info:
             nRF5340 Audio nRF5340 Audio DK cpuapp
             NCS base version: 2.3.0
             Cmake run : Thu Nov 07 15:59:22 2024
    HL [00:00:00.006,439] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.006,439] <inf> fw_info: HEADSET left device
    HL [00:00:00.017,059] <inf> board_version: Compatible board/HW version found: 1.0.0
    HL [00:00:02.051,605] <wrn> bt_hci_core: Controller to host flow control not supported
    HL [00:00:02.054,565] <inf> bt_hci_core: No ID address. App must call settings_load()
    HL [00:00:02.054,626] <inf> ble: MAC: 00:00:00:00:00:00 (public)
    HL [00:00:02.055,206] <inf> ble: Controller version: 3424
    HL [00:00:02.180,267] <inf> cis_headset: Set direct advertising to C5:24:9D:F9:E6:5B (random)
    HL [00:00:02.180,908] <inf> cis_headset: Advertising successfully started
    HL [00:00:03.027,343] <inf> cis_headset: Connected: C5:24:9D:F9:E6:5B (random)
    GW [00:04:25.818,023] <wrn> bt_hci_core: opcode 0x206f status 0x0c
    GW [00:04:25.818,237] <wrn> bt_hci_core: opcode 0x206f status 0x12
    GW [00:04:25.818,237] <inf> cis_gateway: Stream 0x200046ec stopped
    GW [00:04:25.819,000] <inf> cis_gateway: Disconnected: E7:F7:B5:23:BC:DE (random) (reason 0x08)
    GW [00:04:25.819,091] <inf> cis_gateway: Stored bonding found: E7:F7:B5:23:BC:DE (random)
    GW [00:04:25.819,122] <inf> cis_gateway: Scanning successfully started
    GW [00:04:25.824,035] <wrn> streamctrl: Problem with sending LE audio data, ret: -140
    GW [00:04:26.513,977] <inf> cis_gateway: Connected: E7:F7:B5:23:BC:DE (random)
    GW [00:04:27.015,289] <inf> cis_gateway: Security changed: level 2
    GW [00:04:28.715,362] <inf> cis_gateway: Stored bonding found: E7:F7:B5:23:BC:DE (random)
    GW [00:04:28.715,942] <inf> cis_gateway: Scanning successfully started
    GW [00:04:30.117,492] <inf> cis_gateway: Sink discover complete: err 0
    GW [00:04:30.220,642] <inf> cis_gateway: LEFT sink stream configured
    GW [00:04:30.223,327] <inf> cis_gateway: Stream QOS set: 0x200046ec
    GW [00:04:30.227,783] <inf> cis_gateway: Stream enabled: 0x200046ec
    GW [00:04:31.015,686] <inf> cis_gateway: Stream 0x200046ec started
    I: Swap type: none
    HL [00:00:02.052,062] <wrn> bt_hci_core: Controller to host flow control not supported
    HL [00:00:02.054,992] <inf> bt_hci_core: No ID address. App must call settings_load()
    HL [00:00:02.055,053] <inf> ble: MAC: 00:00:00:00:00:00 (public)
    HL [00:00:02.055,633] <inf> ble: Controller version: 3424
    HL [00:00:02.180,725] <inf> cis_headset: Set direct advertising to C5:24:9D:F9:E6:5B (random)
    HL [00:00:02.181,365] <inf> cis_headset: Advertising successfully started
    HL [00:00:03.551,727] <inf> cis_headset: Connected: C5:24:9D:F9:E6:5B (random)
    HL [00:00:07.253,784] <inf> cis_headset: Codec config for LC3:
    HL [00:00:07.253,814] <inf> cis_headset:        Frequency: 48000 Hz
    HL [00:00:07.253,814] <inf> cis_headset:        Frame Duration: 10000 us
    HL [00:00:07.253,814] <inf> cis_headset:        Channel allocation: 0x1
    HL [00:00:07.253,845] <inf> cis_headset:        Octets per frame: 120 (96000 bps)
    HL [00:00:07.253,845] <inf> cis_headset:        Frames per SDU: 1
    HL [00:00:07.258,789] <inf> cis_headset: Presentation delay 10000 us is set by initiator
    HL [00:00:07.953,796] <inf> cis_headset: Stream started
    HL [00:00:08.064,605] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:00:08.065,612] <wrn> audio_datapath: Data received, total underruns: 790
    HL [00:00:08.164,611] <inf> audio_datapath: Drft comp state: INIT
    HL [00:00:08.165,618] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:00:08.166,595] <wrn> audio_datapath: Data received, total underruns: 791
    HL [00:00:08.265,625] <inf> audio_datapath: Drft comp state: OFFSET
    HL [00:00:08.726,104] <inf> audio_datapath: Drft comp state: LOCKED
    HL [00:00:08.734,100] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:08.844,085] <inf> audio_datapath: Pres comp state: WAIT
    HL [00:00:08.944,091] <inf> audio_datapath: Pres comp state: INIT
    HL [00:00:08.954,101] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:09.065,093] <inf> audio_datapath: Pres comp state: LOCKED
    Can you provide more information about this? How often is "sometimes"? When does this discovery error happen?
