ENOTSUP when trying to connect to wifi using T91X
I am attempting to connect to a Wi-Fi network using Exercise 2 from Lesson 2 of the Wi-Fi training in Nordic Academy. However, when I try to connect to the network, I encounter a -134 error while executing the following function:
net_mgmt(NET_REQUEST_WIFI_CONNECT, iface, &cnx_params, sizeof(struct wifi_connect_req_params));
Here's my main.c
 * Copyright (c) 2023 Nordic Semiconductor ASA
#include <errno.h>
#include <stddef.h>
#include <string.h>
#include <stdio.h>
#include <zephyr/kernel.h>
#include <zephyr/types.h>
#include <dk_buttons_and_leds.h>
/* STEP 3 - Include the necessary header files */
#include <zephyr/net/wifi.h>
#include <zephyr/net/wifi_mgmt.h>
#include <zephyr/net/net_mgmt.h>
#include <net/wifi_mgmt_ext.h>
/* STEP 12.4 - Include the header file for the Wi-FI credentials library */
#include <net/wifi_credentials.h>
LOG_MODULE_REGISTER(Lesson2_Exercise2, LOG_LEVEL_INF);
/* STEP 4 - Define a macro for the relevant network events */
#define EVENT_MASK (NET_EVENT_L4_CONNECTED | NET_EVENT_L4_DISCONNECTED)
/* STEP 5 - Declare the callback structure for Wi-Fi events */
static struct net_mgmt_event_callback mgmt_cb;
/* STEP 6.1 - Define the boolean connected and the semaphore run_app */
static bool connected;
static K_SEM_DEFINE(run_app, 0, 1);
/* STEP 6.2 - Define the callback function for network events */
static void net_mgmt_event_handler(struct net_mgmt_event_callback *cb,
			  uint32_t mgmt_event, struct net_if *iface)
	if ((mgmt_event & EVENT_MASK) != mgmt_event) {
		LOG_ERR("Event is not CONN | DISCONN");
		return;
	if (mgmt_event == NET_EVENT_L4_CONNECTED) {
		LOG_INF("Network connected");
		connected = true;
		dk_set_led_on(DK_LED1);
		k_sem_give(&run_app);
		return;
	if (mgmt_event == NET_EVENT_L4_DISCONNECTED) {
		if (connected == false) {
			LOG_INF("Waiting for network to be connected");
		} else {
			dk_set_led_off(DK_LED1);
			LOG_INF("Network disconnected");
			connected = false;
		k_sem_reset(&run_app);
		return;
/* STEP 7 - Define the function to populate the Wi-Fi credential parameters */
static int wifi_args_to_params(struct wifi_connect_req_params *params)
	/* STEP 7.1 Populate the SSID and password */
	params->ssid = CONFIG_WIFI_CREDENTIALS_STATIC_SSID;
	params->ssid_length = strlen(params->ssid);
	params->psk = CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD;
	params->psk_length = strlen(params->psk);
	/* STEP 7.2 - Populate the rest of the relevant members */
	params->channel = WIFI_CHANNEL_ANY;
	params->security = WIFI_SECURITY_TYPE_PSK;
	params->mfp = WIFI_MFP_OPTIONAL;
	params->timeout = SYS_FOREVER_MS;
	params->band = WIFI_FREQ_BAND_5_GHZ;
	#if NCS_VERSION_NUMBER > 0x20600
	memset(params->bssid, 0, sizeof(params->bssid));
	return 0;
	/* STEP 8.1 - Declare the variable for the network configuration parameters */
	struct wifi_connect_req_params cnx_params;
	/* STEP 8.2 - Get the network interface */
	struct net_if *iface = net_if_get_first_wifi();
	if (iface == NULL) {
		LOG_ERR("Returned network interface is NULL");
		return -1;
	LOG_INF("Hello this is connect wifi sample");
	if (dk_leds_init() != 0) {
		LOG_ERR("Failed to initialize the LED library");
	/* Sleep to allow initialization of Wi-Fi driver */
	k_sleep(K_SECONDS(1));
	/* STEP 9 - Initialize and add the callback function for network events */
	net_mgmt_init_event_callback(&mgmt_cb, net_mgmt_event_handler, EVENT_MASK);
	net_mgmt_add_event_callback(&mgmt_cb);
	/* STEP 10 - Populate cnx_params with the network configuration */
	wifi_args_to_params(&cnx_params);
	/* STEP 11 - Call net_mgmt() to request the Wi-Fi connection */
	LOG_INF("Connecting to Wi-Fi");
	int err;
	while(true){
		err = net_mgmt(NET_REQUEST_WIFI_CONNECT, iface, &cnx_params, sizeof(struct wifi_connect_req_params));
		if (!err) {
			LOG_INF("Connecting to Wi-Fi succesfull, err: %d", err);
		LOG_ERR("Failed to connect to Wi-Fi, err: %d", err);
		LOG_INF("Trying again in 1 second...");
	k_sem_take(&run_app, K_FOREVER);
	return 0;
my prj.conf :
# Copyright (c) 2022 Nordic Semiconductor ASA
# Wi-Fi
# STEP 1.1 - Enable the Wi-Fi relevant configurations
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
CONFIG_WPA_SUPP=y
# STEP 2 - Configure the Wi-Fi credentials
CONFIG_WIFI_CREDENTIALS=y
# STEP 12.1 - Diasble static Wi-Fi network configuration
CONFIG_WIFI_CREDENTIALS_STATIC=y
CONFIG_WIFI_CREDENTIALS_STATIC_SSID="WIFI_NINA"
CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="TERRAPERAMERA!"
# Networking Management API
# STEP 1.2 Enable the Network Management relevant configurations
CONFIG_NET_MGMT=y
CONFIG_NET_MGMT_EVENT=y
CONFIG_NET_MGMT_EVENT_INFO=y
CONFIG_NET_MGMT_EVENT_STACK_SIZE=16384
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_WIFI_MGMT_EXT=y
# STEP 13 Enable support for shell commands
# CONFIG_SHELL=y
# CONFIG_WIFI_CREDENTIALS_SHELL=y
# CONFIG_SHELL_STACK_SIZE=4400
# Logging
CONFIG_LOG=y
# DK library
CONFIG_DK_LIBRARY=y
# System settings
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_NANO=n
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_IPV6=n
CONFIG_NET_IPV4=y
CONFIG_NET_DHCPV4=y
CONFIG_NET_BUF_RX_COUNT=16
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_NET_BUF_DATA_SIZE=128
CONFIG_NRF700X_RX_NUM_BUFS=16
CONFIG_NRF700X_MAX_TX_AGGREGATION=4
# nRF700x is main consumer: (16 + 8) * 1600 = ~40KB + ~40KB control path (experimental)
CONFIG_NET_TC_TX_COUNT=1
# Memory
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=80000
CONFIG_NET_TX_STACK_SIZE=4096
CONFIG_NET_RX_STACK_SIZE=4096
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=30000
CONFIG_WIFI_FIXED_MAC_ADDRESS="04:E8:B9:5C:E0:27"
my .conf of t91x :
# STEP 12.3 - Create a board-specific file for the secure build target
CONFIG_WIFI_CREDENTIALS_BACKEND_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
Could you provide guidance or suggest a solution to resolve this issue?
Youssef
