FOTA over BLE fails after upgrade to NCS 2.8.0
I'm trying to implement firmware updates over BLE with mcuboot as boot loader.
I got it working with NCS 2.6.1, but I've upgraded to NCS 2.8.0 and now nRF Connect for iOS gives the error: Sending the request timed out.
I have the following configuration (of which I think it's important to the issue):
sysbuild.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="${APP_DIR}/priv.pem"
SB_CONFIG_PARTITION_MANAGER=y
SB_CONFIG_DFU_ZIP=y
SB_CONFIG_DFU_ZIP_APP=y
prj.conf:
CONFIG_BT_SMP=y
# FOTA configuration
# Configuration is basically the expansion of:
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_MCUMGR=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_NET_BUF=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW_ENCRYPT=y
CONFIG_IMG_MANAGER=y
CONFIG_STREAM_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y
CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
Apart from shuffling a few config's from prj.conf to sysbuild.conf, the only change is that I needed to add 'CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW_ENCRYPT' to allow access to the SMP characteristics as CONFIG_BT_SMP is enabled but I do not have MITM protection.
I can use nRFConnect for iOS to list the images, get bootloader info and reboot the device, so it seems that the basic SMP commands are working. Why does it error-out while trying to perform the actual update? Did I miss something while migrating to NCS 2.8.0?
Thanks in advance.
Remco Poelstra
    Which version of the nRF Connect for iOS application do you use?
    Have you tried to use Device Manager mobile application instead? Do you see any difference in result compared to nRF Connect for iOS?
    You can look at this testing steps when performing FOTA update on the nrf52 device.
    What happens if you do not add CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW_ENCRYPT? Do you get the same error?
    Dejan
    I'm using nRF Connect for iOS version 2.7.13(40).
    I just tried Device Manager (1.8.1(3)) and it seems to have the same problem. It gets stuck on UPLOADING... after I press 'Start'. Other functions seem to work fine.
    I I remove CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW_ENCRYPT I can't use the SMP functions at all. The device disconnects and reports an error (over RTT) that the requested authentication level can't be reached (which is an understandable error in my situation).
    During the last tests I had some logging intensive task running and I noticed that during the upload the device (also) logs 'mcuboot_util: Image index: 0, Swap type: none' and keeps logging the other task for a short while and then completely stops. It seems the processor completely hangs. There is no other output and running the firmware in the debugger also doesn't trigger a breakpoint or something. It simply all stops.
    If you have any newer Android phone, you could try to test if the same problem appears when using corresponding Android applications.
    Dejan
  • I'm sorry, I don't have a recent Android device.
    I think the problem is on the firmware side, as I can't explain the hanging of the firmware otherwise. That would explain why the mobile device can't continue the upload, though.
    What happens if you remove all logging intensive tasks?
    Could you provide full logs when using both nRF Connect for iOS and Device Manager?
    Dejan