    Can you try to update to the newest NCS version and test with it? Please also provide the same logs on both sides.
    Dejan
  • Thank you for your reply.
    ⇒As a procedure, turn on the power for both the headset and the gateway and link them.
    After that, if you turn off and then turn on the power on the headset side only, the link sometimes fails to re-establish.
    ⇒Occurs about once in 30 times.
    ⇒I have obtained the logs using SDK 2.8.0 and will send them to you.
      Since there were no failures with SDK 2.8.0, only the logs from successful attempts are included.
    GW [00:00:44.530,212] <wrn> bt_hci_core: opcode 0x206f status 0x0c
    GW [00:00:44.530,578] <inf> bt_mgmt: Disconnected: FB:2A:C5:30:5D:F1 (random), reason 0x08
    GW [00:00:44.530,609] <inf> main: Disconnection event. Num connections: 0
    GW [00:00:44.532,714] <inf> bt_mgmt_scan: Local addr: 48:5E:E1:C2:11:93 (random). May time out. Updates not printed
    GW [00:00:44.532,714] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:00:44.532,714] <inf> unicast_client: Stream 0x20012294 stopped. Reason 8
    GW [00:00:44.535,949] <inf> bt_mgmt_scan: Creating connection to bonded device: FB:2A:C5:30:5D:F1 (random)
    GW [00:00:44.538,757] <wrn> unicast_client: No active streams
    GW [00:00:44.538,757] <wrn> main: Sending operation cancelled
    GW [00:00:44.542,205] <inf> bt_mgmt: Connected: FB:2A:C5:30:5D:F1 (random)
    GW [00:00:44.542,236] <inf> main: Connection event. Num connections: 1
    GW [00:00:44.612,243] <inf> main: Security changed
    GW [00:00:44.822,479] <inf> bt_vol_ctlr: VCS discover finished
    GW [00:00:45.172,515] <inf> main: Set members found: 1 of 2
    GW [00:00:45.173,645] <inf> bt_mgmt_scan: Local addr: 48:5E:E1:C2:11:93 (random). May time out. Updates not printed
    GW [00:00:45.173,645] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:00:45.482,299] <inf> unicast_client: Discovered 1 sink endpoint(s) for device 0
    GW [00:00:45.503,784] <inf> unicast_client: LEFT sink stream configured
    GW [00:00:45.503,814] <inf> le_audio: LC3 codec config for sink:
    GW [00:00:45.503,814] <inf> le_audio:   Frequency: 48000 Hz
    GW [00:00:45.503,814] <inf> le_audio:   Duration: 10000 us
    GW [00:00:45.503,814] <inf> le_audio:   Channel allocation: 0x1
    GW [00:00:45.503,845] <inf> le_audio:   Octets per frame: 120 (96000 bps)
    GW [00:00:45.503,845] <inf> le_audio:   Frames per SDU: 1
    GW [00:00:46.032,318] <inf> unicast_client: Stream 0x20012294 started
    GW [00:00:46.108,612] <inf> audio_datapath: Drft comp state: INIT
    GW [00:00:46.109,588] <inf> audio_datapath: Drft comp state: CALIB
    GW [00:00:46.209,533] <inf> audio_datapath: Drft comp state: INIT
    GW [00:00:46.210,510] <inf> audio_datapath: Drft comp state: CALIB
    GW [00:00:46.310,455] <inf> audio_datapath: Drft comp state: INIT
    GW [00:00:46.311,462] <inf> audio_datapath: Drft comp state: CALIB
    GW [00:00:46.411,376] <inf> audio_datapath: Drft comp state: OFFSET
    GW [00:00:46.611,419] <inf> audio_datapath: Drft comp state: LOCKED
