Simultaneous multi-image DFU with usb is failed(Serial recovery, external flash)
I try to simultaneous update (app + networkcore) with usb and external flash on my custombord
And  serial recovery, not DFU from app.
this is mcuboot config. I have set the configuration of simultaenous multi-core updates.
# Enable Serial Recovery over UART
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_UART=y
# Disable UART, since Serial Recovery uses it
CONFIG_UART_CONSOLE=n
# Configure boolader to use only one slot.
CONFIG_SINGLE_APPLICATION_SLOT=n
# Turn on a LED so we can see when Serial Recovery mode is active
CONFIG_MCUBOOT_INDICATION_LED=y
# Configure serial recovery to use CDC_ACM, which by default uses the USB
CONFIG_BOOT_SERIAL_CDC_ACM=y
# Increase flash space for MCUboot child image, to fit USB drivers
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x16000
# Enable Retention
CONFIG_RETENTION=y
CONFIG_RETAINED_MEM=y
CONFIG_RETAINED_MEM_ZEPHYR_RAM=y
CONFIG_RETENTION_BOOT_MODE=y
# Enable Reboot
CONFIG_REBOOT=y
# Set Boot Type
CONFIG_BOOT_SERIAL_BOOT_MODE=y
CONFIG_BOOT_SERIAL_NO_APPLICATION=y
CONFIG_BOOT_SERIAL_ENTRANCE_GPIO=n
CONFIG_USB_DEVICE_PID=0x0001
CONFIG_BOOT_MAX_LINE_INPUT_LEN=1024
CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
# Enable logging for MCUboot
CONFIG_LOG=y
CONFIG_MCUBOOT_LOG_LEVEL_WRN=y
# Reduce flash useage
CONFIG_CBPRINTF_NANO=y
# Enable QSPI driver for external flash
CONFIG_NORDIC_QSPI_NOR=y
# Increase number of sectors
CONFIG_BOOT_MAX_IMG_SECTORS=256
# Enable simultaenous multi-core updates
CONFIG_NRF53_MULTI_IMAGE_UPDATE=y
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
CONFIG_BOOT_UPGRADE_ONLY=y
CONFIG_PCD_APP=y
# Dependencies for CONFIG_NRF53_MULTI_IMAGE_UPDATE
CONFIG_FLASH=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
And this is prj.conf
# Disable fatal error reset
CONFIG_RESET_ON_FATAL_ERROR=n
# Enable RTT
CONFIG_USE_SEGGER_RTT=y
# Enable console
CONFIG_CONSOLE=y
CONFIG_LOG=y
# Enable RTOS Events
CONFIG_EVENTS=y
# Enable USB Driver
CONFIG_SERIAL=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_LOG_BACKEND_RTT=n
# Enable MCUboot
CONFIG_BOOTLOADER_MCUBOOT=y
# Enable Retention
CONFIG_RETENTION=y
# Enable Reboot
CONFIG_REBOOT=y
# Enable cmsis-dsp
CONFIG_CMSIS_DSP=y
# Build with NewLib
CONFIG_NEWLIB_LIBC=y
# Enable FPU
CONFIG_FPU=y
I have also set up the configuration to use external Flash.
      chosen {
	      nordic,pm-ext-flash = &mx25u128;
this is partation
I try to dfu with mcumgr command line tool, and I use dfu_application.zip
this is the image list before upload.
Images:
 image=0 slot=0
    version: 0.0.0
    bootable: false
    flags:
    hash: 63c737a287db489da724bbbbeb64be46615c55a192bf014910ba3773141ffd60
 image=1 slot=0
    version: 0.0.0
    bootable: false
    flags:
    hash: Unavailable
Split status: N/A (0)
this is the image list after upload dfu_application.zip.
Images:
 image=1 slot=0
    version: 0.0.0
    bootable: false
    flags:
    hash: Unavailable
It is complete to upload dfu_application.zip but after reset, the nw app doesn't start.
The bootloader is running, but the app doesn't seem to be running.
I attach this file.
4454.dfu_application.zip
Why can't I update simultaneously even though I have the configuration set?
In the first place, is it not possible to perform simultaneous updates using an external flash with serial recovery?
When updating simultaneously, I entered "mcumgr -c testDK image upload hoge\dfu_application.zip", but is this incorrect?
Please let me know if you know anything.
best regards.
