FOTA over BLE fails after upgrade to NCS 2.8.0
I'm trying to implement firmware updates over BLE with mcuboot as boot loader.
I got it working with NCS 2.6.1, but I've upgraded to NCS 2.8.0 and now nRF Connect for iOS gives the error: Sending the request timed out.
I have the following configuration (of which I think it's important to the issue):
sysbuild.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="${APP_DIR}/priv.pem"
SB_CONFIG_PARTITION_MANAGER=y
SB_CONFIG_DFU_ZIP=y
SB_CONFIG_DFU_ZIP_APP=y
prj.conf:
CONFIG_BT_SMP=y
# FOTA configuration
# Configuration is basically the expansion of:
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_MCUMGR=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_NET_BUF=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW_ENCRYPT=y
CONFIG_IMG_MANAGER=y
CONFIG_STREAM_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y
CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
Apart from shuffling a few config's from prj.conf to sysbuild.conf, the only change is that I needed to add 'CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW_ENCRYPT' to allow access to the SMP characteristics as CONFIG_BT_SMP is enabled but I do not have MITM protection.
I can use nRFConnect for iOS to list the images, get bootloader info and reboot the device, so it seems that the basic SMP commands are working. Why does it error-out while trying to perform the actual update? Did I miss something while migrating to NCS 2.8.0?
Thanks in advance.
Remco Poelstra
    Thanks for suggesting to disable the logging intensive task. This allowed me to track down the issue to the following call:
    err = adc_read_async(adc, &sequence, &adc_signal);
    It doesn't matter whether I include the &adc_signal or not, if it's NULL the firmware upload still times out. So it seems that the ADC code running results in some kind of dead-lock in the system.
    I've included the complete ADC reading code, but it's basically a timer that calls adc_read_async at a 100 Hz interval. I'm unsure why this should cause a dead-lock when used in companion with the mcumgr code.
    #include <zephyr/kernel.h>
    #include <zephyr/drivers/adc.h>
    LOG_MODULE_REGISTER(adc, LOG_LEVEL_DBG);
    #include "../common.h"
    #ifdef CONFIG_BOARD_T502534
    #define ADC_NODE DT_NODELABEL(adc) // ADC node from the device tree
    static const struct device *adc = DEVICE_DT_GET(ADC_NODE); //Data of ADC device specified in device tree
    static const struct adc_channel_cfg channel_cfgs[] = {
        DT_FOREACH_CHILD_SEP(ADC_NODE, ADC_CHANNEL_CFG_DT, (,))
    #define CHANNEL_COUNT ARRAY_SIZE(channel_cfgs)
    /* Define a variable of type adc_sequence and a buffer of type int16_t */
    static int16_t buf[CHANNEL_COUNT];
    static struct adc_sequence sequence = {
        .buffer = buf,
        .buffer_size = sizeof(buf),
        .resolution = 12,
        .oversampling = 0,
        // Optional
        .calibrate = true, //TODO: Will this cause the ADC to calibrate for each sample?? We don't want that probably
    static struct k_poll_signal adc_signal;
    static struct k_poll_event adc_event;
     * ADC main loop called by the timer
    static void adc_timer_handler(struct k_timer *timer_id)
        int err;
        if (err < 0) {
            LOG_ERR("Failed to initialize ADC read: %d", err);
            return;
    void adcInit(void) {
        ASSERT_ERROR_AND_REBOOT(!device_is_ready(adc));
        for (size_t i = 0; i < CHANNEL_COUNT; i++) {
            sequence.channels |= BIT(channel_cfgs[i].channel_id);
            ASSERT_ERROR_AND_REBOOT(adc_channel_setup(adc, &channel_cfgs[i]));