    *** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
    *** Using Zephyr OS v3.7.99-0bc3393fb112 ***
    HL [00:00:00.268,096] <inf> board_version: Compatible board/HW version found: 1.0.0
    HL [00:00:00.300,506] <inf> fw_info:
             NCS base version: 2.8.0
             Cmake run : Fri Nov 22 16:02:19 2024
    HL [00:00:00.300,506] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.300,506] <inf> fw_info: HEADSET left device
    HL [00:00:00.372,711] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 6.0 (0x0e), Revision 8270
    HL [00:00:00.372,924] <inf> bt_mgmt: Local identity addr: FB:2A:C5:30:5D:F1 (random)
    HL [00:00:00.401,458] <wrn> unicast_server: CSIP using the default SIRK, must be changed before production
    HL [00:00:00.405,975] <inf> bt_mgmt_adv: Local addr: 43:BA:F1:32:7B:45 (random)
    HL [00:00:00.406,066] <inf> bt_mgmt_adv: Adv directed to: E0:D7:9C:28:A7:C9 (random).
    HL [00:00:00.406,646] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:00:00.861,053] <inf> bt_mgmt: Connected: E0:D7:9C:28:A7:C9 (random)
    HL [00:00:00.861,083] <inf> main: Connection event. Num connections: 1
    HL [00:00:00.861,236] <inf> bt_mgmt_adv: RPA (Resolvable Private Address) expired.
    HL [00:00:00.861,328] <inf> bt_mgmt_adv: Local addr: 43:BA:F1:32:7B:45 (random)
    HL [00:00:00.932,037] <inf> main: Security changed
    HL [00:00:00.932,250] <wrn> bt_gatt: Device is not subscribed to characteristic
    HL [00:00:00.932,250] <wrn> bt_pacs: PACS notify failed: -22
    HL [00:00:01.411,895] <inf> bt_content_ctrl_media: Discovery of MCS finished
    HL [00:00:01.812,805] <inf> le_audio: LC3 codec config for sink:
    HL [00:00:01.812,805] <inf> le_audio:   Frequency: 48000 Hz
    HL [00:00:01.812,805] <inf> le_audio:   Duration: 10000 us
    HL [00:00:01.812,805] <inf> le_audio:   Channel allocation: 0x1
    HL [00:00:01.812,835] <inf> le_audio:   Octets per frame: 120 (96000 bps)
    HL [00:00:01.812,835] <inf> le_audio:   Frames per SDU: 1
    HL [00:00:01.832,672] <inf> main: Presentation delay 3000 us is set by initiator
    HL [00:00:02.268,859] <inf> unicast_server: Stream 0x20010fdc started
    HL [00:00:02.281,463] <wrn> audio_datapath: Data received, total under-runs: 1
    HL [00:00:02.379,486] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:00:02.479,461] <inf> audio_datapath: Drft comp state: OFFSET
    HL [00:00:02.879,638] <inf> audio_datapath: Drft comp state: LOCKED
    HL [00:00:02.889,099] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:02.999,084] <inf> audio_datapath: Pres comp state: WAIT
    HL [00:00:03.139,099] <inf> audio_datapath: Pres comp state: INIT
    HL [00:00:03.149,108] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:03.259,094] <inf> audio_datapath: Pres comp state: LOCKED
    Thank you for additional logs.
    Since there are no errors when using NCS v2.8.0, I recommend that you continue using that NCS version if there isn't anything that is preventing you from doing that.
    Dejan
