nRF9151 no GPS fix
My custom boards with nRF9151 don't get gps fix. I'm using the same GPS antenna and LNA as DK. Soft is from DevAcademi example, but tried also GGSN sample and some other samples, but never got fix. Same soft with nRF9160 board works ok (devicetree overlay is different). UART, SPI, I2C, sensors, flash, pMIC, all ok.
When GPS cycle starts, then always during 2minutes and 10sec nRF9151 finds only 0...3 satellites, all with cn0: 0. On 2:10 satellite count jumps to 12, all with good cn0. It lasts 6...7sek, then drops again to 0...3 sat, but this time cn0 is different from 0 (seems real). It repeats with every GPS cycle, never gets fix and always 2:10 from start and lasts 6...8sek. Current monitored with PPK2 seems normal.
LNA is connected to COEX0, but tested it also with always power on - same result.
Tried modem FW 2.0.0, 2.0.2, SDK 2.7, 2.8, 2.9 - no diffrence.
Tried different LTE PS modes and values - same GPS pattern.
Tried to set GPS priority over LTE - same.
Tried with two boards (same batch) - same pattern.
NRF9151-LACA-R7 bought from Mouser, details installed to PCB in factory.
Br
Urmas
[00:02:13.645,202] <inf> gw2_2: Searching...
[00:02:13.649,810] <inf> gw2_2: Number of current satellites: 0
[00:02:14.569,488] <inf> gw2_2: Searching...
[00:02:14.574,066] <inf> gw2_2: Number of current satellites: 0
[00:02:15.573,944] <inf> gw2_2: Searching...
[00:02:15.578,521] <inf> gw2_2: Number of current satellites: 0
[00:02:16.574,371] <inf> gw2_2: Searching...
[00:02:16.578,979] <inf> gw2_2: sv: 4, cn0: 207, signal: 1
[00:02:16.584,838] <inf> gw2_2: sv: 11, cn0: 210, signal: 1
[00:02:16.590,759] <inf> gw2_2: sv: 16, cn0: 217, signal: 1
[00:02:16.596,710] <inf> gw2_2: sv: 3, cn0: 288, signal: 1
[00:02:16.602,569] <inf> gw2_2: sv: 31, cn0: 213, signal: 1
[00:02:16.608,489] <inf> gw2_2: sv: 1, cn0: 213, signal: 1
[00:02:16.614,349] <inf> gw2_2: sv: 24, cn0: 207, signal: 1
[00:02:16.620,269] <inf> gw2_2: sv: 30, cn0: 211, signal: 1
[00:02:16.626,220] <inf> gw2_2: sv: 23, cn0: 207, signal: 1
[00:02:16.632,171] <inf> gw2_2: sv: 7, cn0: 215, signal: 1
[00:02:16.638,000] <inf> gw2_2: sv: 199, cn0: 214, signal: 3
[00:02:16.644,042] <inf> gw2_2: sv: 25, cn0: 220, signal: 1
[00:02:16.649,963] <inf> gw2_2: Number of current satellites: 12
[00:02:17.574,401] <inf> gw2_2: Searching...
[00:02:17.579,010] <inf> gw2_2: sv: 4, cn0: 239, signal: 1
[00:02:17.584,869] <inf> gw2_2: sv: 11, cn0: 242, signal: 1
[00:02:17.590,820] <inf> gw2_2: sv: 16, cn0: 241, signal: 1
[00:02:17.596,740] <inf> gw2_2: sv: 3, cn0: 252, signal: 1
[00:02:17.602,600] <inf> gw2_2: sv: 31, cn0: 239, signal: 1
[00:02:17.608,551] <inf> gw2_2: sv: 1, cn0: 243, signal: 1
[00:02:17.614,379] <inf> gw2_2: sv: 24, cn0: 244, signal: 1
[00:02:17.620,330] <inf> gw2_2: sv: 30, cn0: 243, signal: 1
[00:02:17.626,281] <inf> gw2_2: sv: 23, cn0: 241, signal: 1
[00:02:17.632,202] <inf> gw2_2: sv: 7, cn0: 242, signal: 1
[00:02:17.638,061] <inf> gw2_2: sv: 199, cn0: 242, signal: 3
[00:02:17.644,104] <inf> gw2_2: sv: 25, cn0: 244, signal: 1
[00:02:17.650,024] <inf> gw2_2: Number of current satellites: 12
[00:02:18.573,486] <inf> gw2_2: Searching...
[00:02:22.574,523] <inf> gw2_2: sv: 4, cn0: 246, signal: 1
[00:02:22.580,383] <inf> gw2_2: sv: 6, cn0: 255, signal: 1
[00:02:22.586,242] <inf> gw2_2: sv: 16, cn0: 243, signal: 1
[00:02:22.592,163] <inf> gw2_2: sv: 31, cn0: 244, signal: 1
[00:02:22.598,114] <inf> gw2_2: sv: 1, cn0: 246, signal: 1
[00:02:22.603,973] <inf> gw2_2: sv: 24, cn0: 246, signal: 1
[00:02:22.609,893] <inf> gw2_2: sv: 30, cn0: 245, signal: 1
[00:02:22.615,844] <inf> gw2_2: sv: 23, cn0: 247, signal: 1
[00:02:22.621,765] <inf> gw2_2: sv: 7, cn0: 249, signal: 1
[00:02:22.627,624] <inf> gw2_2: sv: 199, cn0: 243, signal: 3
[00:02:22.633,636] <inf> gw2_2: sv: 25, cn0: 242, signal: 1
[00:02:22.639,587] <inf> gw2_2: Number of current satellites: 11
[00:02:23.568,969] <inf> gw2_2: Searching...
[00:02:23.573,577] <inf> gw2_2: sv: 6, cn0: 249, signal: 1
[00:02:23.579,437] <inf> gw2_2: Number of current satellites: 1
[00:02:24.568,847] <inf> gw2_2: Searching...
[00:02:24.573,455] <inf> gw2_2: sv: 6, cn0: 249, signal: 1
[00:02:24.579,315] <inf> gw2_2: Number of current satellites: 1
[00:02:25.568,420] <inf> gw2_2: Searching...
[00:02:25.573,028] <inf> gw2_2: Number of current satellites: 0