        // use a timer to precisely trigger ADC reads at 100hz
        static struct k_timer adc_timer;
        k_timer_init(&adc_timer, adc_timer_handler, NULL);
        k_timer_start(&adc_timer, K_MSEC(10), K_MSEC(10));
        k_poll_signal_init(&adc_signal);
        k_poll_event_init(&adc_event, K_POLL_TYPE_SIGNAL, K_POLL_MODE_NOTIFY_ONLY, &adc_signal);
    static void adc_report_error(int result) {
        switch(result) {
            case 0:
                // Success
            case -EINVAL:
                LOG_WRN("Parameter with an invalid value has been provided");
            case -ENOMEM:
                LOG_WRN("Provided buffer is to small");
            case -ENOTSUP:
                LOG_WRN("Requested mode of operation is not supported");
            case -EBUSY:
                LOG_WRN("Another sampling was triggered while the previous one was still in progress");
                // try a longer interval
            case -EAGAIN:
                LOG_WRN("ADC read returned EAGAIN, conversion not ready");
                // try blocking reads instead
                LOG_ERR("Error reading ADC (%d)", result);
    int getPositionBlocking(int16_t val[2], k_timeout_t timeout) {
        // wait for adc read to complete
        int ret = k_poll(&adc_event, 1, timeout);
        if(ret != 0) {
            // LOG_ERR("k_poll failed (%d)", ret);
            return -EAGAIN;
        // check if adc has error flags
        if (0 != adc_event.signal->result) {
            adc_report_error(adc_event.signal->result);
            return adc_event.signal->result;
        // inform callers of updated value, available at &buf
        val[0] = buf[0];
        val[1] = buf[1];
        // housekeeping at end of loop
        adc_event.signal->signaled = 0;
        adc_event.state = K_POLL_STATE_NOT_READY;
        return 0; // return success
    void getPosition(int16_t val[2]) {
        val[0] = buf[0];
        val[1] = buf[1];
  • Regarding the logs:
    I couldn't get Device manager to log anything, but I've attached logs of the firmware and of nRF Connect for iOS.
    SEGGER J-Link V7.94i - Real time terminal output
    SEGGER J-Link V11.0, SN=821001711
    Process: JLink.exe
    [00:00:14.754,455] <dbg> main: main: Hello world!
    --- 3 messages dropped ---
    [00:00:14.754,760] <dbg> fs_nvs: nvs_recover_last_ate: Recovering last ate from sector 0
    [00:00:14.760,223] <inf> fs_nvs: 2 Sectors of 4096 bytes
    [00:00:14.760,253] <inf> fs_nvs: alloc wra: 0, d68
    [00:00:14.760,253] <inf> fs_nvs: data wra: 0, 3f0
    [00:00:14.760,437] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                fe 2c f9 6a 7f 36 22 2e  a0 79 c0 40 be 2c 03 20 |.,.j.6". .y.@.,.
                                                40 c2 f3 32                                      |@..2
    [00:00:14.763,580] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:14.763,610] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:14.763,641] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 254.63788 Build 573996906
    [00:00:14.764,160] <inf> bt_hci_core: No ID address. App must call settings_load()
    [00:00:14.768,096] <inf> bt_hci_core: Identity: F3:A9:1D:26:35:79 (random)
    [00:00:14.768,127] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x104e, manufacturer 0x0059
    [00:00:14.768,157] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x104e
    [00:00:14.778,778] <dbg> pwm_nrfx: pwm_nrfx_set_cycles: channel 0, pulse 0, period 32000, prescaler: 0.
    [00:00:14.778,839] <dbg> pwm_nrfx: pwm_nrfx_set_cycles: channel 0, pulse 0, period 32000, prescaler: 0.
    [00:00:19.924,438] <dbg> ble: ble_init: BLE enabled.
    [00:00:19.925,933] <inf> ble: --- MY MAC ADDRESS: F3:A9:1D:26:35:79 (random) ---
    [00:00:19.925,933] <inf> ble: Known bonds:
    [00:00:19.926,025] <inf> ble: 0. 9C:25:95:6E:95:66 (public)
    [00:00:19.926,116] <inf> ble: 1. 84:AB:1A:A1:0E:BF (public)
    [00:00:19.926,147] <inf> ble: ---- total: 2 ----
    [00:00:19.930,206] <wrn> bt_hci_core: opcode 0x2027 status 0x12
    [00:00:19.930,236] <err> bt_id: Failed to add IRK to controller
    [00:00:19.930,938] <wrn> bt_hci_core: opcode 0x2027 status 0x12
    [00:00:19.930,969] <err> bt_id: Failed to add IRK to controller
    [00:00:21.931,488] <inf> ble: ---- Acceptance list ----
    [00:00:21.931,793] <inf> ble: 9C:25:95:6E:95:66 (public)
    [00:00:21.932,098] <inf> ble: 84:AB:1A:A1:0E:BF (public)
    [00:00:21.932,128] <inf> ble: ---- list length = 2 ----
    [00:00:21.932,128] <dbg> ble: advertise_with_acceptlist: Acceptlist has 2 entries
    [00:00:21.933,258] <dbg> ble: advertise_with_acceptlist: Advertising successfully started.
    <<<<connect>>>>
    [00:01:23.361,175] <dbg> ble: mtu_updated: Updated MTU: TX: 23 RX: 23 bytes
    [00:01:23.364,074] <inf> ble: Connected via BLE
    [00:01:23.364,685] <dbg> sc: commandHandler: Handling command: PairingModeSetState (26)
    [00:01:23.970,733] <inf> ble: Security changed: 84:AB:1A:A1:0E:BF (public) level 2
    [00:01:24.000,366] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
    [00:01:24.030,334] <dbg> ble: mtu_updated: Updated MTU: TX: 527 RX: 498 bytes
    <<<<upload>>>>
    [13:47:32.0770] Normal: Scanner On.
    [13:47:32.2800] Normal: Device Scanned.
    [13:47:41.0990] Normal: Connected.
    [13:47:41.2280] Normal: Discovered SMP Service and 94FF08D8-7129-4446-8057-4A1AB3B2EBC1 Services.
    [13:47:41.2320] Normal: Discovered SMP Characteristic Characteristics for Service SMP Service.
    [13:47:41.2520] Normal: Discovered 94FFFA00-7129-4446-8057-4A1AB3B2EBC1, 94FFFA01-7129-4446-8057-4A1AB3B2EBC1, 94FFFA02-7129-4446-8057-4A1AB3B2EBC1, 94FFFA03-7129-4446-8057-4A1AB3B2EBC1, 94FFFA07-7129-4446-8057-4A1AB3B2EBC1, 94FFFA0A-7129-4446-8057-4A1AB3B2EBC1, 94FFFA0B-7129-4446-8057-4A1AB3B2EBC1, 94FFFA0C-7129-4446-8057-4A1AB3B2EBC1, 94FFFA0D-7129-4446-8057-4A1AB3B2EBC1, 94FFFA0E-7129-4446-8057-4A1AB3B2EBC1, 94FFFA0F-7129-4446-8057-4A1AB3B2EBC1, 94FFFA10-7129-4446-8057-4A1AB3B2EBC1, 94FFFA14-7129-4446-8057-4A1AB3B2EBC1, 94FFFA29-7129-4446-8057-4A1AB3B2EBC1, 94FFFA2A-7129-4446-8057-4A1AB3B2EBC1, 94FFFA2B-7129-4446-8057-4A1AB3B2EBC1, 94FFFA37-7129-4446-8057-4A1AB3B2EBC1, and 94FFFA3A-7129-4446-8057-4A1AB3B2EBC1 Characteristics for Service 94FF08D8-7129-4446-8057-4A1AB3B2EBC1.
    [13:47:41.2520] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic SMP Characteristic
    [13:47:41.2520] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA00-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2530] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA01-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2530] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA02-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2530] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA03-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2530] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA07-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2530] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA0A-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2540] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA0B-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2540] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA0C-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2540] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA0D-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2540] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA0E-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2540] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA0F-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2540] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA10-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2550] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA14-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2550] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA29-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2550] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA2A-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2550] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA2B-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2560] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA37-7129-4446-8057-4A1AB3B2EBC1
    [13:47:41.2560] Normal: Discovered Client Characteristic Configuration Descriptors for Characteristic 94FFFA3A-7129-4446-8057-4A1AB3B2EBC1
    [13:47:42.1490] Normal: Appearance changed from Generic to McuMgrDFU.
    [13:47:42.5680] Normal: Found valid Firmware in file:///private/var/mobile/Containers/Data/Application/73766C67-A4C0-4FD7-B430-DE6AFA4D74E4/Documents/dfu_application%202.zip for Device DFU McuMgr.
    [13:47:54.4600] Normal: Upgrade started with 1 image(s) using '.testOnly' mode
    [13:47:54.4600] Normal: Firmware Upgrade Started.
    [13:47:54.4610] Normal: State changed from none to requestMcuMgrParameters
    [13:47:54.4630] Normal: Central Manager ready
    [13:47:54.4630] Normal: Peripheral connected
    [13:47:54.5440] Normal: Device ready
    [13:47:54.6380] Normal: Mcu Manager parameters received (4 x 2475)
    [13:47:54.6380] Normal: State changed from requestMcuMgrParameters to bootloaderInfo
    [13:47:54.8160] Normal: Bootloader Info received (Name: MCUboot)
    [13:47:54.9070] Normal: Bootloader Mode received (Mode: Swap without scratch)
    [13:47:54.9080] Normal: State changed from bootloaderInfo to validate
    [13:47:54.9990] Normal: Image List response: Header: {"version": "1", "op": "1", "flags": 0, "length": 134, "group": 1, "seqNum": 215, "commandId": 0}, Payload: {"images" : {{"pending" : false, "slot" : 0, "active" : true, "permanent" : false, "version" : "1.0.0", "bootable" : true, "confirmed" : true, "hash" : 0x95343950CD4D75F1FCD4C70E51BAA7B6C451E615269D56151290131956123F24}}, "splitStatus" : 0}
    [13:47:54.9990] Normal: Scheduling upload (hash: 0xDB18C0FDE243BFC8546A04A2A7957C90D61CA79222120D15CB547B48077B2E8A) for image 0 (slot: 1)
    [13:47:55.0100] Normal: State changed from validate to upload
    [13:48:05.3490] Normal: Retry 1 for seq: 217
    [13:48:05.3510] Normal: Retry 1 for seq: 218
    [13:48:05.3550] Normal: Retry 1 for seq: 219
    [13:48:15.3570] Normal: Retry 2 for seq: 217
    [13:48:15.3570] Normal: Retry 2 for seq: 218
    [13:48:15.3640] Normal: Retry 2 for seq: 219
    [13:48:25.3620] Normal: Retry 3 for seq: 217
    [13:48:25.3630] Error: Request (SMPv2, group: image, seq: 217, command: upload) failed: Sending the request failed.
    [13:48:25.3630] Error: Sending the request failed.
    [13:48:25.3630] Error: Upload cancelled due to error: sendFailed
    [13:48:25.3630] Error: DFU failed: Sending the request failed.
    [13:48:25.3640] Error: DFU Failed with Error: Sending the request failed.
    [13:48:25.3660] Normal: Retry 3 for seq: 218
    [13:48:25.3710] Normal: Retry 3 for seq: 219
    [13:48:55.5200] Normal: Disconnected.
    [13:49:32.0610] Normal: Scanner Off.
    Thank you for additional logs.
    In the nRF Connect application, there should be "Configuration" section below the "Start" button for DFU. One of the items in the configuration is "Number of Buffers". You can try to set its value to "Disabled".
    Dejan
  • Disabling the buffer count doesn't solve it, the firmware still stops running.
    I did notice however that the BLE connection itself is maintained when the firmware stops running, so it seems that not everything in the firmware stops. Assuming that the firmware needs to do something actively to maintain the BLE connection...
    You could try to check the logs. Debug logs are disabled by default. You can scroll to the top of logs, tap on Filter and enable "Debug".
    Dejan
