Suspending the UART using PM_DEVICE ACTION_SUSPEND does not reduce power consumption that much
Hello
As the title says, I am suspending the UART using PM_DEVICE ACTION_SUSPEND, but the power consumption is not decreasing significantly.
With CONFIG_SERIAL=n and no UART used, power consumption is now around 20uA.
When using pm_device_action_run, the power consumption was about 1.3mA.
Please tell me the correct way to stop UART.
SDK : nrf Connect SDK 2.6.1
Board : Raytac MDBT42Q-DB
#include <zephyr/kernel.h>
#include <zephyr/pm/device.h>
#include <zephyr/device.h>
#include <zephyr/drivers/uart.h>
LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
static uint8_t Buffer[16];
static const struct device *Uart = DEVICE_DT_GET(DT_NODELABEL(uart0));
static void Callback(const struct device *dev, struct uart_event *evt, void *user_data);
#if defined(CONFIG_SERIAL)
    if (!device_is_ready(Uart))
        LOG_ERR("device is not ready");
        return 0;
    const struct uart_config cfg = {
        .baudrate = 1000000,
        .parity = UART_CFG_PARITY_NONE,
        .stop_bits = UART_CFG_STOP_BITS_1,
        .data_bits = UART_CFG_DATA_BITS_8,
        .flow_ctrl = UART_CFG_FLOW_CTRL_RTS_CTS,
    int err = uart_configure(Uart, &cfg);
    if (err)
        LOG_ERR("uart_configure (%d)", err);
        return 0;
    err = uart_callback_set(Uart, Callback, NULL);
    if (err)
        LOG_ERR("uart_callback_set (%d)", err);
        return 0;
    err = uart_rx_enable(Uart, Buffer, sizeof(Buffer), 1000);
    if (err)
        LOG_ERR("uart_rx_enable (%d)", err);
        return err;
    int count = 0;
    while (count < 10)
        k_msleep(1000);
        LOG_INF(".");
        count++;
    err = pm_device_action_run(Uart, PM_DEVICE_ACTION_SUSPEND);
    if (err)
        LOG_ERR("pm_device_action_run (%d)", err);
        return 0;
        LOG_INF("SUSPEND");
    while(true)
        k_msleep(1000);
        LOG_INF(".");
    return 0;
    switch (evt->type)
    case UART_TX_DONE:
    case UART_TX_ABORTED:
    case UART_RX_RDY:
    case UART_RX_BUF_REQUEST:
    case UART_RX_BUF_RELEASED:
    case UART_RX_DISABLED:
    case UART_RX_STOPPED:
